View Full Version : The Tech Garage
- Installing full Mazdaspeed suspension
- Where to buy a new ECU? and how much?
- Questionable Manual Paddle Shifting
- I need wiring for home link mirror
- pcv valve
- SERIOUS problem while driving (long read; PLZ help!)
- Eccentric Shaft Position Sensor (ESPS) B1-27.
- tape on exterior accessories
- clear side markers
- Fuel Starvation Problems
- stealth bulbs
- Catalytic Converter Shield?
- small accessories needed
- motr oil
- catch can on intake?
- confused about oil?
- Another coolant question
- Painted Engine Cover or Side Outlets
- gas mileage vs. oil level...
- Where is the EPS Motor Relay? Help Pls.
- Can the ECU be replaced?
- painted calibers, should i clear coat too?
- clutch Replacement Question?
- Anyone with access to the SAE international tech papers Database?
- IDLE issues..????
- how do u know which flash do u have on ur 8?
- Proplem after Oil change (( 8 is geting nasty on me ))
- Dyno plots: really that bad?
- Water in Tail light
- How long to run Dino oil before switching to synthetic
- gear handle shakes
- Automated gearbox like Ferrari F1
- Will this work
- What size are the stock injectors?
- Microtech Software and Serial to USB Adapter Issue
- how to understand scanalyzer data HELP
- trailer hitch points....
- Air/Fuel Ratio Gauge
- Removing Carbon Deposits
- What does LTFT 7% mean?
- Gear change
- Interesting Idle Vacuum Correlations
- Ever Have the Tach Needle Suddenly Die While Driving?
- Local Dealer: "We replace about one A/C condenser a week."
- Flooded smoke?
- :shocking: Engine light
- Metering Oil Pump and also Oil Pump??? P1688
- My 8 keeps getting broken into
- How to remove door wiring harness clip?
- Punched it in first engaged clutch and BANG!!!
- Possibe cause of low mileage - dying battery?
- parking light rust?
- NEW way to remove your stuck oil filter
- Auto transmission fuel???
- special tool for removing front rotors?
- SEMA Project RX8 Drift - suggestions, comments, etc.
- Need help sourcing a plug
- Replacement for incompetent gas cap?
- Valentine one concealed display
- Engine dying on freeway
- Changing interior dash lights
- Oil Additive for extra lubricant?
- Help: Installed Pulley - Now Getting CEL
- Transmissions
- engine conversion...
- 3rd to 4th grinding...Mazda said everything is fine.
- washer fluid sensor?
- Parking and side marker lights
- i think i killed my rx8..
- Oil question.
- Whining noise debate (please read, responses welcome)
- Help!-Battery
- Battery Dead For not Starting vehicle 8 days!!
- Engine Under Tray + 140 MPH = ....
- Clicking noise
- need advice on brake pads
- Is This Right
- Free Maintenance Schedule 2
- squeeky sounds at idle
- Where can I get a new O2 sensor???
- late oil change...
- MIS-SHIFT am i ok?
- RX-8 book
- Power problems
- 2nd Gear Problems
- 3 MPG extra from different TYPE of gas?
- Spark Plug Question. I searhced. It's about RX-7 plugs.
- replacement for "advance" key for 2006 rx8
- Auto headlights...
- Whats this?
- Driving around without the undertray
- Remote window & sunroof close
- Apex Seal
- Crank Pulley
- Requesting Radiator Installation instructions
- 15,000 miles service necessary?
- drag a racoon underneath car check engine light on after?
- this question is for automatic transmision?
- Dent Repair Kit Opinion
- Anyone try the K&N Oil Filter?
- Shel Helix Ultra 5W40 mixed with Dexelia?
- Oil Cooler Question
- Possible 350z convert to RX-8
- Anyone heard of the Turbonator
- HELP!!Effect on Engine due to Gas Kit explosion
- Control Arm Broke!!!!!!
- Drive-up Ramp for Oil Change
- I add engine oil when...
- The hunt for the drain hose
- Problems with Harrison R&D CanScan USB software.
- some questions about warranty.
- Rear end shudder
- Keep the RX8 or something else??
- Speedometer Calibration
- rain effect on my AEM?
- Help! Settle this debate....
- flash news flash
- 91 oct required for 2006?
- Help Please, Check Engine Light Problem
- Transmission Diagnosis, Any Guesses??
- Problem getting into 3rd
- loose bulb in tail light
- Were to connect to Comfort-CAN Bus?
