View Full Version : The Tech Garage
- Eagle One Nanowax vs Meguiars NXT
- C.E.L On
- Greddy T618Z wastegate
- 20b
- Dashboard unit w/ Navigation wanted
- Dashboard unit w/ Navigation wanted !!!
- should an '07 owner get the new pcm flash?
- Ignition Kill Switch + Fuel Pump Kill Switch? (Thefts)
- New TSB 3/14/08
- Help! Starting issues
- Anyone with Vertical Doors Inc. Installation Guide??
- Engine Failing?
- Diagnostic Code Scanner/Reader
- Taking out of storage
- Possible clutch/transmission problem -- What is my car's deal?
- Problem with intercept X on Greddy turbo
- Any rotory tuner shops in Dallas or San Antonio?
- Oil Filter Relocation Kit
- 2005 recalls
- WIPO articles
- Driver side fog is out.
- Canadian model front bumper removal
- Another Car won't Start Thread (Yes I searched!)
- Perfect Replacement for Fender Well Clips.
- Idling Question
- first time driving a rotary (help please)
- 02 sensor replacement
- The Best Oil Money Can Buy
- Stock Cat Switch Ratio?
- Tachometer Needle Flickers and DSC off
- Tachometer Needle Flickers and DSC turns off
- re:
- Need help :(
- CEL 701 and O2 sensor
- Clutch issues - Help?
- Need Cowl Removal/ Install Instructions
- rx-8 oil problem
- Air Pump Removal: Header Flange. Any Interest?
- Tech trick to save gas
- does any one know a stock rx8's actual stats?
- fuel filter loc?
- Water inside tailight..!!! :(
- Small Rear Access Panel or Port
- I Need Your Advise!!! Help!
- Stock clutch question.
- Im throwing a CEL P0302
- 2nd Gear Chatter
- Did I tear my Apex Seals ???
- Pre-lube starting procedure?
- Ok so I did what!!!!!!!!
- If It's Not The Cat Then What?
- Service Up Date Help me out
- oil problem!
- New engine concerns
- prosport water temp gauge
- Help needed ASAP oil problem!!!
- CEL? Por Que?
- Help Please? CEL
- Just took the msp16 update on my new 04 rx8-BIG DIFFERENCE!!
- Advanced Keyless - Shock Sensor?
- dearly departed 13b..pics
- Fearing Recurring RX-8 Problems.........
- Mid-Pipe Rattle! Help!
- Radiator coolant Boiling
- 5w20 vs 5w30
- What is seafoam for our engines?
- Headlight issues?
- Low on power
- Fuel Filler Door
- strut brace
- Small Question
- Converting my 8 to a hybrid ....
- if you take out your rear seats, this is what it will look like.
- Now here is something that will make hybrids worthwhile, or even do away with them.
- Blew off the fuel pump line
- Concerned..
- Mazda Dealership Overfilled Manual Tranny While Performing 30k Maintenance
- need help with my CEL light
- Just changed the Final drive Do I need running in?
- Burning-hot smell from under car......
- spark plug torque and location of OBDII
- Trouble starting
- Ideas for a BOV recirculate fitting?
- how would you do it?
- Someone Want to explain this?!?
- $3,000 Rebate Vs. Reliability
- Coolant leaking directly into Engine Sump Advice Needed !!!
- Help! Need New Engine! Pissed The Hell Off
- AEM Tru Boost Controller
- 3rd to 4th gear grind.
- New software for Rx8?
- Oil Analysis
- Well Now-my Car Wont Flood-it Dont Use Oil-it Doesnt
- Loose Rotary Crest
- Is it true?
- beeotchs accident =(
- Rough shifting 1-2 and 2-3
- Help- Keyless entry dosnt work on driver side
- help ! Grinding geers ...
- Flooded Rx8
- removal of front flare to install strakes
- Wideband routing
- Why the connecting holes inside the water jacket are so small?
- How much do dealers charge for tran and diff fluid change?
- MSP-16 Reflash done
- Custom Turbo kit??
- ECU modding?
- Coolant inside engine ?
- install of after market strakes
- water temp goes hey wire!
- oil change, improves shifting feel....?
- Front-bottom chassis cover part name?
- FYI: For those who own the AFE short throw
- Coolant Level
- Shifting- weird sound and vibration
- Know any service shop in Milwaukee,WI?
- How do you get better MPG?
- bought new battery but....
- whining when starting
- Flooded my Rx8
- Oil filter: by hand or by wrench?
