View Full Version : The Tech Garage
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46
  1. Clarification on manual trans & differential crush washers part numbers
  2. Oil cooler/radiator fin comb
  3. Wife dented/scraped rear bumper....
  4. Driver-side headlight died today (SilverStar)
  5. Gas Cap Cause Engine Light Reset
  6. Changing oil in MT and differential
  7. Oil Pressure Guage high?
  8. Different E-manage setup?
  9. Diff Ratio
  10. UOA or just change more often?
  11. Oil Coolers
  12. 100% better shifting!
  13. Dip Stick
  14. Location of the tpms fuse?
  15. Whining sound when accelarating?
  16. How to Explain the Rotor/Eccentric Relationship?
  17. Underdrive Pulley Set and Voltage Test
  18. Sixth oil sample
  19. Where is the intake temp sensor module
  20. Removing the Stock Intake
  21. If i upgrade?
  22. Intake Mod
  23. Which exhaust and air flow
  24. 2 New Buyer Questions
  25. Alarm System
  26. Under hood light
  27. How many times should you break and re torque the suspension bolts?
  28. What requires lubrication?
  29. Manual Stock Shift Knob fit Auto?
  30. Electronic engine protection
  31. opening car door
  32. backfiring - advice
  33. Oil Analysis 4000 mile interval
  34. Filtermag alternative?
  35. The RX8 Torque
  36. "Daaammnn Speed Limiter...!!!"
  37. Battery cable disconnect
  38. Rotary Extreme Parts Question all I want for christmas
  39. what is the best spark plug for RX8?
  40. Coil test
  41. Tire & Rim Size Calculator
  42. 2005 softer than 2004?
  43. Greddy Catback Install Help
  44. First post. Have a question. Is this a blow off valve?
  45. Aerodynamics/characteristic's
  46. Dealer used wrong Oil!!
  47. Dealer Used Wrong Oil!!!
  48. Diagnostic code scan tool
  49. Hi Power - Lo Power ?
  50. Std radiator dimensions
  51. Done Removed my catalytic converter....!!
  52. How to access the low beam headlight housing?
  53. A/T vs. M/T: Different front air intakes?
  54. does this explain the dyno problem
  55. Time for Real Fuel Debate
  56. oil consumtion
  57. Rotaries Run Hot?
  58. need help installing ground wires
  59. Damaged Sunroof!
  60. Base RX8, Fully Fueled Weighs 2960lb, Without Driver
  61. Technical Info on Fuel Consumption??
  62. What cools the rotors?
  63. 225kms or 139 miles on a full tank of 91 octane!!!
  64. Maintaining High RPMs
  65. steering-wheel-mounted paddle shifters??
  66. First Oil Change?
  67. did i F**K up my car some how!?!
  68. is this where your HP went to?
  69. On Oxygen Sensors
  70. OIL Pressure wiring ?
  71. Wheel Nut Torque?
  72. Exhaust ports
  73. Hypothetical Rotor Distruction?
  74. Clutch Questions
  75. Oil Help
  76. Winter storage = Reset of Ecu?
  77. When is the A/C Compressor Running?
  78. Rotary Break-in procedure
  79. Fuel Economy, Testing It Correctly
  80. Front Seats
  81. Mazda DWS system for the RX8
  82. What makes the 3250-3500rpm rattle?
  83. checking oil question
  84. Oil in RX-8
  85. DCS and ABS mutually exclussive!?!
  86. Torque specifications needed...
  87. Speed Governor
  88. What would you do when oil light comes on?
  89. Can DSC be added to a base model?
  90. How strong is your e-brake ? How to adjust?
  91. Adding Oil?
  92. From Halogen to Xenon
  93. Clutch still rubbing when pedal depressed?
  94. my temp gague never reaches the halfway point
  95. ? about underbody part
  96. my friend cant find his dipstick, can anyone help?
  97. 1st gear question
  98. Downshifting from 5th to 4th...
  99. What fuel is best for an RX8?
  100. Question about exhaust controller...
  101. what rpm does your car idle at once warmed up
  102. Stock Air Filter Removal
  103. what does it take to set off a airbag
  104. hood adjustment
  105. Resetting E-Shaft Plate for exhaust install
  106. Identifying trans & diff crush washers
  107. HID Headlights or standard
  108. MAF wiring question
  109. NEO synthetic
  110. Increasing max speed/removing the governor
  111. Fuel Filter
  112. Leaving for a year need storage advice
  113. Fan position on center dash readout
  114. RX-8 trany gear ratios
  115. New USB canscan from harrison
  116. Has anyone lost their dipstick?
  117. What would you do??
  118. Battery Tender
  119. KAM tutorial?
  120. ECU Reprogrammed after running out of gas?
  121. ECU in learning mode = higher MPG?
  122. Redline Transmission Oil
  123. HELP: I may be in trouble...
  124. ECU/ Flash version?
  125. Help, 1st oil change, could not find the crusher
  126. RX-8 locks up by itself within 30secs?
  127. All the rotary tech you've ever wanted to know!
  128. HELP--- Alignment
  129. What Octane Fuel Do You Use
  130. Campaign code?
  131. What is your Oil Use and gas
  132. 05 keys
  133. Type of Oil Do You Use?
  134. pics of old oil pan with the old baffles
  135. Breaking in question, need answer ASAP
  136. Safe jacking points? (pics)
  137. Help please! I think I'm screwed!
  138. Shop manual
  139. Oil pressure gauge question
  140. 2 piece versus 1 piece apex seals
  141. Ground Stabilizer
  142. Water getting into engine
  143. Is it suppose to be like this???
  144. 1 rotor = half the gas consumption of two ?
