- Blown Shocks???
- Well take a look and let me know what you think about spacers.
- new rims, need help with tires fit
- The Age of Your Tires
- Whats the best 1st handling mod?
- WTB After-Market Brakepads and Rotors
- which sway bars???
- HELP what springs to buy!!
- What do you guys think about these?
- 10mm spacers? location to buy ?
- Has anyone here downgraded?
- Brake Calipers (Decals)
- New wheels/tires. *PICS*
- Mixing old school with new.
- Does anyone here have the Eibach springs?
- Where to buy new 2009 RX8 19" Mazda rims?
- New wheels! Rota Boost soon to be on VR
- coilover question
- Where all do you look for aftermarket rims?
- Installed HID problem....
- Help! Being attacked by the Camber Bandit!
- need an opinions
- D-Spec rear extension adjusters install help?
- Tools to replace rear brake rotors
- Enkei RS+M wheels
- Anyone running 20x10 in the rear
- Do you think that these brakes would look stupid on my car?
- 17's with a drop look bad?
- The Battle of Blizzaks: WS-60's vs LM-25's
- Anyone able to explain stretching?
- Tires for 19x8.5x45
- Question on new rims?
- caliper paint duration
- What is the stock wheel width?
- kumho mx and kumho spt report
- RX8- 09 or status quo?
- Opinion: SSR Type-C RS wheels on a red car
- RS*R Ti2000 Springs
- easiest way to lower the 8?
- TSW Nogaros + Yokohama Advans on BB
- Best all season tire for RX-8
- Smaller wheels same overall diameter = more mpg or not so much?
- 2009 Mazda RX-8 Shocks
- Best Springs on RX-8
- a set of HOT PINK VOLKS TE-37's!
- WTB: Polyurethane MS Sway bushings
- Energy Suspension Polyurethane Control Arm Bushings
- Warped Brake pads?
- Coilover adjustment query
- which rims? need opinions!!!
- In Stock: Fn01rc Time Attack 18x9.5
- Help Rear Tires 245/45R18
- So I'm thinking of getting the Enkei GTC01 Wheels...
- new wilwood caliper for rear brakes.
- Need HELP With RIM INSTALL ASAP
- camber plate confusion
- Kumho Ecsta SPT Tires?
- question-stock susp. w/sways
- Fesh out of RS-5s?!
- Yokohama YK520
- Help Redrilling rims
- Wheel locks
- Brake Noise??
- Help on new installed rotors
- Show wheels vs. go wheels times eleventybillion
- More Evo-R endlink pics
- New Brake Pads Already?!!!
- coilovers
- Brief review of Falken Ziex ZE-912 tires
- Best 1 piece rotor replacement?
- Which option would you go with?
- Anyone have these wheels?
- Will MX-5 GT 17" rims fit RX-8?
- paint stock rims
- spare tire for rx8
- Shocks/springs for Track / Street???
- the lowest offset wheels that will fit
- Is +60mm offset too much for the rx-8?
- Time to start saving for winter tires
- powder coating san diego??
- Powerslot rotors?
- tokico dspecs and swift springs
- heres a noob question
- Help with Bolt Pattern
- Ate Super Blue Brake Fluid okay for Rx8?
- would i need spacers for +60mm offset?
- My suspension setup and D-Spec Setting!!!
- pictures of rims
- Update to my Mazda6 17" winter wheels
- Michelin X-Ice Xi2 Winter Tires...?
- Turning rotors?!?!?
- normal or sport suspension?
- blue lug nuts
- What wheels are these?
- painted rim poll!!!
- Poping noise...
- Coilovers vs. Konis/Springs
- sway bar or strut bar??
- Can I fit 22's
- 2009 RX8 Wheels
- Rotors and pads possible damage, replacement summary/questions
- need part number for front left brake pipe
- All season with snow/hills
- compatible springs
- Chrome Rims?
- What lug nuts/locks are you using?
- Brake Caliper tool
- Cutting stock springs...
- G2 BRAKE Caliper PaintSystem
- Wagner thermoquiet brake pads anygood??
- adjusting the E-Brake...
- Goodyear Eagle F1 All Seasons - Proper Inflation
- SPRINT lowering spring
- 40th anniversary rims
- 09 rx8 front sturt bar
- Tpms
- 245/40 18 vs. 245/45 18 on stockies
- What tire do you run?
- Help deciding the offset for stock wheels
- 2008 winter tire availability
- Tokico D spec - or Mazdaspeed?
- Mazdaspeed suspension vs. Racing Beat / Koni
- PT sway bar bracket broke
- Mr Tire and Yokohama Avid W4S Reviews
- Will G35 wheels fit our 8?
