View Full Version : The Tech Garage
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 [46]
  1. airflow meter sensor
  2. Key
  3. New fob blade not cranking the engine
  4. Could this be reverse switch?
  5. NEED HELP with shifting
  6. My little fix for a bad starter solinoid
  7. IS IT POSSIBLE??? please help
  8. Replacement OEM Autodim Mirror?
  9. Something fell off from my 04 RX8
  10. Forgive me, another compression thread...
  11. P0076 Solenoide Valve Replacement
  12. Cat Back system question
  13. Fuel pump ????
  14. Sway bar, Front or Rear?
  15. ESS Cleaning FAIL! Help!!!
  16. switchblade?
  17. Anyone know what tips/exhaust this is? (pic)
  18. My motor is blown.
  19. Engine out of warranty - How much did it cost you?
  20. Side Markers
  21. Ironic window sticking problem
  22. Driving the Car Hard Pros and Cons after Engine Pulled Apart
  23. Diagnostic test for audio unit
  24. In the market for a used 2004 rx8 engine
  25. Rx 8 headlights
  26. Drivers Door wont Open
  27. Headlight Questions from a new owner
  28. Compression test on a nonstarting engine????
  29. 1 month review/ suggestions?
  30. Help me identify this diff cover
  31. RX8 electric hybrid conversion
  32. upgraded starter
  33. BHR coil kit
  34. ZEX nitrous
  35. Hard start up
  36. Fresh out of Storage!!!
  37. Back pressure
  38. Anyone replaced a window regulator?
  39. RX-8 Complete Workshop Manual.
  40. Clutch problems!!!! Help!!
  41. Some issue
  42. Some issue's
  43. 13b engine in a Rx-8
  44. b 12 carburetor cleaner vs sea foam
  45. Removing stock air filter box!!!
  46. Anyone swap out their battery cables/terminators?
  47. Pop / clunk only when turning right.
  48. warm starting issues
  49. has anyone ever tried to keep there SSV open all the time?
  50. SCCA with a midpipe? "cat" and catback?
  51. Flywheel nut removal tip
  52. high power interior loom into low power
  53. Rebuilding Renesis ,anybody have a wiring diagram?
  54. MSP16 poll
  55. Another compression test thread
  56. Let's play name that connector! (please:)
  57. P2070 intake manifold tuning valve stuck open
  58. Need a DIY on Mod from the 09 Fuel assy to a 04
  59. P2096 and P0171 System LEAN
  60. Kenwood 6980 Radio Replacement, Setting the Time
  61. Thread pitch help
  62. Oh Vey
  63. rx8 crank speed
  64. Engine disasembly Issues
  65. Need a quick response regarding seafoam!
  66. Radio Help Please!
  67. So I went ahead and changed my plugs... xD
  68. Ls rx8
  69. ssv wiring
  70. Torque - auto CEL clearing
  71. Key Fob Boot Button
  72. Getting my rx8 thuesday!!!
  73. spark plug removal vid
  74. Need some opinions
  75. Oil Pressure Regulator
  76. power problem...
  77. Rattling Trays Fix
  78. after market coolant bottle
  79. Clutch Job + Rear Main Seal?
  80. omp
  81. Move the RX8 A/C condensor
  82. Using a front O2 sensor for the rear O2 sensor slot (briefly)
  83. Engine management trouble. . . . . .
  84. Considering Buying An Rx-8 But Im A Total Noob
  85. question about engine swaps
  86. bad first gear stumble when dropping from second
  87. Use Series2 OMP when rebuilding a Series1 engine
  88. Whew !!!!!
  89. Hey knowledgeable members!
  90. tail light gasket driver side???
  91. My car is shutting down
  92. I'm getting a new engine core--what else should I do at the same time?
  93. I fixed my hot start! ! Fix your rx8 for under £5
  94. wondering what oil i have???
  95. transmission swap
  96. Ziebart
  97. Cruising speeds, what speeds gives the best MPG?
  98. Engine gone ........
  99. Alternator Alternatives
  100. Storage
  101. time for a New clutch - dealer or indie shop - NYC shops?
