View Full Version : RX-8 Discussion
- 2 Months sitting, First startup large CLUNK
- A mistake... Please help!!!!
- Could the wankle be brought back 2 stroke?
- Premix ratio
- Engine Builders
- WHEELZ: Show us your current rims
- Is my cat dead?
- Halogen to LED headlamp conversion
- Quick question about grinding gears
- Engine coolant temp
- Is this worth buying? Stolen?
- Insurance Valuation
- World record for slowest starter speed?
- LF Pics of rx8+rx7 Center Irons
- S2 Loss of power help please
- Apex seal discussion
- Crankshaft position sensor
- Wishing everyone a Merry Christmas
- RX8 refuses to crank for compression test
- Right dash cracked, hard to replace?
- Renesis with REW housings?
- Reading spark plugs
- Ignition coil Trailing and Leading wire follow through?
- Recommended Engine testers?
- Reviving an S2 GT
- Is S1 different than S2 for the following parts?
- Scraped rear passenger fender on brick, need Sunlight Silver paint
- Shes gone.
- Renesis VS REW reliability theory
- How to connect to a iphone
- is there an android auto / bluetooth kit that works with the factory mic?
- Turbo Charger
- I Finally Drove an FD Today.
- Weird startup after sitting several days?
- Quick oil question!
- Series2 transmission with a act hd clutch
- Rx8 stalls when hot and won't fire till cool.
- donation
- Talked myself out of a rescue project.
- Castrol 5w30 Conventional No Longer Made
- Reliability modification: exhaust port cleanup
- No start, no click, no nuthin
- 2020 Rotary return?
- Super bummed - My 04 RX8 may be "totalled"
- AutoEXE Motion Control Beam (MCB)
- What is a "stage 2 flywheel" ?
- Sirius radio-Free life time?
- Talking Rotaries With Pan Speed
- Rebuild - Options??
- Pineapple Racing info
- What does RX-8 have in common Vipers, BMW 1M, Exige...?
- What about Mazda rebuilds?
- Doug DeMuro Finally Reviews The RX8
- Cleveland area compression tester
- how many people found out later that you had a secret compartment with aux?
- Masks
- Getting back in the game....
- Lookin for a flywheel
- front air dam damaged
- Can I recharge my battery with this power pack
- Pre-Mix Kits, What are you using?
- Oil Filter Adapter Question
- Will This Clutch Kit Fit an RX8
- Mazda OEM engine price increase
- Engine rebuild mods for reliability suggestions
- Three months into owning my 2011 RX-8 R3, suggestions on maintenance.
- Replacement CC
- Merry Christmas
- Franken N/A 13B PP
- Rebuild!
- Help Clutch Release Bearing
- Hitachi IGC0089 Ignition Coils - Corresponding Mazda Version
- Stock wheels , time to change tires
- Think about selling my 06 rx8 what do you think it's worth (low miles)
- Buying another JDM RX8 Spirit R. Need to swap the aftermarket head unit with Bose
- Inexpensive R3 in blue that looks nice at a Toyota dealer
- OEM Rx8 clutch blow at race Track
- Looking for R3 side-spoiler large related part number
- Interesting Temperature Readings
- Overheating pain in my pocket
- Update: 2005 6MT Sport w/149,000 miles on original engine
- Is My Cat Bad?
- Anyone regret trading an Rx8 for an Rx7?
- Exhaust shrouds melting
- Which fuel pump lock ring should I buy?
- Engine Cradel passange side stud size
- 2004 RX8 overheating
- Soo can't find this, anyone know the part number?
- Oil Pan baffling in plane
- Difference between S1 and S2 exhaust pipe
- Another Jalopnik Needs More Hits Article on the Mazda RX-8
- Pedal Extensions?
- Why Is Mazda Testing This RX-8 at the Nurburgring?
- Remanufactured engine updates
- Question for ppl who have Pettit Racing’s secondary coolant tank
- Question on Engine condition - compression numbers S2
- Engine rebuilt E Spacer and still too tight.
- Information Display Turning to Lines
- Leaving the RX8 owners club
- BHR Ignition Kit Refresh (Old Style)
- Engine recall
- AEM Cold Air Intake Help Please!
- Got an animal living under hood
- Post your ltft
- Cat rattle. What are my best options?
- FL-22 coolant ratio question
- Made a visit to Pettit Racing
- Can I use Protek-R in my Sohn oil metering pump?
- Can I use Protek-R in my Sohm oil meter ring pump?
- Back in The Game!
- Rotor Condition Opionions
- For those Interested in a possible RCTV5.2 compression tester Groupbuy!!
- PurelyRx8 members on FB
- Must grab every chance you get
- Low Compression, now what
- Injector Ground Location
- Ac question
- Immobiliser removal options
- Immobiliser push start?
- Rocket bunny body kit
- Buying OEM Mazda Parts
- Rotor Help - Is this able to be used?
- Clicking noise in the front end
- 2011 Compression Test Results at 45K Miles
- Quieter Catback with a BHR Midpipe
- Rx8 body kits.
