View Full Version : The Tech Garage
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 [28] 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46
  1. heat shield rattle question
  2. Lost of power then the engine quits
  3. RX8 Overheats after over rev
  4. Vacuum Test meter which model you got ?
  5. My wheel LOCKED while driving! WTFROCK?!
  6. Clicking/popping noise from clutch?
  7. Problem @ 7500 RPM
  8. Pilot Bearing
  9. Low Profile jacks?
  10. Transmission noise
  11. oil
  12. renesis out. conventional in?
  13. Airbag light 22
  14. Is The Recommended The Best For The Car?
  15. NON RX8 overheating problem.
  16. playing Burnt Cds in the 8
  17. Another New Engine!!!
  18. Service advice, HELP
  19. DSC Problem?
  20. i'm afraid to mod my 8's engine
  21. going catless is good for car?
  22. Engine Under Cover Install ?
  23. *shurgs* Another new engine coming soon ?
  24. Clonking / Knocking going over bumps
  25. Dyno'ed the Rx8 today. Impressive results for what it is!
  26. where can i find some....
  27. How to lower the turn signal blink rate?
  28. flip key problem??
  29. 2004 Owners, What To Do To Get To 09 improvements
  30. NEED HELP! Oil change in turbo RX-8
  31. Front seat cloth covers clean / wash?
  32. RX8 Service Repair Manual
  33. Calling all Sohn OMP adapter users
  34. engine mount part numbers
  35. Exhaust leak
  36. Took the rx8 to the track now it wont start!!!
  37. Auto Leveling Headlight Malfunction switch
  38. Should i install turbo kit @ 70,000 miles
  39. 04 RX8...perhaps locking brakes?!?!
  40. torque specs on enigine
  41. power steering issue/price
  42. Dexron VI flush - 2004 GT-A
  43. Dumb Gas Question
  44. 0-60 Drag Race
  45. 0-60 Drag Race
  46. Bad Alternator or Bad Battery???
  47. Any DIY on Air separator tanks/breather tanks?
  48. Shake, rpm?
  49. Another Noob
  50. 6port auto to manuel swap????
  51. Help!!! my 8 wont idle
  52. 6th gear grind
  53. Possible TCS Malfunction...or not??
  54. Loose Hose, to Vacuum Chamber?
  55. Help with fixing exhaust tunnel bracket!!
  56. Renesis housing widths ?
  57. Can the trunk open?
  58. Cool the Cat by running rich--please explain
  59. Engine Temps II
  60. Shaking at 1700 RPMs
  61. Brass or PVC?
  62. help my 8 is dead
  63. Changing Gears - Not Smooth
  64. Gear Grind 04 rx8! help
  65. DCS blinking, and car swerving light
  66. Gauge Levels
  67. Novice replacing rotors and brake pads, painting calipers
  68. getting an engine swap; lost an apex seal
  69. Question about Mazda's Extended RENESIS Warranty
  70. Bugs in taillights
  71. car wont start(non rx8) need help
  72. small rx-8 to big rx-8 change
  73. Not good... (power loss)
  74. Daytime Front/Left light doesn't work
  75. Transmission rebuild, any hints and tips?
  76. Dash Warning Light
  77. Rotary Engine Oil System
  78. ~~~Motor Mounts and Clutch - New Owner~~~
  79. Oil to top off
  80. fuel economy issues..not any more!!!
  81. rotor mounts?
  82. Lead substitutes in cat-less 8s?
  83. Car won't start, or jumpstart. Assist needed
  84. Check Engine Light...help please...
  85. Oil light on?!?!?
  86. Sulfer Smell - Tranny Fluid
  87. Any other DIY suggestions for better performance?!?!
  88. unusual request
  89. Jacking the car up?
  90. Unable to start the engine
  91. My Keyless Entry System Stopped Working!!
  92. Is my diagnosis correct?
  93. Reving up on shutdown
  94. Went out today really hard to sh8ift
  95. Oil In My Air Filter...
  96. Clutch pedal removal?
  97. Idemitsu Racing Rotary ( Oil / Fuel Lube )
  98. Idemitsu Engine Oils & other Lubricants
  99. Travel tools??
  100. Help Analyzing Engine Issues
  101. Shifting into second.
  102. keep power port valves from sticking?
  103. car running like crap
  104. How not to change differential fluid....
  105. it starts, but struggles???
  106. AEM intake
  107. Help!!!
  108. Flooded?
  109. MPG increase with Fuel-Injection Shock Treatment?
  110. Any advice on pull starting?
  111. Voltage Drain
  112. What is your vacuum readings?
  113. Won't go into 4th at high revs and other problems
  114. final stage
  115. Aftermarket ignition coil experience?
  116. Cat Problem?? Or exhaust issue?
  117. TPMS: When does the "Check Tire" Warning Trigger?
  118. Steering Knocking Noise - Problem FIXED
  119. Replacing heater core
  120. Could someone tell me how to install an afr
  121. Advanced key programming?
  122. shaking, please help
  123. Water for gas & rotarys
  124. Water for gas & rotarys
  125. Difference Between....
  126. 2 questions on AC and tires
  127. Leaded gas better than premix?
  128. little condensation in headlights?
