- Throttle Postion Sensor/Canscan
- Missing Part?
- [b]size Bulbs[/b]
- RX8 reflash version question
- Drumming sound/vibration from rear?
- Did not break in properly :(
- Impressions after installing Royal Purple Engine Oil
- RX8 oil gauge
- Leaving Car For Long Time :(
- New size of oil filter
- Mazdaspeed exhaust
- EVAP Pump gone bad
- Throttle Problem??
- Exhausts......
- Hello, engine mangement question..
- honey comb grill 1/2 blocked
- Whats the fastest?
- Spark Plug Gap
- 4AT engage, "click" sound
- 05 remote/key incompatible with 04 cars
- flooding!! please help
- problem?
- noisy as hell
- lack of acceleration - new info
- Brand new RX8 issue
- Tien S Suspension Vs. Tire Wear
- inprint on the rear bumper ouch!!!
- Compression Values on new RX8
- Clutch Disc Failure.....
- Check Engine Light Flashes?!
- Brake squeel
- How hard is it to..
- Hydrogen Powered?
- Question about oil
- Poor performance in high temps?
- I think I have a Lemon!
- First oil change...
- Mazda Hood Badge Removal
- Temp gauge
- What happens when you try to save gas....
- running slow after gas fill up?
- Where is Radio Antenna Filament?
- mazda wouldnt give me a compression test..
- Hesitation at low RPMs?
- HELP! Heads up Display is on the Fritz
- Sneek Peak of new Hymee Enhanced Product
- trimble after M flash?
- Need Help Imediatly if posibble car wont start
- Need more HP
- MazdaSpeed Flywheel Milage results
- strange noise
- 1st oil change
- Defective radiator cap?
- Redline Oil for Transmission
- Floormat Attachment Peg
- Slow shifting A/T...
- rx8 needs oil change
- Power Potential versus Gas Mileage
- Been Searching for TOO long
- Rattling noise every time my engine nears 5800 rpm's
- Axis Milano 19's
- Passenger Window Auto Open?
- New problem with A/C?
- Front suspension creaking noise
- Dyno'ing & A/F
- Need Help
- Power loss after changing gas from 91 to 89.
- rotten egg smell on start up ...
- Easier way to turn off DSC
- MPG went up.
- Turbo discussion is just as bad as the MPG discussion....
- Exhaust problem?
- Auto tranny fluid change
- Oil level on dipstick
- fed up with second gear.....need some suggestions
- What The hell my rx8 flooded with 25,000 miles
- Check Engine Light?
- Oil Coolent light?
- Help!!!
- Clutch: Ok what is this thing in the picture?
- Location of the oil pressure sensor?
- Need Help - Parts Info
- Red Line Synthetic Motor Oil
- Why is it called a short ram air?
- Where to get shop manuals???
- Post your UOA's here
- Pissed off .. help me out ... flooding ,dealership giving me bull
- Oil pressure level
- Optimal RPM's for shifting into first
- 3000 miles and a new set of front rotors!
- Check engine light on!! and emblem Q.
- break sqeel
- weight of factory exhaust?
- Where do I go?
- Squeeks near center console
- tranny issues. Too Weak....
- Foglights quit working
- Clutch stuck engaged
- Stock intake resonance chamber - plugging the hole
- Questions with M flash
- How to adjust the e-brake?
- Problem
- Will changing to Redline tranny oil improve the "notchy" feel of 1st and 2nd gears?
- MY RX-8 is slanted
- Help i want to remove the whole stock intake . should i do it please i really need he
- Clunk Noise
- Sensor on rear sway bar?
- Something that might help with flooding issue?
- Can some 1 do a pic by pic of....
- Pull to the left or right when breaking?
- Help! Dealer Screwing with Me!
- A modest proposal--engine swap
- cant find 5 20
- Whats the stronger tranny
- where can i locate the iat sensor unit / pictures
- RX8's Crank Pulley : How Secured to Engine Shaft?
- Gas/Oil Premix Thread
- Coolant leak
- How about a mild hybrid version of the RX8?
- Oil Injection Pump gone bad...
- stalling out in 3rd and in 4th with clutch in ....
- SR Intake Problem??
- About M Flash..
- What Happened?
- An interesting read on Helmholtz tuning
- when i buy the....
- Let's examine how ram air is different from other systems
- What's the best CAN Scan tool?
- New brake pads and shims = little brake dust
- Where pass from Engine and internal Car with wire?
