- Why is the battery not a maintenance free one?
- My first oil change experience
- -=DIY=- Topic
- Rear Differential problems?
- hey guys my engine light came on
- Moisture in my headlights
- Crate motor and new ecu
- Cracked Spark Plug?!?
- Milky substance on my dipstick....
- Grinding noise?
- Lights don't flash on alarm arm/disarm..
- change tranny oil
- Headlight focus
- Magnetic Oil Plug
- Optima Battery - Red or Yellow?
- RX8 cruise control
- Has anyone taekn a drivers seat out or Reupholstered the seat, I want to move (m)
- Anything besides the radio need to be reset
- Brace behind the backseats?
- CEL Light Flashed Before I Started Car
- Steady Oil Pressure Reading
- American/Australian ECUs??????
- Need louder redline buzzer
- New Dynojet RunViewer
- check engine light/ oil light
- over filled on diff. and tranny oil.
- Weak spark Plugs?
- Couple of questions about flooding
- interesting discussion about 5w-20 oil
- oil leaking...?
- aux cooling fan
- Engine temp goes DOWN while driving?
- My Baby Died in the Cold
- Awsome Rotary book
- Taking my car for a full day for tests!!
- Anyone have the PCM code list?
- Engine/Front axle squeaking..
- horrible gas mileage...
- Hear a sound like a siren when accelerating.
- Electric-assisted power steering
- P420 Code when CEL lights after 6 Months
- Engine warning light meant New Cat & Exhaust
- Oil Cooler Flow Question
- rx8 clutch problems at 7,200mi
- Bonneville Rotary?
- Flooded 8 rescued
- Got Milky Oil?
- oil in the air box?
- Protect your coolers - 3rd batch of Grill kits in production
- Consumption Of The 'small' Engine
- Time for a stupid question....
- For ppl who have reached 10k mi
- Stage 1 dyno
- mechanical noise when going from R>D
- How can a quart/2000Mi do ANYTHING?
- New Noise
- Fuel pump switch
- Palm OS Based Scan Tool
- Anyone Street Port the new Renesis?
- Spark wires
- White Smoke ...
- Dyno'ing and "Safe Mode" - some do, some don't.
- Crush Washer
- Break in oil - when to change?
- Synthetic Oil???
- Just got my RX-8! How should I drive it?
- Is it possible to remove the tail light reflector?
- K&N Replacment filter ready
- need rear swaybar endlink part number
- New Intake..... Rough Idle?
- Anyone else have probs opening airbox?
- How many miles for 1st oil change?
- Single Rotor RENESIS
- New RX-8 FILTER from K&N
- K&n filter dyno
- difference between cold air and short ram?
- Break In Period...
- Blown engines
- Renesis engineering tidbits from an engineering-process magazine
- Auto Enginuity Scan Tool
- Did I hurt my engine???
- How perfect can an alignment be
- getting worried about oil consupmtion
- Stripped thread installing Mass Air Flow Sensor - could use some assistance
- Access to behind rear bumper?
- added 5w30 by accident
- Self diagnosing the RX-8 and OBDII interfaces
- Is my 8 a LEMON???
- Gas smell in Oil, Driver's Seat Creak
- Anyone installation the night lights?
- gas tank presurre pump?
- Transmission whirr-rattle at idle & low rpm
- Rear Door handles/panels
- question Hp rear wheel power vs fly wheel power
- Not another Oil Thread
- Is it flooded?
- hard starting?
- dump the engine cover?
- Webasto heater
- cruise controll for Europe ?
- Splashing sound?
- Another clutch problem
- Cold start flooding @ 30ishF & 8000'
- Australian Tuned RX-8's
- Optimal Fuel / Octane Question
- Flooding sticky?
- Price for mount and balance = $120??? Opinions please.
- Pineapple Racing on blown engines.
- Mazdaspeed front four point strut
- web link to rx-8 problems
- Road Speed Governor>>>>disable
- Installing Shock Sensor
- oil usage
- Rear End Clunk
- Question for automatic owners – weird shifting
- 9000 rpm question
- Power Plant Frame info
- Anyone push started a flooded 8?
- Crazy Hazard Light/Blinker Malfuntion
- where to fill manual transmission fluid?
- Oil brands mixing?
- Clamp-on Clutch Pedal
- Clearing NV RAM
- Ive read all the debates on Synthetic
- TCS/DCS off--more power and smoother shifting?
