View Full Version : The Tech Garage
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46
  1. US Spec flash in Germany?
  2. ? about the angled end of the dipstick....
  3. Help with leather seat swap
  4. Rear end gears
  5. Transmission failure
  6. Racing Beat Focus Group?
  7. Power Drops @ 7-8K
  8. exhaust cutout
  9. Anyone with post-Sept car get their AC fixed?
  10. Possible problem with "M" flash
  11. Road debris got caught under my car
  12. Low idle noise
  13. Help on valve caps
  14. help please
  15. driving hard while engine is cold
  16. Rear Rotary Accent Light
  17. Why does the renesis "lope" at idle?
  18. instrument cluster test
  19. Question about Start Button
  20. remote starter? -- flooding prevention
  21. Help Problem!!!
  22. Replacing Blue Dash LED's with UV LED's?
  23. Stability problems
  24. shifting gears
  25. blitz intake
  26. Exhaust needs back pressure? Myth or Truth?
  27. car flooded?
  28. Two mysterious interior items....
  29. Racing Beat Focus Group Update
  30. Any fixes for engine ticking and exhaust rattle
  31. Rough Idling~! please help
  32. mazdaspeed engine oil
  33. 6 to 4 shifting question
  34. when A/C on, RPM goes low? anyone has this problem?
  35. Lighter Flywheel (? more trips to Citgo)
  36. GREAT IDEA: Slacker oil holder
  37. Horsepower rating
  38. What about an auto Climate Control retrofit for us American's
  39. Restricter Plate help
  40. question about engine sandwich design
  41. quick question not trying to annoy
  42. Thrust Bearing noise
  43. Looking for rotary books
  44. AC issues
  45. Will evo 8 brembo brakes fit on our 8's
  46. dead battery
  47. What were to happen if your CAT melted?
  48. Oil Drain Plug
  49. Can the electronic throttle help save the engine?
  50. Car won't start
  51. round cover next to glove compartment
  52. Opening trunk while engine running
  53. v8 swap
  54. Headlights - Adjusting
  55. Stuck Intake Valve Problem
  56. Shifting without Clutch
  57. Useful Tip: Finding/Pushing the trunk release button
  58. Orange gas light
  59. borla smoking on new install
  60. Oil Problem
  61. Ticking sound
  62. Oil Filter
  63. hp
  64. Ignition Coil Failure
  65. Hot weather VS Renesis warm up
  66. Why is the automatic Rx8 louder than 6spd manual?
  67. Oil on Air filter?
  68. New cars with pre-L PCM firmware?
  69. My gas mileage improvement idea
  70. Tire Rubbing/ Grinding...
  71. msd ignition?
  72. is there a DIY for the MS Side Skirts?
  73. Longer throw to 5th?
  74. Chewed up 1st gear?
  75. does all the rx-8 have the temp and oil presure meter point to exactly to the middle?
  76. For All the A/T Owners
  77. schematic or scan of installation inst. for footwell lights?
  78. fuel reserve when needle low...
  79. working oil pressure gauge
  80. Fuel Filter?
  81. Has this happen to anyone?
  82. M calibration include prior updates?
  83. A stupid idea?
  84. Only changing front coilover and shock
  85. Cigarette lighter and wiring
  86. electronic exhaust
  87. weird idle
  88. engine oil issue
  89. engine oil issue
  90. (another) MPG FIX (possibly)!!
  91. Whine at High RPM
  92. 23.8 Mpg
  93. Amemiya Headers
  94. 3 Rotor Engines
  95. Synthetic Oil or Organic?
  96. Reset the DSC/TSC?
  97. Rev Limiter
  98. Possible New recall
  99. How do you change the time on the navigation?
  100. 1st Problem today
  101. think these filters are any good?
  102. Noise from throttle body with key "On"
  103. Lights don't blink with door locking/un
  104. Unlimiting Top Speed?
  105. Noob Question
  106. Problem - Need help
  107. Leather Seat Wiring versus Cloth seat wiring?
  108. Better air flow ?
  109. Valentine 1 - Radar Detector
  110. Rediculous CD skipping?
  111. Info for all of you wanting with new intakes
  112. Oil light !
  113. Steering problem w/600km??
  114. the worst gas mileage, help
  115. How do you cool the garage when you park in it?
  116. "Internal" air scoops?
  117. warrenty issues w/aftermarket parts
  118. canzoomer ecu? who, what, where, how?