- whats the best kind of intake for the 8?
- heat shield Advice.
- Maintenance done besides what manual states
- Check engine light?
- Imported RX to Canada
- Intake manifold?
- Tach wiring in Cosmo powered RX8
- New Cat, Same Problems. HELP!
- MS CAI Water in Intake - CEL!
- In the shop again
- rebuilds
- wheel bearing/brake dragging vibration?
- what the hell did I break.. what does it do?
- changes over the years
- Problems with transmissions?
- Shit..... need some help on my A/C
- Need Feedback
- I need some clutch / trans guys to help me out (hand controls)
- When was your last Gear/Rear Diff. Oil service ?
- Weird cooling fan issue...
- Unknown features and questions
- Misfire CEL
- dented fender - will paint match?
- deciding if i should get 1
- where do you fill up? and what octane do you use?
- override security ???
- SR polley install "help"........
- Tranny and Diff. Fluids
- exhaust question
- Where is the DSC button located?
- How long should the OEM shocks last on this car?
- Oil and Engine
- clutch threshold question
- Auto Transmission like a cement mixer!
- HELP!! Post-Jiffy Lube problems...!!!
- Equivalent fuel consumption of Renesis?
- Factory engine oil
- engine help
- What is this vacuum line connected too?
- Disengaging The RX-8
- Keyless Entry Programing
- Anyone know anything about keyless window control?
- Octane booster? Yes or No?
- *Mazda Module Programming* software screenshoots.
- strange idle issue - any ideas?
- Request: Tail Light Lens Cover Replacement HELP
- Gas spilling at fill up
- Front o2 sensor broke. what are the effects?
- Reliability of the RX-8 rotary?
- help! MS CAI install
- HELP!! alternator stuck...
- What happens to the airbag system with seat removal?
- CAI discounts
- stock engine... how much boost?
- starting issues
- MS clutch kit upgrade Q
- More "Marbles in a Can" Observations
- Oil Temp
- Help ~ DCS\TCS light won't go away
- Questions about the New Flash.
- Got MYSCAN RX8 database?
- which rx8 to modify ?
- Help with the simplest thing
- Do Blackberrys and Macs work with a CZ??
- M/T Ecu connector pinout
- Is there a DIY subwoofer thread?
- Metal rotary oil cap too hot for gasket?
- Flooded Engine
- RX-8 downloadable manual
- What is behind solid front grill?
- anybody know what part this is??
- help broken stud from replacing flat tire -what is the part called that I need ?
- Coolant level light on & off. Bubble in water tank when rev.
- Another scan tool option Auterra
- What are my choices for obdII/can scan tool ?
- Fuel System
- help with code 3305-g campaign
- interceptor-x question!!
- Noob Question on Bumper Removal
- Quick Filter Cleaning Question
- Question, and yes I've searched.
- catalytic converter
- HELP! short shifter dilemna!!!!!!
- spark plugs and new fuel injectors?
- 12V other than lighter + ash tray light
- F/S MicroTech Interceptor
- ? about Water Wetter
- Idle Roughness Fixed With 5W-30?
- Grit On Tip of Dip Stick (Seeking advice)
- Looking for some part numbers....
- Inner tie rod failure
- ?? reset ecu after install intake ??
- Air Box Split?
- Redline
- Rusty Welds On Sub-frame?
- questions after installed intake
- AT synthetic fluid recomendations
- engine flood ??
- Exhaust question
- Air Conditioning AC Worries
- Are check engine lights stored even if you clear them?
- DSC switch
- Navigation DVD-ROM
- UK V US Spec Cars Oil Change Interval
- Laptop or Pocket PC
- if your car vibrates and its not the mounting?
- Tach Sweep on Starting - Flash indication?
- Brake squeal problem fixed with new tsb.
- After market radiator caps
- Clutch warranty - how long
- C.A.R.B Restrictions
- Vented hood - How to prevent engine&intake being soaking wet?
- Premix & Tail Pipe Soot
- Fuel efficiency drop
- alignment specs
- Why 6MT 250HP and 4AT 210HP
- RPM rises in gear
- Brake pad size for MT 2005
- 2004 getting new engine
- Can-scan
- Loud humming noise at high rpms??
- "Womp, womp, womp" noise...
- Vacuum leak
- What i need: 4AT to 6AT
- Theory about oil in the air box and filter
vBulletin® v3.7.5, Copyright ©2000-2012, Jelsoft Enterprises Ltd.
