View Full Version : The Tech Garage
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46
  1. ECU clear/reset - what are the numbers 01, 02, 03, "on" and "off" display?
  2. New Rx8 owner
  3. Remote won't program
  4. Idemitsu Rotary oil
  5. Loss of power ?
  6. My Rx-8 is making strange sounds from the engine bay.
  7. push start buttons
  8. tire pressure
  9. Purpose of the 4 rubber gromets
  10. !!!What are the best mod's for the Money!!!
  11. High pitch noise from engine????
  12. Can anyone make a copny of the dvd rom for me?
  13. Rear Mid Mount Rotary Concept
  14. Possible overheating?
  15. newbie to RX8...maintenance questions..
  16. check engine light
  17. 2 booring RX8 Noob questions....
  18. "R" Flash( How can you check?)
  19. Rattle at high RPM's
  20. Installing Midpipe
  21. How dose the saddle gas tank work?
  22. 6-cycle engine patented by founder of Crower cams
  23. Sludge in oil with less than 1,000 miles
  24. Replacement of Stock Exhaust System.
  25. ??How Much Turbo??
  26. Mirror Disassembly help request
  27. Would an RX8 bellhousing bolt right up to the Miata 6 spd tranny?
  28. Can you paint ROTORS when painting hubs?
  29. Dealer incorrectly re-installed my Axialflow Shifter
  30. How the %&¤$£@ do you remove the generator pulley?
  31. How is the DSC/TCS recognized by the ECU?
  32. !!@#!@Turbo or Supercharger!!@#!@
  33. Lighted dipstick hole?
  34. RPM warning buzzer
  35. Mixing Fluids?
  36. Need Help !
  37. Catalytic converter went out in a blaze of glory
  38. Tach/ECU/Battery problem?
  39. Vents in trunk?
  40. tapping power from rear accessory plug
  41. Radio gauge display
  42. Another Oil Post
  43. Body Q
  44. Best Intake For the RX-8
  45. Thinking of Adding a Resonator...
  46. annoying noises...anyone got a clue???
  47. Dead Acceleration Spots
  48. New owner - A/C question
  49. 250 BHP Jap / 230 BHP rest of world
  50. Steering feedback
  51. ECM/ ODO info needed.
  52. Stainless steel braided hoses for the hot summer days ?
  53. Where to get clear corners
  54. Grinding when starting
  55. Synthetic oil Q - Is it like a normal oil change?
  56. my grounding kit results
  57. Head lights
  58. Ceramic internals, what do you think?
  59. Transmission Fluid
  60. Very High Oil Consumption
  61. windshield
  62. Power signal?
  63. What is the lowest octane an RX8 can safely use?
  64. How to approach service with ignition problems
  65. Auto / AC climate control (extra consumption)
  66. Torque specs for Wheel Hub
  67. Traded in my AT for a MT.....Loving it!!!!!
  68. break upgrade opinions..
  69. oil grade and type
  70. Vfad & kn
  71. Make your own shortshifter
  72. Looking for a DIY for brake bleed/brake fluid swap
  73. Installed new shifter bushing - problem
  74. Vote For Sopranos or Gotti
  75. Genius idea to prevent flooding!!!
  76. wiring harness and airbag light
  77. After flooding RX8, what to do with sparkplugs???
  78. Flooding question
  79. Why wont my 8 shift?
  80. side mirror defrosters for touring RX-8
  81. Valentine 1 Or Passport 8500
  82. RX-8 Problems need HELP!!!
  83. Fuel Injection services
  84. Request DIY Greddy Emanage Ultimate
  85. Installed new airbag light still on??
  86. Odd noise when changing gears???
  87. RX-8 breaking in (Tough Method)
  88. Exhaust Pipes
  89. Hypoy???
  90. Cluch noise
  91. gas pedal catching
  92. Car flooded Mazda Fixy
  93. Auto Exe Carbon Fiber Front Lip
  94. Underdrive Pulleys: Who has them? Comments.
  95. Anyone tare down a rotary after extended Synthetic use?
  96. Start Engine Problem!!
  97. New Owner Question?
  98. Another Flood....
  99. low oil preasure no start dead at work
  100. Do I really need to change brake rotors together with pads?
  101. Tach Signal?
  102. Puzzled by fuel guage graduations !
  103. request DIY Canzoomer
  104. why dosnt the RPM drop when the air comes on
  105. Japanese Market Trans difference?
  106. screw pattern
  107. Starter question
  108. Excessive fuel burn to light up the Cat?
  109. tranny & diff fluid
  110. Brake Service
  111. Sputtering?!?!
  112. Gas question that hasn't already been asked.
  113. Question about PCM Flash level (Yes i already searched)
  114. Quick Question - AuxMod install
  115. Finally changed 'em...
  116. newb to rotary, quick question
  117. octane usage
  118. JIC Install issues
  119. Turbo
  120. Loose a little coolant get a new engine
  121. Q
  122. Quick question about rx8 GS
  123. Heat/Thermo wraps?
  124. Engine Oil Viscocity
  125. Calling all DIY writers
  126. How long for Clutch + Flywheel install ?
  127. I used fully synthetic oil I need help with information?
  128. VDI failure...? any1 else?
  129. New starter motor, K&N, grills
  130. How accurate is the mazda usa website?
  131. upgrading suspension, what else to replace?
