View Full Version : The Tech Garage
- engine almost stalled again
- How do I add exterior LED lights?
- backfires while warming up
- My 17-cylinder RX8
- Any1 have engine problems in the cold??
- Where to download service manual?
- When they replace your Rear Combination Light, do they replace the gasket as well ?
- UPDATE - 4th Gear Grind -vs- Dealer
- leading spark plugs in all 4 spots?
- 2009 RX-8 Transmission Gear Chart and Discussion
- Good Place to get replacement lights
- CAD drawings of common parts
- shooting flames
- synthetic royal purple oil
- New '8 ownr, clunk sounds in snow/slippery conditions?
- Need DIY Rp Supercat
- Removing My Cat
- Key FOB question
- Dry Cell battery for RX8
- Bucking Bronco- Engine Mounts Again?
- OK to mix Redline MT90 and Royal Purple Max Gear 75W90 in manual trans?
- Engine starts and dies after 3 seconds
- Haven't Driven My Car Since Last March
- Help! any ideas?
- Major clutch+trans problems
- Break In period?
- funny ABS DSC TCS behavior
- Difficult to start when warm
- Got Car To Crank after Flood but now will not crank again
- Help! Freezing temps + very low/old coolant
- sounds like a cricket is in my radio untit....
- Redline question
- DSC OFF blinking after....
- New Coils and Plugs help
- car turned off in the middle of driving it..Help!!
- Midpipe Or Racepipe
- car wont start
- XM or Sirius.
- Coolant Leak costs 1100 dollars at Oak Tree Mazda?!
- Rear Differential/LSD Problem (?)
- Houston, we have a problem....
- Fixing scratches
- Base Auto Upgraded rear LSD/Rear Diff Question
- A question on the transmission.
- Interesting Issue with Cat Converter
- Had a CEL today
- Check Your Radiator Hoses!
- My RX-8 "Repaired" **WARNING NOT FOR THE SOFT OF HEART**
- 5th gear grinding???
- basic 2-year maintenance?
- Coin Holder Light?
- po420 error code
- 22,500 "checkup"
- Would a high quality vacuum cap work in this application?
- 20B benefits
- What stock plugs look like after about 14K miles + premix about 8oz per tank ~
- I need some tips with my new Rx=8
- Counterweights
- pics of my spark plugs, what does it mean?
- How does my stock dyno look?
- How Many DIY Engine Rebuilds?
- Horn Location and removal
- Oil Pressure
- Water pump inlet/outlet
- was replacing my air filter and found..
- scraping sound from engine
- wheel hop
- Extremely dim xenon headlights
- anything goes
- Putting the AT in neutral while at longer stop lights
- Purolator PureOne oil filters cheap @ Amazon
- Water in my Engine! HELP! NEWBIE!
- Automatice Transmission Fluid
- Loss of power?
- AFE Short Shifter Install
- Mazda Authorized Modification sticker?
- New Reverse Light for my 8
- just got a recall notice...
- removing oil feed line from the block
- MOP Oil Flow Direction..
- Is redline the 8 good for it or bad?
- big problem!! fuel cut??
- okay to mix oils?
- New owner- Engine light problem
- My MS duel canister catback is defective
- Paxton Supercharger.....on Rx8.....possible?
- problem with starter
- ABS, Break, and Traction Control lights come on
- car dead
- Battery cautions:
- Shock Sensor - HELP
- smallest wheel size for snow tires
- Thinking about RX8
- need help figuring out reverse light project details
- engine swap
- Heat A/C Controller:
- why no oxygen sensor DIY?
- Not sure if traction control is working properly
- How to adjust clutch engagement/disengagment point?
- Throttle Body O.D.
- Occasional Hesitation at WOT
- Would taking out the metal thingy behind the bumper be a bad idea! Pic inside!
- RX-8 Rolls backward in 1st Gear on 20-30 degree incline?
- Re-Program after Upgrades
- is "cylinder #1" the front or rear rotor?
- power loss and engine rumble?
- spark plug analysis please?
- Long start
- Cheap Spark plugs
- ECU codes
- Mazda put all leading plugs in my RX8, Mazsport gave me all trailing plugsWTF?!
- my 8 is half dead
- Missing Splash Tray
- What should I do next?
- Mecahnics Tools Needed for RX8 Maintenance?
- Oil catch can vs breather vs breather catch can
- What is that "knocking" noise?
- Grounding Wire Install
- smaller rotors
- rx-8 VR4
- Regular headlights to hid headlights.. any problems?
- Renesis engine issues finally identified?
- thing attached to the oem air filter
- buying a used turbo kit
- IntX Dongle needed or not?
