View Full Version : The Tech Garage
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46
  1. I R Flooded 8/
  2. My Engine is Burning Too Rich? Help!
  3. Measuring backpressure
  4. Are there any clutch kits for te 6MTs?
  5. Did I do something wrong installing RE intake?
  6. Measured Mass Air Flow & Efficiency
  7. Replaced Catalytic Convertor
  8. Low oil light issues
  9. Anyone remove fog lights???
  10. Clutch power ratings
  11. Dyno the Xylene
  12. How to shift ? Fastest way
  13. Apexi SAFC
  14. Ok answer some confusion on S/C'ing the 8....
  15. A/T shifting.....
  16. O2 Sensor removal
  17. Replacing Plugs
  18. local mazda dealership's recomendation
  19. Question bout idle
  20. The Air Conditioner in The rx8
  21. hot center console - did a search, can't find the info
  22. Side Markers, can they be altered to blink?
  23. Would a highlfow Cat help reduce cabin heat?
  24. ???display Unit Doesnt Work???
  25. Gear shiftin
  26. MAF and MAP?
  27. ECU/PCM for the 192hp. "M" reflash: idem 231hp???
  28. Engine Cover - Serve any real purpose?
  29. M flash
  30. As the engine was making my garage an oven
  31. Slight metallic sound at about 6000 rpm
  32. K&N Dyno [kandn.com]
  33. arizona drivers!
  34. How do you Dyno this thing.
  35. regular oil or synthetic
  36. Vacuum leak or something else?
  37. Fog Lights
  38. Proper Technique for 4 jack stand use
  39. 1.5 Liter HP?
  40. Front Splash guard installation problem
  41. Problem with brakes whisteling
  42. Question for you wiring gurus
  43. A/C Cycling, Jan 2004 Build?
  44. transmission...again
  45. CEL on freeway
  46. Just bought an RX-8...and just got a CEL.
  47. Trunk Space
  48. idle RPM is constant but I feel some slight vibration when idling
  49. Amsoil ATF?
  50. Why a 27% power loss?
  51. 3 rotor means...
  52. Seals
  53. Guys i have a big problem i think my tranny,or clutch went bad
  54. Question about Renesis firing frequency/order.
  55. Cool stuff: eMachineShop and related
  56. Why is the e/R ratio so critical?
  57. Over Heating issues
  58. I have big Tranny problems, clutch, and flywheel
  59. Hiroshima, I think we have a (lubrication) problem....
  60. Check Engine Light
  61. My Mazda dealer uses synthetic???
  62. Mileage: 3250 - 3750 rpm is the key
  63. need new gas lines??
  64. They told me why I couldn't get past 6krpm
  65. Renesis motor in a Lotus 7?
  66. burnt coil question
  67. Flashes-can you get them flashbacked??Low end power loss...
  68. Rear End Noise
  69. theyre going to fix my squeeking brakes, opinions needed
  70. Engine Break In
  71. Car wash Broke the Tire Pressure Sensors
  72. Burning "What Kind" of Midnight Oil?
  73. Screwed up with motor oil, I think :(
  74. Oil filter questions
  75. M-Flash ?!
  76. Oiling System
  77. Installing grounding kit. Question about order of install?
  78. How Much Is That Oil Filter In The Window?
  79. Dynamic Stability Control
  80. Intercoolers and superchargers
  81. Idle vibration almost gone
  82. Oil Change
  83. WTF is Killing my Battery :(
  84. Tire Pressure question.
  85. 3M Rockguard
  86. Redline fluids. CHEAP!
  87. Cooling Fan running???
  88. maf options
  89. clicking sound around the steering wheel
  90. Which is better? Redline or Royal Purple?
  91. CEL light
  92. PCM Flash Verification
  93. Getting your new RX-8 into SHAPE! Sample Service Log Doc
  94. Is it normal for cars to drift to the right?
  95. ECU (made by? and sensor inputs into it?)
  96. dum question please answer tuning
  97. 6th gear??
  98. Griot's fluid extractor...a new way to change the oil?
  99. V-power gas by shell ?
  100. Question about grounding and the ECU
  101. not even a year old yet and
  102. Spark Plugs*When did you notice you needed them?
  103. Question about down shifting
  104. Do's and Do not's??
  105. Wiring harness short/ECU reflash
  106. about CZ
  107. weight reduction
  108. 13B-MSP assembly
  109. BOSE POWER cable
  110. Hard Shifting 1st to 2nd
  111. Engine Noise
  112. DSC/TCS OFF - Does it matter when?
  113. Blown headlamp already?
  114. Grinding sound from engine
  115. Minimum RPMs?
  116. Programming Help
  117. checking overnight and every-other-night gas levels
  118. Electrical problem
  119. Premix on the RX-8
  120. new radiator cap...question about pressure
  121. Which First?!?!?!
  122. Problems with Air Conditioning
  123. Whirring noise gone
  124. RX8 internal parts
  125. Anti-freeze/coolant shelf life?
  126. Do not trust Mazda tire pump bar reading
  127. Rx8 engine runs hot
  128. getting oil change
  129. what vin? what month?
