View Full Version : The Tech Garage
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35
  1. Rear O2 sensor
  2. Transmission grinding sound when clutch is out
  3. Bleeding and Flushing Brakes on 2007
  4. different years batteries
  5. Engine stutter @ 7000
  6. Anyone use ZMax?
  7. Permanant Damage From Driving With Bad Coil???
  8. AEM intake issue
  9. Engine Oil for an HOT and HUMID Island
  10. Very compelling synthetic oil test
  11. SRMotorsports Claims?
  12. kcackling/chirippy noise @ cold start/acceleration..?
  13. engine flooded problem :(
  14. Stock cooling fan CFM?
  15. Need help - rock hit a/c condensor
  16. Gas cap cover problem
  17. Spark Plugs and Anti-Seize
  18. 2 questions ,please help!
  19. Need to identify speedo wire
  20. air con pollen dust filter location
  21. Finally a TSB for Water in the Rear combination light.
  22. my car doesnt burn oil at all!!
  23. Best way to wire interior light?
  24. Getting Started
  25. Check Engine Light @ 115mph?
  26. Reuseable Oil Filter... yay or nay?
  27. Any Electrical Engineering folks I can bounce a modifcation idea off of?
  28. boosted datalog request
  29. OBX Catback
  30. TPMS gasket?
  31. Storing in summer
  32. Hard start after recall
  33. Fuel consumption measurement
  34. Airflow sensor
  35. car still NOT working
  36. oil filter kinda small eh?
  37. Is my seal leaking?
  38. Comparison of magnetic fuel filters
  39. Can RX8 Rotors be used in series5 or 6 Rx7 13B's
  40. Electrical gremlins and the 6 searches
  41. ...MORE problems
  42. Power loss when outside temp gets to about 70
  43. 2 Questions on 04 RX-8 AUTO
  44. does anyone have the sound for MS exhaust system?
  45. Getting Close to my first oil change
  46. long lost zip file of rotary information
  47. Can they steal my RX-8?
  48. transmission sound
  49. Carputer
  50. How do i put an Amp on my RX8??
  51. Slightly different acceleration after new cat
  52. Engine Temps
  53. Handbrake Removal
  54. FYI: Oil Filter information, comparison, & tests
  55. Screeching sound from Pulleys?
  56. Transmission Fluid Flush
  57. potential problem during acceleration
  58. clutch engagement point vs clutch pedal play?
  59. hydrogen rotary questions
  60. traveling out the country, need advise
  61. Auto Transmission Problem
  62. My very own oil question..(NOT dyno vs. Syn)
  63. Wheel Replacement
  64. Automatic Door locks
  65. whos done water treatment on their 8
  66. Advice Wanted On 8 Faults
  67. Top off oil suggestions? don't know what's in there now
  68. 1st oil change
  69. Phoenix Local Turbo Parts Shops
  70. Oil found in intake
  71. Shifting DOWN into 2nd Gear? Grinding, etc?
  72. oil pressure gauge
  73. Service mode
  74. Need Some more oil
  75. Engine light after removing bumper & install rb intake.
  76. Fuel lines
  77. Speed Bleeder size ?
  78. Start car, revs to ~4k RPM...WHY?
  79. Fan after shut off
  80. Getting my windshield replaced...
  81. Whirring sound at idle
  82. Anybody here tried Castrol GT LMA Brake Fluid b4 ?
  83. HELP!! dealership is ripping me off!
  84. repair manual!!
  85. Where is the fuel filter?
  86. maintenance spreadsheet
  87. my car is dead
  88. Mm.. New engine...!?
  89. Rx-7 plugs
  90. Brake bleeding photo pictorial
  91. weird idleing...then dying ><
  92. Only have 1 master key for 2004 model. What can I do?
  93. A question about the amount of motor oil
  94. Location of VSS??
  95. money coming outa my exhaust
  96. Spark plugs?
  97. Suspension Problem
  98. Thumping Noise Coming from rear..
  99. Removing Brake Rotors
  100. Kilo Per Tank
  101. Electric Turbo - Someone tried?
  102. Replacing the rear view side mirror down-lights
  103. Stock Fuel Pressure?
  104. checking oil when engine is cold...
  105. cooling system
  106. Tranny grinding / canada warranty issues
  107. Spark Plug Analysis Needed (Pictures)
  108. Am I an idiot? DIY for Changing headlights??
  109. Low (civic like) power when its hot outside... WTF?
  110. A/C Help... posted before? Probly... but be kind and help anyhow :-D (I did search..)
  111. Lower MPG right after an oil change?
  112. Where should I start for $2k
  113. Low traction, reasons besides the obvious
  114. 6k bog down
  115. Problem with RX-8 Ram-Air Sealed Cold Airbox Intake System
  116. humming sound?!?!
  117. Coils life span?
  118. Should I? 4206F Recall letter
  119. Valvoline SynPower 10W-30
  120. One more strange noise when car is hot
  121. Homelink reset
  122. weird idle all of a sudden...
  123. anyone use this oil????