- Oil Pressure Sending Unit Threads?
- engine looks jumpy
- Please help! P2004 APV stuck open ON 2 CCM
- VFAD upgrade
- sirius oem sat antenna
- curious question
- brake piston (cylinder?) seal
- new goodies and a question.....
- no cat .....normal codes???
- Spark Plug Wires
- Herky Jerky at low speeds
- Haynes manual for RX*
- Shift boot keeps falling down...
- Red Line Limited Slip Differential Fluid
- Oil and plug change after flooding???
- Lets look at expo1's over 100K renesis motor
- automatic transmission harness
- TSB -vs- Dealerships and Rebuilding Tranny
- electric supercharger
- Engine Removal?
- Thermometer doesn't go below 1 degree?
- Has anyone drilled the oil injectors?
- True or False?
- 5500 rev limiter????
- rust on rear door sill near b pillar catch
- Is there any reason why I wouldn't be able to install an analog speedometer?
- High Revs is making the rear end make thumping noises!!!
- Which one of the THREE oil filters is better?
- Why Carbon Build-up
- Engine Temperature Light:
- How do you remove the rear Hub? Tire Kingdom F'ed up!
- AWP and FI
- 2004 switchblade remote program
- Clutch problem!!
- What is this?
- Do we have a DIY compression test?
- Ambient Temperature Display
- Newbie question
- I don't know where to begin...
- Whats the speed limit of an 04 RX-8?
- Assistance interpreting instructions
- Fluid HELP!
- Transmission Whine : 6MT, cold, only when in gear
- fireee!!!
- Engine Light!!
- Replacing airbags? anything else that has to be done?
- Ideal coolant mix for street/track use?
- Performance mods that dont void warranty?
- Possible power steering problem?
- "Sport" model differential specs?
- Racing Beat oil cooler & AC condenser screens
- Vaporizing Fuel
- holding the DSC
- quick wheel fitment question!
- cat blown? rx8 turbo?
- Noise comming from Trans??
- honest opinion between these cars ?!
- Do I need new bolts and Gaskets
- How to adjust handbrake
- Hi Flow exhaust
- is my engine on its way out ?
- CEL code P2060
- Heavy vibration above 45mph
- Extremely Noob Question
- sparkplugs?
- HELP - ABS, Tire Pressure, Service Engine Soon, Traction Control LIGHTS ON
- Air/Fuel..Gauge
- temp,pressure,air/fuel
- Engine ticking at 6000rpm ?
- CEL not on after midpipe install :[
- hesitation at 6k rpm please help
- No pick-up
- First cell in over 4 years. . .
- Installation of clear corners....where did the 'how to' go
- Spark plugs
- what service light is this?
- CAT and Misfiring!!
- Is it time to change...
- misserable grinding issues!! help please!
- RX-8 Engine Problems
- Car is new to me....taking to in for headlight issue...anything else?
- Interesting fuel pressure
- Went Fast and Died
- Looking to buy an RX8.
- What does this light mean on my dash?
- Installing Exhaust
- Manual Shift Cover Install??
- Clean up grease?!
- RPRacing Dyno Day March 08
- CEL flashing
- oil change every 7,500miles?
- emulsified oil on dip stick
- Recommended mods for beginners?
- My gift to the world of RX-8 and rotary/renesis enthusiasts everywhere.
- CEL P2096 Question
- Black Halo Racing and RotoRocks - At Home Motor Rebuild
- Front Wheel Studs same as Rears?
- Zomg! 30mpg!!!shift11111
- Antifreeze...
- Tire size/Speedometer observation;
- Octane booster long term effects?
- Loud click at 3.5k-4k RPM. Not the marble problem
- To any CanScan users - please email me the USB driver??? (site's down)
- Turbo8 and Spark Plugs......
- Exhaust smell inside car
- Help removing OEM fog lights
- Just got car back yesterday from shop
- SFR Protecta Engine Oil Booster
- porting
- ??? Clutch Replacement ???
- bent radiator fins
- need some help - Question for Sandwich plate and water sensor adapter ?
- Mazda 16X (Large Pics)
- Battery Drainage
- Oil Pan Heater / Engine "Block" Heater (ATTN Canadians!)
- possible engine failure??? HELP!
- Do you have the Wheel bearing numbers
- Fuel smell!
- Need some advice..Starting to worry.
- seat belt minder shutoff?
- Tire sensor blinkig
- Test drives & Break in periods
- more power!?
- small tears in the leather seat
- car wont start?!
vBulletin® v3.7.5, Copyright ©2000-2009, Jelsoft Enterprises Ltd.
