View Full Version : The Tech Garage
- something weird happened...
- Amazing PCM
- Fuel Lubes
- Oil Cooler Leak
- CEL again, still, AARGGG!
- trouble starting
- Engine whining?
- Can it be fixed?
- Dealer oil change & oil weight
- A/C Problems???
- What's with all the funny noises?
- Aftermarket Shift Light
- Apex Seal Tech
- RX-8 Engines........... AT vs MT
- A/T vs M/T - gas milage difference
- Intermittent low water and tire pressure lights
- 13b engine block
- CEL Flashed Today
- Rattling noise going over bumps at speed
- De-Snorkel Stock Intake?
- A look quick look at the ECU where it seats
- Switch panel question
- "Thump" while shifting?
- Rear fog light install instructions?
- Strange Sloshing Noise from Car?
- BS intake and exhaust HP claims
- N/A timer
- Rx8 LSD
- rx8 oil filter
- Aftermarket headers + stock exhausts
- Brake Squeal - Won't Go away & I'm out of ideas
- 2275 Miles and.....
- Tokyo AutoShow's Mazda "RX-8 HYDROGEN RE"
- Plasma Ignition
- Help! Brand new car with a nasty smoking habit.
- list of service bulletins
- A/F with RPM - Graphs
- Transmission whine
- New Mazda 5-spd "auto-shift-manual"
- DSC on Auto?
- push button starter
- oil change time
- SEMA Visitors
- Head lights
- how many of you have had oilpans?
- rx8 computer reset
- Yes, another dyno post.
- Midpipe flanges
- 0-60 Times ?
- Car wont start and it is not flooded
- Light knock @ start of engine
- Sqeaky when cold
- alarm that comes with the rx8, and after market remote start
- Intentional confusion re DSC/TC/LSD and HP?
- Steering wheel buttons
- A SATNAV upgrade we should all ask for
- Engine Replaced
- Help: How do I remove the stock mirror (non homelink)
- What's the difference between 5W-20 & 5W-30?
- Temperature Control and/or Fan Control Dial Break OR Come Off
- HP claim(s) bullshit check..
- Service Bulletin: MIL with DTC ..... ?
- How can I tell: (oil pan, dipstick)
- Engine replaced / and why ?
- service manual tranny fill procedure?
- Mazda oil filter part number?
- Air directed to floor - A/C compressor cycling?? WTF?
- Will dealership give me oil under the warranty?
- Transimission Replacment
- Mazda INFORMATION
- strange transmission noises?
- all-motor set up
- Oil additives?
- Oil additives?
- Happier about mileage
- Are our Renesis handbuilt!?
- oil change amount
- Wiring info request
- my car wont start?!?!
- Can I make the "beep" sound louder??
- I broke my engine,tranny and diff.
- Redline SAE 20
- Downshifting w/automatic transmission in the manual mode
- ECU: Mazda same as Ford?
- When do I need to add anti-freeze?/coolant
- cigarette lighter
- A dyno run on an Australian RX-8
- Synthetic Oil and the Renesis Engine
- Oil level meter ??
- Steering Wheel
- Hp increase?
- Replacement keyless remote?
- Automatic Trans not upshifting to 4th
- Question for someone w/ service manual
- Oil pan TSB question
- Adding Oil--Must Engine be Warm?
- Renesis Supply Chain
- Any 20B. 13B REW or any other engine done to RX-8s yet???
- ECU Re-flash Article !
- Oil Filter Wrench
- Will pushing the car void warranty?
- have you checked your dipstick? I have sludge and water!
- First Oil Change Timing
- RX-8, tough nut to crack for tuners
- Remote entry replacement?
- clicking noise...very confused
- Engine RPM
- MoTeC Australia ECU for RX8
- Checking antifreeze / coolant level?
- Clutch Question
- metallic rattling noise on 3rd gear accelerating
- Oil Analysis .....for the anal retentive
- Shift Point Technicques
- options for the free maintenance
- Source for stainless steel mesh?
- Supercharger?
- TCS & DSC Info/Questions
- Air temp too cold to start!!!!
- EBay scam? or boom?
- Replacement Oil Filters
- Why 1.3?
- ECU and warranty
- ECU codes
- Displacement on Demand
- Downshifting problems?
