- What kind of wheels
- Performance Brake Pads (MS)
- Just ordered a pair of Dunlop Direzza Sport Z1's !
- Factory Wheels
- Mazdaspeed suspension feedback
- Help with wheels
- tein s.tech springs
- Brakes + Rocks = Terrible Noise
- Bought my coilovers today
- New Brakes, Rotors, Lines.., Suggestons
- Help With Lower Springs
- Help with alignment problem.
- Koni shocks, progress bars. Which Teins????
- My Progress sway bars
- OEM Bridgestines - noise?
- Need Help Choosing Summer Tires
- Question about Work vs XX wheels
- My New Rims Part 2
- How often to rotate tires on low mileage car?
- How much tread is left in these?
- Axis Deals?
- Hotchkis Miata Sway Bars
- sway bar problems.....
- Track Prep: 17" wheels and swaybars?
- RX8 brakes - rotors shuddering
- Wheels like 2008 / 40th Anniversiary?
- Driver's rear brake piston keeps turning...and turning....and turning....
- Good books on suspension tuning??
- Wheel and tire question
- Yokohama S.drive
- Mazdaspeed suspension vs. Bilstein or Koni
- Aftermarket wheels less likely to bend?
- HP Evo Lightning 18" Wheels
- help with exhaust sounds and wheel info
- I want a mean set of coilovers!
- Tein S techs different drop heights in two front wheels
- any jic magic dealers here?
- Reliabilty of refurbished OEM wheels
- Question about rear pads...
- Wheel purchase question
- rollin fender...can you elaborate?
- Need some help finding these rims!!
- Any problem with switching inside/outside brake pad?
- No More Axis Reverb
- need some opinions.....
- Another member with the best looking wheels for our cars...
- what do you guys think about this wheel choice?
- Greddy Strut Bar
- brakes made a wierd sound...
- original black rims on a yellow rex
- Personal Review: Potenza RE960AS Pole Pos
- 16 inch wheels
- rear aftermarket springs too compressed and clunking.
- Factory Anti-Roll Bar Measurements
- Opinions?
- Cooper Zeon Sport A/S
- New wheels: Pre careHell
- Down to two tire choices...
- THK Endlinks
- Need Help/Advice :) (noob)
- HELP: Rattle/creek from the front suspension.
- Nexen Tires
- opinions on rims
- BBS Rim Protector: I know some people that need this!
- Fat red lips...
- What wheels are these?
- What is the widest tire for stock rims?
- tire wear
- Ti Grey with Tenzo Type M
- TPMS light didn't turn on .. and offset ?
- what wheel to go with?
- Toyo R1R
- Stock Black Rims on a Titanium RX8
- Motion ratio
- New tire available for 225/45/18: Bridgestone Potenza RE760 Sport
- Which Wheels?
- $128 225/45-18 Dunlop Direzza Sport Z1s
- Can you use beatrush braces and autoexe braces together?
- So which 2 wheels on the car should be the grippiest
- yes or no to these rims?
- OEM Wheel Weights + Offsets
- any body try drop zone springs yet?
- Rota P45R or Tenzo DC5 black red lip???
- offset question
- Coilover Wrench
- What are you riding on?
- Help Please
- 18x(9.5-10.5) +(40-45) wheels for less than $300/each??
- Rims on the 40th anniversary edition
- Anyone here run Bilstein PSS9's?
- Wide Rims and Coilovers
- Racing Beat springs - which dampers best match them?
- Mazdaspeed Question
- How much to chrome plate my wheels?
- What about this rim/tire setup?
- Can stock TPMS be transfer to another stock rim?
- Work Emotions CR KAI
- 18x10 possible all around?
- Mazdaspeed Shocks vs OEM Tokicos.
- Bent wheel question for forum
- Broken Rear Endlinks
- OFFSET Suggestions
- Need tire choice advice.......
- Just arrived: Goodyear Eagle F1 A/S
- Tein S-techs Questions
- would these fit?
- MS Coilovers vs. MS Shocks and Springs
- These Wheels.....
- what to put on tirerack.com
- Need some 2.5" Center Caps - Help
- Maximum width for stock rims
- Wheel well liner rub
- Falken Azenis RT-615 vs. Nitto Invo
- DSC is it standard
- Anyone in NYC have tein s tech lowering springs?
- 1st post-new here-just purchased 04 rx8 loaded-has roaring noise
- Discounttires.com?
- Another TPMS Problem
- eibach springs.
- Which wheel would be best?
- JIC FLT-TAR Installed!!!! Finally!!!
- Legit Volk Dealer?
- Need help with rims size and offset with tien mono flex suspension
- Wheel Feedback Wanted...
- progress, whiteline, and adjustable sway bar questions
- Witch wheels ?