  129. Bolt and Nut Sizes--Exhaust
  130. NY Emissions for FI
  131. intake sensor?
  132. shock proof oil redline
  133. Anyone have the PDF for engine decarb?
  134. Operation of Secondary Ports
  135. Starter???
  136. Need Install on Greddy Pulley Set
  137. Need a new clutch. What and where to get it?
  138. Vibrating on acceleration-
  139. Coil Coolers?
  140. turning the rx8 off
  141. Throttle body spacer
  142. engine dyno?
  143. Need some part numbers, quick
  144. just ordered side lights
  145. Horn Doesn't Work
  146. Anyone tried Nitromethane?
  147. Boost Controller
  148. MMO as per carbon TSB-REVIEW
  149. parts catalog/parts numbers
  150. would this work for us?
  151. whats going on with my car...
  152. Seat Airbags
  153. Stock cat operating temp?
  154. Some questions on fuel pumps?
  155. Yet another post on oil.
  156. Upgrades and mods for Rx8
  157. Bad Coils?
  158. installing an engine
  159. oil change on 09
  160. Clutch/brake fluid
  161. Loss of Power due to Aftermarket Navi and DVD
  162. Shifter question
  163. Help :)
  164. steering wheel.. uh oh
  165. G-tech pro meter
  166. Ambient Pressure Sensor Connections
  167. Gear Selection problems at idle
  168. Aftermarket Bulbs
  169. Helmets and RX8's seats.
  170. Mazdatrix Kudos!!!
  171. Buying 2004 rx8 HELP
  172. Data equipment
  173. midpipe sound like junk?
  174. Need Help Asap
  175. engine light wtf?!?
  176. How long do OEM plug wires last?
  177. Anyone Eliminate The Cat?
  178. Engine Grinding
  179. Two questions on our knock sensor.
  180. Besides coils, what else usually fails on the RX8?
  181. Steering angle sensor location myth.
  182. Check Engine Light
  183. Power front seat question
  184. Idle Problem
  185. Trouble starting and no power over 5,000 rpms
  186. Salvage parts?
  187. My heat is...crazy...
  188. Little Confused...
  189. Changed Battery now Traction Control Off
  190. Need some SARD boost control help.....
  191. Sohn Adapter & Premix Questions
  192. Blinking CEL with P0301 code help please!
  193. Cost to fix broken air dam?
  194. RX8 Seatbelt Pretensioner Resistance
  195. OEM Intake Resonator - black hollow box....
  196. GL5 vs. GL4 Gear Oil for Transmission
  197. P0031 after resetting PCM :-(
  198. Engine Condition after 20,000 miles
  199. Need Help Installing Pulley Kit
  200. Is ACV / Air Control Valve Noisy?
  201. Stalling after new battery
  202. Flooded engine....please help!!!
  203. Catless midpipe
  204. Do you need a speed bleeder for the master cylinder?
  205. traction control engaged while driving...
  206. Figures it happened to me :)
  207. I need your opinions please.
  208. Oxygen Sensor - Need Help
  209. OVERHEATING????? HELP!!!!!!! Door Clickers, Cant make them work???
  210. FL22 Coolant
  211. Raspy Sound and Coils
  212. removing fuel pump
  213. Manual Transmission Notchy or Smooth? Poll!
  214. P-port Renesis
  215. what temp is to cold for oil temp?
  216. Rock chip on windshield
  217. is there a short sifter for the 09?
  218. Replacing the Suicide Window
  219. Replacing the Suicide Door Window
  220. Windows Go Down By Itself? No one in Car?
  221. Engine Performance - Computer Upgrade Recall
  222. Anyone used water to clean carbon vs. seafoam/zoom?
  223. RPM question
  224. turboxs midpipe problem.
  225. oil pressure question
  226. AEM ugeo wireing - help
  227. Car blogs, and struggles....
  228. Uprated Oil Coolers
  229. Winter storage
  230. 2004 vs. 2009
  231. weird idle in my rx-8
  232. Slipping clutch....help
  233. Engine Light is On...=(
  234. 4 point harness
  235. First gear on an incline
  236. oil tip
  237. Having a PROBLEMM any ideas what it is???
  238. cold start overheating
  239. RX8 Ticking noise
  240. my car wont start
  241. Parts, Frame, Drive Train, Sections - What's Under the 8's Skin
  242. $2000 in repairs? what?!?!
  243. HELP!!! Fender Bender!!!
  244. Fuel Level Sending Unit
  245. Recall Question???
  246. Dynamically Balanced Rotors
  247. Do I have a DSC problem?
  248. blitz FATT DC 4 turbo timer install
  249. Flooded Engine and More
  250. Heated and power seat?