- Anyone w/ M flash dyno
- Remote Starter, help with warm-up ?
- Cabin Air Filter
- Beeping- at 75 mph or more
- Brake Squeal Solved by Mazda, new TSB
- Flash Procedure
- Misfire at idle?
- A/T power loss and rough idle
- pyrometers
- Tbo
- Can we Mod the A/C to run on a electric motor?
- Open Door light after lojack install
- How to install a Cruise control on European RX8
- Tire/Alignment problem
- Wobbly Front Wheels HELP PLS
- Need K&N instructions
- What type of high beam / fog light bulbs?
- Performance Enhancing Chips available for Rx8? Help please
- Better Gas Mileage?
- 6MT - Anyone notice this ?
- Anyone's radio vol. knob rattle
- Fuel System Cleaners
- RPMs. measure rotor or output shaft?
- Oil Filter/Oil change Question for the experts
- A.P. Removal
- Engien oil
- question about middle exhaust port
- Reduce Shock Alarm Sensivity?
- Radiator Fan Damaged! - Check Yours?
- Cargo Net Installation HELP
- MOD suggestion: Auto close moonroof w/ windows.
- Finally happened - sliding console lid broke
- Running rich
- 1st to 2nd Shift Noise
- Oil Gauge
- Why doesnt my engine shut down?
- hard shutdown
- Airflow calculations
- Where Can I put an Inverter (12x-->220v) and Xbox?
- Removeable Panels?
- Pulsating Brakes
- Flywheeling
- Im approching 25K miles and it's only 7 months old
- Weird idle with lower octane gas (87 or 89)
- Big Big Problem
- gas hog????
- Couple Problems..... Advice
- burnt clutch and high rpms
- accessories for the rx8
- dropped left battery holddown into compartment
- Argh.......cracked windshield
- 0-100 mph
- Repsol Mineral 10w30 and mazda 323 oil filter on RX8
- Renesis Durability
- The best strut bars
- PSI for 19's
- Engine rejuvination
- The Rotary Engine Illustrated
- First Oil change?
- "clunk" when first pulling away? More strange noises from the '8.
- Uneven Brake Wear and Smell from engine.
- Burning smell right after AC Amp replaced
- New Rollover Sound Question
- CEL and weird idle after experimenting with diff. grades of gas
- A/F ratio plots - normal?
- rx 8 navigation help
- Question about transmission fluid overfill
- Clutch/Brake Fluid Reservoir & HP Brake Fluid
- AIR bag help PLEASE QUICK!!
- Which oil? 5w30 or 10w40?
- So many different bulb types! Help!
- Running TOO cold??
- Benefits of 5.1 brake fluid?
- The little things add up..
- Oil Level Help
- Redline Beep..
- Part # for center console clips???
- Who likes Amsoil better than Royal Purple?
- Help me break in my new renesis...
- What does this mean?
- MAF thought
- 20B crate Rotary Engine?
- removing steering wheel?
- Volumetric Efficiency and Gas Mileage - Any Way To Improve On The Design?
- Fumoto Valve vs. Fram Sure Drain..
- OEM Airbox Modification
- Identification numbers
- Installed LED parking lights and Modified INTAKE
- Japan RX-8 bulletin boards?
- Cold start problem ?
- How much would you pay?
- Suspension/axle noise on driver's side rear
- Noise from rear suspension/axle
- Engine Cover Needed?
- Central Locking
- How do u switch out the small light bulbs in the front.
- Excessive Carbon on Spark Plugs
- Break in on the RX-8
- Exhaust Rattle after HF Cat 4000 RPM
- quick question
- Rotary longevity?
- Best GAS?
- shoulde i WORRY about Engine vibration ?
- TPM Question.
- Rev matching the AT RX-8
- Help with front turn signals
- Dipstick
- 30,000 miles- too late to start using synthetic oil?
- what ia a pulley kit???
- Tranny & differ. oil: Why Red Line has one for each but R. Purple has same for both?
- If I Always Use 93 Octane, how come....
- 7500 mile maintenance service really necessary?
- Engine Oil Analysis & Amsoil vs Mobil1
- Renesis for a 914 ?
- Trunk WEIGHT
- Winterize the 8
- How to change Oil
- Anyone taken apar an instrument cluster?
- Speedo IS faster than actual speed *pics*
- Scraped underside of the RX8 and now CEL
