View Full Version : The Tech Garage
- 2009 RX-8 Oil Drain Plug Location
- OBD II Bluetooth dongle
- Rebuild Or New Car?? Whats your Opinion
- Late model 3pt front strut brace on an 04?
- How to remove trunk lid?
- cant shift!!!
- Is there a DIY taillight removal?
- DIY ignition
- Car stalled after drift
- Cute plugs+coils.
- speaker lights help
- a lot of issues
- Installing rear under deflector(OEM Aero kit)
- How The Hell do I get this apart!
- Clutch master/release cylinder
- HELP ME PLEASE!!! power steering out...
- 6 speed AT
- Weight Distribution
- Possible Cheap Overheating Solution
- Fan Shroud Kits: Mishimoto vs. Mizu/Are they Worth It?
- Traction control light problem!
- Rx8 engine + rx7 turbo kits into a mazda 323f
- No peddle response and car has jumping revs!
- RX8 Complete Html Workshop Manual
- Complete Workshop Manual for DIY Users
- Resistance shifting into even gears
- Neutral Position Switch Removal?
- My new rx8
- How to tell if you have a new engine?
- Differences between Phase 1 and Phase 2?
- what is the recomended fuel jet to start out with for the ZEX kit+BHR
- Heat
- Got oil in your throttle body?
- N3Z2 Starter On 04 RX-8?
- Advance Keyless Entry Question
- Feels twitchy after rear suspension rebuild
- O2 Simulator. Does anyone make a direct unit?
- Rotor tip seal - an idea?
- Is the 09 cd changer and faceplate compatible with the 04
- Accelerating Problem...
- What Is this part called??
- Oil Filter Relocation Kits!
- not a weekend driver?
- Removing stock intake
- Help Rebulding Greddy T618Z Turbo
- Seibon Rear Lip Install Question
- Dealership says engine oil pan is leaking
- Uh, there's a hole in my engine...wtf!
- Possible Clutch Problem ? PLEASE HELP
- Crazy rattling noise! *VIDEO INCLUDED* take a listen....
- Engine Cover Missing? Ramifications?
- advanced auto zone spark plugs
- What is this?!?!?
- Headlights aimed at the ground
- I fear the worst.......
- Confirmed; No Compression. Now what?
- How to change to clear corners?
- Three rotor project, a few questions!
- License Plate Bulb Stuck, Any good way to take it out?
- Really need help!
- What is stock MT Diff Ratio
- LED Timer
- Use a relay to auto shut off led lights?
- CEL: P2096 and P0456
- Kinky Kelsey's Build Thread
- transmission oil spec help
- Cold Air Intake?
- how to set up the garage opener in my 8'?
- Gross Idle/5000-9000rpm growl
- Wheel Well LED help
- IAT sensor - wrong temp?
- HKS or Greddy bov?
- 8 wont start
- 97,000 mile RX8 checkup
- Best Mod for around $4 IMO
- New guy with some old problems...
- tranny and diff oil - how important is it to replace?
- trading my welded oem cat to exhaust for separated.
- New purchase rx8 05 gt, questions
- Idleling low
- Tiburon vs. Rx8
- remote acces problem
- Would this ebay thing work?
- Speedometer not working
- Stupid - left key on - did I do damage?
- Cooling fans won't shut off!?
- Hard Start Troubleshooting Steps
- LED 3rd Brakelight
- Headlight bulb change
- ssv sensor
- Catalytic converter heat shield
- throttle issues
- LSx Engine Swap: affects on handling
- Replacing the coolant reservoir
- Where to buy carpet that matches?
- Cleaning Engine with Mazda Cleaner
- aftermarket stereo
- interior swap help needed
- I have researched engine ticking
- 30,000 Mile Service
- Won't restart for up to 20 mins.
- Clutch help :( haven't had my car in 2 months
- Hesitation at ~4200rpm
- Does the Spark/Ignition Firing Order Change in the RX-8
- need new radiator??? HELP PLEASE!!! need to decide by tomorrow
- My clutch is GONE! what exactly do i need now?
- OMP problem Please Help
- Fuel Leak
- Big Willy! Puddle Lights Help
- need a design
- Cooling fan replacement
- really simple LSD question
- Draining Oil
- Replacement transmission for FI 13B
- Trouble starting when hot
- Headlamp removal?
- New RX8 owner with a question about moving the clutch pedal (wide feet)
- Underbody Engine Cover Clips Replacement
- CODE p0850 HELP Please
- body mod
- Looking for an engine wiring harness?
- tacho and speedo
- Idemitsu Premix Oil Turn Dark?
