View Full Version : The Tech Garage
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 [35] 36 37 38 39 40 41 42 43 44 45 46
  1. Renesis OIL PRESSURE Discussion with Dealer Tech
  2. Spoiler Installation
  3. water on the passenger-side floor
  4. "Hard Shift" Code ???
  5. '07 Front Brake Caliper on an '03
  6. broken clutch pedal?
  7. Running terrible...need help.
  8. Rear End Ratio & MPG
  9. Car stalling and shaking help...
  10. need HELP!
  11. Weird noise on full throttle?
  12. car acting strange @ idle
  13. WTF loss of power in 3rd gear. A lot.
  14. Engine dies sub 1k rpms
  15. Hey Help with my coolant!!
  16. Dealer Say New Plugs For The 8's
  17. heat works some of the time?
  18. RX-8 40th Anniversary NA tuning help
  19. newb vfad question
  20. keyless remote stopped working after battery replacement
  21. Question for those who've used Sea Foam or other cleaner
  22. Why is the tach so far off?
  23. Manual Transmission Front and Rear Seal
  24. Extremely loud rattles at 8000RPM around glove box and passenger floor pan area
  25. 350z or evo brembo brakes
  26. starting issues - please help!
  27. do anybody have this???
  28. What is included in a factory rebuild?
  29. New to the RX-8
  30. Engine flooding
  31. GI: Metal Underbody Tray
  32. squeeky suspension...
  33. very frustrated - HELP?!
  34. So the oil level meter isn't really accurate is it...
  35. Retard noob question (premix)
  36. I need help now!!!
  37. FD Trans in an rx8
  38. Odd electrical problem
  39. Replace actual heater core vs. entire HVAC AC/Heater unit
  40. worried 8 driver!
  41. Rx8 front brake pads and rotors
  42. Sticky gears WHY????
  43. Is it illegal to drive with no hood?
  44. Cooling Choices - Most Bang for Buck?
  45. Oil Question
  46. Engine Mount Collapse (How bad is it)
  47. Idling issue, can't idle while engine is cold
  48. Might be a stupid question
  49. OBD2 - P2102 Throttle actuator circuit low input ON 1 CCM
  50. Oil warming cycle - how long?
  51. Shifting at 8k really needed?
  52. How to remove rear seats?
  53. Dry nitro?
  54. My 3rd gear keeps crunching
  55. Caliper Rebuild?
  56. Another Winter Storage Thread
  57. removing horn in air box
  58. Used Oil Analysis - Post Them Here
  59. How do you remove the intake & tray?
  60. Engine mount question???
  61. Leak Testing?
  62. Steering Wheels
  63. Front 02 sensor gone - runs the same?
  64. Sorry but another diff. fluid thread
  65. I want to dump my water pump.
  66. Buddy Club Racing Spec Condenser
  67. Cyberdyne Gauges
  68. Wheel Well Screws?
  69. Putting away for winter
  70. R3 Suspension Specs Question
  71. Coolant/ running water sound
  72. 2004 MAZDA RX8 plugs
  73. Door panel removal
  74. Tech Help! (ignition coils)
  75. Headlamp Sensor Linkage Rod Broken
  76. Main fuse box clicking and car won't start
  77. oil change frequency?????
  78. Testing coils
  79. diy request
  80. Throttle Cooling Bypass
  81. HELP - Bad coil (flashing CEL) Then cat got red hot?
  82. Anyone use autopart store coils?
  83. Oil Change Interval for Synthetic & Experiences with AMSOIL Oil?
  84. How do you de-carbon an engine
  85. New Engine for me!
  86. rear splashguard install
  87. control system for turn on to instant turn off
  88. obd2 scanner tells me...
  89. spark plug wires
  90. Has anyone tried using the QTech electric exhaust cutout?
  91. I need a new engine, Mazda wants proof of oil changes
  92. Went back to stock now PROBLEMS!!
  93. Is there a DIY for Water Pump replacement?
  94. Car Stalled Out Today...
  95. Primary O2 Sensor?
  96. Anyway to make the stock tach more accurate?
  97. Squeaking noise when turning steering wheel
  98. Differential Additives?
  99. BG Quick Clean Transmission flush?
  100. Safety System for Flooding Issue on Low Engine Temp Shut-offs
  101. tpms disable thread broken
  102. Time for a new clutch... I think
  103. Ignition Coil Replacement Question
  104. Will Greddy oil pan solve the oil light TSB?
  105. 16X missing performance and fuel economy targets
  106. "Clicking noise"
  107. Oil Change Help
  108. Unusual tpms light
  109. Looking for some advice
  110. Steering "Bumps" When Turning Wheel
  111. Junk yard PCM
  112. 2009 rx8 radio removal
  113. Power cuts off around 6500 rpm (no cel)
  114. Engine feedback through speakers when charging iphone
  115. How tough is the RX8 6-Speed transmission?
  116. I needa diy rear o2 sensor pleaseeeee
  117. Leading or trailing plug difference
  118. CEL code 2109 and 2112
  119. Check Oil Light
  120. Wiring Harness questions
  121. Allignment quick check
  122. Symtoms of a dirty fuel filter?
  123. Electrical Fan Broke down
  124. Engine Light On
  125. anyone with the 09 oil pressure reading
  126. just wondering if anyone has advice before I take the car in.
