View Full Version : The Tech Garage
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 [32] 33 34 35
  1. CEL - P0103 - Mass Air Flow (MAF) Circuit High Input
  2. Traction Control "Off" Module
  3. Oil Drain Plug Gasket
  4. whats the best exhaust system for a 2007 rx-8
  5. Little upgrades new owner
  6. Easter Tune-Up - Like a New Car
  7. Gear & Diff Oil
  8. A transmission question for any one who has or has thought of changing gear ratios.
  9. what exhaust system produces the most hp gain
  10. The Engine Oil Journey... from filler entrance to oil pan
  11. need help with wiring
  12. Car died, will not start
  13. Minor noise when idling
  14. 4th gear scratches when shift into it at high revs
  15. Spot the difference on this housing?
  16. Need help/tip with putting rear link back on
  17. broken tein damper bolt
  18. How long does it take to change four coils?
  19. annoying static sound coming from under my steering wheel
  20. requesting mazda comp test software...
  21. No spark or when trying to start.
  22. EJ257 (STI motor) in my rx8?
  23. Getting a new engine under warranty :) and the road to it...
  24. Honestly has anyone noticed a difference while driving on regular and premium?
  25. Abs dsc tcs - c1937
  26. Eibach Springs - Pro Kit
  27. Is 09 Oil Filter OK for 04-08?
  28. ABS and TCS Light
  29. Success Story - P0704 / no cruise control / started fine
  30. K&N V2 Cold Air Duct?
  31. Washer Fluid Removal
  32. Replace Clutch, Now Engine is Surging
  33. OMG this is crazy I'm getting about 9.5 miles per gallon help plz
  34. what to tell dealer to get newest ECU flash??
  35. Autometer Shift Light
  36. Newbie questions
  37. 04 starter under warrenty?
  38. Synthetic oil causing misfire?
  39. Driver door lock stopped working
  40. Help on A/C low side service port
  41. Sharp exit ramp=dash lights?
  42. New Engine Break-In
  43. Fog lights not working properly
  44. Stalling or Idle Problems - Quickie TB/IAC test
  45. Explosion under my a$$
  46. Wheel Hop?
  47. How to remove 3M automotive double-side tape?
  48. P0000 / Lack Of Power?
  49. Easy way to correct your comp. numbers for rpm
  50. How does out washer fluid sensor work?
  51. Steering Stiffness and Pull
  52. New differential gears install
  53. CEL P0037 After RP cat install
  54. Vengeance Power Engine - The "better wankel"
  55. electric cutout install and sound improvment
  56. OMP adapter install help
  57. my omp oil rez
  58. CEL help
  59. car tough start
  60. MT-90 Bad for Warranty?
  61. Need OEM clutch
  62. Oil Light @ 1000 after Oil Change
  63. Making sure im buying the right part
  64. Premix= AMSOIL Saber or Sabre Pro?
  65. Door Lock Actuator
  66. is my rx-8 safe to drive after rough idle and stalling?
  67. Why do the rear brakes squeak?
  68. Marbles in a Can/Sand in a Blender Issue Fixed
  69. air fuel gauge/ o2 sensor issue
  70. Truth About Redline WaterWetter(R)
  71. 05 Switchblade key
  72. Cycle Logic's Engine Ice Coolant
  73. Results: TR-01 Rotary Engine Compression Tester
  74. How much oil you need when perform transmission flush?
  75. Synchro's are going out
  76. Diy how to take out fog light lens??
  77. federal emissions warranty?
  78. Help - I took my caliper off to paint them.
  79. A/C not working and a myriad of CELs
  80. Fixed low power issue!
  81. Replacement Oil Filler Cap
  82. Airbag light problem
  83. custom exhaust help
  84. AC recharge
  85. Oil shelf life?
  86. HID equipped - what High Beam bulbs?
  87. Mazsport Motor mount for JDM rhd???
  88. Help with INT-X Idle
  89. Help with RP Transmission/Gear Oil
  90. Pictures: Spark Plugs @ 37.5K Miles
  91. How much should the 30,000 mile scheduled maintenance cost at the dealer?
  92. Front passenger fender removal
  93. Is the TB gasket reusable?
  94. how to remove blank buttons?
  95. OMP adapter install -- done
  96. car has power and is turning over strong...but wont start
  97. reflash does what?
  98. reflash or new computer??
  99. Greddy Infometer Touch - Installed
  100. Headlight haze
  101. people say they lose HP when...
  102. ALASKA! Can I still drive my RX8 in the snow and ice here?
  103. transmission noise in 2nd, 3rd & 6th
  104. A Bad excuse?
  105. HELP, car not starting?
  106. Throttle Actuator problem
  107. Just wanted to know if im upgrading correctly
  108. 2 questions - coilovers & RB flash
  109. diagnose me
  110. im freaking out man!
  111. any point in changing coils and plugs at 50k kms if...
  112. Trunk Keyhole Replacement
  113. Another 8 With Damned Shifting Issues
  114. My car sounds like tractor...
  115. ignition help.. appreciate it
  116. Oil Filter Relocation SII
  117. Florida heat. dash gauges vs aftermarket gauges
  118. Going On Vacation.. What should I Do?
  119. Quick question - electic plug near the oil filler.
  120. Anyone use Lucas Products?
  121. Replacing top part of dashboard 56k
  122. 2 questions.........
