View Full Version : The Tech Garage
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24 25 26 27 28 29 30 31 32 33 34 35
  1. Please Help Please Read
  2. Reverse....
  3. Additional Cooler
  4. Need Help Installing A Taillight
  5. gear overlap
  6. 911!! MAFS sensor information help please!
  7. 192 hp to 230 hp
  8. I dont have an accessory outlet but I....
  9. Rx8 Navi Hack ??
  10. New Engine Losing power in upper revvs
  11. HELP! P0139 question
  12. 2004 rx-8
  13. Can someone recommend a Code reader
  14. Annoying Exhaust Sound
  15. Post-storage problems-- PLEASE HELP
  16. ruff idle only in gear.
  17. shocks squiking exhaust ratle help
  18. headlight adjustment
  19. Moved from hot climate to Michigan. What oil to change to?
  20. Noob with reliability questions
  21. Does the cat just go or does it go slowly (CEL comes and goes)
  22. helllllllllllllp! over heat?!
  23. What are some symptoms that mean its time change my transmission fluid?
  24. New Computer Worries
  25. exhaust problem
  26. Coating on Fog Lights??
  27. front wideband sensor
  28. Transmission Sound...any ideas?
  29. does anyone use trufilter?
  30. rx-8 motor swap
  31. Midpipe without CEL?
  32. Rush morning starts
  33. Dead battery, need to replace help
  34. Check engine light?
  35. 4 x 750CC INJECTOR
  36. "Formula" for power upgrades?
  37. Clutch suggestions..
  38. Would this be my coils?
  39. Rev-i intake query
  40. Friends 07sport feels faster than my 07gt
  41. Mysterious flap in the wheel well
  42. Oil Problem
  43. Check Engine Light/ Reset ECU?
  44. Help Please Need To Know What Light Means
  45. Heater and AC Issues??
  46. *NOT* burning oil... is that a problem?
  47. Failed Inspection!
  48. Problem with "pinging/spark knock/detonation" what ever you call it...
  49. Battery light on extended trips
  50. Aftermarket steering wheel hub adapter on oem wheel?
  51. Royal Purple Syncromesh
  52. Question on Drivetrain Power Loss
  53. HELp check enginelight on...
  54. DSC off & DSC off (7 second option)
  55. Advice on Purchasing Air Wrench/Gun
  56. Anybody use FULL SYNTHETIC Shell Motor Oil for their car ?
  57. Battery terminals oxidation - fixing under warranty?
  58. Spoiler Question
  59. Programming the Smart Keyless Entry Fob
  60. Effects of fuel on oil
  61. Where is best place to get new Clutch???
  62. Rev limiter
  63. Oil change through the dipstick tube using a pump?
  64. Rotor/Pad Install Problem
  65. Renesis Life Expectancy
  66. Engine Replaced at 67k
  67. Strange idle after disconnecting battery
  68. rx8 on the Dyno Dynamics
  69. fuel gauge
  70. multiple warning lights after start
  71. 2004 RX-8 Wont start
  72. Fuel pump cable
  73. Problem with lower control arm front camber adjustment bolt
  74. 13b to a 20b
  75. Rear bumper vent ?
  76. 04 rx-8 going into limp mode off and on
  77. Lost Keys - Anyone do the total reset?
  78. Heating Up
  79. Start Engine button AT 2006 RX8
  80. Um popcorn?
  81. Can anyone run this carfax
  82. What if the L and T plugs are installed incorrectly?
  83. 6port in an 06 AT Shinka?
  84. Spark Plug Help
  85. Condition of my Cat. (pictures)
  86. Power loss from 7250+
  87. CorkSport stainless Steel braided clutch line
  88. Red Line Transmission Fluid
  89. Help, Car Wont Redline!
  90. 0w-20 safe to use with renesis?
  91. DIY cf interior?
  92. Raising the height of the throttle.
  93. Gas Mileage
  94. Installed new exhaust now my check engine light is on! Help?!?!
  95. 04 Rx8 keeps stalling when A/C is on
  96. More Torque?
  97. parking brake adjustment
  98. Temporary loss of power.
  99. Missed a shift -- shifting is rough?
  100. 2004 rx 8 15000 miles, should i get extended warrenty
  101. Intake vacuum lines
  102. stored RX-8 for 3 months
  103. Sensitive throttle
  104. DIY request: pulley help!
  105. Screws for under car panel
  106. exhaust flames dangerous??
  107. Changing fog light bulbs
  108. dealer told me my seal blew
  109. On-line manuals- server shutdown.
  110. Clutch and Flywheel
  111. Pilot Bushing
  112. Seriously gummed up intake???
  113. brake rotor stuck...
  114. oil-p gauge?
  115. How to keep engine running at peak efficiency
  116. engile light on is it normal???
  117. 3 rotor??
  118. tire pressure fraud :(
  119. How can I remove the A/C expansion valve?
  120. Pinging 4 Port...Your thoughts?
  121. DIY: Engine Cover Painting
  122. Car Certification (Toronto, Canada)
  123. engine bogging on cold start?
