View Full Version : The Tech Garage
- What size is the pipe inside the Air Intake Box?
- Heat won't work
- Failed inspection because of gas cap
- question on lubricating gaskets
- Manual & Diff Drain Plugs
- Replacement rubber grommets for air filter box
- my ac n heater dont work
- after putting new spark
- low speed shudder
- Rx-8 Problems, Idle And Driving Problems
- New plugs, coils, wires? Not warrantied at 57k? Can I replace myself?
- neutral safety switch
- Rotary engines life
- Does this modification work on the hks racing suction intake??
- Clicking on start up.
- Need to know where I can get replacement body parts
- AIR BAG light came on
- Missing nut For Battery NEgative
- Low cost Low profile jacks?
- Air bubbles in coolant tank
- Hood Damper Problem Warning (and a few pics)
- air pressure tire warning random flashes...HELP
- ECU wiring diagram
- 2006 shinka
- Oil Warning Light Question
- removing the throttle body??
- Correct Compression Test Numbers
- removing headlights?
- Are my coil packs done? Hesitation, power loss
- Shifting without the clutch?
- Any know how to install angel eyes?
- Can you ID this sound? video link included
- Sparks and coils which goes first
- High pitch sound in 6th gear
- Headlight washer help
- Help!!!! Running Bad....
- Removing Front Bumber
- Well, crap... rx7 Plugs and related issues?
- Fuse busted........
- Redline MT-90 vs 75w-90NS in transmission
- back seats removal
- ok........this one I really need help
- differs between SP and HP
- vibration
- flywheel counterweight question
- Help. warning lights randomly turned on.
- RX-8 Parts Catalog
- Gear/Transmission whine....
- Cel #p0506
- My Engine Flooded? Is is covered by Warranty?
- How many miles before replacing brake pads?
- HKS Twin power DLI II ignition amplifier
- How To make fog lights on when parking lights on?
- Dealer Air Filter vs Aftermarket. Any Substitution??
- I know but 51 pages of flooding is a flood.
- New RX-8 Owner
- Why won't my radio work?
- Squealing when i brake
- Need Help with the 12000K HID replacement >~<
- Foglight adjustment question
- Check CEL/Oil lamp
- 04 8 whines when going into 2nd only...
- Anyone with AEM intake...or not.
- Recommended Mazsport NGK spark plugs
- helpp ..urgent
- blown engine?
- 3rd Engine poll
- For Sale 60GB Apple Video iPod...$150
- Power Steering out
- An idea to the fix cel for not having a cat
- 2004 RX8...Am I crazy??
- wheel bearing / drive axle removal
- how long an rx-8 engine last?
- oil build up
- MSD ignition
- Which is the Best air intake?
- Question involving driver side vent...
- Plugs and coils
- what could be the reason?
- Replacing REAR brake pads on RX8
- Got my new engine
- Pulse Plugs?
- Tranny destroyed? Need major help!!!
- TYPHOON V.1 killing me!!!
- Advice on damaged bodywork
- Airbag Blink Code 14
- Oil question?
- Spare tire
- urgent, need help. please!!!
- another cold start problems.
- Winter storage -fuel question-
- Removing residue left after condensation in tail light?
- OEM exhuast question. quick Q.
- strange smell?
- Strange noise
- Mazdaspeed front tower bar
- unorthodox pulley installation delay
- ENGINE PROBLEM - Urgent Help Needed !!!
- ABS, DSC, and E brake Light is on need help
- Running OBDScan (or similar) on a Mac.
- Help!!
- New clutch new smells and feel?
- midpipe sound.
- Difference in Exhaust.
- high mount brake light not working
- when is it time to switch?
- oil preasure
- 3rd and 4th grears grind randomly with clutch all the way and no throttle
- new/used Rx-8
- Heater problem diagnose?
- MT-90 in the differential
- How do these plugs look?
- MAF sensor cleaning
- accelerate problem
- Spark Plugs
- RX8 won't start. The love/hate relationship begins. Please assist.
- 4th gear ratio
- Engine Lights on. Code P0301-FF-RCM Help please!!!!
- Driveing tips
- OBD II scanner won't pull code-CEL
- Re-tune the De-tune?
- airbag codes
- All RX8 info you will ever need
- Anyone have their motor mounts replaced more than once?