  119. Is there a law that requires...?
  120. Lurching when braking hard
  121. Wonder if they ever make something like this ..
  122. Gear Shifting Problem
  123. Shift Knob Installation
  124. Fog lights
  125. RX-8 Break in!!!
  126. Warrenty on tranny
  127. custom hitch
  128. Anyone have the PCM flashed in Canada?
  129. Tire Pressure Warning
  130. Clean your MAF Got the Best MPG ever in 8 months of owning this car
  131. Xenon lights
  132. How do you clean the air sensor to improve gas mileage??
  133. A Dent in the 1/4 Panel
  134. Canzoomer upgrade Testimonies
  135. Odd Bbehavior at full throttle
  136. Something Wrong...Pop in right wheel and now lots of rust.
  137. Name for M-Flash in Canada
  138. oil and more oil
  139. Engine Coolant?
  140. How hard to install Clutch hose
  141. Misfire
  142. rear license plate mount fell
  143. MY change, how about make it lighter?
  144. high pitch wistle @ idle
  145. increase fuel economy with oil change ?
  146. The Sound of a Flood
  147. Light Fly Wheel Details
  148. How do I verify the M flash is installed?
  149. body panels made of ?
  150. car = in shop, tranny problems
  151. PLEASE HELP.... Heat problem
  152. Ridiculous M Flash story
  153. Brief loss of acceleration at morning start...
  154. Gas Cap causing check engine light
  155. Campaign 146046 (or 14604b)?
  156. Have you had the AC serviced?
  157. Flywheel Install Instructions????
  158. engine failure
  159. out of gas
  160. Failed wheel Balance
  161. Oil topping up with different grade ?
  162. Searched but can't find specific
  163. Mazda's response to my spark knock
  164. Diff Gears?
  165. Halogen Headlight,,,,
  166. Strange Intake Manifold Sound
  167. How do you remove the nav screen?
  168. MSP04 Campaign
  169. Throttle Lag?
  170. Squeal at high RPM
  171. Lost that 5K and 7K rpm boost after M flash?
  172. Hesitation/skipping below 5k RPM
  173. Puttering in idle.....
  174. Another oil change post....
  175. DSC Light
  176. serious advice needed stat!!!!
  177. Light Bulb problem... plz HELP!
  178. Intercooler w/o a turbo?
  179. First oil change
  180. brake piston diameters?
  181. RX-8 3rd Brake Light Cover
  182. New TSB I Hadn't Seen Yet
  183. can you measure real horsepower?
  184. Drain off engine oil. How?
  185. European climate control part number?
  186. A/C still sucks & 6000rpm "Bump"
  187. RX8 mileage & ECU Tuning
  188. new cat
  189. AMSOIL engine oil
  190. Cold Intake Air
  191. Engine Rattle at High RPM?
  192. Should I have flooded?
  193. 9000 miles and all is well
  194. First Oil Change: Miles or Months?
  195. Ground Wiring to help with rough idle?
  196. Bogged down feeling when taking off
  197. Emailed Mazda USA about engine oil...
  198. Did I screw up this oil change?
  199. IAT sending unit
  200. Tire Rotation
  201. Engine doweling?
  202. Burned Coils
  203. Did my car get faster or am I nuts?
  204. Pseudo power steering failure (long post)
  205. I love my car and hate it right now.
  206. Water injection and the 13B-MSP
  207. Service other than oil change at 16,000km?
  208. Engine light
  209. Another benefit to synethetics?
  210. Crap, used wrong transmission oil?!
  211. More ignition coil madness!!
  212. Sounds like power hissing at shift ?
  213. Pinging Problem? Solution?
  214. Apexi Super Ground
  215. After market exhaust
  216. car being left undriven for 1 1/2 months.....
  217. e-brake relocation?
  218. rewiring foglights...help please
  219. Question about first cold start of the day
  220. Any Short shifter compatible with the 8?
  221. Mazda says "238 hp and we're sticking with it"
  222. parking light install?
  223. Regarding Coil Damage detection?
  224. Redline Water Wetter - Thoughts?
  225. Anyone install the Aluminum Accelerator Pedal in an Auto?
  226. Engineering Power and Torque Figures
  227. REPLACED ENGINE CLUB!!!!........
  228. Rotary engines inefficient ?
  229. vertical doors
  230. noob oil prob...
  231. Turbocharger specs?
  232. Info on squealing brakes from Mazda
  233. Squeaking Clutch
  234. VFAD ???? and K&N
  235. please help, bad miss at idle
  236. APEXi Power FC
  237. weird noise at about 6k rpm, am I paranoid?
  238. Manual Tranny cooler?
  239. Transmission question...please help
  240. Transmission fluid help...comeon mazda
  241. Fluid Extractor
  242. HELP!Vibrating sound from undercarriage
  243. Coolant pressure
  244. RX8 to heavy????
  245. Oil gauge and temp Gauge idiot gauges!
  246. RPM problem! My 8 is slower!
  247. Traction control still on .. even completely off ?
  248. squeek or chirpng sound in man tranny
  249. anyone rreplace the front seats with racing seats?
  250. Check Engine Light Code Checking
