View Full Version : The Tech Garage
- Rev-matching while downshifting....
- Fluid Rx Pro One
- Tire Air Pressure
- Loose Steering Column - how to fix?
- Lol, AC question.
- The light that indicates "ECO mode "on""
- JDM Spec Restoraton!
- losing weight
- Fuel Injector Info
- Hi Beams and headlight alignment
- Fuel pump changed and new symptom shows up ~~!
- Drivetrain Weak links, High HP failures
- Missing something from my engine cover?
- aftermarket ECU
- Transmission Squeak
- Need HELP with K&N CAI
- changing my oil early morning..
- How do they hold the SSV in place
- Engine block Drain plug and Gasket part number?
- Newbie Question Here
- Power Steering
- CEL on after intalling AEM intake and SRmotorsport pulleys kit
- !#!@$!%! Fuel Pump!!!
- car smells like crap! need exhast help
- Exhaust help
- Possible to Screw Up Computer When Programming New Key?
- Clutch disk RX-8
- re-chroming housings....
- what to do with o2
- tire fitting
- cant start car after battery hook up
- So I have lots of Mobil 1 left in the garage....
- Caliper Questions (help)
- Question regarding exhaust pipe size?
- Paint or replace rusty rotor dust guards?
- 3 questions: stock airbox bracket, insulation, oil temp gauge
- Engine Troubles...where to go from here?
- Added too much engine oil
- Side marker LEDs
- Anyone know what's new in BP gasoline?
- PCM swap/programming information
- instrument cluster/odometer programming information
- MS Exhaust - easiest way to connect pipe with exhaust??
- Need Help - how easiest to connect MS pipe to MS exhaust?
- Should I switch to rotary oil?
- 2005 bumper on a 2004
- 13B engine rebuild step by step
- Weird Clanking Noise!
- 2009 reliablity mods older cars can use?
- What motor OIL should my RX8 have?
- Fast Idle change on 09s
- prolong add for rx8
- ls swap
- Process of elimination.
- Front End Rattle
- o2 sensor replacement
- Rate of Oil Consumption
- Braided SS lines for vaccum hoses, oil, etc?
- Clanking Noise backing up, forward and now CEL
- Fuel Filter?
- Torque wrench needed for water pump?
- 2009 Mazda at Japan Parts
- intake mod?
- Temp sensor?
- power stearing problem
- A challenge: Just for fun, lets assume...
- Questions about DSC
- Can the standard ECM/ECU be used in a different car?
- Rough idle and vibrations
- Cel
- Simple Headlight Adjusting??
- help! time sensitive
- Engine Coolant System
- water to coolant ratio?
- 1 rx-8 high power question
- Adding a sunroof
- MAF Sensor
- Transmission Problem
- Scared to buy the RX-8
- transmission
- weird engine issue with 8
- Cold exhaust?
- [CEL] Check Engine Light - Code P2079
- Cleaning with Sea Foam / Mazda De Carb?
- Royal Purple motor oil
- 04 rx8 automatic stalling..help!!!
- Pcm Flash
- 20B Twin Turbo RX7 Engine in a RX8?
- Oil change info.
- Transmission problem someone tell me something PLEASE
- HID problem....
- Problem with rpm's, power and stalling
- Starting Issue
- air pump help please
- Rotary Miata
- Is it Flooded?
- New engine @ 29k, yes I premixed.
- RX8 taking crap
- loss of power in upper rpms
- INtroducing P61190
- Another premix thread????
- MSP16 recall question
- Service for Auto Trans
- LightWieght Pulley
- Hell Trunk
- TPMS Indicator Light Blinking
- Moisture in tailight:
- 7k Missfire?
- Tools/Tips for engine replacement
- Limp mode with Seafoam?
- what is 40 weight oil
- Electronic control unit update
- Batt Light plus doesn't rev up
- Manual Transmission IN an AT
- rough idle
- 0 to 60 times for an AT
- WOOT!!! my coils are GONE!!
- $700 "tune up"
- Battery Issue (or something else) need help.
- Oil Change?
- Overheating???
- RacePak G2xtrem datalog ~ tach signal source & programing
- How often does your A/C cycle?
- Electrical assisted steering stopped working mid drive?