  130. jack stands/ proper jack?
  131. Future of the rotary?
  132. Transmission Durability
  133. Crush Washer Importance
  134. Is Mazda Maintenance Schedule Adequate
  135. Light weight flywheel facts ~ weight or Moment of inertia Q
  136. Registration Specification
  137. Tire repair kit
  138. Help, Installing Apexi RSM
  139. Rethinking the Garage
  140. Mazda Rx8 workshop manual
  141. 6 port sleaves
  142. 87 octane?
  143. VIN #? How to read?
  144. Driver seat bolster splitting!! Help!!
  145. Idle Rattle Question???
  146. Headlights still screwed up.
  147. RX8 side seals
  148. Need ECU pin-out or wiring diagram.
  149. Service Manuals on CDR
  150. Special tool for DIY brake job
  151. CEL is "no big deal" ?
  152. Auto Tan- filter/fluid replacement- any advice
  153. Help me ID what part I need
  154. wat will u choice?Supercharger or Turbo or Nos
  155. Oil Analysis on Castrol Syntec Blend 10W-30
  156. Oil light came on for about 5 min then went away?
  157. Mineral Vs Synthetic
  158. Dealer over filled Oil
  159. 89 octane increased mpg and power
  160. headlights off?
  161. RX-8 Loud Squeek
  162. Exhaust install questions
  163. Oil Reservoir
  164. annoying squeak from console
  165. Casper 02 Simulator 104052
  166. Denatured Alcohol
  167. Engine Oil
  168. Anyone remove their console lids?
  169. Winter technical storage details
  170. 2 weeks without my '8 (Transmission)
  171. Grinding in reverse ... should I bring it in ?
  172. strang boggin
  173. Does DSC off long-press record a code?
  174. RPM vs. Gear vs. MPH?
  175. Anyone have Charcoal Canister or evaporative hose problems?
  176. Crush Washers
  177. Royal Purple Tranny/Diff Fluid Swap
  178. Problem with CZ.1 ?
  179. Adjusting Headlights with Coilovers
  180. m flash/ecu question for new 8s
  181. DCS TCS and what others?
  182. Racing Voltage Stabilizer?
  183. speed force racing turbo kit
  184. engine bogging and check engine light
  185. Has Anyone played with Iridium plugs yet???
  186. New Problem with RX8?
  187. tip for spring install
  188. Tail light problem!!!!
  189. Anyone know where to get the flange that connects the exhaust manifold to the cat?
  190. Engine stays on when key is removed
  191. Liquid sound in dash
  192. Custom Parts ?
  193. recall for lack of power
  194. Changing fluids =easy/fun
  195. Gruppe-style intake for the RX8
  196. engine pausing, bogging when shifting?
  197. Clunking Sound
  198. Opening tertiary ports at high RPM?
  199. efficiency of the rotary engine
  200. Slinky noise
  201. Hybrid Electrocharger
  202. Looking for Rotary Professonal to Speak at College
  203. Started using V-power and weird. .. I get 19 mpg now ..
  204. Oil that lasts 30,000 km....
  205. Steering Bushing Replacement
  206. metric wrenches
  207. Improving entry/exit?
  208. Removing the Moonroof
  209. Headlight leakage, etc...
  210. What did I break?
  211. anyone else have problems with headlights or windshield?
  212. Oil Light coming on...
  213. CEL - Weird readings
  214. USA RX8 in Germany Vol 1 - My Tranny Sucks
  215. Noise coming from somewhere?????
  216. Very Poor sense of center.
  217. UK member posts dyno results showing 213.x hp and 147.x T at the wheels
  218. Dont make fun of me
  219. how easy is it to remove stock airbox?
  220. Oil Changes & Synthetic Oil, Just Changing the Filter
  221. High Pitched Whistle on Throttle Release
  222. Engine Whistle and the dealer...
  223. Anyone had a hole in the a/c compresser caused by a rock?
  224. FD engine in the RX-8?
  225. electrical problem?!?!?!
  226. Red line
  227. Some problems after 1 year
  228. How to remove the headlights and fog lights
  229. Actually gas Mileage numbers??
  230. Horn Failure
  231. Fogs kaput!
  232. Removing Resonator.
  233. What THE HELL is this?
  234. headlight help
  235. Tinting vs. antenna
  236. Air Pump Question
  237. Weight vs. Traction
  238. what i think ito did....
  239. Mazda Dealer uses 10W-30?
  240. Putt Putt And Backfire
  241. Flooding-the latest excerpt
  242. weird sound with power windows and side mirrors
  243. Do any of u experience this problem??
  244. Cranking AC on Start=Faster Warm Up
  245. Synthetic oil - more confusion
  246. Oil LEVEL gauge... possible?
  247. Testing your own engine compression
  248. Can't get my oil filter off
  249. WTB:wiring diagram manual for the 8
  250. NEED HELP on turning lights and rims ASAP