  102. High flow catalyst
  103. Replacing Fuel Pump
  104. Diff fill plug
  105. Front Stub Axle
  106. Catalytic Converter Mod
  107. What is a good exhaust?
  108. Can I use any filter cleaning/oil solution on air filter
  109. Fuel Injector Male Connectors
  110. cat /air pump delete
  111. How does the OEM Navi tie into the stock stereo system?
  112. Why doesn't my OEM front bumper fit flush anymore?
  113. Need help!
  114. Transmission and Diff Bolt Head Sizes
  115. New here new to Mazda
  116. Engine Code P0850 Engine Idle Hunt Problem
  117. Non Mazda mechanic stated flooded spark plugs?
  118. ssv
  119. First Time Rotary Engine Owner
  120. center panel help
  121. faster starter
  122. Engine Swap
  123. rate my plugs
  124. Ongoing fuel pump issues - on pump #4, fuel cuts out at 8k, 7k, 6k... etc.
  125. MT Clutch Stiffness Question
  126. Need to replace oil sensor, help!
  127. Need service in south NH/North Mass
  128. Compatibility of revB coils and 2.0kw starter with an 04
  129. coils, wires help
  130. Rx8 misfire on startup..Then Runs fine..
  131. Have a multimeter? Please take some readings for me!
  132. General Recommendations
  133. Spark plug issue
  134. Transmission Problem..Help*
  135. How to Find a Universal Joint
  136. Long block price
  137. Opinions please...
  138. My MAF is in pieces!
  139. hello fuel
  140. advice on running my rx8
  141. seized glide pin on front caliper
  142. engine bay noises
  143. new motor questions
  144. Rx8 Underbody crashed
  145. RX8 ABS/Traction control. Both stuck on
  146. before the motor goes in.
  147. Can someone describe what spongy brakes
  148. OBD/CAN reader with USB for laptop
  149. Replacement hose kit ???
  150. an RX8er's rebuild thread
  151. Help w/ vacuum hoses
  152. Help with Radiator
  153. Summer Oil - South Texas
  154. How do you install the A/C compressor belt?
  155. Echlin IC581 coils - experience pls
  156. Is Mann the OEM Air Filter?
  157. extra motor
  158. Replaced Starer and idle problem =[
  159. P0301 after rebuild please help
  160. Engine destruction caused by bearing failure.
  161. Help with Rotary Compression Math
  162. Help
  163. 04 rx8 head unit
  164. Another RB Oil Cooler Screen Install
  165. Wiring Harness for Fuel Injector Hookup
  166. Hand lapping, what compound do I use?
  167. Gauges : AEM VS autometer VS prosport
  168. READ ME:Considering rebuilding your engine?
  169. Difference in control knobs
  170. Fuel Lines? Where do they go?
  171. New 8 owner - Quick Q's
  172. Return fuel system chronicle
  173. Where does this connector go?
  174. Rotor housings
  175. Waterless coolant vs 50/50
  176. opinion, using used rotor housings?
  177. High RPM Hesitation.
  178. p0301 and p2096 help please
  179. What hose goes here?
  180. New york meet up...
  181. Power steering needs reset.
  182. Wiring diagram for Ignition Coil and wiring harness?
  183. How can I fix my switchblade key?
  184. Optima YELLOW TOP For Rx8
  185. How to remove the rear bumper
  186. premix and break-in
  187. Help Car will not Rev over 3500 RPM sometimes
  188. Hazards keep flashing and weird buzzing noise
  189. Finally!
  190. Coolant light on startup
  191. 2.0kw. starter
  192. ssv acctuator is dirty
  193. length of transmission??
  194. Engine Recon
  195. 04Rx8 Airbox breakdown please!!
  196. Charging System
  197. ATTENTION ROTOR HEADS (turbo charging question)
  198. Lpg
  199. New owner, power loss and misfire concerns
  200. Oil Filling
  201. New to the forum, had technical questions.
  202. Anyone have OEM from caliper bracket/carrier for quick sale?
  203. new starter recomendations
  204. Read my plugs! (spark plugs after 58k miles on BHR ignition)
  205. Anyone know the dimensions of the trunk pass-though?
  206. Alternator Belt
  207. What would you do ?
  208. Ring gear came off
  209. What else to get with a new engine
  210. Oil regulator problem with T618Z BNR
  211. Apparently DSC/TCS "full off" isn't full off.
  212. Need Help with Lack of Power and Trouble Starting
  213. Starting and Power loss Problem
  214. questions about 2004 to 2011 engine switch..
  215. Renesis Engine Vertical Installation
  216. Is this exhaust worth getting?
  217. Brake pad size for sport-suspension '05?
  218. Wet snow go the best of my 8.
  219. Clutch Question - I know beating a dead horse
  220. Warranty History_Engine,Short A/T
  221. rx7store midpipe + borla exhaust rasp?
  222. Headlights aim too low since lowered
  223. 2 questions on engine rebuild
  224. engine rebuild
  225. coils,starter what else?
  226. Starting problem
  227. jumping wires to make fuel pump run on high and low mode?
  228. Exhaust Question...newbie here.
  229. Engine dying pretty sure... :(
  230. Engine check light is coming up intermittantly
  231. Advice/help needed
  232. Coil packs and spark plug help.
  233. Sidemarker harness connection.
  234. fuel mileage - fuel injector cleaner??
  235. Radiator fans
  236. Premium gas or Octane boost?
  237. Oil pressure
  238. 2008 manual transission Replacement Under Warranty Summary
  239. Need to replace airbag module. Need info
  240. Compression problem?
  241. car runs hot in hot weather when AC is on
  242. Engine cuts off during high acceleration
  243. Rebuilding question... and possible issues
  244. engine capacity
  245. Trying to find a part - OMP Black Sensor
