View Full Version : The Tech Garage
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28 29 30 31 32 33 34 35
  1. Remote stopped working help!!
  2. rust........ eeeewwwwwwww!
  3. Help Needed
  4. Bad in Reverse, worried about Transmission
  5. Spring Time Tune-Up
  6. new 8 owner wondering what oil/fuel to use
  7. 5-20 vs 5-30 oil -do I use it after 44K miles?
  8. Headlight focussing//auto-levelling
  9. 5-20 vs 5-30 oil - do I use it after 44K miles?
  10. Cant search, where is DIY for water in tailights??
  11. reverse light wire routing
  12. Paddle switch stopped working
  13. Turbo XS Exhaust
  14. Advice Needed: Turbo Kit
  15. Drying moonroof after rain?
  16. 18in RX-8 rims on a 95 626
  17. my CEL
  18. Oil - Technical
  19. Fuel Mixture With Aftermarket Parts
  20. flat spot
  21. mazda motor policy?
  22. low dyno results + recall
  23. Engine Lubrication System
  24. Buttery dipstick
  25. Cleaning fouled plugs
  26. Power Steering
  27. CEL driving to work
  28. Gear Oil.... Prefernce Poll
  29. Air intake
  30. engine turnover
  31. gas milage,thrmostat,ignition questions
  32. Starting and Idling issue - See Video -
  33. looking to but a 04 rx8 with a greedy turbo, need help
  34. Side-exit exhaust ideas...
  35. Mobil 1 Advance Fuel Economy Engine oil ????
  36. Question about Keys
  37. Horsepower, torque, and engine design
  38. renesis removal/rebuild
  39. Eneos Motor Oil
  40. care about ur engine? check this out...
  41. I don't understand...is this rotary design wasting power this way?
  42. No power after 6k rpm
  43. How I made 22-25 mpg in my RX-8
  44. My engine replacement nightmare
  45. Front Ride Height Sensor Wiring HELP!
  46. flywheel with clutch?
  47. where to buy a supercharger
  48. just purchased
  49. HELP! Engine revs up and down during first day crank
  50. Sounds Like I Need A "Valve Job" ...
  51. Check out my battery project
  52. Mod question from a new RX-8 Owner
  53. Speedsource tranny
  54. Fabricating motor mounts
  55. What is that ticking noise???
  56. give me an opinion on Borla exhaust
  57. Increase in horsepower or torque?
  58. How much R134a Coolant and Compressor Oil Needed to Recharge AC
  59. HEY GUYS! 1st post, stupid question.
  60. Low Engine Coolant Light Comes On?
  61. Coolant level Temp and Proper Checking
  62. Denso universal Oxygen Sensor
  63. Triple-cone synchros / double-clutching
  64. Stock exhaust
  65. Good mods for longevity of the Renesis?
  66. recomended tools/ what you use?
  67. Are these Spark Plugs ok???
  68. my thoughts on the upper manifold
  69. 4th oil leak from engine
  70. Best Foglight Bulbs?
  71. Decarb+MSP16=not so loud K&N?
  72. So I broke off this bolt.
  73. What is the different between right and left handrive RX-8?
  74. I F@#$3 Up the Mirror
  75. down on power......grrr
  76. Engine Problems
  77. Clear Corners Troubleshooting
  78. DIY on testing OEM coils
  79. reseting ECU after installing mods
  80. CEL is on, and questions about warranty
  81. Uneven rear tire wear
  82. Urethane mounts?
  83. Power steering malfunction light!!!
  84. engine problem/issue
  85. stock coils vs. mazsport
  86. 30000 mile check-up: Do I need all these things they're trying to sell me?
  87. 16X Engine – Possible Technology Applications
  88. Official Synthetic Oil for the rx8!!!?
  89. stock suspension height ?
  90. Midpipe length?
  91. Spark plug wires
  92. Engine Vacuum Testing
  93. keyfob programming
  94. Doesn't want to start
  95. Console lid
  96. awesome oil filter
  97. Crank, Yes Start, No
  98. Tire pressure - 19" -- 40psi?
  99. Cusco 6pt roll cage: will it fit?
  100. help w/ new exhuast
  101. searched threads, still clueless
  102. taking out catalytic converter?
  103. Rotary advancements/skycar
  104. Rear End Problems
  105. Iridium plugs - lower cost?
  106. Help with anti-corrosive coating on replacement OEM brake rotors
  107. Engine overheated - what now?
  108. CAS info needed.
  109. new exahust question
  110. Black stuff on the underside scraped off - bad?
  111. A/C Condenser Leak!! HELP!!
  112. cant remember...
  113. green kind of slime in the oil?
  114. Mazda Dealer ask me "Your car is fine. Why would your rev up to 6.5-7k"
  115. oh crap i bought wrong gauges
  116. Oil Catch Can install question
  117. need info on motor
  118. A different way to program your key fob?
  119. Mazda Extends Engine Core Warranty!!!!!
  120. Will Air in the Cooling system affect pressure/coolant temp ?
  121. Cobb AccessPort Swap
  122. HUD tach or normal Tach?
  123. OEM front brake pads question
  124. oil report results
  125. shaddy gas mileage
  126. Some ?'s
  127. I need to replace a new rotary enGine??!HelP ME Plss!!
  128. Mazda RX-8 High power enginelight turns on in the dashboard
  129. fan will not cut off after shutting car off?
