- Best coilovers for a street driven rx8
- Powder Coating Wheels (OPINIONS PLEASE!)
- Big Brake Kit Opinions?
- how much rubber..is too much rubber?
- Ninja Wheels???
- cheap coilovers
- fiding a tire help/advise
- Just Two Rear Winter Tires?
- Sway bar link woes....
- How to get heavier steering? Pull EPS fuse?
- Help With Tire Air Pressure On Bigger Wheels
- So I wore out the tread on my tires in about 3 months...
- Storing stock rims
- a couple rotor questions
- take a look at what i ordered
- Need advice on pads
- Wire Wheels?
- New suspension
- Squeaky Coilover?
- I bent something
- Anyone run MS springs with Bilsteins or MS shocks?
- Enkei Falcon
- 16 inch Mazda 6 wheels
- Need help with rims...
- Anyone ever heard of ....
- Will these fit on the RX?
- Aftermarket tires; how to knoW needed tire pressure
- Which wheels should I get?!?
- What Shocks Should I Get?
- Little help. Advan RGII
- Question: Rotors
- Help me identify rims
- 2 options for rims here, which do the community think look better?
- Quick camber question???
- Opinions PLEASE!
- slower speeds with winter tires
- Here is what happens when your ABS fails
- spring question
- Should I put these on my wb rx8??
- they couldnt align my car WTF
- tirerack thin tires only for 8?
- shipping question
- Kazera KZ-K or Enkei RPK
- buddyclub wheels
- Anyone got a picture of their car with 18x9 tenzo R Cuzco black wheels?
- Photoshop request
- ZR+ or FN01R-C Hot Version
- best swaybars????
- Help me decide on a great deal on wheels
- Line Locks
- What other stock rims will fit on the 8?
- Control Arm Bushings
- Wheel well skirts?
- what do you think about these?
- Sways or springs first?
- Ideal Alignment: Numbers Please
- Clunking suspension ? New owner...
- want to get new set of rims but questions
- Concave to a whole new level "Rota Grids"
- Enkei Center Caps
- Wheels, wheels, wheels...
- Recommendations
- EBC Ultimax Slotted Rotors
- general exclaim UHP for my 8 help!!
- bent rims, worth buying??
- Help me Find these Rims
- Wheel spacers help
- Should I rotate my tires on my 2007GT?
- anyone had these rotors before ??
- Yay! Blew up my tire.
- R3's 19-inch Charcoal alloy wheels for import to South East Asia
- KW varient 3 settings?
- Who has Stance coilovers
- Volk TE37s
- 4 Tire alignment?
- Lowering question
- tire size help...
- 11" wide fitment?
- Dunlop SP Sport Signature tires
- opinions on rims
- The Shinka vs Stock RX8, what's true and false?
- Rota G-force wheels
- Open end lugnuts
- Tire size help
- Help me find some wheels !
- rota grid
- How to switch Tire sensors to new wheels?
- Acura Tsx Wheel Fitment?
- Koni shocks on sale at tirerack
- wheel width/tire width
- Tire gets stuck on the inside of the fender when turning left.
- Custom Stainless Steel Brake Lines
- Progress Tech Springs + Koni = 2+ inch drop in the rear
- Fender braces?
- Newly painted stockerz
- Springs for Tokico D-Specs: Need Opinions from owners
- WEDS Wheels LISTING
- 3m Pad+rotors=???
- POLAK DECALS: Can I apply paint and clearcoat over them?
- G2 Caliper paint seems to be too glossy. Any other options?
- Bondo Spot Putty for fixing 'curb rash'
- Which paint is almost PERFECT match for RX8 OEM wheel touch ups?
- When Painting the Petals, do you paint both sides?
- Glass Rims?
- Wheel studs...
- Racing brake stainless lines & 17" winter/tire rims.
- Kazera KZ-J Anybody?
- Quick rim/tire size question i'm not 100% sure on...
- Yoko AD07s on closeout @ TR
- Anyone runnin Megan Coilovers?
- MS Strut Brake Brace
- Has Anyone Ever had this problem?
- how much brake fluid
- Car pulls slight to the left
- Anyone tried the 'Wurth Alloy Wheel Spray Paint' to fix curb-scratches?
- Suspension?
- Quite the task a couple weekends ago....
- Knuckle support - yay or nay?
- Koni Yellow adjustment question
- help me attack my time...lols
- do you think this will work
- Stock Struts?
- WANTED REVIEWER! GTSPEC 6 Point Chassis Brace!
- Brake Problem...Repair or Replace?
- Problem with internal spline tuner lug key
- New tire feedback?
- Question about wheel rubbing/lowering springs
- New rims, or Powedercoat?