- Help identifying transmission
- rebuild
- Towing an R3
- 2004 RX-8 with Black and White Interior?
- Mazda problem
- Cooling fan on with ignition
- Fixing Rear Fender Rust
- FOB not locking/unlocking doors
- Clacking noise near red line
- Road & Track video of blown engine teardown
- The Holy Grail of Rotary Engines: SkyActiv-X?
- Suspension/Steering issue
- Idiots at the dealership
- Looking for windshield gutter part number
- Just a little rant LOL
- My RX-8 was hit from behind today
- My Laguna Seca track day adventure
- leask detector pump Bosch number ??
- Too bad GE doesn't make these anymore!!LOL
- Coming out of retirement
- Confusing misfire issue
- Thinking about buying a RX-8
- Still don't know why my car is eating transmissions...
- Windscreen washer bottle questions.
- Carbon deposits
- Update: '05 6MT 155,000 Miles Original Everything, No rust, Runs like New
- Part number/ID questions
- Weird effect from Exxon/Mobil fuels vs. Shell & others...?
- Fuel mileage
- Stock Halogen to Stock HID Wiring Diagram or Adapter.
- Rx8 header questions
- Choppy exhaust sound.
- The RX-8, road noise, and noise-cancelling headphones
- How good is a $260 front bumper paint job?
- Disconnecting 0BD2 Port-Wiring From The Dash
- Great tool for trans and diff plugs
- Displacement on demand RX8?
- RX8 Electronics Questions!
- HELP!! 2004 AT RX8 Dies At idle
- Engine mount bolt size help!
- How much of this is true? Kuro
- Polyurethane engine mounts advice!
- Engine mounts! Can't get oil out
- Still don't know whats making my tranny grind...
- burning smell
- Is this the rock bottom for RX-8s?
- Coming out of Storage
- My low mileage R3 "build"
- Plastic coolant tank......
- burning smell at wits end
- "Offerup/letgo" $140 dressed mystery motor teardown & rebuild
- pics taken with borascope of rear seal leak
- Compression test results without multiple pressure figures
- Slightly worried about these spark plugs
- rear eccentric shaft seal leaking on new build
- RX8 kart gets crashed a little bit
- RX-8 Restoration : Planning Phase
- Dexelia Ultra substitute?
- What year?
- OEM rebuilt backorder?
- A good RX8 Mechanic in / near Toronto?
- Car won't start, blown fuse?
- new clutch fail
- LOUD bang after ignition ON
- Are these genuine Mazda parts??
- My 8 might be TOTALED!
- Should I be mad
- Reminder to check the air pump in your fix a flat kit
- omp pump faults found definitively
- What to do with my RX8 paper weight?
- Speedhunters - A Turbo Series II Pandem Kitted RX8's Road to SEMA
- I'm Back
- the eternal debate: S2 RX-8 vs S2000
- rx8 lost power and it doesn't go over 2000rpm
- Tune up time, talk me out of C coils and into??
- Blown Oil Cooler Rings. Looking to recoup some costs.
- Premix question
- Quick DIY Fuel Pressure Guage
- See-through rotary in operation
- Rebuilt. Now what?
- RX-8 Memes
- Need help with one last issue.
- Rx8 engine sounds
- Series II standard & options brochure by model
- Help! Quick Q (Already Searched): Size and thread count of license plate screws
- Pratt & Whitney Rotary Engine Patents!!
- Mazda CEO: Rotary to Return Soon, EV Due Around 2020
- Mazda Revives Rotary Engine for Toyota's Self-Driving Fleet
- Strange noise high RPMS , power issue
- key fob battery replacement
- Replacing the Card Key
- Future collectible classic...
- Rebuild my LHD, or dump the LHD and rebuild a failed RHD?
- Series 1 Bose non-Nav stereo in Series 2 RX8?
- Need Advice on vacuum leaks/idle problems
- I filed a provisional patent-Renesis EGR stratification
- mod to member ratio is messed up
- Storage & Starting
- Rough Cold Start Issue
- Merry Christmas
- Using Series 2 rotor housing in Series 1 engine
- Rotary Patent Print
- 2009 R3 - Compression Test Results
- Anyone in Houston good with RX8's?
- Pretty sure my engine is finally dead
- Power Steering Issues
- Dealer Incompetence
- "Compression is the root of all evil"
- Series 2 Maintenance Schedule
- RX8 seats in SEMA C3 restomod
- Having some recalls done, what to watch for?
- Combustion temps
- Dead RX 8??
- Rx8 Electrical Issues
- Some little things..
- BG Engine Assurance: someone want to talk me out of this?
- Still at a loss.
- Insane dealership quote
- Mazdaspeed catback
- Tough low-ash engine oil specs
- oil metering intermittent problem
- Is the price right? 2009 RX-8 Sport, less than 20k miles
- So who here picked the RX-8 mainly for its chassis?
- Finally really hope!