  127. Front driverside ABS harness needs replacement
  128. So I replaced my clutch pedal...
  129. Squealing brakes
  130. Best Winter tires for Rx8
  131. Stock Rotor and Height question
  132. Keep getting CEL. I need help plz.
  133. multiple problems, please help!
  134. tore down another 12A
  135. 04 AT Rx-8 dosn't turn over
  136. Coil wiring color
  137. Taking the badges off??
  138. terrible idle
  139. Single Oil Cooler
  140. No dwell change needed for LS 1 coils?
  141. Which Battery To Get?
  142. car idles weird in 1st gear??
  143. I'm thinking fuel injector leakage or clogging
  144. will the 09 oil pan fit earier models?
  145. DSC/ABS Malfunctioning after jump start
  146. Looking for Engine Expertize
  147. To install Transverse Member, Raise Engine?
  148. oil pan instant gasket stuff
  149. Mazda dealer has no tool to fix grind into 4th gear...
  150. first time replacing clutch questions
  151. New odd noise
  152. Rotor Question (HELP Only 1 Hour to answer question)
  153. 2004 RX-8 MT - Dead after 145k Miles - Replace the Engine?
  154. Mazda NOT selling new short blocks????
  155. How are NGK Spark Plug Wires? Worth it?
  156. Ignition Coils Help (BHR Ignition Upgrade)
  157. Engine oil, warranties, and Mazda
  158. OMP Oil line.
  159. AC help, half warm half cold. Help.
  160. Discoloration Found Inside 2004 RX-8 Transmission
  161. Shops in or near Houston to preform swap?
  162. O2 sensor with Catless Midpipe
  163. Dealer Service Codes
  164. Rx8 lsd oil
  165. How to remove E-Shaft Bolt!
  166. Where is the trunk lamp in an RX-8?
  167. car wont start
  168. Best Oil??
  169. Coolant leak
  170. Recent Service
  171. Microsoft Zune integration
  172. A couple battery questions...
  173. Oil Temperature Gauge: Auber Instruments
  174. RX-8 ECU (PCM) Inbuilt Temp Sensor for After Cooling... S2 Only...
  175. Best way to jack up car for midpipe install?
  176. constant flooding after vfad removal
  177. Diff Oils Compared......
  178. when flooring it and reaching 6-7 rpms i hear rattling and my car buckles.. why?!
  179. Oil: Product Data Sheets
  180. Botched brake job
  181. Anyone use the updated Valvoline brake fluid?
  182. Oil gauge idea?
  183. Plug Reading
  184. Idle and Recall Questions
  185. Low Temp Thermostat?
  186. Brake Light Plug
  187. How do you bleed the clutch?
  188. Airbag Warning Light
  189. Leaky Lights
  190. 04 AT problem
  191. oil drain plug size?
  192. lowering 09 rx8 r3
  193. dropping the exhaust
  194. fuel pump problem (maybe) ??
  195. alternator belt
  196. How much do you spend monthly??
  197. Keep investing in mods? Or is the engine too old?
  198. DIY Request: A Fully Functional Oil Pressure Gauge
  199. Car smoking
  200. Car wont start
  201. lowering number plates
  202. coolant..
  203. zoom zoom engine cleaner, where to buy :-S
  204. Have you got your 2nd email from NHTSA for the clutch bracket issue?
  205. New Rx8! Need Help!!
  206. Is there a DIY for clutch bracket plz help
  207. Need help starting problems....
  208. Clutch problem
  209. check engine light codes??
  210. HIGH OIL CONSUMPTION DUE TO WRONG AIR INTAKE HOSE Series 1 ONLY
  211. Help - Check Engine light on - Scan tool reading error
  212. Need help! ABS module replacement
  213. After-market catalyic converter help
  214. Who can guess what Renesis engine part this is ......................................
  215. Do you rev before turning off?
  216. Midpipe/Cat/Premix Question
  217. lost of power whlie driving..
  218. Bumper Self-Repair issues/rust/confusion etc
  219. SSV Noise and shaft play?
  220. newbie's question
  221. transmission install question
  222. Loud Whurring Sound at Start Up
  223. Anybody have pictures of where the Starter is located?
  224. Is this Bad?
  225. RX-8 previously recalled for 4% less horsepower then calculated
  226. Seat Belt won't latch
  227. WTB - Yet another Headlamp leveling Sensor
  228. Engine stall help
  229. Coolant Light -- Intermittent On/Off?
  230. car won't start ?
  231. Cranks but will not start
  232. possible answer?
  233. What Upgrade Should I Buy?
  234. Rough Idle When Lights Are On
  235. Installing second oil cooler
  236. Belt for Aftermarket Pulley
  237. Good Battery replacement for the Stock one?
  238. 9.7mpg on last tank.
  239. P2102 Code
  240. AFT and powertrain warranty ???
  241. New plugs and coils or something else?
  242. Pulley Set
  243. Seafoam with a newbee!
  244. Cabin Noise__
  245. Ba Humbug. Poltergiest has control of my throttle
  246. Average Water Temp
  247. hot exhaust
  248. Motor Mount Installation Question
  249. How to turn rotors well car is off?
  250. Anything to look out for?
