View Full Version : Interior, Audio, and Electronics
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 [29] 30
  1. pammygo1963
  2. Source for Yazaki Connectors?
  3. FYI: Bose door amp relay problem (front door speakers dead)
  4. Help! How do i remove connectors from the back of the stock stereo?!
  5. Need info for new Nav DVD
  6. "Stock" Sirius tuner
  7. Subwoofer enclosures
  8. Issue with Stock Headunit
  9. Unorthodox subwoofer instillation
  10. After market seats and srs airbag light issue.
  11. Help with Radio wiring (AMP Related)
  12. stock head unit
  13. Satellite Radio Antenna
  14. Headlight Low Right fuse keeps blowing
  15. electronic entry cards (credit card)
  16. No Sound from Stock BOSE speakers?? Help!
  17. Blown Speakers...Can These Replace Them?
  18. Corbeau brackets don't allow for factory seat belt bar
  19. 2004 rx8 steering wheel wiring diagram
  20. 8" Bazooka Tube Install
  21. Radio noise with rear screen on
  22. CarPC with OEM Nav Hood W/O Wiring Harness
  23. Custom Car PC (Android)
  24. Interior sound issues/cracking
  25. Possible to add an 8" subwoofer in the rx8?
  26. Cheapest Audio Upgrade Ever = $50
  27. No Radio, but Nav and AC cluster have power
  28. Replacing the steering wheel. Leaking airbag light?
  29. Steering Wheel Dye Coming Off???
  30. DIY Custom gauge pod (ashtray)
  31. Replacing 2007 RX8 6CD changer radio in UK
  32. xcarlink install
  33. Lilliput 629 screen adjustments
  34. The text in my radio display....
  35. How do I fix this? Leather Tear... (Sad)
  36. HELPP! L.E.D. Reverse bulbs
  37. remote start??
  38. Really, this is Bose?
  39. Having trouble with Ipod Hack
  40. 9.53 and iPod Options
  41. R3 recaro seats
  42. mounting a aftermarket stereo deck under dash??
  43. Is it cool if I show my stuff?
  44. push button start/keyless entry
  45. 2012 bose radio/navi in 2004?
  46. Ipod and MP3 AUX intergration kit in 09's Models
  47. Genuine iPod Integration Kit - Radio Now Extremely Quiet
  48. Sirius Works Intermittently
  49. Sub pop on switching on
  50. An alternative Ipod adaptor
  51. 10" sub and amp install
  52. Redline beep is gone
  53. removing rear/main Bose amplifier
  54. Problem: Remote does not lock or unlock
  55. 2005 rx8 interior bulbs
  56. 12v supply that is only powered with car OFF?
  57. Installed Metra - Climate Control Not Working
  58. I.C.E help please
  59. Satellite radio button quit working?
  60. A/C/HeaterControl
  61. where does the metra box go?
  62. Looking for reliable clear corner LEDs
  63. How wide is our trunk?
  64. Steering Wheel Cover
  65. Aftermarket fog light problems
  66. Double Din Radio? Which one?
  67. My sunvisor...
  68. iPod connector
  69. Speaker from Previous Car Fitment??
  70. want to upgrade speakers
  71. How to make sub control switch???
  72. Series 2 Steering Wheel in Series 1 car
  73. Avic z120bt and sub install
  74. Dimmer/Illumination Wiring Help (Aftermarket Deck)
  75. Gauge cluster or ecu?
  76. any idea??
  77. Gauge problem
  78. Emergency Handbrake Replacement
  79. Metra kit but...
  80. When does AC turn on?
  81. Novice Stereo Upgrade
  82. bose sound, bass stops intermittently
  83. Single 10" box and amps
  84. seating question
  85. Sub not getting enough power
  86. What was done to my car?
  87. Keyless Entry Remote Not Working
  88. Any aux/ipod adapters
  89. aftermarket cd player question
  90. No sound from Aftermarket Headunit
  91. Front door speaker depth (bose system)
  92. What to use for a rearview mirror wire cover
  93. Question on mounting aux input
  94. RX8 Homelink Rear View Mirror Question
  95. samsung galaxy tab as your radio??
  96. Bose Center 3" Speaker Question
  97. A big name manufacturer finally takes a step in the right direction
  98. 2004 rx8 cd player problems
  99. 'Check CD' ?
  100. Help me find sub enclosure!(:
  101. Keyless ignition, start button and coded keypad
  102. Audio Dilemma....
  103. Need a bolt for radio
  104. Re-wire battery to the back
  105. Navigation buttons issue
  106. Keep getting a cd error
  107. aftermarket tweeter in base system...
  108. Throw a Series 2 system in an 06?
  109. need some help finding a stereo system
  110. I need some new music suggestions
  111. Need a cheap passenger side visor!
  112. Bose system hum static loud beep etc..
  113. Aftermarket LED's through Fog switch
  114. Interior color difference
  115. Repeat blow fuse
  116. Radar detector
  117. Custom subwoofer enclosure Install. Pictures!
  118. Rockford Custom upgrade
  119. Alt Aux Power port
  120. Stock Head unit with Subs??
  121. iPod input?
