View Full Version : The Tech Garage
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 [37] 38 39 40 41 42 43 44 45 46
  1. Oily Mess in Intake accordion
  2. Octane: what it actually means and does
  3. Need help my 2004 rx8 is making a knocking noise
  4. E-brake "cover" broken
  5. Alternator
  6. So madd. Should I sell my car now?
  7. 1000hp/tq for $1500?
  8. Rotor Housing Hardening
  9. Electrical ?
  10. electronic throttle control
  11. Engine Trouble - Need Advice
  12. Best Aftermarket Battery
  13. Spark with no ECU
  14. Rust on Endplates
  15. Need Help wiring O2 Sensor
  16. If i buy a used Power Steering Control module do i have to program it??
  17. Borescope
  18. Complete newbie asking a quick oil question
  19. clutch master cylinder bore?
  20. Why so much trouble with this car???
  21. Clutch Pedal Pushrod
  22. tired of these iridium and old style sparkplugs!
  23. Why so little trouble with this car???
  24. Question about 5w20 vs 5w30
  25. Cad Models or Drawings of Rotary Engine
  26. Very Rough Idle!!!!
  27. Tail light removal?
  28. DIY: Oil Catch Can/Hose question
  29. ipod to stereo issue
  30. The dreaded CEL: a P0410
  31. RX-8 Carbon Issues
  32. Transmission Replacement Where?
  33. Immobilizer Issue
  34. Flow Master 44
  35. seafoam
  36. Spark Plug Ignition Wires
  37. Is lucus upper cylinder luburcant/ injector cleaner safe?
  38. ABS and Traction Light Help!
  39. radiator filter
  40. Air bag connectors underneath the seats
  41. how to removal tag light bulb
  42. Keyless remote
  43. Anyone running without an OMP?
  44. studering problem wile driving
  45. Bad Thermostat Replacement
  46. midpipe question
  47. New Engine "Picture"
  48. Oil Weight Usage?
  49. Will S2000 Rims fit on a 04 RX8 ?
  50. Transmission disasembly
  51. Flow Master 44 with custom built bumper
  52. My car has a mind of its own -- has this ever happened to anyone before?
  53. Can you still get a recalled engine?
  54. Interpretation of compression test results
  55. Vaccum hose routing diagram needed
  56. 05 6 speed vs. 06 6 speed AT
  57. trouble shooting coils?
  58. No LOW Washer fluid light? WHY?
  59. Need Help Momo Wheel
  60. Ack - where does the little hose from air intake go?
  61. How much for a new engine?
  62. Racing beat intake length
  63. Premixing Supertech TC-W3 from Walmart??
  64. Possible DRL issue?
  65. Interior parts for 04 - 05
  66. how can you tell when sparkplugs are bad?
  67. Glovebox Striker
  68. Royal Purple Oil Check & Clarification
  69. Does anyone have the full Mazda Sevice Dept deflooding procedure?
  70. New Radiator, tell me what you think
  71. A bird living in my clutch
  72. RX7 rotor in RX8 housing
  73. A/T motor to M/T Chassis
  74. noise
  75. Problems with new engine.
  76. Engine flooded now (exhaust sound changed, sluggish engine)
  77. my 8 needs a repair, but what???
  78. maf sensor cleaners question
  79. Msp16 killed my engine!!?? :(
  80. Transmission Rebuild (Syncro issue)
  81. carbon fiber parts
  82. Brake rotor opinion. (Should they be turned)
  83. New engine block??
  84. engine hesitation
  85. Oil help - but not quite the normal question
  86. where is the fuel filter??
  87. CAI vs. Short Ram???
  88. Custom Shift Knob
  89. Loose Plug Wire
  90. Upper radiator hose ID? (Water temp adapter)
  91. strength of rear end
  92. Possible LOSS of power after Seafoam?
  93. FL22 Coolant Replacement
  94. drivers door wont open
  95. Gauges question.
  96. Service interval on an '09?
  97. Starter Motors, which year???
  98. P0300 question/advice
  99. i'm no rocket scientis
  100. NGK Plugs/Coils
  101. New owner of a RX8 with a dead engine....
  102. Simple question
  103. best spark plugs to buy for the rx8
  104. New Engine??
  105. how do i put on hks grounding wire
  106. Slipping clutch causing engine misfire
  107. DRL Module Removal?
  108. Mazda RX8 FSM - Technical Manual
  109. Stabilizer Links
  110. Clutch fork and plate ... no spoon
  111. Experiment: O2 SIM
  112. deep gash?
  113. Heating/AC Problem (I've searched)
  114. Spark plugs problem Help
  115. Can someone plz tell me
  116. LUg nut bolts
  117. prosport gauges
  118. how to remove left door with out opening the door
  119. Stock air box back in, +20% LTFT
  120. so this was weird
  121. Not just the average LS2 coil question
  122. shop broke the "key"?? when istalling my clutch
  123. 3M Do-It-Yourself Fuel System Tune-Up Kit, 8963
  124. What is the difference between these 2 yellow injectors?
  125. Mitty Vac Questions
  126. Fuel Sending Unit
  127. Undertray necessity
  128. programming procedure?????