- need sprak plugs and wires!
- e brake light!!!
- Clutch "burned out".. I dont believe it.. is the dealer trying to screw me?
- need some help
- dies when coming to stop and hesitates when cruising in5th gear
- Symptoms
- Hm. This is normal right?
- Intake runner length and Torque peak
- "Maintenance" issue
- Gearbox/vibrating and grinding problems...
- Drained Battery
- Click noise after start
- OEM part # for shocks
- I'm gonna take out the rear seats...
- New RX-8 Owner
- Help! Mechanical Issue
- Oil Light between autoX runs...
- Stiffness In Stering Wheel
- Fuel Additive help. What to use and what not to use?
- Updated Coils
- i think my car is..
- Squeaking clutch pedal assembly...
- Unveiled: Pioneer AVIC F-Series Car Navigation [PICS]
- Best Exhaust For RX8
- Limp Mode
- Help Me Install A Coil
- hollowing out a cat
- Finally Pick the Car Up...Now Back to the Shop
- damage on ignition wire boot
- help with exhaust install...
- head light issue
- Is this serious
- Adding OEM Moonroof
- cel p0031
- Anyone break a RX8 rear end yet?
- Keyless entry issues
- ecu compatable
- ECU Clear/ Reset question
- Looking for some guidance with oil type/brand
- Where Can I buy parts in Canada?
- Quick questions on Shock/Spring install
- Spark Pulgs Fo N/a
- Rack & pinion do it yourself!!
- Question about mpg
- Air Conditioning Problem on new RX-8
- Quick Question
- Coil Replacement Inquiry
- Need Advice
- help with install revi ram intake
- Dyno Advice
- Transimission Fluid Inquiry
- what can
- Anyone know how many coolant temp. sensor we have?
- New Motor Install!
- Help save my car from TS Fay!!
- Why is our oil filters so small?
- No BEEP at redline
- Throttle Body Size ?
- weird AC situation
- Size of throttle body?
- clunky shifting
- racing beat air duct
- What motor oil are you using on your RX8 now?
- What oil filter are you using on your RX8?
- error code p0031
- Tapped footwell lights into wrong wire!
- Car thinks it's stolen?
- Pic request of Dipstick
- HELP Possible water damage
- Some TPMS help!
- Adding DSC to non-DSC rx-8
- I need a new clutch
- Mixing Oils
- need a new front o2 sensor which one do i get?
- smoking after oil change
- Loss of Power
- Gears or Cluth?
- Alright call me dumb
- Interesting Idle Vacuum Correlations PART 2
- Problems starting
- What tranny fluid
- Rear license plate washer
- Help out a new driver?
- P0850 CEL Code
- does the front bumper from the 192hp model fit the 232hp model?
- Change default front seat angle?
- Codes for CEL and "DSC OFF" flashing
- Picked up a 2004 RX8, what are the first main things to check?
- Strange raspiness under load
- Power loss at 4th gear and 6000+ RPMS
- E10 blend issues?
- Bad engine vibes
- smoked lights
- My 8 won't start?!
- Suck At Driving
- What It This???
- Good NJ Mazda service place near Hoboken?
- High Pitched Sound at 6000 rpms?
- What are these connections
- Royal Purple trans fluid?
- Power loss when accelerating.
- POWERLOSS !!.. NEW SITUATION !!.... i need help ...pretty please ?
- Mazda's iPod Integration Module???
- Wheel concern
- Fuse Problem?
- Loss of Power on Hot Days???
- Greasing???
- 30k miles service DIY help
- Spark Plug Wires
- Blinking Light Question
- Neon ignition tubes?
- RX-8 Air Conditioning Problems Please help
- Cel
- Rattling in engine maybe?
- RX8 04 CD players
- more horse power! help!!!
- HELP ME!!Rattling noise in exuast somewhere!
- Need RX-8 shock removal tips
- Just A Question
- cobb accessport on AT??
- Revving=engine coolant light on
- Replacing Transmission Guide
- exhaust manifold question
- Quick Help With Cel: Have Code And Description
- noise when shifting from 1st. to 2nd
vBulletin® v3.7.5, Copyright ©2000-2012, Jelsoft Enterprises Ltd.