  130. premix motor faliure
  131. Need help (wiring)
  132. Strange power loss/bog...
  133. Very low dyno, with tune and AP
  134. Weight Reduction
  135. Thinking of doing some work on my 2004 RX-8
  136. deployed to iraq, car in storage and battery died
  137. New Engine Replacement Question
  138. 4 port porting...
  139. Power Concerns
  140. rx8 diff gears
  141. brakes and rotors at 20,000
  142. Effects of overheating..
  143. Ignition Coils, can you find the bad one?
  144. Leaky Differential
  145. Fog Light Question
  146. Where is the stock oil pressure sensor and temp sensor?
  147. Where in the drivetrain is the RX-8 losing so much power?
  148. Starter Motor Cover
  149. error code p 0355
  150. Squeeling noise from the a/c vent area..
  151. Radio buttons don't work, steering column ones do
  152. new engine break-in period
  153. Do I need new spark plugs?
  154. im new to rotary engines
  155. Issues with rear brakes
  156. Car become lazy after 16k miles service
  157. Can Anyone Hinder a guess how this happened?
  158. Front End Rattle/Noise TSB
  159. 1st CEL today
  160. electrial engine connectors?
  161. Funky Radiator Light
  162. Where did you mount your Battery?
  163. how reliable are F/I turbo?
  164. Hydrogen reactor
  165. Oil basics, help please.
  166. Figured out the Check Engine Light
  167. Strange Vibration coming from under the car...can be felt in the drivers seat
  168. REVi....good or bad?
  169. Do the Underdrive pulleys set!!!
  170. difference between 13b tip and manual
  171. Switch to 10w40 and hardly any oil consumption
  172. lower intake observations
  173. Question about OHMs of Resistance
  174. Another Glowing Cat Thread
  175. Zoom Power Cleaner question
  176. Sparkplug question
  177. enginelight and burned catelytic
  178. Question about switching thermostats?
  179. tricking the pcm
  180. Strangish problem after my first new engine
  181. 11.8 sec 0-60!
  182. CEL after using SeaFoam Engine Cleaner
  183. New Steering wheel/airbag light on
  184. Bad throttle response after changing coils
  185. Trunk rusting from spoiler install?
  186. Left shifter paddle
  187. Throwing 2CEL's after wiring done under engine...
  188. other jack locations
  189. fill air conditioning fluid
  190. secondary air injection cel
  191. Please HELP HELP HELP
  192. Hunter's Road Force Balance ?
  193. 2006 w/Auto Tranny - Vehicle shudders & hesitates @ 55 mph
  194. looking for a garage
  195. Aem Cai
  196. question about oil level going down
  197. What is an EVAP emission control system?
  198. Engine light after winter
  199. Change Spark plugs with coils?
  200. Taillights and Sidemarkers won't turn on
  201. Where did this dent come from?!
  202. rotor dead
  203. Flashing battery light!
  204. Looking for ECU connetor/plug housing
  205. Cooling Mod (sorta)
  206. Radiator Treatment/cleaner
  207. Setting up Headlight Washers on US car
  208. rx8 gasket?
  209. New to Mazda... Brand Info
  210. Urgent: oil pressure
  211. E-Brake Light wont' shut off
  212. My First Post
  213. new rx8 ower have a questions just found out
  214. 87 octane
  215. Redline at fuel cut-off....
  216. intake manifold
  217. high performance 02 sensors
  218. Overheating engine?
  219. Change In Oil.....
  220. Help Needed Climate Controls Not Working
  221. Engine Removal
  222. Clutch Replacement
  223. ??? climate controls ???
  224. Opinions on oil change before & after track event.
  225. Central locking issue
  226. Couldn't shift into any gear yesterday.
  227. How much oil do I add when "topping off"?
  228. Daily Revving to ~7k RPM
  229. My first post and already...
  230. Poping sound
  231. replaced coils, now there is a friction feeling?
  232. Liqui Moly oil additiv
  233. Lost the Exhaust Manifold?
  234. RHD Conversion.
  235. Fuel pump Hi/Lo pressure circuit and where's that fuel pump DIY thread?
  236. Maintenance on my RX8
  237. what is a shinka?
  238. MS CAI DYI Installation - easy?
  239. Weird noise please help
  240. Define "dirty"
  241. CE1 option / Cali emission
  242. HELP: Missing power under 5k rpm!?!?!?
  243. Next Mod...
  244. Rotary compression tester
  245. How to Fix Exhaust Rattle?
  246. Engine Light - Require assistance ASAP
  247. Question Regarding Adding Oil............
  248. 30,000 Mile Service - Reasonable Cost? Dealer or Independent Shop?
  249. radiator fans not turning on?
  250. Is the RX-8 a daily driver?