  124. Where is the ECM fuse at???
  125. Breather Mod
  126. How to tell, Rich or Lean?
  127. Installed HID kit and now no pwoer steering??
  128. DSC going nuts
  129. Ram Air Already
  130. How long does computer relearn?
  131. Auto base line DSC and TSC
  132. VVT Turbo
  133. electronics working but cars not turning over
  134. Made my flip key for 04 RX8 for $30.00
  135. electrical problem
  136. How to Change Console Shifter Light Bulb??
  137. engine replacement and spark plugs
  138. time for the 8 to do a tune up, where is the best place I can get them?
  139. Loud Grinding Noise
  140. idiot friend with rx8, many poblems
  141. Failed RH engine mount pictures
  142. Electrical Gauge(s) - Grounding Sending Units
  143. how many parts should I change after ECU change?
  144. How do I know if I need new ignition coil?
  145. CEL P0456 Driving me crazy.....
  146. Car in the Shop for ever, need D1 GT body kit ASAP
  147. ClutCh
  148. quick question regarding spark plugs and spark plug wires
  149. OBX exhaust systems
  150. Vibration after transmission install.
  151. Battery Draining
  152. Is there a TSB or part # for a longer power steering wiring harness?
  153. Drove with loose oil fill cap
  154. Cleaning the MAF?
  155. Other plugs types in the Renesis
  156. Spark Plug Question
  157. exhaust..what is your fav
  158. knock sensor problem.
  159. Cold start
  160. crashed my rx-8 today
  161. CEL light on
  162. no cold air intake for AT?
  163. Iridium Plugs
  164. Technical Service Bulletin work
  165. Mazdaspeed Exhaust - JDM spec (single)
  166. Car flooded (yet again) - No Roadside coverage beyond 50k?
  167. How to fix curb rash?
  168. Anyone with an upgraded clutch experienced this?
  169. Replacing rear O2 sensor
  170. ATTN: Transmission experts, need advice.
  171. DIY sideskirt
  172. i want to put in H.I.D
  173. removing front bumper HELP.!!!
  174. warning light.
  175. Fall is here and Winter is coming! Things to remember about YOUR RX-8
  176. Why didn't I get a CEL, MIL, or whatever the cool kids call them nowadays?
  177. Removing upper dash panel
  178. Calling all welders!
  179. RE: Removing the 9000 rpm limiter
  180. Snapping Noise
  181. Can Anyone Carfax this for me?
  182. 12V outlets not working
  183. OEM iPod adapter
  184. DIY: A clutch pedal your foot will never slip off of.
  185. gas cap holder
  186. Am I missing a spring loaded flap on my fuel neck?
  187. RX-8 Engine Damper?
  188. Constant Flooding from Catalytic Convertor
  189. Cleaning my K&N filter
  190. Best Oil?
  191. Turbo Talk
  192. Constant Stalling at stops... HELP
  193. Help: clutch/transmission problem
  194. Adjusting clutch???
  195. Differences between '04 and '05 and up motor design
  196. bad wheel bearing?
  197. RE7C-L vs RE6C-L Leading Spark Plugs?
  198. Help! I have an array of warning lights!
  199. turboXS exhaust owners, quick question
  200. dealer said it's fine...i say it's not
  201. what do you guys think of my exhaust idea
  202. Who makes the electric terminals
  203. Greddy Profec B ready for the bin?
  204. Warranty over 6 days ago...ABS/ASR lights stays on
  205. Oh forgive me: tranny oil check.
  206. throw out bearing and engin replacement test
  207. Help! Clutch pedal stuck, couldn't shift
  208. Airbag Light Problem - Please help!
  209. A/C Evaporator Core cleaning?
  210. 3 Rotor Idea well 2 and a half rotor
  211. changing spedo from miles to kilometers
  212. High mileage success tips
  213. Racing Seat Installation Help
  214. whirling sound in 1st and 2nd
  215. Clutch Petal Crack
  216. any tips for a rookie ?
  217. coils
  218. How much oil coolers??
  219. Steps for re-torqing?
  220. inside the air box
  221. where r the plugs
  222. DATA LOGGER and AFC...... gotta find it
  223. Warranty coverage ...
  224. Performance of automatic versus manual Rx-8.
  225. Sprint Booster?
  226. Quick Oil Q
  227. you miss me?
  228. Had my 04 MT GT in the garage
  229. Any sound clips of magnaflow exhaust?
  230. rpm range
  231. Motul PA-90 anyone ?
  232. Pulstar Plugs?
  233. Engine Stalled while in idle
  234. What does the 3 intake tubes do?
  235. Golden Oldie... What ECU?
  236. Need Diagnosis
  237. melting cats
  238. Broken rubber hose on RB intake
  239. Should I be worried?
  240. Ryco Oil Filter
  241. rx8 will be sitting in the garage for 6months ??
  242. Headlight Auto leveling problem ? Help!
  243. ECU Removal ?
  244. Please Help Me !!! Problem With Engine
  245. 13b T2 Swap
  246. New owner. Power steering, headlights, and shifting issues ('04 AT)
  247. RX-8 Problems
  248. Help with AFE Short Shifter install
  249. first rx8
  250. 61K New engine?
