View Full Version : The Tech Garage
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35
  1. Smell when approaching 100mph.
  2. Rotor material
  3. Fill/Drain plug washers part number
  4. SPARK PLUG FOULER & MIDPIPE
  5. Royal Purple Questions
  6. Pre-mix in the RX-8 may not be a good idea
  7. Q: Speed Bleeders versus Bleeder Kit
  8. p0662
  9. Koni Remote Adjustments for Rear Shocks?
  10. Mazda Work Questions...
  11. Squeak when opening door...
  12. Weight Loss: no compromise (except $$$)
  13. RX-8 Idle
  14. rx8 reliability mods (cheap and DIY)
  15. Dark nasty smoke = burning oil ??? (plz help)
  16. Driving lights?
  17. First Oil Change
  18. Richard Sohn OMP Adapter
  19. Steering wheel problems
  20. Metal Shift Bushings?
  21. Is it possible to remove factory installed Sirius radio ?
  22. engine light on. reset ecu everything went back fine
  23. Scan Gauge Problems
  24. For the techies!
  25. Engine temps+A/C airflow from outside
  26. Suicide door stuck
  27. GReddy turbo kit question...
  28. Air/Fuel Meter
  29. I Call Bs On this guy.
  30. 04-05 RX8 TSBs
  31. 12v Hardwire??? Please help me?!
  32. Trick to removing RH motor mount?
  33. Magnetic filters
  34. Magnetic fuel filters
  35. Tyres recommendation
  36. how to replace parking brake lever
  37. Free Streaming Videos On How to Rebuild a Rotary Engine
  38. Tech question, CEL blinking 7 times when car not urnning
  39. Shifter shake?
  40. Drive By Wire Throttle Wiring Question
  41. How MUCH oil to put in?
  42. e-brake light
  43. RX7 sparkplugs for the RX8?
  44. fuel lines HELP
  45. Spark Plug Spacers - Does anyone Run With Them Removed?
  46. Change radio odd frequency to Europe
  47. Clutch pedal funky after turbo install
  48. e brake fault
  49. Retractable Key
  50. My new toys......
  51. Your avg spark plug lifespan?
  52. Switching transmissions...
  53. An RX-8 that won't go?
  54. Diamension of Mazdaspeed RX-8
  55. 04-05 tail lights fit in 06?
  56. Transmission Plug Washer Opinion
  57. Mazda Crackhead engineering at their best
  58. Table saw in my car
  59. Tar under the car
  60. turbo renesis- enough said-
  61. Spare tire mount install?
  62. Cooling fan control kits...?
  63. Dirty Tips...
  64. speed/ rpm wire
  65. Advance keyless entry system settings
  66. Buying a used car, how do I know how much "life" is left in the clutch?
  67. Request: Engine port and intake + exhaust manifold holes.
  68. Whats Wrong?
  69. Nasty sound after startup (it's not the ABS test!)
  70. rough idle, rough ride
  71. Differences between 5MT and 6MT
  72. Advanced keyless entry problems
  73. K&N Typhoon vs. REVI intake?
  74. Black plastic
  75. Do i need the Recall if...
  76. Hear Spinning sound at the rear (interior) when drive slow
  77. I need a car cover!
  78. problem with deflooding.
  79. hard to start when hot!
  80. FWIW: 4206f flood protection
  81. Rotary Tuning for Dummies
  82. QPower Advanced Engine Motor Oil 5w30..
  83. Check engine flashing
  84. AfterMarket Manifold = 3 port exhaust for Auto?
  85. Needed OEM Battery Cover(s)
  86. Heads up
  87. 232 HP vs. 238 HP???
  88. Engine oil
  89. Front Seat Belt in Rear Latch EASY FIX
  90. Engine light and firmware update
  91. Help: How to setup RX8 for Drifting?
  92. When i get up to high rpms and punch it bad stuff happens!
  93. Weight Reduction Practices/Mods
  94. Which Exhaust System puts out the most HP?
  95. Cracking sound of rear axe
  96. Gas Gas Gas!!!!!
  97. Technical question about metals
  98. New Transmission only after 1 1/2 Years??!!
  99. Leather seats install, how to do it?
  100. Won't rev past 6500
  101. Motor Mount TSB
  102. Installing woofer solution needed.
  103. "Marbles/Sand in Can" Problem -- please respond
  104. How to remove the air ducts from the PCM housing???
  105. Everything you ever wanted to know about Motor Oil
  106. Transmission Oil Life: Royal Purple versus Redline
  107. Engine block heater
  108. Drivetrain losses: My RX-8 versus my A4 Quattro
  109. ANy companies making a 20b MSP yet?
  110. Tail Light Removal on 2006
  111. Help! Wont Start
  112. question
  113. tips for sparkplug change
  114. Next Generation technology of RX8
  115. car is not starting
  116. Heater Control Unit Question
  117. Renesis seem to like the cold
  118. Rotary Specific SAE Papers
  119. Do I need to check my spark plugs?
  120. Code P4700 what is this?
  121. Yellow goo in oil...
  122. Stock Oil Catch Can installation needed
  123. air bag lights problem..
