View Full Version : The Tech Garage
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 [36] 37 38 39 40 41 42 43 44 45 46
  1. Olddragger's Old engine Autopsy
  2. Anyone Use Royal Purple motor oil on their 8 ??
  3. vibration and jumping rpms
  4. Battery/Start Upgrade, any recommendations?
  5. Where is the rear O2 sensor and how do I change it?
  6. Recognizing TPMS procedure
  7. Transmission and Differential Oil changes..When do you guys perform them ??
  8. Has anyone had dealer replace sunroof guide pins?
  9. Check engine codes, Loss of power
  10. updated spring install?
  11. Ignition Issues and asking for advice.
  12. Intermittent Power Loss and Rattle at 5800 rpm
  13. Esmeril vs Greddy Turbo Kit
  14. finally installed oil temp gauge. how hot is too hot?
  15. Mazda Servicing: What is an immediate concern?
  16. Manually move heat/ac actuator?
  17. Does the engine run cooler with Royal Purple?
  18. LOW MPG SUCKS! and speaker problems.. any help?
  19. ignition coil prices are going up, spark plug prices going down?
  20. Suspension overhaul
  21. My Side Marker Lights are Flickering
  22. Installed F1 Racing clutch & not sure if its OK
  23. Carbon Buildup on tailpipe
  24. BHR contact information????
  25. First time Cobb user
  26. dyno test
  27. Compression Test Results - How much life left on my Renesis?
  28. Can one of you geniuses tell me how to....
  29. Help!
  30. Rear sway bar
  31. software for a tech 2 handheld scan tool???
  32. someone explain these stupid headlights to me
  33. Front jack point...clarification
  34. ECU error Code help needed
  35. 05 RX-8 heater blows cold
  36. Cel code p0456?????
  37. Agency power exhaust dyno sheet.
  38. fuel tank Pressure compensating valve
  39. What are these plugs?
  40. My coils failed finally after 6 years!
  41. Coolant Question...
  42. AT Fuel Injectors
  43. Max Weight Capacity
  44. Engine Being Replaced @ 71K - Replace Water Pump Too?
  45. Cruise Control doesnt work
  46. Second gear always grinds???
  47. 6speed tranny "bell housing"
  48. Prepare for Winter
  49. Please don't tell me I bricked my pcm!!!!!!
  50. CEL P2070 and seafoam
  51. Manual trans to automatic trans swap
  52. Which exhaust?
  53. 04 AT Engine and Ignition
  54. Two issues: cold stuttering and possible worn clutch?
  55. Cost To Change Spark Plugs, Coils, etc???
  56. Battery/Alt
  57. Help! Need some part numbers
  58. ram air + turbo
  59. sporadic oil light
  60. shaking issues
  61. New Batterie car keeps flooding with Cobb AP flash
  62. Ignition Coil Choices - Airtex
  63. Carbon Buildup
  64. Anyone with this set up?
  65. how do i know when it's time to change my brake pad??
  66. some more on the oil froth
  67. Shop says "no spark" at ignition
  68. Warm engine start problems.
  69. Shifting problem
  70. Check engine Light came on... help please.
  71. Question about keys!
  72. Bad Vibrations...
  73. white smoke + rough start + coolant smell = cracked rotor housing?
  74. My "2004" RX 8, AT 4 speed problem. Need help!!! :banghead:
  75. Engine hose sleeving kit
  76. clutch bracket broken at 72,000 miles
  77. New engine advice needed...
  78. Engine Compression Check FINALLY!
  79. rotor swapping
  80. How to adjust windshield washer nozzles?
  81. headers???
  82. Engine Rebuilders
  83. Build Thread :)
  84. ram intake / cold air intake...?
  85. Ok im really tired of my 8 being a gas guzzler
  86. autoluminations.com any good??
  87. Original 2004 Service Manuals Update
  88. new owner, 2004 GT, 81,000 miles and engine replacement within 3 weeks
  89. so here are my mods so far!!!
  90. Engine swap! urgent!!!
  91. Looking for COMPLETE parts list
  92. Is the switch worth it 04- 09? E85?
  93. Fluids and oxygen exposure
  94. best shop lakeland Florida
  95. Possible Engine Fail?
  96. OEM Ignition Wires
  97. Lost power in higher rev's? :(
  98. RX-8 Swap
  99. Possible oil leak or pretty normal?
  100. RB Oil Temp/Pressure adapter installed
  101. Need keys cut and don't want to use the dealer...
  102. clutch pedal frame
  103. A/C help needed
  104. White residue at bottom of dipstick
  105. Statrer issue?
  106. Dropped a socket... where'd it go?
  107. stereo interface protocal?
  108. 5w-20 or 5w-30? I've heard thing about both..
  109. remote engine start oem
  110. anyone seeing 200F oil temps now?
  111. running midpipe with no CEL
  112. Pics of ap links installed? Might have installed Wrong
  113. Is Keyless Entry Standard On An 2004 RX8?
  114. 9000k rev-limit?????
  115. tpms???
