View Full Version : The Tech Garage
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46
  1. NEW Miles per tank RECORD!!
  2. Weird DTC Code
  3. Headlight Problem
  4. Synthetic Oil Life Study
  5. Install Passenger Airbag Kill Switch?
  6. Need Help---please
  7. Switched to Redline
  8. Mixing sinthethic and regular oil...
  9. small synchro tranny problem
  10. Torque-steer and AWD
  11. help needed measuring stock air box outlet
  12. Ground wire, where to install?
  13. When was your first oil change?
  14. Is it ok to use: Seafoam and Fuel Injector cleaners
  15. not sure if this is true
  16. No Beep?
  17. G-Tech Graphs
  18. Dreaded Flooding - Advice Requested
  19. growling noise
  20. Car unstable at High Speed
  21. rattling noise from steering wheel
  22. RPM drop when air-con is turn one
  23. [PICS] My 8 got smashed. What damage was done?
  24. <help> RX8 check engine light - ignition coil
  25. Check engine light flashes 3 times, then goes off?
  26. smoothest most balanced engine
  27. smoothest most balanced engine
  28. My car died...any thoughts?
  29. smoothest most balanced engine
  30. Shop Manual
  31. AFR at idle
  32. 3rd Engine Club
  33. Temperature sensor question
  34. Warning Lights @ Autocross
  35. Activating Keyless Entry Autolock Function
  36. Amazing or hoax?
  37. Using injector cleaner
  38. starter and plugs again?
  39. Blinking VS constant
  40. New TSB from Mazda Australia says mineral oils only!
  41. Stripped brake screw, suggestions?
  42. Does Ethanol Blended Gas Raise the Octane Beyond What is Advertised?
  43. very interesting ?
  44. How often do you change the spark plugs?
  45. Winter gas milage drop?
  46. shift knob question?
  47. Oil Pressure Gauge
  48. New Greddy site !
  49. Mounting changed.... "gluk...gluk..." sound
  50. Mounting changed but... "gluk ...gluk..." Suspension broken?
  51. RL Water Wetter question
  52. Poor MPG/gear oil smell after trans oil change
  53. Greddy Synth Oil ?
  54. ARC Titan Hood Panel?
  55. Possible solution for power losing while cruising on hot climates
  56. cruise control
  57. Stock Euro RX8 CanScan graph
  58. !!! Check Your Plugs !!!
  59. Mechanical Steering Issue
  60. Any have a good way to bleed the clutch?
  61. MAF sensor, mods, and resulting ecu adjustments
  62. RP Midpipe Question
  63. Rough feeling at deceleration in Neutral - Problem with Neutral Switch?
  64. CEL after spinout?
  65. V1 Remote in a 993 tach
  66. A little help please
  67. Longer slave cylinder rod?
  68. Quick Q: Why WOULD I use synthetic?
  69. Recall???
  70. Looking for a photo of the oil cooler.
  71. 10% Ethanol and rotary
  72. Problems shifting into 4th
  73. Redline Oils
  74. High Mileage and Driven in Winter? MUST READ
  75. Who makes the Mazda Oil Filter for the RX-8?
  76. CEL caused by bad gas??
  77. fuel cap hanger?
  78. C.E.L. after clutch install
  79. PROBLEM STARTING MY CAR!! help plz
  80. Question about Grounding the Coils
  81. A/C recirculate and idle smoothness
  82. redline beeb
  83. Engine washing
  84. Bought a 05 Retractable Key for my 04
  85. Detonation Pic!!!
  86. CEL cleared after power-washing the engine
  87. renesis powered diasio claims 255hp
  88. OEM Muffler Cross section or diagram?
  89. Brake pad check list- make sure I am ok
  90. Strange resonance (scratching, ball bearings?) in 3rd gear
  91. HELP - Front Sway Bar Removal
  92. What is the OMP stepper position curve like w Stock ECU & Motec
  93. Is it normal to smell oil?
  94. EPS problem
  95. Testing this week for Rx-8 ZTek Exhaust in Sacramento FREEBIES!!
  96. Am I suppose to be burning so much oil?
  97. pulley install ?
  98. Can't Drift. why?
  99. Same 5W-20 Oil inj very hot conditions? Help please...
  100. K&N FilterCharge to clean Green Filter?
  101. e-85 fuel
  102. Mazda Extends Powertrain Warranty for all 2004-2006 RX8's
  103. 6 ports or 4 ports
  104. Leading/Trailing plugs?
  105. spark plugs
  106. Help, SonyEricsson blue tooth kit
  107. The Tube That Connects to Nothing???
  108. some b-ach backed into me
  109. CEL after specific driving pattern
  110. whats the difference in the 2 rx-8 engines?
  111. 15000 mile service what to ask for help
  112. rx8 Service Manual
  113. Where does your clutch safety switch trip?
  114. Trunk not working
  115. NEEED HELP! 5th and reverse!!
  116. Greddy Full Synthetic Oil ????
  117. Cruise Control Button Relocation
  118. Engine Rebuild
  119. Help- where is the clutch bleeder?
  120. WTB seats wiring
  121. justwondering...
