- Stock radio question
- Removing Cover from lock/window controls?
- spilled milk on navi controls, joystick stopped working help!
- Pics of my interior with retractable nav box.
- amp and sub install on the Bose?!?!?!?
- Need help finding tach wire
- metra kit is out
- Upholstering Interior Custom:opinions
- summing a stereo signal to mono?
- how do you feel about??
- Sirius/XM Merger
- trunk light
- need help installing greddy profec b spec2
- Help!!! on board gps mazda 6
- Iphone 3g integration
- Steering Column replacement
- anyone have neons installed under there car?
- Ignition Lead tap in...
- Whats needed to upgrade my nav unit to the DENSO unit?
- center console broke off
- Ipod mod help.
- Is it possible to play normal dvds in the car...???
- whats better 6x9 or 6.5...possible setup with 6.5 shallow sub in rear
- What is stock cd deck worth.?
- Integrate iPhone into factory stereo via BLUETOOTH
- Upgrade audio advice
- Carpet change
- Interior LED (Back Dome Light)
- Why cant I get my remote programmed?
- possible control carputer with navi control?
- Broken Nav please help
- Where to get feed from lambo sensor
- amp problems
- Broken Ashtray
- OEM 6-Disc MP3 swap
- does Mazda's iPod Integration Module work with the iphone?
- wiring questions regarding rb gauge pod
- Axxess ipod kit
- AMP Confusion
- Fried my head unit!
- Help...urgently!
- Help-need To Remove Glove Box!!!
- my new center consol sub box
- Prob w/ cd changer
- Is there a way to drop the steering wheel lower?
- Sirius in Ashtray
- Where is the ground strap bolted?
- Stereo Won't Come Out
- All electrical systems cutting out
- Floor mats wont stay in place??
- Interior Trunk Help
- Whats wrong with the stock coolant & oil pressure gauge?
- remote wire
- My Apple Car-Puter Install Project - First Pics
- iPod Navigation control
- Tuner - USA vs UK
- Interior LED's.
- help!!!
- anyone have remote start on MT?
- Change the Steering wheel
- Memoryfab seats?
- How do i wire rear fog into back lights
- Desperately seeking passenger seat advice
- Metra kit is in....
- backseat,,,,,,
- Amp Draining Battery?
- AuxMod Wanted
- Factory navi hood!!!!!
- Navi Software and Dvds??
- Radio cut off problem
- Clear corner bulbs burning out?
- Vent pod and gauge opinions
- Swap to Mp3 player affects my BOSE system?
- ipod adapter question
- Removing dead pedal?
- Bose/system questions
- HELP!!! Vomit in my back seat!
- Dead Battery + Car Alarm
- Seat measurements
- Replacing Steering Wheel Plastic Trim?
- base 05 to base 09
- Horn Problems
- Why does the little light in the trunk draw so much power?
- Increased Headroom ... What options available
- Center console broke?
- Lost Keys
- Pioneer AVIC F-Series Navigation [demo video]
- WTB: RX-8 Leather Doors Panels
- AP engine light question
- Mazda Smart key on '04?
- Exasperated...
- rx8 stero kit - heat/cooling problems
- how to
- valentine one
- A-pillar gauges?
- help me about stereo display :( i pod connect
- Dvd Player?
- navigation software erase
- changing interior
- diy retrim
- Sirius Radio "Acquiring"
- Best Subwoofer/Amp Addition to Your Rx8
- brooken button on my center console
- Painting interior trim pieces-FAILED.
- Using car battery power and ground loops etc
- Dashboard part number
- Gauging Interest
- Use Nav while driving?
- Strobe flasher lightining kit ?
- New pod to replace ashtray
- RX-8 Metra Kit and Heater not working
- How do you remove the front seats? (GT Leather)
- 2009 r3 SEATS ON 05'RX8??
- Need HELP! Straight to the point. How To Add An Amp and Subs to bose system.
- [HELP] No sounds from speakers, possible amp fault?
- Difference between radar detector
- Sub Boxes and Other fiberglass stuff.
- Does leather burn?
- need male and female sirius/ipod head unit plugs ... I want Sirius AND IPOD
- Anyone Tried the CarPC USB->Stereo adapter?
- little help please?!?!
