PDA
View Full Version : Series I Tech Garage
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 [45] 46 47 48 49 50 51 52 53
  1. Water in lub oil:((
  2. 93 octane
  3. A bit off topic but...
  4. Fuel Overflowing
  5. 0w20 oil?
  6. Skipping 5th Gear
  7. Is my AFR too high?
  8. How do we figure out how much fuel is being used at a given time?
  9. Mazda new engine replacement program
  10. Instrument Panel Lighting ???
  11. exhaust entering cabin . . . .HELP
  12. Engine bay pics?
  13. Does front license plate restrict airflow?
  14. How would u upgrade fuel injectors?
  15. Re-oiling Green Filter
  16. Can you identify these components?
  17. VFAD (Variable Fresh Air Duct) - Possible place to mod?
  18. Advice needed on RX-8 purchase
  19. Storing your stock exhaust
  20. Altitude effects on intake/boost pressure
  21. time for new clutch?
  22. Anyone else have new spark plugs installed.....
  23. Cloth Seat Adjustment
  24. Oil change not so bad...
  25. Oil Filter on Tight from Factory
  26. What could they have possibly done?
  27. possible fix for idle vibration in seats
  28. Battery weight, Engine cover weight, lug nut weight
  29. How much power at the wheels?
  30. Fuel tank upgrade?
  31. Question about odometer
  32. Hymee's 3000th Post. Something Special - Instantaneous Fuel Consumption
  33. New spark plugs installed "PIC"
  34. Evaporative Pump
  35. DIY website, check them out
  36. Lucas Oil Stabilizer!!
  37. Rx-8 question from a new owner :)
  38. New Transmission!!!! WooT
  39. Old School Rotaries -- Spark Plugs
  40. TT turbo any one ?
  41. MPG saver...
  42. Engine Coolant Leak
  43. I Have Whine!!!!
  44. fuel pressure gauge?
  45. Big Tranny Probelms Need Advice A.S.A.P !!!!
  46. reset the computer and now dsc light keeps blinking
  47. Mazda oil change(RX8)
  48. Revised TSB for flashing procedure?
  49. Warranty repairs...
  50. Has anyone relocated their battery?
  51. Manual transmission questions
  52. Rolling start for Cold Start?
  53. Oil light problems
  54. Forgot to turn off my lights again.
  55. Technical Specs of RX-8's Spark Plugs...
  56. Fuel Efficiency - How did they do it?
  57. Parts no request.
  58. Engine Cover???
  59. Idle - Why is it bad?
  60. Scheduled Maint
  61. CEL kode kwestion
  62. Foglight Prewired?
  63. Is anyone certain about the engine difference...
  64. Look New "Service Bulletins"!!!
  65. Rx8 owners I need help...
  66. Help ME PLEASEEEE! i gotta problem
  67. Carry some Spares
  68. Brake Pad DIY?
  69. Temporarily Disabling Driver's Door Switch
  70. Anyone using Mobil 1 in their differential?
  71. Yet Another First Mod Thread - Fuel Door
  72. Replacing engine oil,tranny fluid and differential fluid
  73. what are some telltale signs that your clutch is slipping?
  74. Frozen Clutch---Suggestions
  75. Gearing...
  76. A puzzle for you engineers (What is this??)
  77. Grinded my Clutch
  78. Cracked foglight
  79. Developed vibration at slow speeds
  80. Can too much oil cause damage
  81. Pumping capacity of RX8 water pump
  82. High beams burn out simultaneously.
  83. The 05 Retract key
  84. Need recommendations for tranny service
  85. Compression, HP & Gas Mileage?
  86. Replacement battery sizes
  87. Redlining and proper care of my RX8 rotary
  88. Bilstein engine flush?
  89. Any problem adding distilled water only to coolant reservoir?
  90. 2005 key for 2004
  91. how to take care of water in the Oil
  92. Has anyone put a CarPC or CarPuter in their RX8?
  93. DSC flashing fix - redo?
  94. fitting water temp gauge?
  95. MS Front Strut Question
  96. o2 sensor...
  97. Does NE1 have Key Blanks for '05 key?
  98. New Developement yet another chapter
  99. can somsone give me their maintenance schedule?
  100. Got a CEL for air pump?
  101. CEL and Redline warning light..
  102. Tire Pressure light on-don't have option
  103. shop manual
  104. "rotary shaped alterntor pulley"
  105. 1 rotor = half the gas consumption of two ?
