View Full Version : The Tech Garage
- Spark Plug boot wont 'pop'
- Govebox keep breaking
- Car won't start security light is on. What do I do
- New RX-8 COILS every-time you Replace your PLUGS?
- Clicking noise from Exhaust after shut off
- Headlight positioning sensor question
- throughout bearing or...
- Whistling noise when in D and R.
- R134a sucks ! How about Freeze-12 ?
- real quick help me with a vacuum check
- Coolant Overflow Hose Fries Cooling Fan
- Possible fix for low idle/ vibration at idle when hot
- Oil leak........Will they cover it?
- MPG& some Techni ques!?
- E85 conversion - Troubles ? Experiences ?
- Not your typical brake squeak
- Need a new motor?
- New Battery and POOF!
- RX8 Engine Oil Type
- quick brake socket help
- Added Oil for Compression Test
- help please
- High Pitched Whine with AEM CAI
- DSC Problem
- Valvoline's 300,000 mile guarantee.
- How Do I Align my head lights
- How do I remove or open the front headlamps?
- Iphone integration using Iphone headphones
- stupid rx8 alarm. . is somebody awake? help
- help slight engine hesitation under load
- Help! Bloomington, Illinois Flooded RX8
- Amsoil xlf 5w30 946 ml
- Need Help With Peeling Clear Coat
- Dyno Power performance Chip For Mazda Rx-8
- Which lightweight battery?
- torn frame rail
- Newbe Upgrades
- Moving to california, whats the latest on emissions?
- Too much differential fluid
- does the performance chip work?
- Help!!!! Lost Key problem
- Nylon Motor Mounts
- How Loud is The Muffler Delete?
- Radiator Light
- read my RX-8 Spark Plugs Please!!
- Shift sound at high rpm
- AC Pressures
- Clutch & flywheel
- Should I swap out the OEM coolant?
- Damn Rocks
- Radio display not working.
- Annoying rattle -- need your help to properly diagnose!
- wear on rotor housing sidewall
- E-shaft info, I need advice (size)
- Broken stud on the housing
- Rough Idle
- A couple questions!!??
- cel: coolant circuit low input
- How hard would it be to install an exhaust system for a noob to exhaust?
- Gasket between Cat Pipe and 'Middle Pipe'?
- Help !! don't wanna CEL with new Midpipe???
- K&N intake
- power issue?
- Pre-loading question???
- Steering Wheel Removal
- Weird blue crap on battery terminal!
- Oil LEAK - Please Help me
- Emco Transmission
- DIY Cluch Install
- HUD Lights
- DIY: engine replacement
- Sticky Goo?
- Battery terminal part corroded.. question!
- Custom yukon(d585) coil install.....
- Trying to bleed clutch, Gray fluid comes out !?
- MAF sensor DIY problem!!?
- Steering Wheel Replacement
- Who has the most miles using pure synthetic oil?
- how do I make an Oil return line gasket from OEM pan?
- Power loss with hot humid weather?
- Mazsport cooling fan issue?
- Torque specs on clutch and tranny
- Tachometer Pickup
- Ignition Problems
- Castrol Syntec Blend
- Transmission rebuild
- HELP! VFAD trouble
- Coil and wire change!?
- What kind of gear oil for our car
- Premixing Options
- What is this?
- Paint Rotors?
- Smoking after SR Mid Pipe Install
- Good anti-seize compound to get?
- TPMS sensor questions?
- Idle issue please help
- engine turns off
- Driver Door Will Not Open!!!!
- RX8 Rebuild
- HID ballasts issue
- Do 2009 tails fit older models?
- Parking light install
- Performance Chip Question
- water in engine bay
- mid pipe question
- Want to change front brake pads out for Hawks - best how-to?
- can it be done
- AC Maintenence questions
- Strange Whine Problem
- rx-7 exhaust on rx-8??????
- Oil Cooler Lines
- Push Button Start / Keypad Ignition / Proximity Sensor
- upper intake manifold removal?
- New guy vibration problem
- Check Engine Light
- starting to worry. engine bogging/sputtering between 4 and 6k
- hi guy my RX8 IS LEAKING
- My car is broken ;(
- Door panel removal.....
- powertrain warranty!?
- Cleaning the Engine...
- stock parts compatibility
- clutch bleeding
- Car wont start - Not flooded
- p2070 cel?
- Long crank time, not starting when warm
- Any way to test the Oil Metering Pump?
- New Aponte Racing P.R. Videos!!!
- Duplicolor caliper paint color question.
- Amp inputs?