- Front Door Amp Repair
- Which tranny fluid for cold climate?
- poor gas mileage / spark plugs?
- 2nd gear grind
- LSD parts available?
- Quick Question about trunk
- Code Poo76 04 RX8
- built renesis with greddy turbo problems please help!!
- Question about damaged intake valve.
- Axial Flow Shortshifter
- Engine Health, Input Appreciated
- Anyone have compression #'s for a Renesis with 3mm Apex seals??
- Radiator smell
- 99,872 mile checkup..what a cryin shame...awww...
- Center console and foot well are very HOT...Any ideas?
- Is the 04 bose 6 cd changer compatible with the 07 ?
- Injector Cleaner
- Renesis Refresh w/Pictures
- Loud 'bang' noise.
- Front crank shaft seal replacement
- speakers not working correctly
- 3 gauge a pillar
- car sitting for over a year
- Flip Key Question
- heater issues
- clutch/transmission question
- Mom floods the rx8..
- New to RX8's
- Koyo radiator
- Air filter removal issues on rx8 2008
- Power Window Problem
- Anybody else ever have a problem with the tranny output seal?
- Why am I getting less MPG than a hummer? 9MPG on the highway... seriously??
- Dealership: "$800 to replace primary cooling fan motor and fan blade"
- wheel bearing
- DSC Question
- K&N air intake installation question
- abs lights on?
- New clutch/flywheel sugestions
- catch can
- new starter motor--mazda or mazdarotaryparts.com??
- Mid Pipe Flanges
- Look at my Gas Mileage
- Headlight help
- A/C Refrigerant line replacement???
- switch to 5w-30 oil
- Catalyic converter Problems
- Found a crack on wastegate
- Exotic speed header installation
- huge power loss... help!!!
- How much to have the throw out bearing replaced
- carbon fiber trouble
- Rx8 left sitting without Sparkplugs
- Can't find a fuel line
- Mid-Term Storage?
- Airbag Light on. Sensor, Front Impact F151-57-K1X
- How to paint interior pieces
- Vacume Hose removal/Airpump
- Removing car for Preservation
- 2009 Muffler for 08 earlier models?
- Cat/Engine warranty questions!
- Locked out of my car...Any explanations?
- New Catalytic Converter
- cat delete???
- Emergency car died while driving
- Help Identify This Part...
- Welded Diff options?
- Remedy for a Stripped MAF Screw Thread
- UK-spec Cat
- 2003 help
- "new" rx8, previous owner used full synthetic
- newb with cat converter problems
- I'm new to rotary engines and I'm looking to purchase and RX9 soon. Help please.
- Sold my RX-8. Anyone want my RX-8 GT ZoomZoom license plate frame?
- generation part swapping
- Broken Coil Mounting Posts...what do to?
- 60000 mile srevice
- Battery Ground for P0336 Code
- Heater Hose and Exhaust
- Pulled Off broken Sun Visor and blew fuse
- issues, etc
- door handle
- new car long term maintenance question
- Should I buy this car?
- Driver side rear caliper - Ruined threads on piston's sleave. What to do?
- One more single oil coolered.
- Filter relocation kits, experience with mazda
- Tail light complication....
- Brake job gone wrong. Massive fail.
- need someone to ans a quick question
- New guy here, have some questions
- tokyo drift engine swap :)
- Which coils - wires goes where??
- Does the rx8 have a timeing bealt or chain ?
- How to do a compression test.
- Gathered some data from my New Dashhawk- How do these temps look?
- Anybody had problem with NGK wire set???
- engine very hot
- suspension
- Air Box Ventilation
- Congratulations, you got an 8.
- Going crazy; dealerships are lying..
- Exhaust gasket (header/midpipe)
- K&N Air Filter issue (pcitures)
- Move the battery?
- Exhaust install question
- 20b Engine Questions?
- Free engine replacement
- really REALLY need help finding this piece!
- Ignition coils catalytic convertor coolant level
- control arm bushings toast...nast clunky noise...
- Need some advice buyin RX8
- Throttle position sensor problem?
- DOT officially investigating faulty clutch pedal brackets on 04-06 RX8s
- Make your intake look bamf for cheap!
- heating up
- Clutch Issue?
- Rear axle ratio modification!
- low compression
- Ignition Fuse Blowing
- CEL light comes on
- about intake
- Aldehyde Cabin Air Filter (Cleanable?)
- question about the keys for my 06
- New to rotary...!
- Manufacturer of OE RX8 brakes?
- door won't unlock
vBulletin® v3.7.5, Copyright ©2000-2012, Jelsoft Enterprises Ltd.