  124. Sudden increase in top speed.
  125. "Intake" to muffler- question- exhausted my searches
  126. questions on physics and the rotary
  127. MOP Injection Rate while Premixing
  128. Fan Running?
  129. 75-90 or syncromax
  130. New Catalytic Converter @ 30K??
  131. Help!
  132. Need help choosing tires
  133. Renesis physical dimensions and weight
  134. [Poll] Failed fuel pumps and premixing
  135. Question on an item with front bumper
  136. Airbag light
  137. Clutch or transmission noise?
  138. Oil Change = Rough Idle = Cracked Engine Mounts?
  139. Replacement oil drain crush washer
  140. Is this Necessary. 4speed to 6speed engine
  141. Clutch Question(s)
  142. Oil pressure gauge range
  143. Detonation and the Rotary Part 1
  144. Greddy turbo CEL and possible cure
  145. Noise under the hood when cold starting
  146. How long will the motor last?
  147. warped flywheel???
  148. engine vibration
  149. Cat removal and mileage gain - and one question
  150. got engine mounts changed at dealer
  151. Bluetooth OBD-II tool
  152. Rotor #2 failures/misfires?
  153. Royal Purple oil weight
  154. Terrible AC noise
  155. turbo timer help
  156. 3-stage variable intake manifold
  157. Fan still run even without the key ???????
  158. Sports & standard suspension
  159. Intake Air Temerature Sensor
  160. My Rx8 wont start
  161. A question about how long to drive before parking.
  162. How many injectors in a RX-8??
  163. anyone run more oil pressure yet?
  164. Precautionary measures...
  165. Tuning Question
  166. Reprogramming FOB
  167. front oil seal leak?_)*)&^%##$^&*()
  168. what is a hydraulic transmission?
  169. Weird Dealer reccomendation - spark plugs
  170. Brake Rotors uh? Sport suspension ? Normal Suspension what do i have?
  171. Whir in neutral with clutch out.
  172. strange noise...Cricket
  173. Automatic Rx8 - Horrible Noise
  174. Electrical Issue I Guess?
  175. Idemitsu Racing Rotary Engine Oil 10W-30 and 20W-50
  176. using gas with ethanol
  177. Indexing the Plugs....
  178. Squeaking Clutch
  179. ABS warning light and TCS warning light are on at the same time!
  180. Am I screwed or what?
  181. Test Driving the RX8 today!!!!
  182. Bumper Assembly Question
  183. Amount of oil...
  184. Thermal Reactor?
  185. scanaliser ?
  186. Transmission Troubles
  187. areodynamic tests
  188. Ok, I'm an idiot
  189. Bolt part number?
  190. Need ECU connector pin diagram
  191. Getting Oil Changes Oustide of Dealership
  192. The old flame throwers out the exhaust
  193. Drift
  194. Replace a windshield
  195. Random Leaking
  196. RX-8 Engine Swap
  197. Is my dealer crazy or am i just cheap?
  198. Emissions testing
  199. Possible rough idle issue
  200. 8 not running smooth..
  201. SI-1 Red Line Fuel Additive
  202. rx8 v8 conversion
  203. P0662 SSV Solenoid Fixed ?
  204. Release bearing Info: Is ACT RB091 correct? ACT RB600 list in web is not for RX8.
  205. Safe to buy a RX-8 with the engine/cat replaced?
  206. Recommand your Local RX8 Mechanic!
  207. Coolant Light on Dash
  208. A/C compressor cycles?
  209. vacumn gauge reading
  210. Redline Water Wetter and Royal Purple Ice
  211. Off the line acceleration
  212. Toe-out after tire change?
  213. warm up before shut down or fouled plugs
  214. radiator blows...no warning?
  215. Water Leaks - Inside!!!!!!
  216. rx7 spark plugs in my rx8??
  217. Thick Oil and the RX-8
  218. Gap for AutoExe Wires on MazSport's NGK plugs
  219. 3 Simple to Answer questions and 1 tough one:
  220. Gas Line Leaking
  221. When to replace brake pads?
  222. Mazda Dealership
  223. Bodywork repair and rock chips...
  224. Getting my transmission replaced AGAIN
  225. bad brakes at 13k miles?
  226. New engine after only 1170 miles!
  227. Chirping noise
  228. How to Remove 6 Disc Indash Changer??
  229. Fuel saving devices
  230. keyless has gone on vaca!!!!!
  231. Is this oil in my air filter?
  232. Engine Lite on..Possible Oil?
  233. quick help
  234. I'm lost
  235. Question for people who have had their engine replaced.
  236. Rust - who has it?
  237. 4 Port 6 Port Differance?
  238. 4AT blown engine?
  239. Console lights not illuminating
  240. OBDII scanner damage the ECU?
  241. stupid ?, stock BOV??
  242. STP fuel treatment
  243. Fuel flow during coasting? (scangauge)
  244. reliability
  245. Reversing: chirping or squeelling from engine
  246. Blown fuses
  247. Loss of power in top end
  248. 2004 6-Speed Manual Trans.
  249. Can i download the Navtech manual and other question
  250. Making the oil pressure gauge functional
