- The BHR coils vs the new LS-2 Coils
- Video of my 05 RX8 with TopSpeed Pro-1 catback
- Aftermarket Throttle Bodies
- Searched high and low... Masking CEL in new AP's?
- Catalytic Converter Replacement Suggestions?
- Clutch and Flywheel Recommendations?
- Performance Parts
- interchangeable ring and pinion gears
- Which Ignition Upgrade????
- List of performance parts, what next or watch out for???
- Mazdaspeed Exhaust
- aem cai install
- Mini cat
- RX8-LS2 coil converson?
- what midpipes will work with the turboxs catback
- Where can i buy the Cobb+tune ( MM doesnt have one for me )
- Cool New Motor Mounts
- Will Bosch EV6 injectors fit?
- new guy
- The Wayayting is the harrrdest parrrt
- Blitz Nur Spec exhaust
- Simota Intake (SIM-MZ011-POL)
- for my son exhaust!!!!!
- exhaust application question
- NA Hp improvements
- newbie don't know what to do with his 8 +_+
- rx8 k&n apollo intake system
- New motor mounts and undertray
- corksport cat midpipe vs rp supercat midpipe
- Turbo XS Exhaust Review(with race pipe)
- Straight pipes
- Installed BHR Ignition System (review)
- Exhaust recommendations
- Standard/HM vs OEM grade????
- Handling
- Tanabe suspension control
- Can anyone identify this air intake part?
- To PCM management or not, that is the question
- Gilmer Belt Drive kit
- Is this a legit exhaust?
- Another APV Thread...
- ACS-TWIN-COOL Auxilliary Cooling System
- Is it possible to convert key type?
- What is the lightest aftermarket Exhaust setup?
- Turbo????
- Turbo????
- (Q) intake
- custom driveshaft?
- Questions or compressor or turbo kit or 20b
- AP midpipe with BHR resonator problem...
- anyone know the weight of the stock catback of the 2009 rx8?
- Anyone running a BHR midpipe with ExoticSpeed R1-T?
- What coil packs will fit from other cars?
- High flow cat or midpipe
- Full Exhaust OBD
- Canzoomer
- mazdaspeed cai questions.....
- RX8Performance Under Tray Review
- Safe Turbo PSI
- Cheap uprgades?
- Mazda Rx8 Lowering Springs
- exhaust
- Header advice!
- Megan Racing downpipe anyone?
- Add Horsepower!!
- RX8 Electric Cutout
- Will Davesport cat fix midpipe smell?
- Exoticspeed R2 Titan Si - Installed
- Installed Tien Basic Coilovers, Hotchkis sway bars & RB adjustable end links
- Rotary canister
- Input Requested For Next Modification
- AP Midpipe + 2.75" Piping
