View Full Version : The Tech Garage
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35
  1. Any rattles?
  2. 2 Dyno Graphs and the Engine Dyno Graph Compared
  3. Car weight check your door panel
  4. Clicking on turn after hard braking
  5. Opinions on Engine Prelubricators
  6. HP tangent: rich A/F?
  7. Test: RX-8 v.s Mustang
  8. Leaking brake fluid
  9. Rough idle, anybody else?
  10. Has anyone noticed the cap on the muffler?
  11. Where to put the gas cap
  12. Top Speed of my Rx-8 is
  13. Clunking Noise on start
  14. lights
  15. Rough Idling Update....
  16. A/C Cutoff Device
  17. Tech CD info and engine output - DYNO
  18. Clutch Engagement Noise??
  19. how do you install clear corners?!?
  20. topping off your own oil
  21. making the "oil pressure gauge" into a true gauge
  22. Mazda Recall
  23. Dynamic Fuel Mapping?
  24. Gasoline Type to use
  25. taking off front grill?
  26. Oil viscosity question
  27. Warm Up?
  28. Oil additives.
  29. Puddle under my car
  30. K&N Is Finished & Reports...
  31. oil
  32. hp
  33. 13 miles per gallon??!!
  34. Power Steering Noise
  35. oil
  36. Seems that the Major problem with the RX-8 so far is...
  37. Slow cranking of the starter
  38. rotaries: high heat necessary?
  39. Flooding issue
  40. Has anyone ever thought of using AD(Ashless Dispersant) Engine oil to prolong rotary
  41. first gear engagement jolt
  42. Parts Catalog (Microfische)
  43. Number of oil coolers in your RX-8
  44. Weak air flow of climate control system
  45. too much oil?
  46. Shaking while idling?
  47. A call to action!
  48. MPG poll
  49. Removing the driver side mirror / bose speaker
  50. G-Tech pro dyno graph
  51. Supercharge mention in media thread
  52. DSC off...
  53. Frequent tire air loss?
  54. Question from a RX-8 Newbie
  55. OBDII/CAN revisited
  56. Oil Oil Oil??
  57. Rough cold start anyone?
  58. Apex seals lifetime
  59. Clearly definitive reasons for power discrepancy?
  60. RX-8 vs FD, fuel economy
  61. more G-tech dyno results
  62. why im not concerned about hp issues
  63. Compression isssues?
  64. flaking dipstick
  65. Fan running after shutdown
  66. Will higher RPM on AUTOMATIC yield more HP?
  67. Please help with this Math on HP and Torque
  68. Diesel Rotary Engine
  69. Idea for hot autox setup
  70. Automatic gear ratios and final gear
  71. Problem with headlights?
  72. newbie-type ECU question
  73. anyone have 4A performance numbers??
  74. to super or turbo that is the question
  75. 1/4 mile track times.
  76. Just finished dyno'g 2 RX-8's
  77. First oil change.....what a mess!
  78. Best Engine Oil For RX-8?
  79. How much oil are you using?
  80. Dyno on Japanese RX-8 ! (Img)
  81. A thunk and a ticking and more
  82. dyno'd rx8
  83. Oil Metering Pump
  84. Broken Ashtray cover!!
  85. Bypass Oil Filter for RX-8... Advice needed.
  86. Power to the windows after the key is off
  87. Helppppppppppp
  88. idling problems?
  89. I'm happy to report...
  90. Oil change?
  91. Simulated 1/4 mile runs!
  92. Poor gas mileage and low track speeds
  93. RPM related changes and HP implications
  94. break in period
  95. Who's oil filter?
  96. clutch adjustment needed? Wouldn't disengage.
  97. Error on refuelling
  98. Does your RX-8 have a burning smell.
  99. Oil extractors work (sort of) for the RX-8
  100. Specification of tow hook thread/pitch
  101. Is it usual for the car to be so hot...?
  102. Paranoid owner needs advice on noise
  103. Dyno Listing Thread
  104. Is Overdrive gearing incorrect?
  105. AC is always on with floor vents only! WTF!?!
  106. Pics of intake port opening sequence.
  107. Is it necessary to change oil right after break in period?
  108. Any Benefits with 94 Octane Fuel
  109. Power Loss due to ambient Heat (Summer)
  110. Oil Filter Wrench
  111. Updated dyno results - much improvement
  112. gas light on and off
  113. Dyno & Crank HP Analysis
  114. Newbie question
  115. Changing the power assist
  116. mazda changed my oil
  117. Does the stickshift Rx8 sound louder than automatic?
  118. Clutch Info/Questions
  119. Is 9.2 L/100 km hwy realistic?
  120. Hesitation under very light throttle
  121. serious brake/steering problem
  122. Engine Cover
  123. Please explain the chip mapping
  124. anyone elses brakes squeal?