- 19" on WWP
- Mazda 3 Wheels?
- Winter Tires: Blizzak LM-25 vs Michelin X-Ice Xi2
- Floating Feeling after installing Sway Bars
- O.Z. Palladio 19" anyone?
- WTB OEM 18 wheels w/TPMS
- Bedding-in Question
- BSA 264 fit ? Need winter tires
- Indecision for 19"
- sway bars make me hard....
- Need help with these guys...
- sway bars front and back?
- Wheel Restoration 101
- Nexen N3000 and N7000
- Are these tires directional? - I don't want to wreck :(
- Painting wheels Gold..opinions plz!!!!
- Ti Grey, Gold Rims, and Blue Calipers..
- Tire Newb Question
- Falken RT-615 vs. Yokohama S. drive
- Bags specifically for holding/storing wheels/tires?
- Hubcentric ring size
- High performance coilovers
- Newb to Tires. Help?!
- Will these rims fit?
- Picking wheels, are these any good?
- Dunlop Direzza Sport Z1 impressions??
- The Weight vs. Rigidity Factor
- Brought some Nankang NS2, very impressed...
- Can anyone name this wheel?
- F-Sport Lexus Rims
- AXIS HALO matte while!!! OMG!!
- New Wheels for the 8!!!
- I hate metal valve capssss!!!
- Alignment settings change with new wheels/tires?
- Touch-up paint that is close to SSR Anthracite?
- Just bought me some Blizzaks.
- Wheels, Tires, Brakes: Anybody know...?
- 16x8, 16x7, stock rims.. what cars? honda civics?
- Painting wheels??
- Snow tires on stock rims
- Stock TPMS sensors on Enkei GTC01's? And spacers...?
- oem lug nut thread
- Pirelli P zreo nero thoughts?
- Tire pressure question
- Need Advice
- Yokohama S-drive questions
- Tokico Dspec
- What wheels are these?!
- Hand brake doesn't fully work work
- OEM Wheel Touch Up Paint
- Tanabe..
- Painting Rims - Color Opinions
- Hand Brake Light keeps turning on.
- Wheel Help
- Tires vote please
- Gt-6
- Coilovers Wanted!!
- Lowering springs
- Opinion Needed - Falken FK 452 or Yokohama S Drive
- Question about mazdaspeed part
- Name that rim!
- A pic of my big brakes in motion :)
- Tire size and suggestions...
- New tires
- Slotted and Drilled Rotors w/ Brake Pads AMAZON
- B stock wheels?
- winter tires yet?
- Rota wheels... what do you think about them?
- How frequent do u service your coilover?
- Changing tire sizes....
- What BBS rims are these?
- wheel fitment thread ********
- what shocks springs should i get
- 9.5 inches... thats what she said...
- TE37 lip difference?
- 2009 RX8 R3 suspention improvements
- Help on tire size with set of wheels
- Option magazine wheel test: light weight vs. rigidity
- Need advice: Leaning & alignment
- Tallest tire that will fit?
- Anyone think this looks good
- New Springs...
- Springs and Shocks....
- Nismo rims
- Winter Tires, just on the back two?
- Advice on buying new tires
- looking for a stiffer spring. (sprint maybe?)
- Tyres?
- Upgrading suspension and sways
- Preferred Springs for D-spec shocks?
- Do four tires fit IN the 8?
- Axis Halos or Gold rims on a VR in general
- Knight Sports Lowering Springs
- Progress Sway Bars and Endlinks
- What rotors do I buy?
- Greddy Damper Control Unit (EFDC)
- Falken Hanabi?
- Thread pitch/diameter for rear control arm
- Kazera Rim Owners
- spacers
- Adjusting Preload
- Partial lowering
- Question about Springs, Sway bars and Shocks
- i need help with my tires....
- wheelhop SUCKS
- RacingBrake Caliper Owners..
- 88Rotors in South El Monte, Ca .. used to be in Rosemead, Ca
- Help with tire gap
- iForged TMPS adapter
- need help finding wheels
- Autoexe Sways questions (or any sways)
- so what do you think about these rims?
- fitment help.
- Anyone driving All-Season tires in Winter?
- Best tire width for performance on an 18x9
- coilover settings ?
- Calling all SSR wheel owners
- Rusty Rotors
- Need Help and Opinions
- chrome lip on wheels
- First time rim buyer questions
- Frozen caliper piston
- Corksport: Three-Point Aluminum Front Shock Brace
- Rear Tread Life
- while puttin on a tire, one of the screws broke the other is stripped HELP!
