View Full Version : The Tech Garage
- Maintenance Estimate
- Need help asap 13b is half alive
- Trunk release switch inside of glove box for what years/trims?
- Rotary engines and short drives question
- Girly Needs Help!
- Fuel Pump
- The 2004 Mazda RX8 Today
- plug washers
- Question about plug wires
- Did Mazda change to better coils?
- why do the apv's get so gunked up?
- New To RX8
- Stalling issues after intake and pulleys install
- Cleaned REVI Filter, Now CEL?
- Where can I get the Upgraded Starter?
- Stationary gear temp
- Oil cooler hose popped.
- Fuel level sensors
- Intake screen question
- Engine noise in speakers
- Car trouble :(
- Replacing the upper and lower radiator hose
- accidently added too much oil
- Side jacking points
- Spark plug wires/coils/plugs connection
- Rough idle question
- Grinding from 2nd to 5th gear.
- Oil Metering Pump gone...need help
- gauge lighting
- Reset Q's?
- This may even stump Swoope...
- turbo or supercharger?
- I want to change my Brake Fluid !!??
- speakers/stereo not working after the body shop
- Could you please help read my plug?
- Bwap Bwap Bwap (Technical Term...)
- weight reduction options
- Weird Beeping Noise on Startup
- Esmeril Racing Battery Kit
- What Is The Best Oil To Use For An 04 RX8?
- How to reset A/C?
- OBD Key Diagnostics- My Road Test
- What is that noise around the blower fan motor area at 8000RPM?
- what is the best engine oil for the RX 8?
- New battery seems to have fixed A/C problem!
- I need someone to tell me how??
- Problem with r3 seats
- CEL - Power Loss... Engine Stalled...
- Up in smoke!! :x
- Car Sluggish at Low RPM- Help please
- Odd CEL after AP pulley install
- Hot start issue
- Engine Push Start for Auto?
- Cleaning upper IM?
- Need New Key FOB!
- Boggin off the line
- Japanese Engine
- 2004 RX8 most RWHP !??
- Rx8 parts list?
- DIY request: Rebuild renesis engine.
- power steering problem PLEASE HELP!!
- Tightening torque for front lower ball-joint?
- OIL FILTER Change Interval
- Fuel filter
- How do you fool the seat track positions sensor?
- Extended Warranty - worth it?
- to cat or not to cat
- coolant top off
- Check engine light blinking before starting
- weird problem!!
- Resonance chamber
- A/C auto climate, noth works, help.
- upper air intake manifold diagram
- How do I convert spedometer to Kph???
- Best place to order motor mounts online? +random question
- Frequent Oil Changes Kills Your Cat?
- bottom of intake box.
- Loss Of Power Bogging sound
- Resetting the AC, what does it do?
- Spark plug Shims?????
- Mazda's parts microfitch online viewing?
- New owner, TELL me what oil to use (no debates + simple premixing question)
- Temp Gauge
- AFE SS SYNCRO question
- Sensor attached to front bumper beam, what is it?
- premix issue
- Good South FL ( or anywhere close )body shops ?? From Your experience.
- new RX-8 owner (well, used car though lol)
- [Advice Needed] 2nd Oil Cooler
- Engine code p0850
- General impact on performance
- 35 mpg rx8
- 02 Sensor Question.
- Fuse Box Cover
- new engine = new problems...
- Wrong Spark Plugs
- Mazdaspeed Gallery
- Car likes to stall out
- Question about storing premix in car
- Newbee with question.
- how to chance rear licence plate bulb
- rx 8 engine failure
- 2009 Engine swap
- clutch torque
- Can 4AT final drive fit to 6MT
- I'm at my wits end - please advise
- After market sound system
- Another oil thread?
- Will Mazda Replace Tail Light w/ Water In Them?
- We need a DIY upper intake manifold removal
- Too good to be true...?
- 9500 rpm?!
- short in a wire
- Had Trouble Starting After Driving...
- Unexplained radiator light? HELP!
- Starter Interlock Switch Faulty?
- Water in tail light normal: TSB 09-016/09
- Amsoil Synthetic Manual Synchromesh Tranny Fluid okay to use in the RX8's tranny?
- Cat on auto and manual
- Motor mounts / Rough Idle question
- Mazda Zoom cleaner or Gumout cleaner
- Another "Coil" question. Where to use A vs B coil
- Slight oil on rear lead and trailing plugs
- short shifter for 09
- I shifted from reldine in 3rd to 2nd. Is there any problems that could happen.
- 09 coolant temps and oil use?
