View Full Version : The Tech Garage
- Gearbox troubles
- official SAE viscosity specs, 5w20 vs 10w30 vs 20w50
- Pioneer AVIC F-Series Navigation [demo video]
- Few Questions regarding Rx-8
- Engine swap from other cars
- Quarter Mile Times
- Where does this piece belong?
- Mazda RX8 Shaking when it comes to full stop
- What would 87 octane do to the car?
- butterfly doors?
- How to lossen the steering wheel? Help
- short trips
- A/C on and off cycles ac problem need help
- Dont leave the Smart Card in the car..?
- Clutch... Maybe.....
- belts?
- Gear oil Mixing questions?
- additives
- seat belt not recoiling
- Changing brakes
- RP Supercat owners
- A question that has probably been asked a million times
- CEL flashing, car won't start, what does it mean?
- need some hot air
- Fog light replacment
- putting away for winter
- Heater not working... at all.
- Do I have an electric short?
- Thought I had a tranny problem, but it was the $*%&$* clutch pedal!
- Octane booster
- Japnese Manufactured Rx8....Speed Limit Remover
- Damage from autocross, may attempt to fix myself.
- How to make a rotary engine...
- HKS SLD 3 z3 english diagram (speed limit removal)
- K&N Typhoon Intake
- trouble shoot my lean AFR problem
- Outisde Temperature Guage
- Glove Box Bracket
- electrical or mechanical.
- Sell Catalytic Converter To Raise Funds for midpipe?
- electronics guys: instrument cluster Q
- 117k mile renesis teardown
- Auto to Manual
- weird grinding noise from shifter.
- Flooded cabin with coolant!
- Car wont start! Help me!
- Technical issue
- Lost key have new Ignition but wont start
- having problems starting
- real quick
- catless midpipe = CEL?
- ~_~_Engine mounts being replaced~_~_
- catalytic converter
- Adding DSC/traction control on 04MT base model, is it possible?
- help needed =0
- GPS killed the radio star?
- P0704 = emissions failure, WTF
- ~_~APEXi ECV Exhaust Control Valve Pipe Type
- Original battery life?
- Motor Mount Torque specs
- New Battery -- Now car won't start!
- Coolant Overflow Hose
- Problem
- Oil Light On
- Just checked the oil...
- Car wont start
- Need Random Missfire Help
- Don't know what happened, car won't start....
- Wheeling spassing out....
- New engine break in and conversion to 5W30
- is my coolant level low? (pics)
- How much money have you spent on mods?
- obd2 connector.. loose?
- Oil Change at Time
- Cobalt short shifter
- Transmission oil cooler?
- Clutch Release Collar Install Question?
- Airbag light?
- Mechanical Changes On RX-8 Series I to II
- rotory powered b2200?
- Power steering failure due to the fluid?
- Tag Light :/
- Built my first Renesis motor 12/01/08 (Pictures)
- Been to the dealer 3 times and told all normal.
- 3rd Gear Noise???
- coil harness connector piece reusable?
- HELP: Tokico Adjustment cable for KW v3
- is there diffrents in 4-port and 6 port engine block ?
- AMSOIL Fluid Questions
- i'm a retard.. help eh?
- Are all 4 Injectors different?
- removing the screens on my aem cai
- Compression results.
- Not sure
- what happens if I'm switching from ethanol to non-eth
- Mazsport turbo type 3 what else should I buy
- 2nd failure on my '06 w'35K miles in a week!
- Oil was white and nasty today
- Winter storage
- Cooling Fans 1&2 operation Temp
- Need clutch reinforcement kit and the site is down
- Car is turning off at red lights. Engine light on help plz
- redline attempt....problems...
- Chemical / Chlorine smell in cabin
- So confused about OBD II
- microGreen oil filter
- synchros?
- Oil Change Recommendations for a Newly Broken in Engine
- Name that Broken Vacuum line!
- polishing smoked tail lights
- Cel Error P0037
- how to install a block heater?
- driveshaft length
- So whats the best additions i can add to me rx-8???
- Help! Whacked a curb :(
- Oil tank for the Sogh OMP adapater
- 10 hours from buying an rx8
- CEL light flash after engine replacement
- 4-rotor Renesis(?)
