View Full Version : The Tech Garage
- Coolant leak from engine block
- My Baby lives but the Cat is dead
- RX8 Rotors in older motors
- Where can I get cheap parts?
- CEL on today, talk to dealer... got a whole ton of info..
- Diff in G-Tech and Dyno
- First Oil Change
- Shift Knob & Thread Sizes
- transmission help
- Please Help!! Brake question.....
- Hazy film on inside of headlights and instrument cluster
- Moonroof Rattle
- DTC P1416 Code - What could it be?
- adjustable camber
- Manifold pressure gauge and fuel economy?
- MNAO Official Stance on L Flash
- A/C on ????
- PCM Programing
- 2 Recalls, 1 New Cat and a RX-8 in a Service Bay
- Flooding after the "L" flash?
- greek fuel
- Service Bulletins
- Flywheel
- programming key fob (phaub)??
- Which Oil is the best to use for your top offs?
- new concerns about milky oil
- Strange noise when changing gear!
- Rev Limiter Beeper?
- My RX8 is all messed up
- Gas Mileage and Gasoline Revisited
- A/c + Wot
- seat rotor removal?
- What size are the lugnuts?
- Fuel Pump (Attn Shop Manual Owners)
- Anybody have information on the "M" flash
- OIl Consumption
- "L" flash
- Static vs. Dynamic Horsepower -> Cause of Apparent Missing Power?
- Link to the "L" TSB, so I can show to my dealer?
- broken emergency break thingy>????
- NAV knob got spilled on! Help!
- Automatic transmission fluid, exactly how do I check it, etc. Please help !!
- Electrical Problem - ACC
- Alignment specs
- Racing Beat oil cooler screens
- Cheaper mods for RX8
- Another A/C thread...
- Timing of M flash availability
- K&N Installation
- a bummer seat
- Rotary reliablity
- Shrieky fuel pump
- So....K&N Drop-In Replacement Filter or Not??
- Question on "L" flash??
- Which brand of oil?
- Drippy Water Pump
- Quicker or Faster? Lets get some things straight here shall we!
- S-dais
- ....Best Leather Seat Re-covers?
- Quick question
- L-Flash and TSBs affect JDM?
- HEADLIGHT ALIGNMENT question
- skipping gears when shifting in forward ok?
- Is "L" still it?
- Stupid question:
- what does fresh synthetic blend oil smell like?
- L-reflash G-tech results
- Drive Train
- A bumper and taillight...
- Car Wont Start. Help!!
- Insulating airbox
- Help! Mushy brakes
- Rear Wheel Drive
- thumping sound from exhaust??
- how much oil
- Accelerating
- Maintenance Prices!! OMG!!!
- Poor Starting
- Fear & Loathing At the Left Pedal:Defective Factory Clutch
- Automatic Triptronic
- catalytic converter question
- 2nd gear grind
- Audi DSG?
- im an idiot and need help to remove a bulb in the light housing
- Quick Quetions on Mustang Dyno
- Traction Delay ?!?
- Newbie with a question
- heated seats
- Hot cup holder
- Something running after the car is off?
- redline all day?
- Rear Wheel Well Material?
- Auto transmission lock up
- Chip rumor in rx-8 engine
- Reflash confusion... is there a "C" update???
- Driver's Seat Issue - Ouch!
- RPM versus MPH
- Recommended Engine Oil
- Why the torque variance?
- Engine is warmed up when...
- Belt Tension
- stock exhaust flaming
- My pressure plate bolts backed out
- Turbo/Supercharger
- Hates to rev?
- help me ID broken damper parts? )pic attached
- Question regarding M Flash
- exhaust popping
- Mazda oil filter #?
- Key turns in the ignition - no crank
- K&N Intake problems
- Oil?
- Premix Anyone?
- Diff problems
- Gearshift Knob Vibration
- CAN Scan tool for RX-8's CAN-OBDII bus
- Long start
- loud rattling
- FActory Alarm Arm/Disarm...
- DSC Always on!
- IMPORTANT TSB: New Oil Pan Courtesy of Mazda,If You'd Like
- i dont drive my car for two weeks...
- CEL at 41km
- RX8 User Manual?
- CEL Problem
- Exhaust "smoot"
- AIr Filter Change Problem
- Oil Filter test
- M flash vs L flash
- Important Info About Oil And What To Use!!!!!!!!!