  106. Is it suppose to be like this???
  107. Water getting into engine
  108. Ground Stabilizer
  109. 2 piece versus 1 piece apex seals
  110. Oil pressure gauge question
  111. Shop manual
  112. Help please! I think I'm screwed!
  113. Safe jacking points? (pics)
  114. Breaking in question, need answer ASAP
  115. pics of old oil pan with the old baffles
  116. Type of Oil Do You Use?
  117. 05 keys
  118. What is your Oil Use and gas
  119. Campaign code?
  120. What Octane Fuel Do You Use
  121. HELP--- Alignment
  122. All the rotary tech you've ever wanted to know!
  123. RX-8 locks up by itself within 30secs?
  124. Help, 1st oil change, could not find the crusher
  125. ECU/ Flash version?
  126. HELP: I may be in trouble...
  127. Redline Transmission Oil
  128. ECU in learning mode = higher MPG?
  129. ECU Reprogrammed after running out of gas?
  130. KAM tutorial?
  131. Battery Tender
  132. What would you do??
  133. Has anyone lost their dipstick?
  134. New USB canscan from harrison
  135. RX-8 trany gear ratios
  136. Fan position on center dash readout
  137. Leaving for a year need storage advice
  138. Fuel Filter
  139. Increasing max speed/removing the governor
  140. NEO synthetic
  141. MAF wiring question
  142. HID Headlights or standard
  143. Identifying trans & diff crush washers
  144. Resetting E-Shaft Plate for exhaust install
  145. hood adjustment
  146. what does it take to set off a airbag
  147. Stock Air Filter Removal
  148. what rpm does your car idle at once warmed up
  149. Question about exhaust controller...
  150. What fuel is best for an RX8?
  151. Downshifting from 5th to 4th...
  152. 1st gear question
  153. my friend cant find his dipstick, can anyone help?
  154. ? about underbody part
  155. my temp gague never reaches the halfway point
  156. Clutch still rubbing when pedal depressed?
  157. From Halogen to Xenon
  158. Adding Oil?
  159. How strong is your e-brake ? How to adjust?
  160. Can DSC be added to a base model?
  161. What would you do when oil light comes on?
  162. Speed Governor
  163. Torque specifications needed...
  164. DCS and ABS mutually exclussive!?!
  165. Oil in RX-8
  166. checking oil question
  167. What makes the 3250-3500rpm rattle?
  168. Mazda DWS system for the RX8
  169. Front Seats
  170. Fuel Economy, Testing It Correctly
  171. Rotary Break-in procedure
  172. When is the A/C Compressor Running?
  173. Winter storage = Reset of Ecu?
  174. Oil Help
  175. Clutch Questions
  176. Hypothetical Rotor Distruction?
  177. Exhaust ports
  178. Wheel Nut Torque?
  179. OIL Pressure wiring ?
  180. On Oxygen Sensors
  181. is this where your HP went to?
  182. did i F**K up my car some how!?!
  183. First Oil Change?
  184. steering-wheel-mounted paddle shifters??
  185. Maintaining High RPMs
  186. 225kms or 139 miles on a full tank of 91 octane!!!
  187. What cools the rotors?
  188. Technical Info on Fuel Consumption??
  189. Base RX8, Fully Fueled Weighs 2960lb, Without Driver
  190. Damaged Sunroof!
  191. need help installing ground wires
  192. Rotaries Run Hot?
  193. oil consumtion
  194. Time for Real Fuel Debate
  195. does this explain the dyno problem
  196. A/T vs. M/T: Different front air intakes?
  197. How to access the low beam headlight housing?
  198. Done Removed my catalytic converter....!!
  199. Std radiator dimensions
  200. Hi Power - Lo Power ?
  201. Diagnostic code scan tool
  202. Dealer Used Wrong Oil!!!
  203. Dealer used wrong Oil!!
  204. Aerodynamics/characteristic's
  205. First post. Have a question. Is this a blow off valve?
  206. Greddy Catback Install Help
  207. 2005 softer than 2004?
  208. Tire & Rim Size Calculator
  209. Coil test
  210. Rotary Extreme Parts Question all I want for christmas
  211. Battery cable disconnect
  212. "Daaammnn Speed Limiter...!!!"
  213. The RX8 Torque
  214. Filtermag alternative?
  215. Oil Analysis 4000 mile interval
  216. backfiring - advice
  217. opening car door
  218. Electronic engine protection
  219. Manual Stock Shift Knob fit Auto?
  220. What requires lubrication?
  221. How many times should you break and re torque the suspension bolts?
  222. Under hood light
  223. Alarm System
  224. 2 New Buyer Questions
  225. Which exhaust and air flow
  226. Intake Mod
  227. If i upgrade?
  228. Removing the Stock Intake
  229. Where is the intake temp sensor module
  230. Sixth oil sample
  231. Underdrive Pulley Set and Voltage Test
  232. How to Explain the Rotor/Eccentric Relationship?
  233. Whining sound when accelarating?
  234. Location of the tpms fuse?
  235. Dip Stick
  236. 100% better shifting!
  237. Oil Coolers
  238. UOA or just change more often?
  239. Diff Ratio
  240. Different E-manage setup?
  241. Oil Pressure Guage high?
  242. Changing oil in MT and differential
  243. Gas Cap Cause Engine Light Reset
  244. Driver-side headlight died today (SilverStar)
  245. Wife dented/scraped rear bumper....
  246. Oil cooler/radiator fin comb
  247. Clarification on manual trans & differential crush washers part numbers
  248. Scraped underside of the RX8 and now CEL
  249. Anyone taken apar an instrument cluster?
  250. How to change Oil