- Need help ASAP
- need help
- Online site for RX-8 schematic & part no. ???
- Idle speed
- Just how fast will my 192 go !!
- help!!! how to fix gap between front bumper and hood.
- Help on fuel injector
- Clutch Problems
- Engine Condition?
- any DIY for Pulley set install?
- Plug wire came off & cost me $874.00
- Wiring for side corner lights
- Running too rich..
- SR Motorsports Pulley Kit (What belt sizing)
- car hesitates
- Weird jumping/shaking when turning
- Once again regarding the fan when engine is hot
- flashers stopped working/clicking noise
- tail light fix??
- Factory Serviice / Workshop Manual
- total mileage (engine life)
- Engine Toast, Warranty Company Denied Claim, Advise Needed
- Fule Pump Gasket (PART HELP PLEASE)
- problem??
- Just a thought on coils causing engine failure...
- Before I take it in to the dealer... (power loss/noise)
- Coil on Plug Available?
- 6th gear pops out
- Smell of gas
- Battery died, jump started and DSC and TCD refuses to turn off.
- Ecu/years
- help with oil cooler lines
- Mixed Oil
- vi performance monitor
- Clutch engage sensor fail/broken car won't start
- Passenger Headlight Assy Anyone?
- i recently gave my car a good ol tune up
- RX-7 plugs VS RX-8 plugs
- govenor
- New Light Making My Idle Rougher?
- installing rebuilt engine from atkins rotary
- Gradual Electrical System Failure
- 30.3 mpg!!!
- this HUGE list of 2004 rx8 factory defects... will they fix it all?
- Transmission Rebuild Literature
- Formula to convert Stock Wideband O2 reading to AFR???
- In need of a Compitent Engine Builder near Oklahoma
- Trouble Starting
- Tired of bugging ASH so asking Series II owners
- Clutch pedal bracket broke today
- any way to make burnt exhaust tip??
- Motor was replaced 10k ago
- Spark plugs and coils
- Low idle RPM during deceleration and at a stop
- Roll Cages: Street legal/Safe?
- Pre-mix
- New plug wires
- highest NA Renesis whp?
- custom Fogs
- Life of the engine after replacement
- where can i find a constant 12V in the RX8 interior
- Tpms
- How a clutch works
- reassembly after intake woes
- reversing up rhino ramps
- help - won't start
- what is this connector?
- Grounding kits
- Metra Kit - Issues - Lights + heater lights
- Power Steering Sensor
- is what the mazda service dealership told me bullshit?
- Power steering as and independant system?
- Cats Do Have 9 lives (or at least more than one)
- intermittent battery light
- Screen inside Air Box has fallen...
- Help! Ac blower motor clicking
- Break light indicator comes on ?
- Issue: Too much compression
- HELP: major loss of power when engine is completely warmed up
- Lost bulb.. help?
- RX8 issues :(
- Leaking lower radiator hose, boil over
- Almost Died
- Coolant smell after shutting off
- Coolant Sensor problem resolved?
- which intake is best for vented hoods?
- new engine or refurb??
- problem :(
- Clutch - what are the signs?
- clutch bad?
- remote does not work !?!?@#?!?#
- Fluid clutch reinforcement bracket
- Looking for 6-port intake pattern
- Engine Knowck Seonsor Low Voltage
- Clutch/Flywheel recommendation
- How to care for your rx8
- Nearing 100k, Current Issues at Hand
- water pump leaking and failing?
- Aftermarket air filter necessary?
- Any idea about installing Auto Climate Contorl on R3?
- New Engine Club, A Few Questions
- pulsstar
- Cloth seat fix? help please
- Cooling diagram
- Immobilizer problem...but not really
- Transmission Question!!!
- Quick Question.
- What Octane Gas?
- Anyone with a blown engine not gotten a new under warrenty
- MSD Blaster Ignition Coil
- pulling to one side??
- Where to get service manual for 2009 RX-8?
- stock timing degrees for renesis?
- 5W30 Oil Don't Cut it, Engine Bearing Pics 58K S1 RX-8 from England.
- The brand of brakes NOT TO USE!
- Changing spark-plugs
- A/C destroyed by ninja floor spikes
- Navigation Button issues
- Sohn OMP ideas
- Does resetting the OBDII system reset to fuel trim?
- Engine compatibilty 2009 vs 2004 ?
- Greddy Oil Filter & oil
- Instructions
vBulletin® v3.7.5, Copyright ©2000-2012, Jelsoft Enterprises Ltd.
