View Full Version : The Tech Garage
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 [30] 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46
  1. Milky dipstick.
  2. turbo timer...
  3. BG 44k
  4. Need Help
  5. Braking Issues/Concerns
  6. Rx-8 wont start
  7. Battery Question
  8. My BAD and Good dealer/warranty story
  9. Question for turbo owners
  10. New clutch - replace original or go w/ performance one ?
  11. Trying To Keep My Car In Good Shape
  12. 2006 rx8 engine oil
  13. Ports and CEL question
  14. Whining on deceleration...
  15. cap in headlight needs snapped
  16. Help!!!!!
  17. injectors at 6500rpm
  18. Anyone with the Greddy oil relocation have input?
  19. Fluid Change Intervals
  20. E-Brake, tighten?!?!?
  21. US Emissions warranty. 80k miles?
  22. DIY removing the front air dam(lip)
  23. Choosing positions for larger injections
  24. Front Tie Bar mounting
  25. Do I need to change oil right after Sea-Foaming?
  26. 30k Service, and a couple question on Oil! Help the noob please =D!
  27. 6 Port Swap into an auto.
  28. Sav-A-Thread helicoil kit for spark plugs
  29. car not starting
  30. clutch kit problems
  31. Fuses
  32. NC swap pieces
  33. 6 Port Auto Vs. 6 Port Manual
  34. How to USE OBD to check engine status
  35. HOW TO: clutch/trans job in under 2.5 hours
  36. HOW TO: engine removal from top/conventional method
  37. dsc error light?
  38. How to align the headlights?
  39. problem help!
  40. Differential gear ratio?
  41. Breaking in a new Clutch...
  42. check engine light on
  43. HELP! DSC and Traction Ctrl. Lights On! Again!
  44. Diesel Rated 15W-40
  45. E-Brake light won't turn off!
  46. CANSCAN USB Drivers
  47. RX8 Air Bag Warning Light Codes
  48. Sparks out the exhaust?
  49. How long do the OEM Spark Plug Wires Last?
  50. aftermarket exhaust
  51. anyone know the sizes of the blinker bulbs?
  52. Frankenpump and Premix
  53. making a true tach wire.
  54. anyone do an LS1 yet?
  55. Help! Accelerator Pedal Position Sensor (P2138)
  56. Oil level above full
  57. Flashing CEL
  58. Time to change the Diff and Tranny fluids
  59. dentist drill sound?
  60. RX8 rattling sound coming from underneath me
  61. Formula Shell engine oil.... anyone used it?
  62. oem clutch disc.. all you need for a clutch replacement?
  63. Dsc and Tcs wont turn off help
  64. Smell/Temp gauge
  65. HELP! Installed new ACT Flywheel, Clutch kit and counterweight ...
  66. is reving up and turning off engine good for rotors?
  67. Please help, rx8 dying
  68. spark plugs?
  69. Help again lol sorry. update
  70. Replacing radiator hoses for upper and lower
  71. squeaking coming from under car
  72. RedLine MT-90 Trans fluid - hard to go into gear
  73. Lightweight Flywheel Sugestions?
  74. Something is eating up my engine compartment paint
  75. New potential Issue. Need theories!
  76. Help Asap...car running horrible
  77. The eternel question: Fuel Economy
  78. Brown-ish "goo" on oil dipstick.
  79. "Fuel Injector Flush"
  80. wierd occurence: CEL but no codes present
  81. possible bad coils
  82. Just a quick Question?
  83. Wideband o2 Questions.
  84. My AFR readings are different? AP vs. AEM
  85. Tranny + mileage
  86. How do you beat the CEL?
  87. Locate Jet Air Fuel Mixing hose
  88. Coolant overflow tanks? and washer fluid etc..
  89. anyone ever install mishimoto carbon fiber short ram?
  90. What things are covered under the warranty.
  91. accessory switch
  92. qucik question about K&N intake
  93. valentine one wiring problems?
  94. To much coolant. Now what do I do?
  95. Car doesnt want to start help
  96. Bad Syncro Maybe?
  97. rear strut bar install
  98. A/C vent lights
  99. Hitting a "wall" in power as RPMs climb
  100. Its all about the Tools!
  101. Do exhaust sound change in time?
  102. when to do a tune up? i think mine needs one
  103. fuel pump
  104. hmmm... airbag/sterring wheel?
  105. problems with grinding gears
  106. O2 Sensor in CAT.
  107. Spark Plug Recommendation
  108. Oil Light Wiring Question
  109. How do you remove the back of the nav housing?
  110. best way to run a wire from the front bumper to driver
  111. Lean spike when stopping quickly
  112. seat wiring diagram
  113. Socal Dyno Day 2009 with Mazdamaniac Tuning - RESULTS
  114. EXHAUST help please
  115. Fog Lights & High Beams On At Same Time
  116. knn air filters
  117. Help - Short Check Engine light blink
  118. Ignition coils? anyone?
  119. oem wing removal ??????