- How can I tell if my coils are bad?
- tune to 87 octane
- Does mazda replace the coil packs?
- Help - Trying to start; click but no crank
- What socket size removes spark plugs?
- Speed bleeders
- Your ground of choice in the engine bay?
- Radio Wiring Harness Diagram
- Are double sided tape necessary for fender strakes
- Low-oil indicator while rev engine
- has anyone speced the side plates?
- has anyone used CataClean for their catalyst?
- Engine, help...
- Hesitated, Then A "Whoosh" Sound.......
- Newbie needs his hand held
- Coolant temp sensor...
- Center Console Crackle
- Question about EBC "Red Stuff"
- Problem TOWING HOOK
- over heat
- Grounding kit: a couple of ways to do it...
- Replacement of coolant reservoir assembly
- Re-establishing LTFT after battery pull
- aircondition filter
- Question about oil
- Mazda Service Question
- aftermarket clutch?
- 16X Swap??
- Catalytic Converter Question
- small gaps in side aero flares
- Uh oh what was that?
- Clutch - Rubbing sound
- Help..clutch
- HELP: Mazda Engine cleaner application done---> now problems!
- engine knocking?
- Will the x16 kill premix
- Baro sensor/Map Sensor/ Pressure sensor.. Where does the vac line plug into?
- Carbon Build Up - How to prevent?
- O2 sensors
- Quick question (Pulse Plugs)
- Where to get a Switchblade Key Cut Besides the Dealer?
- Check flash rev level, scangauge?
- Spark plugs & ingnition coils
- engine stutters ...and DIES
- Advice? Convincing Dealership to do TSBs (I searched)
- Compression test results and dealership woes
- TSB's
- That little beep...
- plugs and wires question
- Block Heater?
- will this help prevent the CEL i'm going toget with a midpipe??
- getting charged for msp16???
- foglight question
- Shift/linkage stiffness
- 100 octane fuel in my 8??? safe/unsafe.... plz help
- msp16 reflash
- What is the best Anti-Freeze?
- i would appreciate a little help, thank you
- wideband gauge power...ideas????
- programming
- Engine trouble *white smoke*
- I changed back to Stock Intake Box ...
- AFR Gage Install Problems
- Remote programming HELP PLZ!
- 60,000 mile service
- help
- omg ...warning light..help help
- 300 WHP auto naturally aspirated possible?
- Air filter replacement
- I think I burned my clutch
- routing for wideband sensor cable
- Lost Pinch Weld Adapter for floor jack, how to jack each corner individually?
- Tapping felt in foot through clutch pedal.
- Radio and Sub volume problem
- gas milage inhancers???
- stripped O2 sensor and a little bit else
- Crash, Suspension Help
- Help Needed
- Preventative maintenance - Should Seafoam/Mazda Cleaner be Annual/Semi-Annual ritual
- DSC help!
- Replacement parts
- bogs out and stalls
- Coolant overflow tank hose diameter
- Compression numbers in relation to dyno numbers
- MSP16 and AudioLink
- Question About Lowering Springs
- Upper Radiator Hoes Replacement
- HID headlight conversions
- AT 3O MPH acceleration pulse??
- engine bay padding
- Weight of the 20B, weight of the Renesis??
- How to remove this ?
- Distilled vs ordinary water for radiator
- Help Plz!
- Flooding
- Missing rpm signal
- Lots of rotary information...
- Clutch
- Exhaust manifold/header installation?
- is my engine blown?
- Cel
- 8 Dead - Then Alive (?)
- transmission rattle?
- Transmission Failure Info
- I have a ram air question
- Brakes Locking?
- OMFG!! got dynoed with horrible results
- Heat stuck on
- glowing red
- Oil smell inside.
- Help, engine dies at idle after spark plug wire change
- Can someone help with the oil pressure gauge
- Challengine conventional wisdom
- Cylinder 1 misfire
- 2004 RX8 HP numbers
- help with seat swap
- How does RX-8 control idle??
- MT-90 + MTL for tranny?
- 2004 A/C programming??
- instrument cluster
- where to get connector
- clogged cat
- Rough Idle due to broken engine mount
- condensation in drivers side headlight
- Improve my mpg
- Is there any workshop that can clean this aftermarket air filter?
- Warranty ends 5/18/08 (still have extended and 1 yr power train)
- new need some awnsers
- New tech center for Rx8's
vBulletin® v3.7.5, Copyright ©2000-2009, Jelsoft Enterprises Ltd.