- Car wont start
- How to make your stock air box sound like MS CAI
- Mileage *mpgs* blues
- oil catch can/cleanable filter questions
- Engine rebuilders/sellers
- Need Part numbers for some Mazda OEM parts.
- Does RX-8 heater core let you cool engine w/ heater?
- Question for MazdaSpeed Cold Air Intake owners
- DIY: Autoexe 6 Point Front and 4 Point Rear Strut Towers
- 9000 Rpm in 5th: CEL Flashes
- clutch/flywheel installation anyone?
- Help, ASB and DSC came on. Also what does this light mean?
- one question?
- Steering Issues?
- Electric motor noise under the hood.
- Opening a renesis with 5281 miles
- clutch bracket reinforecment
- What is the Best intake for an rx8?
- Mazda Zoom Zoom Engine Cleaning Help in TEXAS.
- I am unskilled; Help with OHM coil readings
- Rear view camera install
- can someone in the bay area come look at my car? it won't start. Redwood city.
- screws came out of engine bottom cover
- Transmission Bracing
- pulling out my hair already someone help...
- Blown engine, rebuildable?
- K&N air filter
- Press down clutch and get loud noise
- Starting an 8?
- Wiring diagram for 6 speed
- whistling from tube
- AT Tranny Fluid and Diff Oil info needed....I searched...I suck at it
- Handling issues
- Stuff fail in to the gap between parking brake....
- Is it possible?
- keyring break ignition?
- E-Brake light on at higher speeds
- Car keeps stalling
- Main Fuel Line and TPS
- Engine mount broken...
- Rusty rotors
- My 8 is leaking!
- My 8 still shaky... headache. help.
- high idle RPM problem ? help!!!!!
- Mazdatrix Wires
- 04 GT -- 05 sport brakes>?
- MT to 6 Speed?
- Mods????
- yellow or red top battery?
- Shinka Number?!?!
- How do I find the fuel line(s) in the engine compartment?
- specialty open ended butterfly socket tool
- Premix using Idemitsu and FP Plus - recommended?
- Upgrading Car Alarm
- Hydraulic clutch hose
- My RX-8 is caughing??
- rear license plate
- CEL but car running smoother...!?
- One month storage - should I disconnect the battery?
- Sound!!
- Mazsport (Fluid) Clutch Brkt Installation PDF
- royal purple tranny/rear fluids fail :(
- 8K Clutch Drop, no rev limiter and powershifting = 0-60 in 5.2 ???!
- Is this any good?
- diy to clean throttle body?
- Primary injector diy??????
- Changing Belts need help
- Where is the coolant level indicated?
- FACTORY FUEL PUMP OPERATION???? 13B-MSP into AE86
- Buzzing tranny/shifter
- When to check oil
- Pulling the Room and ABS/DSC Fuse?
- Having Parking lights come on with ignition...
- Startup Oddity
- No CAT on RX8, Need O2 SIM??
- exhaust rattle
- Anyone have a DIY for removing the driver's side mirror?
- TSB MSP16 caused car to stall
- Good technical discussion about Engine Oils
- Et50
- A/C Problems
- How to install racing beat rev i intake
- Problem removing bolts behind the cat: hangar in the way?
- Motor swap
- Torque on flywheel bolts.
- Compression test results normal?
- Bad Stock Cat Symptoms?
- Fuel Map Reset (pulling the room fuse)
- Top Mods for Reliability? Post Up!!
- RX8 engine removal how-to w/pics
- Complete engine teardown to bare shortblock how-to with pictures
- Dealership Tired of Seeing My Car - Offers New Engine
- any engine failures with Cobbs AP, and/or sohn adaptor?
- Press Brake 20 times reset.
- Aftermarket alarm
- Name Your Premix!!
- Pulling a Motor
- Question for those who have Mazdaspeed Sideskirrts
- Fuel Injector Cleaners (e.g. STP) - Safe to use?
- need urgent help.
- Request: rear door interior trim removal DIY
- Intake systems
- alignment question
- Clutch Issue
- Oil
- Engine Braking
- Rear Wheel Hub locknut size?
- 6 Disk radio
- Rx7store.com drilled and slotted rotors.
- emissions engineering evaluation
- Immobilizer question
- spark plugs
- Two AC Questions
- 15% off at Sparkplugs.com
- u prob all seen b4... my 1st time! The rx8 wont start! Only had it 3months.
- radio wiring diagram
- New RX clutch
- ~80k miles, new coils, new plugs, compression testing...
- oil metering pump motor
vBulletin® v3.7.5, Copyright ©2000-2012, Jelsoft Enterprises Ltd.