- Gas in OIl nightmare HELP!!!
- Odd No Start Situation
- 6th gear whine under acceleration ...anyone else?
- Feed Final gear 4,77 - speedmeter
- How thick are new brake pads?
- 158 whp wtf!!!!!!!!
- midpipe bolts
- RX8 parts' OEM Number???
- CEL codes
- WOOOO ! Clutch pedal SNAP off ~~~
- Console with navigation control
- advanced key question
- Finally an oil that will end all further oil related questions.
- Compression check: 2005 6MT, 55K miles
- IAT mod with 1.5k ohm resistor
- needing help finding a vaccum diagram
- change speedo???
- Canadian Day time running lights
- Need Answers Asap
- replacing dash
- Fumoto Oil Drain Valve
- best solution
- engine start-up idle, engine light on
- antifreeze keeps coming out
- turboxs race pipe fits?
- No more flames?
- It cranks, but does not fire ??
- Questions on Exhaust leak & Compression check
- engine light
- engine problems
- Need help - Stalled car - flooded?
- Instructions for Racing Beat's gauge pod
- Replace the O2 Sensor ?
- Wheel well liner destroyed
- 60,000 service
- turbo xs race pipe
- Non-synthetic or synthetic 2-stroke oil?
- Is she just giving up, won't start need help
- Tune up in Dallas, TX ?
- Driver Front Wheel Squeaks and Viberates at Intervals
- shifter vibrates
- engine replacement?
- Anti roll bar replacement
- replacing brake pads
- Rx8 does not start.
- parking light comes on when braking
- Exhaust
- How to make the car faster-anyone?
- Which wires on Voltage (Battery) Gauge ?
- Got a CEL.
- twin rotary engine?
- RB filter removal
- Can I install Oil Press/Temp sensor on stock adaptor?
- Best gas and best gas station to use
- Glovebox stay damper
- Help please on 04 RX-8 4AT
- confused
- If I change the speedo cluster...
- Putting new plugs in
- Esmeril Racing RX-8 Turbo Kit
- any one here have a custom turbo?
- Front brake caliper bolt size ?
- Exedy Clutch?
- is there any good??
- customizing stock exhaust???
- HELP! power steering loss after sways install??
- Should I join the new engine club?
- Normal operating tempature???
- lightweight flywheel
- 4th Gear Grind - New Transmission?
- anyone have a rx8 manual?? i need help on something
- P0335 CEL and aftermarket intakes
- Oil for Brake/Diff/Trans AutoX
- engine cover
- Seat flex?
- Buyers Beware.....!!
- need some HELP!!!!
- Front Jack point (pic) I dont see it!
- Rotary Volumetric Efficiency Explained link
- keyless entry receiver location?
- Bolt for oil drain plug WILL NOT unscrew!
- Strapping the RX-8 to a DynoJet
- weird feeling clutch
- Stealership ripping me off on door fasteners?!
- How difficult is it to change the starter?
- Not sure what this is, need help at work fast!!!!!
- Can you Siphon gas from an RX8?
- Immobilizer or Key RFID Range
- Adding heated mirrors???
- Tranny bushings?
- Blown OMP
- Which grease do you use for tranny work ?
- Window Clunk
- Request for pics of front cover?
- Best rear oxygen sensor to get?
- Another Fumoto valve q???
- Ignition Coils
- My Sohn OMP adapter is not working!
- Need help!!
- power surge at 7000 RPM
- Inside wheel spin?
- My Car is at 56k and CEL comes and goes...
- rotary engines: advantages
- how good is stock radiator?
- How do I remove o/s wing mirror?
- Help , Headlight Clamp
- Just ordered.
- Mechanic said car needs new coils and wires
- pulse star plugs
- 04 rx8 with some issues
- Removing the door
- Need help finding some parts
- 4th gear trouble
- how to modify stock air box
- Need Help With Interior Air Filter
- pulley sensor CEL??
- Beeping - when turning right
- Parasitic Draw
- Cant get in the car!
- Interior rear panel fastener / clip (not finding the part #) :(
- Thinking of buying this, worth fixing anyone?
- New RX8 Owner w/ New CEL
- Foamy Oil???
- help identifying type of philips head on this screw
vBulletin® v3.7.5, Copyright ©2000-2009, Jelsoft Enterprises Ltd.