- Satnav
- rx8strakes & footpedal lighting
- Ashtray and lighter light bulbs
- HELP - CarPc Installation Question - Power -
- how do i get factory sat radio
- help battery died and car won't stay started
- my new interior pics
- rockford fosgate p 1's?
- Dice Electronics iPod kit blows.
- Amp Instalation Question!!
- Car Alarm for M/T RX8
- Heater not working right on my 2005 RX-8. What's the problem?
- Replacing Navi Screen/CARPc
- steering wheel plastic
- Update on the NAV disc issue from Mazda USA
- Custom gauge pod
- Any recommended audio installers in DC area?
- Whats your opinion
- Quick Help! Final Wiring Of Subs!!!
- Bulb fit question?
- Is there an HDTV Tuner for the car
- HELP Please!
- new cd player ?
- Would 2009 Recaro seats fit in 2004-2008?
- any audiophiles try this?
- site for carbon kit?
- New Interior
- Stock Bose Details/Specs?
- Anyone using the Alpine W505?
- Looking for help with Rear Footwell Lights placement.
- HID question
- Removing window tint
- Radar detector wiring help
- please help installing sub issues
- LED's for Puddle Lights (!)
- cd stuck in cd player
- cd stuck in the cd player
- How to cut off sound system?
- ipod adatpor
- Head Unit Firmware - Upgradeable?
- Satellite Radio Receiver Placement
- Auto window Up?
- How to retain steering wheel stereo control on aftermarket head & Metra kit?
- Passenger side Floor Mat problems
- Looking for a new Deck
- whats up with Japanparts.com ??!
- cheap loc's
- In-car camera solutions
- Electroluminescent gauges?
- Phoenix Gold speakers - any good?
- Trouble with Axxess ipod adaptor
- Changing the interior
- Finalizing Install, Few Hiccups
- Greddy Release intelligent infometer touch
- Help with LED load resistors / protectors
- Custom Sub Port
- What is your approach to car audio?
- Ebay Carbon Fiber Dash Kit
- subwoofer question
- HELP!!! DIY went wrong... Accidentally cut a wire.
- 6.5 for front 9 sub - even swap ??
- LEDs ??
- Gauge/Instrument cluster configuration?
- AM Antenna Issue
- Fuse place question
- Speakers Blasting Static at Startup
- RX8 Dash Command skins
- Mazda Ipod adapter connector
- Can we have a group buy of the raio knob?
- suggestion on HU
- Radio Removal Tech Help Ipod Adapter
- DashCommand does it support mpg statistics from scan xl
- Fuse block addition
- momo mmc 690
- HID changing color?
- Gauge Pod Choices?
- Custom GPS Mount / Install
- Vent POD + Gauge installed
- Installed computer in the passthrough experience noise in audio help
- interior carbon fiber pecies i have made
- Mazdatrix Radio Knob
- Carpc: what is recomended position of gps receiver
- factory alarm shock sensor problem
- Help! WOT Rattle
- LED Interior Lights issue.
- My Bro's Sony Woofer/Amp Install
- New Audio Setup Plans
- pastic rotor seat head piece!
- Any help installing flip up in dash?
- got an ONP from Mazda
- Switching Parking Lights To Turn on With Fog Lights Only
- car pc suggestions
- blown bose amplifier
- Factory alarm shock sensor or Viper?
- Kicker 15 l7 Fit ?
- LED Wiring
- some usb interface for 10.01 version?
- Is my CD player dead?
- aux jack for single cd receiver
- back to audio
- Webcam Suggestions for carpc
- Got the LED FOOTWELL set but..
- Information Display went CRAZY !
- Help! Rattle in dash...left side near vent
- Charlee's Sound Build Thread
- Changing the text display on start-up?
- Red main digital display scrambled.
- Does the 09 Require a Kit for a Double Din Install?
- Will it fit?
- wire climat controls!
- Help me choose my audio setup !
- How good is your factory system? Mine blows!
- audio freeze up
- Navigation System unlock
- Brighter rear tail lights
- Help! I need my beat-Music cuts in and out
- Attn: iPhone 3G users... What are you connecting with?
- Feedback? Tried Everything?!
- Interior Diagrams
- CD Player
- No sound from front right speaker
- fuse size?
- 09 Gauge Cluster???
- Got Feedback? Check Here Before Posting
- 2009 R3 TomTom hardwire?
- Help Please...
- 0 Guage
- My Audio Build Attempt 2
- L.E.D License plate assembly swap
