View Full Version : The Tech Garage
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46
  1. How does the Renesis make more power?
  2. Trailer hitch
  3. Might as well put up the first welcome message!
  4. Rotary applications
  5. Which oil, dino or synthetic?
  6. Suspension design/specs? Picture?
  7. Ahhhh, the "weird" bevel...
  8. Renesis observations/questions
  9. Ac / Ps
  10. 4 spark plugs
  11. Lsd Q
  12. Can I add more Torque?
  13. 300 HP MPS? and possible Performance mods for the RX-8...
  14. Steering Wheel Switch-a-roo
  15. Tochiji Fuji "Super" LSD
  16. Warranty?
  17. High Comp. rotor's in the RENESIS engine
  18. RX-8 VS WRX sti VS EVO VIII vs 350z
  19. rx8 brakes
  20. diff between LSD and DSC w/ Tranction control
  21. engine management
  22. Engine housings
  23. Port opening RPMs
  24. Mazda Rotary Engine Schooling
  25. Timing?
  26. Metal Matrix Composite Rotor
  27. Servicing / Warranty ?
  28. Rotor type ?
  29. Engine Coating
  30. Engine Code
  31. Exhaust Upgrade options...
  32. which way does the rotor turn?
  33. 3-Rotor RX-8
  34. Magic Break-in Oil?
  35. Big engine
  36. Visteon Electric Supercharger
  37. Renesis Engine Mounts
  38. Renesis Engine Transplant
  39. Rx-8 Cvt
  40. Cheesy Question
  41. Possible Torque Increase
  42. Engine Oil?
  43. Is performance increase possible?
  44. Rotary Engine Development
  45. Renesis Engine Questions
  46. HP vs. BHP
  47. Is fuel cut at 10K instead of 9.5k
  48. Fuel Consumption
  49. Tornado???
  50. Ceramic Rotary Engine
  51. Graph of the power curve for those interested.
  52. Horsepower, Torque and Weight...
  53. Recommended Fuel Grade
  54. turning ration Q
  55. Expected mileage
  56. Buger and others! What do you think?
  57. 1.3 RENESIS engine
  58. 700HP Rotary
  59. Wheel offset and bolt pattern?
  60. Faster version of the RX8 in a few years?
  61. US specification versus EU specification / hp and torque
  62. Proper Break-in Procedure for Rotary?
  63. Mid-Engine vs. Front-Engine
  64. head light bulbs????
  65. ? re supercharges
  66. tubo boost?
  67. Rotor Tip Seals - Theoretical Life = 150,000 miles
  68. Octane Booster
  69. Weight savings: Target 1.200 kgs
  70. Rotary vs. Piston Maintenance Costs - Concerned
  71. newbie to rotary
  72. rotary RPM = piston rpm?
  73. Turbocharger question
  74. Simulation Software
  75. Superchargers, Aftercoolers, Advantages ?? ??
  76. Engine Covers
  77. Engine Accessibility
  78. Speedometer update speed
  79. Aluminum side housings?
  80. Is it possible to have an engine without a rev limiter?
  81. Clutch Drops?
  82. Gearing of the 5 speed
  83. Chassis Rigidity, RX-8 vs. 350Z
  84. Exhaust System.
  85. Renesis Rotors
  86. 3 Rotor Renesis
  87. Performance increase Poll
  88. Engine???
  89. Engine build rate
  90. quietness
  91. Renesis Detuned?
  92. Rotary Engine Displacement (L/rev)
  93. 4 Rotor e-shaft
  94. why not more uses for the rotary?
  95. more torque? not the kind of thread you think
  96. Do rotary engines "break in"?
  97. not about torque i promise =)
  98. gearing!
  99. dual exhaust ports and a 3rd rotor
  100. RX-8 to use a 9.3" clutch
  101. RX-8 Engine Compartment Layout
  102. oil leaks
  103. RX-8 Auto Tranny
  104. Since the Sport Compact Car article went up... (thanks btw!)
  105. I have a question for everyone
  106. What Happened
  107. Apex Seal size?
  108. detonation
  109. Starter current?
  110. Would a flooded renesis be harder to start?
  111. How to properly break in rotary engine?
  112. specs on an old 7
  113. Displacement on demand
  114. Cold Air / Ram Induction.
  115. UK 5/m tuning
  116. Possible future problems with side exhaust?
  117. Remote Start
  118. Mod possibilities other than FI?
  119. Has anyone thought about this yet???
  120. Money shift?
  121. I WANT TO LEARN... teach me...
  122. Torque vs Horsepower
  123. Turbo or Super?
  124. A Good Book About Rotaries / Rotary Tuning?
  125. what would happen?
  126. win or lose???