  122. Question about the OEM DVD NAV
  123. Radio and A/C Controls
  124. Wiring harness for base head unit?
  125. Car Pc issue, please help.
  126. gauge cover wrap
  127. Mazda MP3
  128. Ground for Wideband with Cobb?
  129. Question about metra kit
  130. thoughts on replica bride seats
  131. Iphone bluetooth adaptor?
  132. Unusual audio upgrade question…
  133. Little help with some panels in the backseat
  134. 1x10" or 1x12"?
  135. Need some Help for my Birthday Gift
  136. Infomation panel question
  137. Factory Navigation unit draining battery
  138. I need some help with a MP3 player adapter
  139. AfterMarket Cd player w/ AUX
  140. Got the navigation OEM hood+screen now what?
  141. Audio upgrade
  142. Subwoofer problem(s)... :/
  143. DRLs on my RX-8
  144. exterior strobes
  145. Shock sensor diode
  146. full ipad HU adaptor suggestions
  147. custom sound system help with thos damn bose amps help!!!!!!!!!
  148. Amplifier Heat Issues
  149. Electrical help please
  150. iPod for another car?
  151. New owner :)
  152. Sirius Ready?
  153. Radio Display Problems
  154. RX8 Interior Trim
  155. iPod Integration
  156. 6 disc changer problem and sound problem help!!!
  157. Deft Motion Products Knob
  158. volume problem (sound problems)
  159. N00b installing Aftermarket Radio with Metra
  160. Metra Kits and OEM Faceplates Question
  161. 04-09 difference in Bose system?
  162. Custom Red Floor Mats
  163. Question Re: Carbon Fiber Double Din Dash Kit w/ Top Gauges?
  164. amp,hu,and sub questions
  165. Climate control Conversion
  166. Iphone 4 hookup for Music/BlueTooth?
  167. Sirius receiver manufacturer?
  168. Anyone replace their Bose Large Amp? Having Major Issues!
  169. Removing boot trim
  170. Shift Knob
  171. Cheap Bose Stereo mod / fix
  172. Replaced the stock Radio....
  173. flickering dome light
  174. Navigation System in Japanese
  175. Anyone tried this AUX adapter for all firmware versions?
  176. MP3 players for older RX-8 models
  177. What Radio's CAN fit into the RX8?
  178. Rockford amp and 6x9 install ?'s
  179. Rear fog light and new stalk?
  180. Metra kit install - No Audio
  181. iPod Adapter vs New Radio?
  182. Requesting Suggestions on Sub
  183. PAC SWI-PS Question/help
  184. Anybody in NJ want a free Metra kit?
  185. DIY: 3.5mm Auxiliary Input Jack with OEM IPod Module
  186. DIY: Blank CD Iphone Aux external controls
  187. fog lights into underglow conversion
  188. SAT radio question
  189. XCarLink Problems!!!
  190. Using factory sat nav once new double din fitted
  191. Parts list - Head unit swap
  192. Trying to find shifter knob and floor mats
  193. Calling all Shift Knobs
  194. Can I retain factory NAV once I replace with a aftermarket radio?
  195. Looking for illuminated gear knobs !
  196. 04 rx8 with nav hood. XcarLink
  197. Alternator wire upgrade
  198. Opinion on Ipod Adapter
  199. Padded center armrest?
  200. What is needed to install a OEM Navi setup
  201. New radio install problems
  202. Amplifier Problem
  203. VIN of 9.55 radio firmware
  204. please help!!
  205. Prosport Halo Gauges
  206. Both 12 V sockets not Working
  207. How significant the difference would be just replacing the rear deck and tweeters?
  208. metra kit and axxess steering wheel
  209. looking for seats
  210. R3 Recaro in an S1
  211. Metra??
  212. nice link for making a cheap lightweight battery!!
  213. redoing my interior
  214. Problem with new metra kit...
  215. questions on audio unit replacement
  216. Which fog light bulbs would you get?
  217. Replacing 2004 Bose Changer
  218. Anyone tried a dockBoss+?
  219. ebay aux adapter...crap, or no?
  220. Bought anything from partsmazda.co.uk?
  221. Install oil pressure adapter and water temp adapter
  222. Aftermarket center console
  223. Symptoms of a failing Bose amp?
  224. Taking out radio circuit board - control knobs
  225. Navigation screen issue
  226. Metra kit with Pioneer AVIC-X930BT - some install issues
  227. homelink rear view mirror not dimming
  228. stereo issues
  229. GROM Bluetooth Install Questions
  230. List of RX8 specific subwoofer boxes
  231. Pioneer AVIC-X930BT installed
  232. problems with bose audiopilot
  233. Radio issue Buttons not working!!!
  234. need ipod adapter for 08 40th anniv
  235. Which screws to remove the Head Unit?
  236. EVO 4G Intergration?
  237. oem cd player
  238. Car PC -Hood controls w/o custom PCB Issue
  239. Dice R2 IPod kit not working w/ iPhone 4S
  240. GROM and Static
  241. [Q] carputer install
  242. DIY Carbon Fiber Dash Board Kit
  243. Retrofit Leather Seats - Heated Seat Wiring
  244. Escort Live
  245. HELP! Speakers malfunctioning!
  246. Where to buy this part?
  247. Leather front seat disassembly - help
  248. RX8 Office chair heated elements?
  249. Annoying squeel, loudness according to RPM
  250. stereo installation kit alternative