  116. Water in tail lights...the final word
  117. Worth paying for a compression test?
  118. HELP!!! factory alarm can't deactivate
  119. winter worries
  120. Mazda Dexelia Ultra 5w30 Vs. Castrol GTX 15w40 High Milage
  121. Where is my starter please help!!!
  122. Blown engine question
  123. Ssv solenoid valve
  124. Steering problem
  125. Clarification of injector size... now.
  126. Are you happy with your RX-8 as a winter (snow) car?
  127. Bonnet insulator
  128. plx devices
  129. Passenger side mirror loose?
  130. Another transmission noise?
  131. AFR and Knock Sensor Accuracy
  132. nav. system
  133. Fuel injectors
  134. what the...
  135. rx8 turbo legal in TX?
  136. Laythor get's gauges part Deux
  137. Sensor Info?
  138. changing the honk sound when i lock the car
  139. Ignition coil revisions and changes?
  140. Racing Beat template
  141. do we need seasonal cooling system?
  142. Water/Meth Injection for NA?
  143. Pls help me to understand something about exhausts
  144. rx8 check engine
  145. New Plugs - old problem? Hot start
  146. What weight oil?
  147. Air Intake Noise
  148. LED side repeaters
  149. 350Z gauge
  150. spark plugs
  151. average cost of changing the clutch
  152. Can anyone help?????
  153. Rear end is slipping??????????????
  154. HELP! ive searched and cant find!
  155. Big problem guys.. need your help (Ignition coil bolt)
  156. Flooding under warranty?
  157. Metra Kit-LCD screen integration problem
  158. 5 x 120 bolt pattern on rx8??
  159. Help!
  160. Greddy RE 9 Pro Rotary Spark Plugs
  161. Engine Rebuild kit: Where to buy?
  162. ATF revives rotary engine
  163. Heated seat switch wiring
  164. Help me choose a GPS!
  165. lets discuss air filters
  166. Oil Change?
  167. Steps Needed Before Premix on rx8???? Also advice on Premix
  168. Odyssey PC-925 Battery Experiences
  169. Whats so good about Carbon Fiber Clutch?
  170. RX-8 OEM hood material
  171. 2009 GT radiator & oil cooler guards
  172. Rx8 using a lot of gas
  173. My compression test.
  174. Filling transmission fluid through shifter?
  175. Spark plugs and gas mileage
  176. Crank 4 sec's 9 (2004)
  177. Odd Starting Issue
  178. Which spark plugs
  179. 90,000 Mile service!
  180. Fumoto Quick Oil Drain Valve install looks funky... HELP.
  181. HID Foglight DIY help please
  182. RX8 turbo reliability
  183. Best exhaust
  184. smart key help
  185. HID Bulb replacement Questions
  186. help me pls
  187. All 04-08 MT RX8 Owners Please Read!!!!!!!
  188. Interior Electrical problems
  189. 5W30 Oil
  190. AP midpipe
  191. Please help with my headers
  192. How often should the clutch be changed?
  193. Help Replacing Starter
  194. taillight vin differences for 2004 RX8?
  195. HELP!!! pISTON WONT GO IN.
  196. Main On-Body Weather Strip
  197. car wont accelrate at 7lb of boost
  198. Which rotor is more prone to failure? Front or Rear?
  199. Catalytic Converter stoping up
  200. Mazmarts oil pressure bypass install with some surprising findings!
  201. Oil Pressure and Start up
  202. Spark plug alert!!!
  203. Newbie...2005 Shinka damaged headlight
  204. Petrol questions ...again
  205. louder
  206. Automatic engine to manual trans
  207. Normal Oil Pressure
  208. need help flooded engine my rx8
  209. Redliining Question
  210. No DIY for an underdrive pulley kit?
  211. Problem with interior light and clicking noise
  212. Need a clutch
  213. Stock cooling system strength.....?
  214. Royal Purple trans fluid
  215. Atkins Rotary Oil Filter
  216. Rear Wheel Studs
  217. Two screws on tailight; 1 broke off
  218. Aftermarket Starters
  219. spark plug removal issue...
  220. Install Turbo
  221. Interesting Article about Royal Purple
  222. Rough idle, bad smell, hard start
  223. Compression test numbers and math
  224. axle bearing and hub assembly parts question
  225. Rx8 only just running
  226. My sneaky plan to extend engine life for Series I
  227. No brake lights ?!?
  228. Bad cat?
  229. T bolt clamps?
  230. clutch pedal
  231. im so DONE with the rx8s transmission
  232. Tranny Clunking
  233. New Engine Replacement for 2004
  234. Pressure vs. Flow - Let's do this!!!!
  235. newbie.. how do u take off the center top the dash
  236. why does RX8 have hard time hot starting with old starter??
  237. Run Diagnostics?
  238. Grrrrrrr im so pissed at my dealer!!!! ahhhh
  239. what does it mean
  240. Gen II Engine on Gen I chassis
  241. Sad Panda
  242. Solid Corner seals?
  243. problem with car stereo
  244. Has anyone done there own 30K service?
  245. North NJ/NYC Rotary Mechanic
  246. Injector nozzle wear?
  247. Starter Issues?
  248. Runing like new
  249. MAJOR electrical problem please help.
  250. about oil pressure guage