- Mazda Zoom Zoom Cleaner .. Need Help
- OEM Parts
- About to change tranny and diff fluid, need some basic giudelines
- Sudden drop in MPG
- Tech Question: Do heated seats come on every GT with leather?
- Help Please: Engine Dies at Stop
- Electrical short?
- Possible thermostat issue?
- Im new, Need advice..
- clutch issue?
- NEED HELP on how to replace the starter.. ^^,
- rx8 repair manual
- Thank You For Tips On Changing Plugs!!
- Keyless unit
- Power Steering is locked! Help.
- HELP!!! Clutch advice.
- Power loss at full throtle....... HELP!!!!
- Parking Brake LIght Remains On
- Need Fuel Pump Help
- yellow cheese wiz in oil??
- Wideband AFR Gauge...
- Engine Light - 2096 Code
- Un-Do throttle body coolant bypass?
- newest problem,car wont start
- newbie problem. HELP!
- crackling noise?
- CEL in cold weather
- Tires
- Racing Beat Ram air - install instructions ?
- Help!! My engine is messing up
- why is this a problem?
- removing the OEM fender
- WOW went to my parking today....
- Problem on neutral and arround 6-7k rpm
- Removing the Intake Manifold Enxtension
- Drained out RP Synchromax for GM Syncromesh + FM
- DIY Request Badge Removal
- Couple Issues
- Car Doesn't Start. Need Help Ignition Problem.
- another gear ???
- Doesn't want to turn over...
- Please help - engine light is on - intake valve:
- something weird this way comes
- Strange noise!! help!!!
- I need a service manual. Specifically for clutch.
- 2nd gear stuck
- electronic problems? temps are wrong, everything is weird
- Lower Intake Manifold
- AC Mod?
- Lack of heat on driver's side
- kendall synthetic blend 5w-30? oil change
- help car in limp mode P1688
- Replacing front head lights bulbs
- DIY: HKS Hi-Powwr Exhaust Installation?
- block heater
- Heating/Ventilation question
- Steel or aluminum headers
- Starting Issues
- Best Battery for RX8
- cold start = engine light on?
- CEL light for ap midpipe
- valentine one DIY without homelink
- all electrical stuff gone to crap
- Fumes
- my 8 won't run right and the engine is humming while off HELP
- Lucas UCL?
- wire off battery question
- ground wire
- O2 sensor
- DIY for front air dam lip?
- Speakers Blasting at Start Up
- So i got new coils and....
- Help Removing old cat
- 08 rx8 CEL light
- Steering Rack, working crazy, HELP!!!!
- Blinking CEL
- ethanol and premix
- vfad
- How does "red lining" clean the engine?
- Water pump and thermostat
- Any Esso XD3/ UFA Polar Plus users here?
- Oil Metering Pump questuoin (TURBU GUYS CHIME IN)
- upgraded starter?
- Air pump relay access
- Engine Noise
- 30k Maintenace questions...
- quick help on ports-4 or 6?
- Car hard to shift into first and reverse
- need help finding TDC for 20b.
- My 8 was out of commission for 2 days, thanks to
- Anyone know why this is happening?
- Need Help Quickly Please!!!!
- RX8 Gears grinding-Clutch?
- My 04' 5 sp(m) cant start
- any pre-start check list?
- Speedometer: Miles to Kilometers?
- left hid light dim. ballest?
- radiator hose size question
- Agency Power Exhaust-CA Smog
- check for tsb adn recalls?
- Why 4 fuel injectors vs 6 on the '09's?
- The Radio Died...
- how to change switch blade remote Blade?
- glowing cat
- Rx8 Upgrade
- worm power low
- Fiance in hospital in MN and car wont start in ga!
- ODB II Scan tool recommendation
- K&N intake oil
- Whats going on here
- How to change thermostat?
- Throttle Adjustment
- where could I buy the covers under hood online?
- 12V outlet
- Better MPG
- oil pan
- Oil Catch Can
- plugs from advanced auto why the price diff??
- RX-8 Repair Costs
- What the CRAP is this?
- Rear Diff oil: Anyone used Castrol Hypoy-C?
- The smell of Gas
- Big Question
- O2 sensor wiring
- The Spark Plug Debacle
- Milky dipstick.
- turbo timer...
- BG 44k
- Need Help
- Braking Issues/Concerns
vBulletin® v3.7.5, Copyright ©2000-2009, Jelsoft Enterprises Ltd.