  127. Can the rotary run on MMT gas?
  128. Shop Manual - How to Order?
  129. Renesis Torque 450ft/lbs.....
  130. win or lose part 2???
  131. LSD and Traction control.
  132. ECU upgrade
  133. Looking for technical information sources
  134. Spark plugs ??
  135. Breaking in a Rotary Engine...
  136. Oxidation Protection
  137. Porting Questions
  138. Diff in 3rd gear acceleration?
  139. Cumulative Synthetic Oil Discussion
  140. Oil Filter
  141. Books on Rotary Engines
  142. Turbo Kits and Aux Ports
  143. Rev limit
  144. Internal Rotary Work
  145. Weight of base model RX-8?
  146. New king of rotary power....link!
  147. self adjusting hydraulic clutches
  148. Engine Warmup Time
  149. LED's
  150. Hp/L?? What's The Best Metric??
  151. carbon removal proceedure
  152. estimated power?
  153. Paul Yaw sets his sights on the RX-8!
  154. Lets speculate on aftermarket performance engine mods
  155. Question Regarding Fuel Economy vs Engine Speed
  156. Renesis Reliability
  157. A good OBD-II/CAN device?
  158. Rotary Engine and NOS
  159. 0-60 SMT vs MT
  160. winter wheels
  161. Heel & Toe is obsolete......
  162. Combustion Recess Differences
  163. is my eyes deceiving me??
  164. Misfiring System or Anti Lag System
  165. Interesting snippets from the Tech Highlights CD
  166. 6spd not for short people...
  167. Factoy Service Manual
  168. Lightweight Battery
  169. Differences between a Catback and Muffler
  170. High Flow Catalytic Converter
  171. Brakes..
  172. First view engine internals - Rx8 Engine Autopsy
  173. How to run-in the RX-8???
  174. RX-8 *Break-in period* *Oil* Got REAL ANSWERS!
  175. Wheel Locks
  176. Buttons on the Steering wheel
  177. rotary questions
  178. Restoring 250hp on the 231hp euro spec
  179. The role of the oil in the rotary engine..
  180. Automatic RX-8 Performance
  181. Xenon and Bi-Xenon
  182. RX8 Oil recomendation
  183. Who is trading in the Bridgestone RE040 Tires for better quality tires?
  184. Octane booster Info/Questions
  185. fixing low torque ?'s
  186. Ports different between auto and manual?
  187. Compression braking?
  188. What exacly does the manual say about breakin?!!
  189. Information Display Question
  190. six port motor
  191. rear end gearing change
  192. E shaft
  193. Return of the Steam Engine?
  194. Exhaust note
  195. 90+mph Rattle
  196. synthetic motor oil
  197. Odd but questions with a point (can't say what yet though)
  198. RX-8 Manual transmission
  199. what kind of turbo does a FI rx8 uses?
  200. Oil Overfill
  201. yikes! another torque thread
  202. Remote engine starter
  203. Question about adding oil
  204. chips?
  205. Oil control
  206. Grounding Wire Kits Info/Questions
  207. Tire pressure control: how it works?
  208. CEL codes, anyone?
  209. RX8 tune-up
  210. Body Question
  211. CAN technical info?
  212. RX-8 tuning potential
  213. Oil Pressure Question
  214. final drive mods?
  215. Extra intakes in Front Scoop?? What are they?
  216. What's to the right of the Battery box?
  217. throwout bearing rattle?
  218. Synthetic is OK (Mazda)...
  219. Non-functional diffuser made functional?
  220. Yes, the Oil Pressure "Gauge" is FAKE.
  221. Tire Pressure Monitor (maybe helpful info)
  222. Mazda's current stance on hp issue
  223. Performance of owned cars...
  224. Air conditioner pump cycling
  225. oil question
  226. Break-in Oil?
  227. Annoying noise
  228. Gear rattling (not throw-out)
  229. Dyno Results w hard data (On a known Dynojet)
  230. Checking oil...hot or cold?
  231. We need Dyno runs on Euro and low-powers
  232. 1st Oil change - 3.75 Quarts
  233. What's the deal with the Hi-Power Renesis?
  234. here's something new. (someone please comment)
  235. RX-8 Oil Filter - same as Miata
  236. Check Engine Light
  237. Oil warning light on at high speed?
  238. Got a question
  239. How do i install fuel cut out system???
  240. Anyone with Oil Cooler Leaks?
  241. **DYNO Problems from SCC Magazine**
  242. Has anyone dynoed an automatic Rx8?
  243. Oil change question
  244. engine cover functionality/uselessness revisited
  245. Missing Throttle Body
  246. My oil light blinks on and off sometimes....
  247. Questions in the name of research
  248. Engine fan on after key out
  249. Engine sound.
  250. RX-8 Reliability Concerns