  125. Clutch Noise
  126. I heard the redline beep noise today and I dont have a stickshift Rx8
  127. Tornado
  128. Oil Pan replacement Mazda NA
  129. Average MPG 18.66 w/4417 miles
  130. How long to fix a CEL light.
  131. Kill Switches
  132. Workshop Manuals?
  133. optimum cruising rpm
  134. Can US owners purchase J-Spec ECUs?
  135. Another Oil Topic.
  136. Alternate Brand of 5W/20 vs Mazda brand
  137. A'Pex Integration components for RX-8
  138. Idle Gas Consumption
  139. RX-8 PCM Info / Scan Tool Progress Update
  140. Oxygenated Gas
  141. Harley vs. Kawasaki - I understand torque now!
  142. Missing something on center digital display?
  143. turning off DSC/TCS
  144. For those who crossed the 5k mile mark (give or take 500 miles)
  145. Muffler ground????
  146. drain plug?
  147. Use of fuel additives/cleaners
  148. Japanese DYNO SPECS
  149. Bosch Platinum 4+ Spark Plugs???
  150. Returning The Rx8
  151. Fill me in Please
  152. WOT Acceleration
  153. Seriously: How Mechanically Maintainable? (long)
  154. Lubricants sold thru Mazda dealers?
  155. newbie question... is it bad to redline on 1st gear?
  156. hot exhaust . .
  157. fyi: autoexe exhaust, 1 -2 hp gain
  158. LOW HORSEPOWER and MAZDA'S RESPONSE
  159. ticking while turning
  160. Fixing paint chips (pics inside)
  161. please enlighten me on this subject...
  162. leaning out the engine
  163. technosquare, possible ECU upgrade for the 8?
  164. dsc flashing
  165. Easy to fix fan speed indicator?
  166. Intermittent oil light. I've seen others post that thier dealer
  167. Changing to wider tires.. need advice
  168. Power loss and pinging
  169. Build Date vs Mileage vs Wheel HP
  170. Gritty sound when putting window up
  171. Car alarm goes off by itself! WTF...
  172. engine revs spike 3-4 times before levelling
  173. Official word from Mazda on dyno'ing RX-8
  174. Limp Mode
  175. Factory fill on trany and LSD
  176. my dealer will have my car for a week
  177. Could more active fan help reduce post-drive cabin heat?
  178. Location of ambient temperature sensor?
  179. Transmission Info/Questions
  180. ECU Map
  181. I have a ? about lights
  182. New RX-8 drive: Heat & Noises
  183. Turbo?
  184. question about EL display
  185. Renesis Oil Filter Spec
  186. Floormat Clip
  187. 212 HP at 8250RPM with G-timer
  188. 600 miles
  189. New Engine at 168 miles
  190. for one last time-which is it?
  191. Tuning with Autometer A/F gauge....
  192. Headlights and Condensation
  193. what brand??
  194. Renesis picture from sevenstock
  195. Engine rebuild?
  196. Hs anyone tried a JSPEC ECU?
  197. vavoline 5-20
  198. explain the rotary to me
  199. Coil Packs
  200. Air Filter Choice?
  201. gear noise
  202. ABS light on
  203. Supplementary Water/Methanol Injection!!
  204. Fuel Computers?
  205. Appreciate input on new car arrival: Things I should bring up to the dealer
  206. tec info carbon fiber wings
  207. Smaller secondary injector = more HP?
  208. low pitched whistle when accelerating
  209. A/F Ratios that you are seeing?
  210. Start Button
  211. A/C Condenser???
  212. Gears
  213. engine lock up in rain????
  214. Any chance for aftermarket Larger Gas Tank?
  215. Adding Oil?
  216. Battery Cover
  217. Over-revving engine?
  218. adjust xeonon auto-leveling mechanism?
  219. Mileage Logs
  220. Formulation of Oxygenated Gas
  221. Synthetic Oil, good or bad for Renesis?
  222. More about odometer - request for verification
  223. Does Oxygenated fuel hurt MPG?
  224. Running very rich!
  225. Engine light
  226. low speed driving?
  227. about older model rx-7s
  228. A/F Graph
  229. Fuel Map question.
  230. Mirror Lights
  231. didnt do 1000 mile service...
  232. TCS in the rain
  233. RPM limit when engine is cold
  234. TCS question
  235. Overfill at dealer oil change
  236. Factory Oil Pressure Gauge
  237. Oil light coming on at high speeds
  238. Position of gas pedal
  239. Weight vs performance
  240. Tach pickup on cluster?
  241. Audio system diagnostics
  242. Bell Sound at 6000 RPM
  243. reverse noises?
  244. Strange Engine Nosise At 650 rpm
  245. accessories
  246. Warning - Bad Fuel
  247. Low idle engine noise
  248. rx-8 in japan having same problems as us?
  249. "Special" oil used for break-in?
  250. Fuel Pump and Filter integrated...
