PDA
View Full Version : Series I Tech Garage
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 [38] 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53
  1. Torque-steer and AWD
  2. small synchro tranny problem
  3. Mixing sinthethic and regular oil...
  4. Switched to Redline
  5. Need Help---please
  6. Install Passenger Airbag Kill Switch?
  7. Synthetic Oil Life Study
  8. Headlight Problem
  9. Weird DTC Code
  10. NEW Miles per tank RECORD!!
  11. Theory about oil in the air box and filter
  12. What i need: 4AT to 6AT
  13. Vacuum leak
  14. "Womp, womp, womp" noise...
  15. Loud humming noise at high rpms??
  16. Can-scan
  17. 2004 getting new engine
  18. Brake pad size for MT 2005
  19. RPM rises in gear
  20. Why 6MT 250HP and 4AT 210HP
  21. alignment specs
  22. Fuel efficiency drop
  23. Premix & Tail Pipe Soot
  24. Vented hood - How to prevent engine&intake being soaking wet?
  25. C.A.R.B Restrictions
  26. Clutch warranty - how long
  27. After market radiator caps
  28. Brake squeal problem fixed with new tsb.
  29. Tach Sweep on Starting - Flash indication?
  30. if your car vibrates and its not the mounting?
  31. Laptop or Pocket PC
  32. UK V US Spec Cars Oil Change Interval
  33. Navigation DVD-ROM
  34. DSC switch
  35. Are check engine lights stored even if you clear them?
  36. Air Conditioning AC Worries
  37. Exhaust question
  38. engine flood ??
  39. AT synthetic fluid recomendations
  40. questions after installed intake
  41. Rusty Welds On Sub-frame?
  42. Redline
  43. Air Box Split?
  44. ?? reset ecu after install intake ??
  45. Inner tie rod failure
  46. Looking for some part numbers....
  47. Grit On Tip of Dip Stick (Seeking advice)
  48. Idle Roughness Fixed With 5W-30?
  49. ? about Water Wetter
  50. F/S MicroTech Interceptor
  51. Do all RX-8 get oil in their Air Box?
  52. 12V other than lighter + ash tray light
  53. spark plugs and new fuel injectors?
  54. HELP! short shifter dilemna!!!!!!
  55. Question, and yes I've searched.
  56. Quick Filter Cleaning Question
  57. Noob Question on Bumper Removal
  58. interceptor-x question!!
  59. help with code 3305-g campaign
  60. Fuel System
  61. What are my choices for obdII/can scan tool ?
  62. Another scan tool option Auterra
  63. Coolant level light on & off. Bubble in water tank when rev.
  64. help broken stud from replacing flat tire -what is the part called that I need ?
  65. anybody know what part this is??
  66. Keyless Entry Programing
  67. What is behind solid front grill?
  68. RX-8 downloadable manual
  69. Flooded Engine
  70. Metal rotary oil cap too hot for gasket?
  71. Is there a DIY subwoofer thread?
  72. M/T Ecu connector pinout
  73. Do Blackberrys and Macs work with a CZ??
  74. Help with the simplest thing
  75. which rx8 to modify ?
  76. Got MYSCAN RX8 database?
  77. Questions about the New Flash.
  78. Help ~ DCS\TCS light won't go away
  79. Oil Temp
  80. More "Marbles in a Can" Observations
  81. Spark Plug Question
  82. MS clutch kit upgrade Q
  83. starting issues
  84. stock engine... how much boost?
  85. CAI discounts
  86. What happens to the airbag system with seat removal?
  87. HELP!! alternator stuck...
  88. help! MS CAI install
  89. Reliability of the RX-8 rotary?
  90. Front o2 sensor broke. what are the effects?
  91. Gas spilling at fill up
  92. Request: Tail Light Lens Cover Replacement HELP
  93. strange idle issue - any ideas?
  94. *Mazda Module Programming* software screenshoots.
  95. Octane booster? Yes or No?
  96. Anyone know anything about keyless window control?
  97. Keyless Entry Programing
  98. Disengaging The RX-8
  99. What is this vacuum line connected too?
  100. engine help
  101. Factory engine oil
  102. Equivalent fuel consumption of Renesis?
  103. HELP!! Post-Jiffy Lube problems...!!!
  104. Auto Transmission like a cement mixer!
  105. clutch threshold question
  106. Oil and Engine
  107. How long should the OEM shocks last on this car?
  108. Where is the DSC button located?
  109. exhaust question
  110. Tranny and Diff. Fluids
  111. SR polley install "help"........
  112. override security ???
  113. where do you fill up? and what octane do you use?
  114. deciding if i should get 1
  115. dented fender - will paint match?
  116. Misfire CEL
  117. Unknown features and questions
  118. Weird cooling fan issue...
  119. When was your last Gear/Rear Diff. Oil service ?
  120. I need some clutch / trans guys to help me out (hand controls)
  121. Need Feedback
  122. Shit..... need some help on my A/C
  123. Problems with transmissions?
  124. changes over the years
  125. what the hell did I break.. what does it do?