- DIY : question , how to install aftermarket exhaust ?
- power steering fluid?
- for the Dyno/HP disbelievers
- tire problem need good advice
- Fumoto Valve not advantageous?
- So whats the verdict?
- Tire rotation
- Whining in drive train
- Manual vs Dealership oil issue
- Oil Changing
- Transmission problems...again...
- Door / Window / Panel
- RX-8 oil filter wiring question?
- Low oil no warning
- Air Ride??
- RX-8 Technical Info (CEL codes, PCM pin list, collision guide)
- F)(#$ing Oil Filter!!!!
- Classes to Learn EFI Tuning
- Can the 8's Renesis match the RX-01?
- Hard Shifting after 1500 miles.
- Rotor/caliper swap for AT car?
- what exactly is this?
- Authorized Mod
- They've FINALLY FIXED the AC (maybe)
- Is there a site that show standard
- New "non-squealing" brake pads???
- CES light @ 800 m
- Houdini dipstick maneuver
- Transmission Failure....PICS!!!
- observation, perhaps problem?
- Mazda RX8 2004 Service Highlights Book
- Spring compressor?
- single rotor renesis
- Dyno
- CZ Stage 1 and Fuel Octane
- Is my syncro bad?
- No light flash when alarm armed
- any one installed the heat mod for the center arm rest ?
- Could DSC be added later? What exactely is DSC?
- Checking for the "M" Flash
- 2nd Gear Grinding
- M-Flash coming... will try to dyno!
- mazda speed L.S.D
- Removing Brake Calipers
- noob tech question
- bizar sound
- Why is radiator fan running?
- Shift Fork?
- My fight for "flashing".........
- Narrow RX8 driver's seat - Solutions?
- Spark plug removal....best way to get to them?
- Lot of broken transmissions?
- Toluene in the gas tank, anybody use it?
- Attention owners of older 8's.. SHift levers
- Go ahead...mock me!
- m flash & smoot
- My dealer flashed the wrong thing?????
- Nology or Autoexe
- Plugs gone bad
- Should car be "smoother" at slow speeds?
- Dealer said use regular fuel?
- how long does reflash take??
- runs better when cool? how can I keep it cool?
- Pros and Cons of a lightened Flywheel
- When to change oil???
- Oil filter quality info
- Gas mileage after flash and brake stomp test
- Factory wheel brands?
- vibration and thumping feel in car normal?
- Thumping sound from wheels?
- probs...new rx-8
- CEL after M reflash?
- Awful Mileage, y ?
- I want to Check my Ecu...but how?
- My one nitpick...
- ECU Clear/ Reset
- My car isnt well :(
- L & M Flashes, What do they fix? Flat Out
- Battery manteiner
- car in service - over lemon law allowence (4 times in MI)....frustrating!
- Weird Idle sound when I start the car and release the clutch
- new rx-8...probs..please help
- How to flash ECU to M-Spec?
- some help please?
- Recirculated A/C and gas and performance
- Rattle On Acceleration!
- Difficult 1-2 shift
- About checking oil every 500...
- No beep on redline
- Smaller Tire Size?
- Engine light "FLASHED"
- Want to put RCE in a motorcycle...
- Regular or Synthetic
- Check Engine Light , Intake?
- Question about 1st gear
- Loud cranking noise...
- Valet Key
- PCM Flash question
- Where is the ECM?
- G-Force performance chip
- Nhtsa
- B&B Exhaust to arrive this week!!!
- Shock Sensor Upgrade Killed AC
- Modding The 4AT / Learning 'bout Cars
- Rear Bumper Reinforcement
- Two stroke oil in fuel...
- 238 hp or not???
- ~ Power Steering Problem? This may be your answer! ~
- Anyone Install Midpipe Yet?
- Tran/Diff oil change and Tranny noise?
- first gear grind
- 02 simulator help
- CZ compatible with which Intake?
- Why wouldn't I want to mod my 8?
- Oh no.. 1 week old and it clunks - Help
- Normal Downshift Noise????
- NEED TECH Help!! (foglight install)
- Exhaust Question
- Dyno Questions
- Clutch pressure variation?
vBulletin® v3.7.5, Copyright ©2000-2012, Jelsoft Enterprises Ltd.
