View Full Version : The Tech Garage
- mazsport box?
- Oil cooler thermostat?
- N3H1-18-100A-9U vs N3H1-18-100B-9U
- Need help with a part # for engine bay insulation
- Brand-new 06 & 07 RX-8 at my dealer: What do I have to check?
- Fender Strakes???
- rear quarter panel removal
- Garage Lift Question
- Best place to buy plugs, wires, and ignition
- OEM HID Module / Ballast replacement
- What is this use for?
- Powertrain warranty ending
- Problems w/ ignition!
- May be a stupid noob question... Please help anyway
- tap cigarette power with racing beat gauges....
- DIY request. Sliding center console.
- Going to begin car-puter project, would love advice/suggestions
- connectors at rear of intake manifold
- RX~ Mazda Part Numbers and Diagram Pics HELP Information THREAD.
- flooded
- Burnt Clutch pricing
- Help!! Before tomorrow!
- Where and What brand are you getting for your new oil filter?
- bad rex!
- help!
- what kind of gas?
- Power adders
- Neutral position sensor, RPM fluctuation at idle
- flashing lights
- HELP!!! Car cranks but no start
- NEED Help! Having an ignition problem :(
- I did something kinda dumb...
- HID conversion kit.
- Driver side power window issues
- Engine Failure - help please
- CEL light on wont go away
- 30,000 Mile Home Maintenance bible?
- advice on plugs
- Can you remove the parking brake handle?
- stock exhaust questions
- car runs like s.h.i.t.
- So Just installed my Buddy Club Condensor
- Advice ref: Engine Warning Light ? O2 sensor
- O2 sensor replacement , any ideas anyone
- Not Starting....
- Squeaky Alternator Pulley
- My Oil is BLACK-------------Problem?
- RX8 Factory Service manual In PDF format.
- rough idle,backdoor,gear stick,seats vibrate.please help
- Engine Oil GF4
- Second failing air pump... (sound clip included)
- any idea where the transmission speed sensor is
- "On Position", CEL Blinking
- vroom vrrom beep kssssh
- Heater not working.
- Help me make my car better!
- New Shell Gas?
- Dropped nut into battery.
- Radiator caps/numbers/temps
- Revised Front Swaybar Enlinks
- i need tuning help
- Cel????
- is it safe to drift in a stock rx-8
- RX8 6 Port engine into Mazda R100
- for those of you with the metra kit
- Fully Biodegradeble Animal Fat based oil
- Warranty Type?
- relays
- Changed my plugs and my car sounds like a Z!
- Noob - Needs Advice.
- Royal Purple
- Is my clutch going out?
- Oem?
- Unknown Noise ...
- Help, my clutch is weird.
- Dealer Plug Prices-If ur wondering.
- Stock Keyless Entry Fob Doesn't work
- Grinding in my clutch
- For those of you with a carputer
- Won't start...
- Manual Tranny fluid question
- still rattles
- Teach me about Oil Leaks!
- Alternative Starters?
- Trailing Spark Plugs
- Deflooding using this windshiel washer method
- engine doesn't seem to be getting gas when cold..
- regarding engine flooding
- Duel-rasonated midpipe
- 2 gear problem
- russel SS brake lines? missing parts?!
- differents between high bhp rx8 and low power?
- 2004 RX-8 Driver/Passenger
- i need help. to much or too little fuel, or even a blown fuel pump.
- how the OEM nav housing works?
- Hot start problem and lose of power.
- Light Rattle Sound from Engine
- '08 Wheels on an '05
- I crashed my RX-8..Lawsuit suited?
- engine ticks
- Bg 44k
- diy hks intake
- removing outer door handles?
- Will not start I did search
- Axel Boot Replacement....on a civic
- Engine trouble
- YAINHT. Car not starting and don't trust the dealership here.
- An interesting "will not start"
- MAZDASPEED Exhaust vs. Borla Exhaust
- Which ECU to use?
- same engine mount on 4-port and 6-port engine?
- Very Light Clutch Pedal
- Engine #3 in my RX-8?
- Back from vacation...and had to get the 8 towed
- want a DIY for chnagine out old engine for new one
- Water Pump
- Opinions on alignment
- best route for a new engine
- How many missfires are normal in a drive cycle?
- yet another ticking thread...
- problem finding this part
- Do all new RX8s have their spark plugs replaced when you buy the car?
- Brand New Engine Original Parts
- car won't start, loud ckicking sound
- Traction Control Light
- how to pre-load springs
- Electrical problem.. HELP PLEASE!
