View Full Version : The Tech Garage
- RX8 Manuals
- New reomte FOB
- Side mirrors that autodim?
- RX-8 Gears and Gear Ratio Calculation, anyone know the number of teeth?
- Question about some Dyno graphs.
- Exhaust temperature of RX-8
- My G-Tech Numbers
- improving gas mileage?
- Humity inside rear light
- Cat inefficiency code info
- NASA Laguna Seca March 21st, on sale Now!
- wideband o2 placement
- plastic battery cover
- Brake Squeak
- does your left headlight aim lower than the right?
- Purpose of under-hood lining
- power loss after ??? km's
- replacement engine cost?
- White grease on oil dipstick
- how to make oem cat into a high flow one
- Tranny Questions for the experts
- Starting Car on Small Incline...
- Engine Misfire question
- Stock Intake Problem Leads To More Headaches.
- Its Mobil1 Time !
- is our absorber servicable?
- How to strengthen the engine?
- weird problem in low rpms
- Loose steering - Noise in left/front suspension
- Rotary Guru's please help!
- Anyone tried an electric supercharger?
- Tansmission switch!!!
- 2 interesting concepts
- Evans Npg Coolant
- Alt torque spec
- my rx8 dies at stoplights
- Where can I get the new coil packs @ 25 bux each ?
- How many cfps of exhast does the engine put out?
- Outside ambient temp?
- Gas usage: Throttle and gear differences
- Ahhh!!
- Quick chirp/squeak
- what is the cause of this happening?
- Knock Sensor Procedure?
- 30K service BS?
- Possible to change the Radio Head Unit lighting?
- car pulls sumtimes
- Heater
- Service codes
- Mazdaspeed kit owners pls help
- 1st gear thud
- Bad Clutch Problem ,,Wont go into 3rd gear sometime
- oddities the car dealership wont acknowledge. Help!
- Car wont go into 2nd
- Timing Problem ?????
- remove front fender
- List of parts required for manual conversion
- Car Shuts off Sometime at a light
- Steering feel and looseness
- Ebay 'Power Chip' doesn't work!
- Driving Lights
- Burnt Rubber Smell
- Catalytic Stud Question?
- How do you change after market pulley??
- New Motor
- I want to lube the door locks and hinges, but which fluid is good?
- p0171 and p0443 question
- Engine compression test record?
- Injector questions
- TPMS Light Flashing
- ACT Clutch Lockout
- Need DIY to disable annoying seat belt beeps!
- Long cranking on cold start
- Replacing rear wheel stud
- does anyone know if this have any positive effect on rx8?
- COMPLETE loss of power, I really need help!
- should i be worried?
- Havoline with Deposit Shield...anyone use this oil yet?
- Techron: bad idea?
- Blackstone labs results .... w0w
- Yellowish substance on oil dipstick
- Flywheel install questions?
- Cylinder 2 misfiring?????????? HELP
- synthetic oil weight vs. climate question
- I Broke A Vacuum Fitting! Help!
- Strange sound under gearshifter??
- Changing Plugs
- Anyone ever try seafoam?
- Lowering Seat
- Normal noise?
- 2 Years of Mileage Data
- How do we improve the mileage on our cars? A brainstorming session
- question on TurboXS test pipe
- New guy
- Another new guy question
- Oil Weights for Trans and Diff???
- EGR Valve question
- Spark plugs
- how to check flash version?
- Bumper Damage
- Ordered Racing Beat Screens
- Clicking noise
- Emissions Test
- Car won't start with Fuse out
- One Rotor, Three Rotons
- 15000 Mile Service
- Rx-8 HP (New car)
- Ceramic Clutch
- Meeting with a pole
- Door Rattle-Striker Pin
- Syncro's and shifting
- Engine Light on
- Rx-8 loves drinking oil
- ACT Clutch with its pressure plate
- need advice 6 spd trans grind
- Optima D35 YT battery starting problem... clicking
- Power loss in 2nd gear?
- RX-8 Maintenance
- MOP - Oil consumption factors
- filled over 'full' on oil dipstick
- Car stalls
- brought the 8 in for recalls and rattles, got it back the next day.
- Starting Issues (Not what you think)
- DSC/TCS Beep
- How can I meter/gauge fuel consumption, realtime?
- Oil Seal Blowouts??
- what would you do... if your dealer messed your car up.
- ping from the back ... cat?
- tail light water in it.