- JIC Magic Interest
- All season tires Question?
- light rims question!
- Rays / Muteki lugs on stock wheel
- HKS vs Tanabe
- Help with JIC Magic FLT-A2 coilvers
- Thinking I might have found my next set of rims
- Adjustable air bag suspension??
- Potenza Re960as Pole Position
- New SSR D5R wheels installed !!
- Can you guess my fitment?
- RB ET300 pads Lower Bite than Stock?
- Will These Fit My Stock Tires???
- Quick OEM Spring question
- Adr-42 M-classic
- Are these tires ok? This is what the dealer put on for new tires
- alignment settings.
- Comparisons to the Toyo T1Rs?
- Finally Ordered My New Rims!
- Replacing only 2 tires?
- Alignment tomorrow morning - questions?
- 19" rim question
- quick eibach q??
- Need help deciding between tires
- Tanabe sway bar
- Staggered look/Offset?
- Question about McGard Lugs
- weird drip on rotors
- Tread Depth
- Switching between winter & summer wheels with TPMS
- 255/40R18 Toyo T1R
- need help to fing 18" in UK
- IN PROGRESS!!! Need advice ASAP.
- what do you guys think of these rims?
- Spare tire + lowered ride
- Ftmfw!!!! Black Rpf1 This Month
- Powdercoating or Zinc Plating
- 19" Axis Super Hiro
- RX8 Vibrations
- mixing pads on same rotors OK? (can I re-bed-in?)
- General Exclaim UHP vs Fuzion ZRi
- Size and offset of these wheels?
- just suggestion ...
- How to fix curb rash at home
- A question for those riding without TPMS
- Shock replacement
- R-1 Wheels
- Question: Rx8 coilover
- Can someone help: 19s or 18s???
- Lug Nuts for WedSport SA70
- So, I have this bad sound....
- Underbracing Clearance?
- Noob Question FOSHO
- Worn tires, front or back?
- A question about brakes/suspension
- my Time Attack idea
- New Tires on my car - Funny TPMS story...
- BFGoodrich G-Force T/A KDW-2 or Toyo T1R
- 4 point strut tower bars
- 18x8's
- Brake pads/Rotor question and help???
- new wheels came in...
- Rota P45F
- Tein S tech and 19 inch wheel owners help
- Picking up 05 22k Miles...Brakes,Tires?
- Adjsuting camber at home?
- Problems with Tokico DSK-519 Shocks and Springs kit
- Evo-R Adjustable Endlinks Installed
- Who makes this strut ladder???
- New Enkei LS5's???
- powder coating
- correct drilled rotor direction??
- Stiffer suspension
- blue brake caliber paint?
- Should I have snow tires and summer tires...? Or All Seasons?
- quick wheel fitment question
- What's Brand is a good front strut tower brace?
- TEIN S-Tech BUYERS BEWARE!!!!
- turning problems...???
- any tips/tricks for spring compressing?
- Would these rims fit?
- Just got my new wheels today
- missed it... widest tire/highest off set combo thread...?
- I search the "Will They Fit sticky"
- Stuck coilover collar...
- What size are the stock rotors?
- spring rates
- Summer Tires Help (decent Goodyears on stock??)
- Review: Porterfield R4S Street/Track Pad
- Rear Swaybar Endlink and Bushing differences by year?
- Good Race Suspension Build
- Mazdaspeed Shocks on Tanabe GF Springs
- Not sure what's wrong: Rubbing or suspension or DSC
- 235/45 or 245/40's Mainly stock
- A Blinking TPMS Challenge
- New Wheels
- Advan Model 5, hubcentric ring?
- Stock Sport Suspension woes
- Black wheels care & protection?
- Time for new tires
- Help Needed
- Brake issues
- Name These Wheels>>plz..
- Enkei LF-10 Rims on a Galaxy Gray?
- 18x10.5 +43et SSR GT2-H are FS
- New Wheels on my VR - Falken 19"s with Falken 452 tires and Rotora brakes
- Question for everyone with coilovers...
- squealing brakes
- There coming...
- tein springs with koni yellows vs tein basic...
- Stock tires ... Bad handling
- So... What do you guy's think of the new wheels?
- For Sale.
- NOOB Ques. Flare rear guards for Wider Wheels. Bad Idea?
- How long does it take to install springs?
- Killing off the last wee bit of tread with some sweet cornering... When to stop??
- Breaking in new performance tires, what's the conventional wisdom?
- What are they worth?
- Help with rim size please
- mazdaspeed rims
- Looking for Rotors New 2008 RX-8
- iRotors.com drilled and slotted rotors
- Anyone have MB Wheels/A-Tech wheels?
- Finding OEM wheels