  132. Strange light problem
  133. Where to order OEM Oil Filter Online?
  134. Use G2 paint for caliper's?
  135. 2 time gearbox has blown ??? NEED ADVICE!!
  136. MAF Location
  137. Diagnostic Connector
  138. Checking CEL
  139. cannot clear NVRAM
  140. Ecu Maps
  141. 110 octane
  142. Hey... I'm getting a Mazda
  143. Vibration
  144. TPS and speedometer wire locations
  145. New to rotary
  146. How install a defi control unit II
  147. Gearbox ratios
  148. Buzzing Sound over 7K RPM's
  149. huge prob with rx8
  150. Big problem with my 8! please help me!
  151. Problem with my RX8
  152. Passenger seat height/angle
  153. Alignment question
  154. has anyone done this?
  155. Strange engine noise...
  156. Remote Matching
  157. Is it okay to grossly overfill the engine oil?
  158. Engine bogs at 5k with CEL
  159. need help with aem cai
  160. Flashing engine light after leaving the dealership in my new RX-8
  161. Matching Remote to RX8
  162. What exactly does Callifornia emissions do????
  163. Changing Coolant
  164. ACT ProLite Flywheel, one peice?
  165. Airbag light
  166. How to make car talk to me like Kit?
  167. Flashing your ECU..
  168. Mazda replacing spark plugs
  169. Mazda Responses on Issues/Problems
  170. Member of the "New Starter" club
  171. CEL and cleaning MAF
  172. Radiator fan control
  173. Center Console Creaking
  174. recall on cat converter?
  175. I did a Gtech Road race run yesterday here are the results
  176. A few issues...
  177. Can someone id these ducts?
  178. Replacing Battery on Keyless Entry Remote
  179. Location of stock horns?
  180. condensation in the taillights
  181. High Beam Lights
  182. RX8 and valet parking
  183. under hard acceleration trouble shifting into forth gear
  184. shifting from 1st to 2nd
  185. Film and Foggy Headlamps
  186. Racing Beat Ignition Wires
  187. Checking coolant...
  188. Lost the Air Pump
  189. Back door not opening!!!!
  190. Why is automatic MPG higher?
  191. $*$*$Stock Mods$*$*$
  192. Mazda does not recommend synthetic oil for RX-8
  193. "Free" factory-scheduled maintence: does it only cover oil changes??
  194. New Gas Mixture and gas mileage
  195. Clicking sound on full lock turn
  196. Recent Repair
  197. Sea Foam
  198. Vibration at 100km/h
  199. My AFR data log
  200. Rear Oxygen Sensor specifications (avoid cat cel) ???
  201. 2004 Remote on 2005 RX8
  202. Did I just void my warranty?
  203. Am I okay? (Tranny Oil)
  204. engine rattling noise
  205. Mazda RX-8 Performance Packages
  206. Revi Duct and Stock duct pictures
  207. Cleaning battery terminals
  208. Royal Purple 20W or 30W
  209. Engine Light!!!
  210. RX-8 going down?
  211. Replace spark plugs at 30 months with low miles?
  212. Listen to this!
  213. Front end diagram
  214. questions about rotors and displacement
  215. Combo Switch Wiring Harness "Pins"
  216. anyone use GM syncromesh in their tranny?
  217. Cargo Net Install Instructions?
  218. regarding jack stand and lift points
  219. 5th Gear syncro gone
  220. 06 rx8 has less horsepower...
  221. Synthetic Oil
  222. Transmission problem: Pressure Plate or Syncro? HELP
  223. any one know the part number for Purolator oil filter for the 03~06 rx8?
  224. grinding in reverse please help
  225. Easy Nav Mod
  226. Need part #'s
  227. Speed senor
  228. Oil Changes
  229. Size of Oil filter, does it matter?
  230. 13b-rew swap?
  231. Yellow Box
  232. How to adjust head light height?
  233. Good (& Cheap!) DIY RB Ram Air to OE Box!
  234. normal oil pressure?
  235. Coolant Change HELP
  236. Plastic airflow cowling from the bottom edge of the front airdam?
  237. First gear gets a hard knocking
  238. Exhaust pops past 4 and 5 rpm
  239. How many horses would a light flywheel free up
  240. I Need A Wire Diagram
  241. [QUESTION]Problem w/ 05 RX8
  242. intake issue
  243. What limits the redline in a rotary engine?
  244. Where to buy 02 sensor?
  245. How long does original clutch last
  246. Conceptual Idea: Traction Monitoring
  247. What is the little white cap with an "H"
  248. exhaust spring washers
  249. Agency Power Under drive Crank Pulley - any good?
  250. Where is the torque Sensor?