- SnyderMazz
- whirring noise at neutral
- Won't start, security light flashes
- Just a few notes....
- Eddy Current Brakes
- test drive
- Oil Type & Usage Info/Questions
- TCS/DSC Question
- Compression, explain?
- engine wear and throttle behavior
- noobie question
- Programming the Display?
- Difference between 4 port and 6 port engines?
- Anyone got their hands on a factory workshop manual yet?
- Anyone fitted an aftermarket ECU yet?
- AutoExe Bonnet Damper
- Advice
- Short Shifter Shaking
- How to remove shifter knob?
- GearBox Sound
- Air Conditioner (or is it a heater?)
- Milage Info/Questions
- im getting new tires soon. But i have a problem
- ecu
- Rx-8 Gears
- I have Good News
- Drop-in capability?
- Irregular idle...possible missing
- Cold running behavior - A/T
- Oil Change & Filter Info/Questions
- Break in mileage – 600 or 100 miles.
- Check Engine Light (CEL) Info/Questions
- Oil Pressure?
- Check your belts!
- Trying to Install S-AFC2 HELP!
- TSB on RX8's oil pan (early VINs only)
- Weird burning smell in A/T
- MY CAR WON'T START, and its not flooded!!
- "rattling/ pinging noise in engine"
- Auxiliary port problems
- Lowering power steering assist
- getting my ECU reflashed
- Hard smack to the front wheels
- how many cats does the 8 have?
- O2 Sensor Fooling
- BEWARE: flywheels and counterweights
- Differential & Gearing Info/Questions
- So can somebody tell me what this part is?
- ** Redesigned oil cooler hose part **
- In-vehicle performance measurements
- 91, 95, 98 Octane - Any HP Change ?
- Fumoto Valves
- Weird Renesis Ignition Tech Info
- Door hold-open detents
- How to make the woosh sound?
- Does the rx-8 have a rev-limiter??
- Tool to calculate rpms and gear changes..
- Question about the '8 not running for a long period of time
- Making fast turns w/very low gas
- will not start
- Assistance with removing an interior trim piece
- strut bar removal
- what part is this?
- Service Manuals
- Separate oil-injection resevoir?
- Redline and no beeping?
- Additinal option for hanging gas cap
- SpeedBleeders
- Hybrid turbo by Mazda
- Anyoneknowwhere i can get an r26b? How much it costs? And if itll fit inan rx8?
- 20b swap?
- Rev limited
- Electrical tape on oil level switch?
- Spark plug fouling remedy
- Back seat heater ducts
- Engine problem or running in?
- Check your weights on your RIMS-- oh my god.
- Seat heater won't turn off
- Rotary Extreme Intake installation question
- How do you get the air filter cover off?
- Vibration at 4000 rpm
- Cabin Blower increase
- quick tire pressure question
- Has anyone else blown their transmissions yet?
- engine knock noise
- beginrer's question in how prevent flooding
- Oil report #1 & #2 from Blackstone
- newbie rx8 questions
- TPMS not working?
- Nav System Question
- More air/fuel graphs
- Check engine light problem
- Shifting has become hard - any advice?
- AC Compressor on cold start
- AFR Gauge
- Weak heat
- Who wants to be the Guinea Pig?
- Best place to buy discount parts?
- Changing Ignition Wires.
- What's the difference between Castrol and Gastrol oil?
- have an issue with seat, does anybody else?
- Mazda's own turbocharged Renesis!! Saw it at NAIAS
- Cause for low torque?
- oil dipstick question
- Replacing the brake pads
- Newbie and some questions
- Rotor Coating?
- 1st CEL - Cat Inefficiency
- Anyone use one of these to change their oil?
- Trailer Hitch
- Now this is a good idea!
- RX-8 engine accessability
- For DIY people, what oil filter do you use?
- Low Oil Consumption
- Spark plug TSB
- detonation / pinging
- turbo timer=no flooding?
- Moving this to Tech Garage...buzzing noise
- apex seals?
- Rev Buzzer?
- coldness revealing the probelem of shifting into 2nd??
- Mazda 6 V6 oil filter info
- Disabling TPMS
- E Brake
- Open Loop & Closed Loop - What is all this about?
vBulletin® v3.7.5, Copyright ©2000-2012, Jelsoft Enterprises Ltd.