  124. P0171 without any problem signs
  125. air scoop?
  126. The white goo in oil fix
  127. Install Woofer with OEM MP3 PLAYER?
  128. doing 30K service myself
  129. DIY Request : Braided Brakeline Install
  130. how do the chatter marks form on the rotary housing?
  131. DTC P0139 - And rough idle
  132. CEL issues
  133. Bad Gas Milage
  134. Mazda ordering a new engine
  135. Loud Pop
  136. Disconnected Hose? Help
  137. engine light is on...
  138. Clutch affects engine note, on neutral !
  139. anybody want a motor?
  140. when to change the ATF, automatic transmission oil
  141. Wheel Spacers
  142. Do you always let your 8 warm up before driving?
  143. A Place for Reading Glasses
  144. CEL Problems
  145. 04 RX-8 Switchblade key and and FOB where to get?
  146. Intermittent power steering going out!
  147. Mazsports coolant mod help
  148. newbi and spark plugs
  149. Possible paddle shift mod
  150. Retro-fit cruise control.
  151. Adjusting ride height on tein coilovers?
  152. RE7A-L or RE6A-L
  153. painting the calipers
  154. Anyone ever install a Valet 561t?
  155. Throttle body cleaning
  156. Engine Light On
  157. grease in tube between airfilter box and trhottle body
  158. Need Help..?
  159. 4AT Air-Fuel ratio?
  160. CFM (cubic feet per minute, ft3/min)
  161. Condensation Scum in intake
  162. Ignition Coils and Sparks replacement?
  163. Bringing my car in for it's first service?
  164. what values cause the pcm to increase fuel pump output
  165. motor mounts and engine trouble
  166. aftermarket horn upgrade
  167. Fiberglass Molding (noob question)
  168. Oil Pressure "Gauge"
  169. running problems
  170. Standalone Wideband O2 Observations vs. Stock
  171. Car WON'T Start!
  172. Rotary Math
  173. Heater blows only cold air
  174. max speed for running stoich with new flash?
  175. RX-8 Manuals
  176. Rim Question
  177. Oil filter replacement.
  178. So I found a piece of my car.....
  179. Need Help!!!!
  180. Crooked Headlights
  181. Car has loss of power...
  182. Cd-changer removal??
  183. Is there such a thing as Clutch not working with certain flywheels ?
  184. Mobil Clean 5000
  185. Dyno Dynamics Chart of my 2004 rx-8.
  186. Replacing Front Grille
  187. BG44k or FP60
  188. Fan still running - key removed
  189. Mobil 1 oil filter
  190. LHD to RHD Gauge POD
  191. what flash is with 06?
  192. Another at the mercy of the a/c amplifier
  193. Gunky Oil Dipstick
  194. Interesting Oil Change
  195. Engine Acting Up Please Help
  196. Po300 Cel
  197. Death of my RP High Flow Cat
  198. 3rd gear synchronizer
  199. REVi intake
  200. Fuel Filler Cap
  201. CEL - Code 1688
  202. Air Pump Noise?
  203. Power Steering Failure
  204. Rear Differential Failure
  205. Well, my water pump failed.
  206. Need opinions on tranny/gear oil replacement interval
  207. Oil sample number nine
  208. AFE short shifter question
  209. Transmission and Differential Fluid
  210. rx8 Sparks & Coils
  211. Key programming question & fog light question
  212. aftermarket MT pedals
  213. RX8 Crash n Burn
  214. Solution to P0171 after 7 months
  215. Starting in the cold??
  216. Idle Quality and Updated Engine Mount Brackets
  217. Misfiring all the way?... -_-^
  218. compass/magnetic field ?
  219. RX-8 Shift Light Install?? help?
  220. Still having Bubble sound when cold
  221. Stainless Steel Clutch Line
  222. ECU Differences - Auto vs Manual
  223. Hood popped open on quick maneuver
  224. squeeky sound at 30k miles
  225. Shock absorber going?
  226. TPMS fix
  227. cost?
  228. Mazdaspeed suspension noise
  229. Need OEM Alignment Specs
  230. Aftermarket clutch bracket/assembly?
  231. Smell in the car when driving 20km and more
  232. Mazda PIDS
  233. Sohn Adaptor...Adjuster Help???
  234. Part number for washer tank pump.
  235. E-85 fuel usage?
  236. How much to replace air pump?
  237. Effects of battery replacement
  238. ECU Circuit Board Pic?
  239. erratic idle in cold start
  240. Floor Jacks
  241. Dealer installed DSC?
  242. Replaced Spark plugs
  243. Trunk interior light Bulb is now 194 ?
  244. Auto Electrical Diagram
  245. Apex Lube Injector Tubes?
  246. Uneven gap between front bumper and hood
  247. How do I fix sloppy drive train?
  248. ECU wiring.. help!!
  249. 3 rotor?
  250. Mileage Problem