- Flooded?
- Autometer Nexus Gauges
- Found a wire that is not hooked up to anything
- Engine Mounts
- Removing exhaust shrouds
- How can I tell that my omp adapter is working ?
- A rotary engine exam?
- rx8 AC problem
- Renesis Swap
- Very hard to start - Flooded or otherwise?
- 100 Octane Racing Fuel
- Turbo for RX8
- tranny swap?
- a/c mod?
- Need help buying a oem part
- Rattling exhaust @ idle.
- 89 or 93?
- most powerful 13b-msp
- Problems with '05
- Is IT a Halogen?
- Help finding Exhaust Gasket
- oil leak please help
- How long would it take a garage to...
- where to find good spark plugs?
- Idle at 200????
- Got my 8 back with reman engine
- Removing the Abs lock system
- Which fuel sending unit is acting up?
- my 8 still shake
- performance tranny!??!?
- She Ain't Starting
- Plug in tranny - just curious.
- How to remove engine air pump???
- Power Steering keeps going out
- RX8 tune up
- the best CAI for the money
- hot air out of vents
- TPMS socket size
- Roof replacemnet
- 15A Engine fuse Power supply?
- Help me solve the mystery of the rear spring install
- CAT + Pipe = Power
- My Baby on fire:
- new owner with questions
- Question about new clutch
- Temp Monitor on Radio Broken
- Noob has a quick question...Appreciate help
- Manual Transmission Question
- white-beige cream on oil gauge?
- open/closed loop
- $700 for 4 spark plugs + engine coils?
- Ya so ya
- Gunk on Dipstick
- ABS and parking brake lights coming on during driving
- p2004 : intake manifold runner control solenoid error
- Diff Fluid=75w90NS or regular 75w90
- Lack of Power? - Change your 'plugs
- Sequential Shifting System
- When do you Change gears to save gas?
- metallic buzzing/rattling at 7000 rpm....
- emergency key
- Confirmed : NYCGPS's Motor is dead~
- Stereo L.E.D lights messed
- Koyo Radiator-What is correct Part#?
- no power before 3500rpms
- Little problem with starting
- Check engine light, help!
- Another...How To FIX COMPRESSIONS In Any Rotary Engine with ATF
- Anyone have anythng that bonds to plastic of UIM?
- Anyone got the part number for this?
- Clutch: To replace, or not to replace...
- 2009 RX-8 Service Highlights (Manual)
- Lookin for some leads
- Dead battery, eaten insulation, won't jump start...
- ignition coil stud snapped
- Just bought a 05' RX8, question about transmission
- room fuse blowing short somewhere.... HELP!!
- Engine Vacuum Voltage Test
- Did I mess Up getting An AT RX-8
- Changing Oil and Breaks
- Coils?
- Clutch Set Suggestions??/
- Question about reflash and no idle
- Cobb AP vs OMP solution...
- My engine coil is melting any idea's???
- Stiffening the power steering?
- missing at high rpm
- HELP! What is this?
- My BHR Expirience
- Pics of my spark plugs at 40k.....
- ignition coil order
- another greddy oil pan question
- Rx8 front license plate
- At what rpm do you guys shift 1st to 2nd and 2nd to 3rd
- Whine sound at 2K RPM
- Caliper Bolt Problem
- radiator/coolant light at track
- SPEC Clutch and Flywheel??
- Unleaded Vs. Premium gas
- Spark Plugs bad -can it cause Crank Position Sensor CEL?? ODB scanner suggestions?
- Darn Manual
- Hooking up an oil catch
- coolant light
- New Owner/found oil in air filter housing
- loading springs durin install question
- Technical Discussion of the 13B-MSP
- PCM and ECM
- Oil change process
- Replacing clutch?
- Issues with AC Controls / not working
- 2009 Oil Cap
- Does anyones engine coolant light come on when they race thier engine
- tranny probs (reverse)
- ABS & TCS/DSC Indicator Lights on while driving
- How do you remove the battery tray?
- IDENTIFY THESE INJECTORS AND WiN...
- Using low impedance injectors.
- Cleaning Racing beat REVi
- My "new" RX-8 has a few problems.
- how does the radio come out
- Coolant Leaking issue.
- AEM and MS Intake owners
- New code after mid pipe installed. FIX?
vBulletin® v3.7.5, Copyright ©2000-2009, Jelsoft Enterprises Ltd.