  120. oil drain plug issues
  121. Heated Seat thermometer
  122. rx8strakes footwell lights voltage.
  123. tire low light on
  124. Mazda switch plate/panel
  125. Help... please
  126. Doing Fuel return line anyone done this?
  127. R&T 09 R3 vs old RX8
  128. help! where does this plug in at
  129. New Compression Tester, handheld and digital!!
  130. Amazing how different.....
  131. Good set of plug wires???
  132. rpm math
  133. Engine suddenly hesitates
  134. Stock Rx8 brakes
  135. CEL TCS/DSC problem
  136. Where to buy redline
  137. New Battery, Car wont Start, No its not flooded
  138. RX8 Battery!?
  139. oil cooler leak
  140. How difficult is it to change the starter motor yourself?
  141. afe short shifter grease?
  142. Tail Light Sealant?
  143. Rear brake pad removal
  144. mazsport
  145. can't get the fuel pump ring off
  146. Just changed plugs, wires, and coils!! HELP!
  147. Problems with rx8strakes foot lights
  148. any ideas what this little piece is??
  149. New coils.......100B-9U???
  150. identity disorder - rx8 thinks it has a cammed v8
  151. Rough Idle.
  152. RX engine swap
  153. 2005 RX8 HID Headlight assembly
  154. adding a switch
  155. Is this tube important? will it ruin my motor?
  156. reaching 80k miles, transmission/Diff flush nessassary or just drain and fill?
  157. Power steering problem
  158. shift knob stuck
  159. painting the engine covers?
  160. I'm an idiot...
  161. Clutch to the Floor
  162. 7 problems...
  163. rx7/rx8 apex seals???
  164. Spark plug broke
  165. Starting Problem
  166. Since we can't get a block heater for the 8...
  167. going to the dealership
  168. The loss power issue
  169. 911 guys i need your help clutch problem!!! please
  170. engine failure reasons
  171. Race Pipe welp!!!
  172. clutch assembly reinforcement, mazsport clutch bracket
  173. RX8 Engine Blew under 100,000 miles!!!!
  174. Interpreting data from OBD2 scanner
  175. spark plugs and coils after 42k miles
  176. how to test cooling fans
  177. 2nd gear grinds when downshifting
  178. Delete
  179. 2 Simple De-flooding questions
  180. Question for those who have installed their own exhaust
  181. Power Steering Control Module Installation
  182. ignition problem??
  183. drivers side rattling!!!!
  184. fd3s voltage regulator on rx8 alternator
  185. I hope am not having transmission problems
  186. New Owner
  187. New guy rebuilding an 05 RX8
  188. Warranty - How to find out how long left on remaining warranty
  189. No DIY for replacing ignition colis?
  190. Guys, need help with finding this part
  191. 4th gear synchro grid when downshifting from 3rd.
  192. Walmart can cut programmed keys for the 8 now...
  193. power steering warning light
  194. Advice on installing headers?
  195. Are there better apex seals than oem?
  196. Need some help or any information
  197. chip for the 8
  198. Engine Flooded? Car starts but idles wildly and acceleration pedal doesn't work!
  199. which bolt for the undertray?
  200. Can anyone here run a VIN for MX history?
  201. battery over charging???? help
  202. Dipstick sleeve?
  203. New aftermarket coil replacement
  204. Other Start-up problems
  205. no 02 sensor
  206. My first major work
  207. Could I make this exhaust work?
  208. Mysterious ticking sound
  209. Big problems, help please.
  210. maybe new engine club
  211. Need a lil help locating
  212. Heavy corrosion on battery terminal ate through clamp
  213. Opptions for ash try gauges?
  214. 2009 backlight into 2008?
  215. 2009 RX8 Fuel Injectors Flow
  216. how many miles on your engines now and previous if any
  217. Phantom oil light
  218. Z-MAX and other like products Discussion(some length)
  219. beginner mods for my rx8
  220. Question on engine replacement
  221. quick tail light question
  222. Weird noise
  223. How I cleared my tail light
  224. First oil change?
  225. supporting the engine
  226. flood engine if snubbed?
  227. Power door lock
  228. ethanol-free fuel
  229. broken plastic under bumper/underbody
  230. oil change on a budget??????
  231. HELP!!! weird things are happening.
  232. Anyone know what goes here?
  233. Engine Misfire at High Speeds
  234. what do you guys think?
  235. HELP! car wont start again
  236. Locating Speed sensor wiring
  237. Looking for Painting Thread
  238. Caribean Rx-8,..Need help,.. S.O.S !!
  239. RPM's Gauge help..
  240. What power source to power a cup holder light from
  241. which plug wires should I get??
  242. Price check on EPS CM
  243. car goes WOoWOoWOo (whistle kind of) when cold and coasting in neutral
  244. Chances of a damaged fuel tank?
  245. gap? is there a " best " gap reccomendation.
  246. 09 trans in earier model question?
  247. New Engine change @ 60k....finally!
  248. gap on front end
  249. Fuel Pressure Gauge
  250. Wankel stroke question