  123. Quick RB Oil Filter Plate Question
  124. Not starting (NOT flooded) and few random Q's
  125. how to get the broken maf screw out?
  126. 07 ECU/PCM pinout/wiring diagram Please
  127. Clutch bracket broke and was re-welded but still haveing problems.... Please help
  128. Non RX8 help needed
  129. How to align steering wheel?
  130. where to buy BHR coils?
  131. 40th Ann. Wheels
  132. putting seafoam in the oil
  133. Engine help plz
  134. Some issues with my 8...
  135. center iron
  136. Warranty Question(s)
  137. Front Rotor Screws
  138. Question for Coils.
  139. Loosing power at high rpms
  140. Questions about RX8 as Donor for Project
  141. Heavy weight shift knob?
  142. Mazda Part Numbers?
  143. My 8 is little bit shaky... ...
  144. Flooded Rotary (Need Quick, Easy "Do it yourself fix")
  145. help!! clutch pedal & syncro
  146. Wiper Blades Making Loud Noise
  147. 7,500 Service
  148. Unbolting the knock sensor
  149. WTF 160 miles on a full tank
  150. Is this correct? Please help.
  151. Radiator removal?
  152. ABS, Skid control, power steering lights
  153. EMS gauge
  154. Help!! Whats this?
  155. Spark plug question....
  156. Odd headlight problems
  157. HELP!!! car loses power when hot
  158. Pep boys sucks!!!!
  159. Reinstalling drivers seat
  160. Question on Innovate inductive RPM Clamp
  161. Can it be fixed?
  162. K-type thermocouple as IAT probe.
  163. Catastrophic Clutch Failure?
  164. Mitsubishi part in our RX8?
  165. Alternator life span ?
  166. rubber accordian tube for intake
  167. headlight wiring Q
  168. axle spline
  169. weird CEL light turns off...
  170. custom alt underdrive pulley test
  171. how do I do my own compression check
  172. breaking news: ACT pressure plate is 2lbs lighter than stock.
  173. ABS and DSC light came on
  174. Possible problem ( see picture )
  175. Help removing front passenger wing
  176. What the...?
  177. Weird Acceleration Sound.
  178. Electrical gremlin...
  179. DSC/traction control issue
  180. Buying WWP paint?
  181. Starter? Battery?
  182. Green Slimy Stuff in Brake Fluid Reservoir
  183. DIY fixing rattle sound in exhaust
  184. Getting hesitation/shaking when car warms up - Please Help!
  185. A/C issue
  186. JIC rx8 with pics
  187. car power loss resolved
  188. backbutton
  189. Right Tail light and Key hole question
  190. Car Stalling
  191. A new engine!
  192. Vibration Fix for SIX SPEED Auto Trans RX-8's 2006-2008
  193. Need help adding engine coolant.
  194. A/C stopped working
  195. Loss of Power / Pinging
  196. Scratched windshield (inside)
  197. help?! power loss possible.
  198. need advice on coils/plugs
  199. yes or no?
  200. Help! Removal of side areos!!
  201. Oil Change questions
  202. Best Cleaner/Polish for leather
  203. Using oil other than 5w20
  204. Help! 2 cel & car runs sluggish
  205. Please help: Hard to start & runs like crap
  206. Changing Fuel Pump
  207. Shift Knob Rattle
  208. Steering rack
  209. throwing codes :( p2096 and p0301
  210. Hard Start & Sluggish
  211. Radiator Fans Stay on?
  212. Help with Motor Mount removal
  213. Please Help with Engine Diagnosis
  214. Detailed wiring diagrams please :)
  215. MT vs. AT Motor Mounts
  216. Keyed Lug Nut Broke - Pics
  217. if i buy a Agency midpipe.....
  218. Broken end links difficult to diagnose...
  219. Power Question
  220. Questions about piezoelectric pressure senders
  221. TurboXS midpipe w/ HKS Hi-power
  222. OBD Baseline
  223. A little help plz.......
  224. few problems, Please give me some idea.
  225. Tires Causing Rear End Issues?
  226. coil change...again...but i think i screwed something up...
  227. dealer installed AT engine mounts on MT car!
  228. what is the correct battery?
  229. Heat Wrap
  230. Keeps stalling with bad idles
  231. Steering and DSC Mystery Problem.
  232. Transmittion Oil
  233. Transmisssion Oil
  234. Getting my engine replaced.
  235. Even after taking off harness wires, airbag light still on
  236. Stutter in the rear end
  237. Help: Replaced Coils...rich enough to dump gas out the tailpipe
  238. Spark Plug boot wont 'pop'
  239. Govebox keep breaking
  240. Car won't start security light is on. What do I do
  241. New RX-8 COILS every-time you Replace your PLUGS?
  242. Clicking noise from Exhaust after shut off
  243. Headlight positioning sensor question
  244. throughout bearing or...
  245. Whistling noise when in D and R.
  246. R134a sucks ! How about Freeze-12 ?
  247. real quick help me with a vacuum check
  248. Coolant Overflow Hose Fries Cooling Fan
  249. Possible fix for low idle/ vibration at idle when hot
  250. Oil leak........Will they cover it?