- A point To Ponder Concerning Overfilling Your Oil!
- What is the break-in on this car???
- Power loss at 7000 rpm
- Type of gas(octane/company) varies performance greatly?
- ***Factory recall/repair of RX-8 w/6MT transmission***
- First Oil Change - Thanks to the Forum
- Side Seal clearances
- What makes a car's ride deteriorate?
- Lastest Recall
- ** Factory Repair/Recall of RX-8 Airbags **
- Just bought a RX-8, need help
- Has anyone upgraded battery or ignition
- track results: weight, hp + so much more!
- Mazda ECU Reflash
- 2004 RX-8 Front Airbag Recall
- On a dyno, where did your car make its peak power?
- Flooding (the water kind!)
- Engine Oil?
- Dealer put in 5W-30 Oil
- Weird!!
- Hotter Plugs / Reflash Mileage Results.
- What RPM do you launch
- 5K before first oil change???
- 110 Octane?!?!
- RX-8 Starting Problem
- Black sut in tail pipes
- A different oil change question
- sweet new hks exhaust
- Brakes question
- Check engine light on
- Performance audio effect the 8?
- need help.. again.
- Foamy oil (& gas mileage)
- alarm shock sensor
- DCS light went on,some info help pls.
- Lug nut torque now 108ft-lb!
- Oh my God! Oil in Intake Manifold!!!!
- Rotor Housings
- First Oil Change?...
- Burning Plastic Smell?
- warning beep and HID's
- Differences in ECU's between 4 port and 6 port?
- Swaping Spark Plugs?
- Ram Air Intake
- engineering drawings
- 4th Gear Pinging
- "little guide" no longer against synthetic?
- High RPMs necessary to ensure engine longevity?
- Exhaust Burning?
- Oil analysis - Second change and milky oil
- First oil change & observations
- My Transmission woes
- Power Passenger Seat
- a Most insignificant Mod
- Orange engine type light
- Braking rumbling/vibration
- So what's behind the front grill
- stupid oil filter. ignore me
- oil change easy
- Blackstone oil report #3
- Anywhere to look up PCM fault codes?
- Firmware "L"
- AEM is back and looking for an RX-8
- security
- Milky Oil & 5W-20 Oil
- Shut Off - Fan Runs
- Intake install
- what is THIS thing called, love?
- APEXI Installation
- Weak interior fans
- Intake Flap
- Potential problems with the engine
- E brake and ABS
- MoTec for your Rx8 now available
- Clutch Drop @3k & 7k Shock Loads?
- Royal Purple's view on synthetics in the rotary engine
- Injector cleaner?
- Exploded View of Model Rotary Engine
- Break in Procedure
- 87 Octane vs 91 Octane - Fact or Myth?
- Oil viscosity information for those who worry about the wrong weight
- How does the Rx-8 receive its mph/km?
- how to describe and is rough idle?
- oil in trunk
- Question on Shifting the RX-8
- ¡¡¡¡¡need Help!!!!!
- 265 Nm (195 lb-ft)
- No power gains from "L" flash.....darn
- Oil dipstick quantity range
- got my car back....here's the damage...
- Kudos Mazda - Automatic "L"
- Is my dealer ripping me off?
- What fixes have you applied to your car?
- Modifications and Warrenty
- Low Speed Steering Problems
- horror story instaling alarm. need help what to tell dealer
- Me and the 8 whent to the dragstip today.
- Weird gurgling sound
- My car is in the shop going to see if they will address all the TSB's
- Headlight aim
- High pitched noise on acceleration
- gear grinding
- Engine flooding in summer or warm weather ?
- What's the Meaning of this Indicator?
- Lightweight Flywheel Install instructions
- Removing Shifter Panel. HOW?
- Service Tech Knocking on Shell Gas?
- FloorMat Holder!
- oil jello?????
- Question about Dyno's
- CEL light and limp mode.......Dangerous?
- Turbo timer and remote start help stop flooding?
- MPH and Milage sensor?
- Anyone want a real gear for cruising on the freeway?
- Help would be appreciated
- almost flooded
- RX-8 Brakes 101 Question
- air fuel wire????
- Rotary Engine Rebuilding Tool set
- Does CZ Stg 1 + Borla = Racing Clutch
- flywheel?
- NVRAM reset+DSC/TCS disable= Loss of DSC/TCS
- Jerking transmision and hic ups
- The procedure
- Flood Pictures and Procedure to fix it by yourself