  145. "rotary shaped alterntor pulley"
  146. shop manual
  147. Tire Pressure light on-don't have option
  148. CEL and Redline warning light..
  149. Got a CEL for air pump?
  150. can somsone give me their maintenance schedule?
  151. New Developement yet another chapter
  152. Does NE1 have Key Blanks for '05 key?
  153. o2 sensor...
  154. MS Front Strut Question
  155. fitting water temp gauge?
  156. DSC flashing fix - redo?
  157. Has anyone put a CarPC or CarPuter in their RX8?
  158. how to take care of water in the Oil
  159. 2005 key for 2004
  160. Any problem adding distilled water only to coolant reservoir?
  161. Bilstein engine flush?
  162. Redlining and proper care of my RX8 rotary
  163. Replacement battery sizes
  164. Compression, HP & Gas Mileage?
  165. Need recommendations for tranny service
  166. The 05 Retract key
  167. High beams burn out simultaneously.
  168. Pumping capacity of RX8 water pump
  169. Can too much oil cause damage
  170. Developed vibration at slow speeds
  171. Cracked foglight
  172. Grinded my Clutch
  173. A puzzle for you engineers (What is this??)
  174. Gearing...
  175. Frozen Clutch---Suggestions
  176. what are some telltale signs that your clutch is slipping?
  177. Replacing engine oil,tranny fluid and differential fluid
  178. Yet Another First Mod Thread - Fuel Door
  179. Anyone using Mobil 1 in their differential?
  180. Temporarily Disabling Driver's Door Switch
  181. Brake Pad DIY?
  182. Carry some Spares
  183. Help ME PLEASEEEE! i gotta problem
  184. Rx8 owners I need help...
  185. Look New "Service Bulletins"!!!
  186. Is anyone certain about the engine difference...
  187. Foglight Prewired?
  188. CEL kode kwestion
  189. Scheduled Maint
  190. Idle - Why is it bad?
  191. Engine Cover???
  192. Parts no request.
  193. Fuel Efficiency - How did they do it?
  194. Technical Specs of RX-8's Spark Plugs...
  195. Forgot to turn off my lights again.
  196. Oil light problems
  197. Rolling start for Cold Start?
  198. Manual transmission questions
  199. Has anyone relocated their battery?
  200. Warranty repairs...
  201. Revised TSB for flashing procedure?
  202. Mazda oil change(RX8)
  203. reset the computer and now dsc light keeps blinking
  204. Big Tranny Probelms Need Advice A.S.A.P !!!!
  205. fuel pressure gauge?
  206. I Have Whine!!!!
  207. Engine Coolant Leak
  208. MPG saver...
  209. TT turbo any one ?
  210. Old School Rotaries -- Spark Plugs
  211. New Transmission!!!! WooT
  212. Rx-8 question from a new owner :)
  213. Lucas Oil Stabilizer!!
  214. DIY website, check them out
  215. Evaporative Pump
  216. New spark plugs installed "PIC"
  217. Hymee's 3000th Post. Something Special - Instantaneous Fuel Consumption
  218. Question about odometer
  219. Fuel tank upgrade?
  220. How much power at the wheels?
  221. Battery weight, Engine cover weight, lug nut weight
  222. possible fix for idle vibration in seats
  223. What could they have possibly done?
  224. Oil Filter on Tight from Factory
  225. Oil change not so bad...
  226. Cloth Seat Adjustment
  227. Anyone else have new spark plugs installed.....
  228. time for new clutch?
  229. Altitude effects on intake/boost pressure
  230. Storing your stock exhaust
  231. Advice needed on RX-8 purchase
  232. VFAD (Variable Fresh Air Duct) - Possible place to mod?
  233. Can you identify these components?
  234. Re-oiling Green Filter
  235. How would u upgrade fuel injectors?
  236. Does front license plate restrict airflow?
  237. Engine bay pics?
  238. exhaust entering cabin . . . .HELP
  239. Instrument Panel Lighting ???
  240. Mazda new engine replacement program
  241. How do we figure out how much fuel is being used at a given time?
  242. Is my AFR too high?
  243. Skipping 5th Gear
  244. 0w20 oil?
  245. Fuel Overflowing
  246. A bit off topic but...
  247. 93 octane
  248. Water in lub oil:((
  249. clutch assembly pedal
  250. New Dipstick Measurements?