- push starting a MT RX8...
- Tray underneath stock air box
- diy request
- Syncro/Trans Repair - who to do it?
- HELP ! Headlight Aiming Procedure
- Dipstick tube extension & new dipstick
- Power rear windows?
- Illumincated Shift Knob -- much brighter than all other lights
- Bad syncro?
- Battery Charging Issue
- just a little insight
- Sigh First Poster New Car
- speed limiter delete
- Thanks to all the DIY posters
- Not all Potenza RE040 tires are equal
- I gotten myself stuck.. anyone help?
- RX-8 Won't Start
- How much vibration is 'normal'?
- 2ng GEN 7 and 2004 RX8
- A little help please!
- Driver side window doesn't work...
- Head Liner info
- RX-8 customizer in Los Angeles
- Custom navigator
- Mixing Oil's after a service ? Can I ?
- keyless key european version
- scratch on headlight
- Had dealer check compression - What's normal though?
- Fuel Cleaner How To?
- lou gerhigs steering?
- Inner fender question?
- Front Door Replacement
- Easy DIY for Flooding
- What exact Brand/type of oil do you use? (NOT A DISCUSSION)
- CEL came on, Same old problem
- Another case of chasing the weird smell... (propane, rotten eggs)
- RX8 Gear Worksheet
- Problem after changing coolant...I know double thread
- rx-8 Throttle body
- Problem with the immobolizer?
- Noticeable change in oil usage.
- which testpipe is better? rx7store or B&B?
- SoCal Dyno Day - RESULTS (19 RX-8's)
- Sirius Install Instuctions
- clutch n exhaust blues
- Steering wheel slightly off center...
- List of compatible oil filters
- 04 stutter problem
- o2 sensor question
- What oil to use?? Royal Purple?
- Which Plugs and wires for my 8??
- New new Floorjack
- drives side window wont go up all the way
- oil change
- How to check/remove coils?
- Fuel cut off switch
- How often to change trans and diff fluid if using synthetic?
- Looking to maintain my used 04 RX8
- Void Warranty ? bcuz of the Aftermarket Intake and I d/c the Vaccum line?
- Is there a new flash?
- Apologizing in advance. new owner. some basic questions
- Compression check results
- Pics: Magnecor Competiton KV85 wires & RX7 Spark Plugs
- switched brand, more MPG
- stock horsepower
- Will a 06 transmission work in 04?
- Sucks, My Tranny's noise is getting worst
- Clutch Pedal Throw Adjustment
- Check engine light P0420
- Spark Plugs?
- Help me out with a part number please
- More sound out of the stock exhaust??
- Seal broke on slave cylinder for clutch
- How to tell coils bad?
- Exhaust noise?
- Speed Sensor Type
- Instant power loss
- please help..center cosole
- Cleaning the MS CAI
- Fog light replacement.......???
- Strange whinning noise
- maintenance = negative effects??
- VFAD Removal ???
- odd....
- DIY Healiner replacement
- Break like sound when starting to move with 1st gear
- Noise when letting clutch out?
- Super LPG RX8 Torque Monster
- Grease leaking from line connecting to brake caliper?
- How about starting hot?
- Rotary Problemz
- Trec-FW throttle electronic control
- sCANalyzer -- use USB or RS-232?
- Missing in second gear only
- Belt squeal after UR pulleys install?
- Remote Start Install on Factory Remote DIY?
- Installing Fuel Pressure Sensor
- Engine dies in the middle of the road
- How do I adjust headlight cutoff (leveler)
- SPARK PLUG QUESTION....need help
- One side of my car sits higher than the other...need help
- Water splashing noise....
- Transmission grinding sound when clutch is out
- Bleeding and Flushing Brakes on 2007
- different years batteries
- Engine stutter @ 7000
- Anyone use ZMax?
- Permanant Damage From Driving With Bad Coil???
- AEM intake issue
- Engine Oil for an HOT and HUMID Island
- Very compelling synthetic oil test
- SRMotorsports Claims?
- kcackling/chirippy noise @ cold start/acceleration..?
- engine flooded problem :(
- Stock cooling fan CFM?
- Need help - rock hit a/c condensor
- Gas cap cover problem
- Spark Plugs and Anti-Seize
- 2 questions ,please help!
- Need to identify speedo wire
- air con pollen dust filter location
vBulletin® v3.7.5, Copyright ©2000-2012, Jelsoft Enterprises Ltd.