  129. parking light help
  130. Air bag module removal-help
  131. New Clutch Flush Method?
  132. Which is best CAT delete for the price? Im a bit confused on the differences
  133. alright i need some help
  134. What premix is cat safe?
  135. Car value
  136. cooling fan electrical question
  137. Help! A/C Doesn't Work after Warranty Engine Replacement
  138. Throttle Body question
  139. MMO-Caution as a premix
  140. 2005 HID headlight assembly
  141. Tryingto look for parts!
  142. 2007 starter on 2004
  143. Does a Non Navi car have Navi wiring?
  144. Requesting DIY for Rear Aero Flares.
  145. Revolution Under Sweep Panel?
  146. rx8 doing dirt devil sound
  147. DIY ? i guess...
  148. Miss Fire (Automatic 2004 Rx8)
  149. Best RPM for high MPG
  150. 350z Carbon Fiber Inlet (In the 8?)
  151. Update Axxess Adapter With Win7
  152. Headlight Restoration for $10
  153. An Idea
  154. HELLP!! pLEASEE !
  155. Ms short shifter! Yea jdm y0!
  156. Smoked out the neighbors today...
  157. difference in halogen and xenon HL assembly???
  158. Can anyone tell me which lights are these???
  159. alarm question...
  160. 2004 RX-8 MT - 45k mi - engine failure
  161. Starting issue
  162. Is their a DIY for battery change??
  163. Bumpy Ride????
  164. Clutch and Brake Rotors
  165. royal purple manual transmission fluid
  166. Best way to drive a rx8??
  167. Battery help!!!!
  168. how do you remove the washer fluid reservoir?
  169. power loss when engine is hot what could it be?
  170. resonator question.....
  171. New Starter
  172. New Updated Starter for $175
  173. How to clean dirty headlights?
  174. Running real rough at idle
  175. What is this plug for?
  176. My old fuel pump doesn't look like the newer one!
  177. Rx8 Mechanics on Long Island???
  178. =====need help with my oil change=====
  179. wont go in gear
  180. exhaust help
  181. Air Pump Delete
  182. hooking up rx8 engine harness to rx7 manual transmission
  183. Screw Size for intake O2 sensor.
  184. starter
  185. Blitz Throttle Controller
  186. Thinking about getting a RX8. Need info.
  187. Engine differences anyone?
  188. Ramps vs. Jack + Stands?
  189. Rear pads and rotor resurfacing?
  190. Fog Light Bulb Preference
  191. cabin filter change??? whos done it
  192. Idle problem!!! Helpppp
  193. Help Interpreting Compression Numbers
  194. BHR Upgraded Fuel Pump
  195. Pictures inside an original 100k motor...
  196. 2009 mazdaspeed sport exhaust HELP
  197. Frozen Rear License Plate Bolts
  198. Radiator Light... and Water Spots...
  199. DSC light flashing & TCS always on!!!!
  200. Question on decarbing my engine...
  201. No shift Beep after Clutch replacement
  202. rx7 turbo setup on our 13b>?
  203. Insight into my compression results
  204. Changing Rear Pads.... Help please.
  205. Oil Metering Pump RX8 problem from Australia.. LHD/RHD difference?
  206. Okada Project Spark Coils
  207. Why ISN'T my check engine light coming on?
  208. rx8 sunroof motor
  209. Front Caliper Bracket Bolts...Torque Settings?
  210. A/C Amplifier
  211. Header / Midpipe Gasket Question
  212. new washer fluid reservoir, pump question
  213. any suggestions for a new kid on the block?
  214. Remote Unlock Interface
  215. Oil Cooler Mesh Guards
  216. Dent in the back door....
  217. Small motor/pump noise from under car after shutoff
  218. Help needed - Engine Over-rev buzzer
  219. insulated oil pan
  220. second gear grind
  221. fuel tank 3 valve
  222. Metalic Noise + Air Conditioning Problems
  223. Disassembly of Rear Light Cluster
  224. Plug Replacement - dealer pricing?
  225. is the mazda dealer trying to rip me off!!!
  226. New to the Mazda - Question Tuning
  227. At 46,000 how to check if brakes need replaced
  228. Street Port Blueprints
  229. Synchronic + Truboost Connections
  230. compression test on a cold engine
  231. Rear Muffler Delete
  232. 192 ? 231 ?
  233. no sound from radio/cd/sat nav
  234. rich/lean question
  235. Any advice for a newbie?
  236. air bag module location??????
  237. 1jz-gte
  238. Seafoam - Dumb Question
  239. No POWER at High Speed then Stalls when I stop at light
  240. Help with Exedy Stage 1 Sport Clutch Spec
  241. Who is screwing me? Emission harness mayhem
  242. I need advise
  243. What exactly qualifies as a hard start
  244. went a smidge over in oil?
  245. Midpipe Swap
  246. No! I have the best exhaust!
  247. 02 sensor question...
  248. Swapping in an RX7 Rack and pinion
  249. Installing Diodes
  250. Something's burning...