- when to start using summer tires?
- front rotors replacement at 60k miles?
- Wheel Fade... Replace or Power Coat???
- Help me choose, cheap wheels or reasonable tires for Mazda 3
- Wrong rotors?????
- Brakes for my rx8 some one help
- TPMS Question
- Brake tool needed....
- My year with Falken Azenis
- Use or don't use TPMS on aftermarket wheels?
- RX8 6 Points Front Strut Brace, Under Chassis Brace *** Install Pics ***
- JIC-RS coilovers
- Help me find these rimms !!!
- TireWorks Deal. Need Help
- What you guys think??
- Tire pressure in winter
- Anyone use Rotiform wheels?
- brake calipers mounting brackets
- My New PF01's
- Nexen N3000 235/40ZR18
- Stance GR coilovers fast question
- Rim suggestions
- SATISFIED Brake Pads.
- OEM 18" rims for RX8 needed
- Different rims?
- 19x9.5 & 19x10.5 +22 all around
- Wheel Paint
- Need help identifying a rim
- Wheels for Velocity Red Rx-8!
- Does anyone have these brakes....are they any good?
- Stock spring rates
- Stock Shocks... What Springs?
- Koni shocks on closeout at Tire Rack -- $558
- Any good Tire deals
- Color of MS springs?
- Help Find Lowest Price on Front Pads
- TPMS programming
- Front brake rotors
- Issue with tanabe GF springs?
- tein s tech - which springs are the front/back??!! help!
- 'Lowering' Worries
- Holy DOPE TE37 Reps!!!!!!!!!
- Effect of aggressive offset on performance
- Quick release link ends
- any ideas on rims
- suspension question
- Five Axis Wheels
- Front Camber kit
- Lowering springs, end link question
- White Wheels?
- springs/noise
- Coilovers Help?
- pettit racing stay bar??
- Thoughts on Enkei RAZR
- TireBuyer.com is giving AMEX ca$h cards on Bridgestone purchases
- tire question
- 18x7.5
- help needed to fix weird ride height on eibach springs with stock shocks
- Can this tire be fixed?
- gt spec bracing review
- How do I know if I need new shocks?
- Quick Question for Punctured Tire
- Hankook Ventus V12 evo K110 - Tire load
- Rays 57F Time Attack vs Finalspeed A-Tech replica
- 1st set of replacement tires
- Help Me Pick Rims
- Stock ride height
- BFG G4 Sport [vs] Dunlop Direzza DZ101
- 20's. should i keep them?
- Drop Engineering?
- EIBACH LOWERING SPRINGS PART#115500701VA and 115500701HA: More info needed please...
- tein basics coilovers any thoughts?
- Love is...
- Broken Racing Beat Rear Swaybar
- Front Camber?
- 18x10+38 RPF1 + 265/35/18 Michelin PSC + stock height = 4 fingers
- is this where its at??
- My new ASA GT1 rims
- Review: GTSPEC Upgrades
- TSW Nurburgring Wheels????
- Flat black volk te37 !?!?
- lowering the rx
- New Suspension experience what to pick ?
- Ordered new wheels and tires now wondering about drop...
- Tein Springs?
- rx-8 issues
- Need good place to find OEM Rotors
- alignment question
- Spring Installation time
- Do these Rim's "POP"?
- Alignment adjusters seized.
- Not interested in lowering the car, but would like new shocks...
- coilover install problems
- Help needed on EBC rotor size selection
- Calling all sprint springs rx8's
- 25MM spacers with stock wheels and 245/40-18's = Flush :)
- GTspec bracing
- Going to change color of rim!!
- S Tech Vs H Tech - A Visual
- Rim and Suspension Installed. ***Work VS-XX CONTENT***
- Need Opinions! Tire and Suspension Related
- Brake pads are toast, track day Saturday -- what to do?
- Noob Tire Question
- sway bars
- gripmotorsports.com
- Mazdaspeed 6 Wheels on an RX8
- noob question dont shoot
- Koni Shock question
- Back to OEM springs from Espelir
- Koni on Sale at Tirerack
- Custom Rims for 2009 R3
- RX-8 wheels on Mazda6; AOK
- Spring/Strut setup for '04 RX8. Ideas?
- Yet Another Tire Thread
- H&R TRACK+ Wheel Spacers for '04 RX8
- @#*&^%*&@^ Curbed my wheel! :( Paint code for Work CR-Kai please.
- Anyone with experience with Yokohama Advan Neova AD07's?
- Question for those running non-oem sway bars
- Snapped an AP Endlink?!
- Getting Wheels Wanting Pics
- GTSPEC 6 pt front strut and front lower brace review
- Centric Premium rotors users, do your rear rotors look like this?