  122. New Flash and Recall/Warranty Work???
  123. Fog light help please!
  124. I don't understand.... (hp)
  125. Why does the rotary flood?... Yes, I searched... want more detail
  126. Need help with belt size, Please helppp!!!
  127. Recall "T" Flash and Roughness Under Deceleration
  128. new to rx8 help
  129. Check Engine LIght?
  130. pls help 15000 service package
  131. Im Getting Traction Control Turning On Out Of No Where
  132. Faulty Gas Gauge / Pungant Tire odor?
  133. Dynoed today before the engine gets yanked
  134. RX-8 service manual available RIGHT NOW
  135. Intake tube diameter
  136. clutch instillation
  137. A "different type" of oil question?
  138. increased tail smoot post recall
  139. changing air filter
  140. anyone have one of these? do they work?
  141. drawbacks of removing the secondary air injector???
  142. will bodykit void warranty?
  143. What are symptoms of rear oil seal going bad?
  144. Gears vs MPG
  145. Advanced Renesis tech
  146. Fan on Oil Cooler?
  147. Ok How Much Did They Screw Up???
  148. Oil cooling brainstorm
  149. Check engine light
  150. Trouble w/5-4 downshift
  151. extended warranty on turbo or super charger?
  152. get up and go
  153. seat heater installation?
  154. New 2006 Rx8 Owner!
  155. Rattles are driving me crazy!
  156. Greddy Profec 2 Boost Controller NOT working.............
  157. Header Brainstorming
  158. what brand of battery is good ?
  159. I hope this is new, to save gas
  160. Pineapple Racing Rebuilding Videos, Now Avaliable free for download!
  161. question...
  162. Measuring & Pouring Premix Oil
  163. Snowboard or Ski roof racks for the 8?
  164. Emissions parts removed to increase performance?
  165. harder starts after "emissions" recall?
  166. flushing injectors??
  167. Differential Kaput
  168. Brake grease to stop squeal
  169. My gear stick is so hot!
  170. Rear View mirror with auto dimmer - Not!
  171. Excessive syncro/tranny noise? Problem??? AFE installed.
  172. Tranny/diff oil question
  173. Drag limit
  174. 2nd gear grind
  175. latest recall?
  176. unichip
  177. do i need to drill more holes for MS spoiler
  178. Help Tranny/cutch!
  179. Cleaning spark plugs
  180. HOW many miles before 1st front bakes replaced
  181. DRL Install in RX-8 (REAL DRLs)
  182. displacment
  183. For all of you premixers out there
  184. Use Mazda apex seals!!!
  185. break in period
  186. Grinding Gears
  187. resetting the computer - Disconnecting the Battery vs pumping the brake pedal
  188. Need Help!!! I Screwed Up My Car!!
  189. Royal Purple question
  190. How does EPA calculate emissions?
  191. Manual Transmission Question??
  192. clutch noise and put some grease
  193. E-brake light is staying on?
  194. Extreme power loss...car basically died this morning.
  195. Rumor regarding long time storage
  196. Zoom44 or anyone. where is headlight TSB?
  197. help: intake install question
  198. Help Revi intake install minus instructions
  199. Flat tire - Will not inflate ?????? :(
  200. Need a Little Help
  201. 55k Mile Clutch
  202. Newbie inquiry on rotary seals...
  203. HELP- Rear Bumper damage after hit & run
  204. 13k RPM rotory?
  205. Price Quote!!!
  206. MT 5mph cruise control
  207. How to check out repaired car?
  208. Weird driver's side mirror
  209. Brake Master Cylinder
  210. New OEM Ignition Coils
  211. Hid Replacement?!?!?
  212. Fender Gills Made Functionable?
  213. "Marbles in a Can" and "Pre-Mixing"
  214. weird sound during throttle acceleratrion
  215. Anyone using or used Lube Control LC20 or FP60?
  216. Computer upgrades
  217. Dealer BS about vac leak?
  218. SoundProofing
  219. *Need help W/ 1st gear*
  220. help with new intake
  221. oil leak from back of engine
  222. review: Braille Auto all-season battery
  223. Coolant drain plug torque
  224. Issues (if any) w/ "free" revving-coolant light?
  225. good source for a switched 12-volt power source under the dash?
  226. Clutch Advice
  227. "Propaney" smell?
  228. No oil cap?
  229. Stubborn Oil Filter: Solution
  230. Exhaust question
  231. Kinetik Batterys
  232. OIL CHANGE: what kind should i buy?
  233. RX-8 recalls...
  234. Need a little help
  235. Smell when approaching 100mph.
  236. Rotor material
  237. Fill/Drain plug washers part number
  238. SPARK PLUG FOULER & MIDPIPE
  239. Royal Purple Questions
  240. Pre-mix in the RX-8 may not be a good idea
  241. Q: Speed Bleeders versus Bleeder Kit
  242. p0662
  243. Koni Remote Adjustments for Rear Shocks?
  244. Mazda Work Questions...
  245. Squeak when opening door...
  246. Weight Loss: no compromise (except $$$)
  247. RX-8 Idle
  248. rx8 reliability mods (cheap and DIY)
  249. Dark nasty smoke = burning oil ??? (plz help)
  250. Driving lights?