  126. wheel bearing/brake dragging vibration?
  127. rebuilds
  128. In the shop again
  129. MS CAI Water in Intake - CEL!
  130. New Cat, Same Problems. HELP!
  131. Tach wiring in Cosmo powered RX8
  132. Intake manifold?
  133. Imported RX to Canada
  134. Check engine light?
  135. Maintenance done besides what manual states
  136. heat shield Advice.
  137. whats the best kind of intake for the 8?
  138. Were to connect to Comfort-CAN Bus?
  139. loose bulb in tail light
  140. Problem getting into 3rd
  141. Transmission Diagnosis, Any Guesses??
  142. Help Please, Check Engine Light Problem
  143. 91 oct required for 2006?
  144. flash news flash
  145. Help! Settle this debate....
  146. rain effect on my AEM?
  147. Speedometer Calibration
  148. Keep the RX8 or something else??
  149. Rear end shudder
  150. some questions about warranty.
  151. Problems with Harrison R&D CanScan USB software.
  152. The hunt for the drain hose
  153. I add engine oil when...
  154. Drive-up Ramp for Oil Change
  155. Control Arm Broke!!!!!!
  156. HELP!!Effect on Engine due to Gas Kit explosion
  157. Anyone heard of the Turbonator
  158. Possible 350z convert to RX-8
  159. Oil Cooler Question
  160. Shel Helix Ultra 5W40 mixed with Dexelia?
  161. Anyone try the K&N Oil Filter?
  162. Dent Repair Kit Opinion
  163. this question is for automatic transmision?
  164. drag a racoon underneath car check engine light on after?
  165. 15,000 miles service necessary?
  166. Requesting Radiator Installation instructions
  167. Crank Pulley
  168. Apex Seal
  169. Remote window & sunroof close
  170. Driving around without the undertray
  171. Whats this?
  172. Auto headlights...
  173. replacement for "advance" key for 2006 rx8
  174. Spark Plug Question. I searhced. It's about RX-7 plugs.
  175. 3 MPG extra from different TYPE of gas?
  176. 2nd Gear Problems
  177. Power problems
  178. RX-8 book
  179. MIS-SHIFT am i ok?
  180. late oil change...
  181. Where can I get a new O2 sensor???
  182. squeeky sounds at idle
  183. Free Maintenance Schedule 2
  184. Is This Right
  185. need advice on brake pads
  186. Clicking noise
  187. Engine Under Tray + 140 MPH = ....
  188. Battery Dead For not Starting vehicle 8 days!!
  189. Help!-Battery
  190. Whining noise debate (please read, responses welcome)
  191. i think i killed my rx8..
  192. Parking and side marker lights
  193. washer fluid sensor?
  194. 3rd to 4th grinding...Mazda said everything is fine.
  195. engine conversion...
  196. Transmissions
  197. Help: Installed Pulley - Now Getting CEL
  198. Oil Additive for extra lubricant?
  199. Changing interior dash lights
  200. Engine dying on freeway
  201. Valentine one concealed display
  202. Replacement for incompetent gas cap?
  203. Need help sourcing a plug
  204. SEMA Project RX8 Drift - suggestions, comments, etc.
  205. special tool for removing front rotors?
  206. Auto transmission fuel???
  207. NEW way to remove your stuck oil filter
  208. parking light rust?
  209. Possibe cause of low mileage - dying battery?
  210. Punched it in first engaged clutch and BANG!!!
  211. How to remove door wiring harness clip?
  212. My 8 keeps getting broken into
  213. Metering Oil Pump and also Oil Pump??? P1688
  214. :shocking: Engine light
  215. Flooded smoke?
  216. Local Dealer: "We replace about one A/C condenser a week."
  217. Ever Have the Tach Needle Suddenly Die While Driving?
  218. Interesting Idle Vacuum Correlations
  219. Gear change
  220. What does LTFT 7% mean?
  221. Removing Carbon Deposits
  222. Air/Fuel Ratio Gauge
  223. trailer hitch points....
  224. how to understand scanalyzer data HELP
  225. Microtech Software and Serial to USB Adapter Issue
  226. What size are the stock injectors?
  227. Will this work
  228. Automated gearbox like Ferrari F1
  229. gear handle shakes
  230. How long to run Dino oil before switching to synthetic
  231. Water in Tail light
  232. Dyno plots: really that bad?
  233. Proplem after Oil change (( 8 is geting nasty on me ))
  234. how do u know which flash do u have on ur 8?
  235. IDLE issues..????
  236. Anyone with access to the SAE international tech papers Database?
  237. clutch Replacement Question?
  238. painted calibers, should i clear coat too?
  239. Can the ECU be replaced?
  240. Where is the EPS Motor Relay? Help Pls.
  241. gas mileage vs. oil level...
  242. Painted Engine Cover or Side Outlets
  243. Another coolant question
  244. confused about oil?
  245. catch can on intake?
  246. motr oil
  247. small accessories needed
  248. Catalytic Converter Shield?
  249. stealth bulbs
  250. Fuel Starvation Problems
