View Full Version : The Tech Garage
- Tire Pressure Light Wont Go Off (Help)
- VFAD missing = Warranty Voided
- Watery break sound.. anyone knows???
- HELP!!! how do i turn DSC back on after completely off???
- What is "flooding" really?
- 2nd gear problems
- Dyno
- HELP!!!Need new ECU Cover
- Changing Spark Plugs
- Brand new car, already has 1-2 gear problem!!
- Midpipes
- Oil "cream" concern
- stock oil
- Oil Issue!
- Best Way To Spend 500$
- will this be covered under warrenty?
- Rotary Work in Pittsburgh Area?
- Oil advice
- P0420 Catalyst Problem ?
- Pain in the Ass rattle in Pass. Door!
- New RX-8 Owners should know.....
- Whom should I believe? or Whose noumena is more real?
- rx8 froze
- car shakes and makes rattle noise...
- spark plugs!!! question plz help!
- Post-REVi Fuel economy report after 2 Tanks
- Car shutting off whening turning steering wheel...
- Which type of coils in the RX8?
- Smells like burning plastic!!
- P0171: System too lean
- clunk noise - coilovers or RB sways?
- Engine coolant light coming on @ cold start
- CEL after bumpy railroad xing
- Diag. Trouble Code look up
- A wonderful article on dynos
- Steering, Breaks....
- Transmission Oil
- watchem scratch there heads as they try to dyno!
- Engine/Tranny oils.. ugh
- stock exhaust ?????
- Exhaust installed but a little moisture?
- while getting my car dyno'ed
- Squeaking in front suspension when cold
- What would you do? Changes to Renesis...
- Worse Gas Mileage In cold????
- 5th gear trouble
- My car doesn't have 50/50 weight distribution!
- Rx8 electrical shop manual
- How reliable is this sensor chip?
- [RIP] Clutch/Pressure plate
- Red line transmission fluid= greatest thing since sliced bread
- Jet Air Nozzle and Oil Metering Pump
- Need to take her in - what should I have looked at?
- Tranny problems..
- Pulleys.
- RX-8 Owners manual
- Bad Throw-Out Bearing
- someone help?
- Stock shift knob
- changing the oil filter
- How to get louder neeee/zeeee noise?
- p0420 cel
- What Does P7000 Mean?
- How do you check for flash/ecu version>
- i think i broke it?
- engine coolant light
- K&N drop-in filter at Amazon.com for $30 shipped
- Flashing CEL
- Damage from bottoming(sic) out...
- Cold air intake
- Mobil One: An Interesting Endorsement
- PARTS ID Please
- Sirius Radio
- The best filter & Header
- I'm really sorry I'd to ask this
- Stock Injector Specs?
- help mazdaspeed
- warm up your car without starting it.
- Machining Rotors?
- Flooded a two months ago, should I still take it to the dealer?
- 6 speed transmission potential
- Remote Not Working Right?
- Ground Wires??
- New Starter / New Sound
- rough idle service??
- Changed Fluids in Car Today!!
- J&R Autosport. NY area
- Dipstick question
- Noise from gas tank
- First service. 1 inch more in dip stick.
- Dirty oil??
- Clutch Adjustment Question
- Caution!
- High Comp Rotors
- mazdaspeed wing
- Oh No.......pls Help <sos> Dsc And Abs Lights On
- Getting my 8 back from 2 weeks in shop
- Nuts and Bolts...
- 24000 miles engine light just came on....
- How many miles do you get out of a Full Tank?
- engine warm-up: how long do you wait?
- CEL codes and battery dying
- Setting up clutch-pedal
- Found these while cleaning...
- How to install FOGS on base model
- speed limiter
- Wiring gurus, I need some assistance!
- Squicky noise when clutch is untouched
- Lowbeams question......
- funny smell
- CEL Question
- oil cooler drain
- swap idea, ms6 2.3, thoughts?
- Problem w/ Fuel
- new flash out?
- Power Steering Problem!!!!!!
- Kinda wierd for the cel
- Ltft
- VFAD Solenoid Valve
- my odometer was rolled back, what should i do?
- Daytime Running Lights?
- where is the knock sensor
- Turbo gauges
- Gearbox Noise changing into 2nd
- DSC and traction lights on
- Should I or Shouldnt I??
- TPMS Light error?
- Removing the air pump?
- Difference between RP race and normal oil?
- Air Injection Pump
- Oil catch can
- Annyoing A/C on in most modes fix
- Cruising RPM?!
- 5 gal royal purple help
- "Run the Piss out of it." - to fix hard start.
- Mazda Air Filter vs Competition
- 87, 89, 91, what's the best fuel?
- knocking noise
- GtechPro Works???
- Engine mass and CofG data anyone?
- Exhaust
- Midpipe CEL questions
- 231 RX-8 with can't rev pass 6.900 RPMS in 6 gear
- Why does my M/T move forward in neutral?
- Grinding/gravelly sound in 3rd/4th gear...
- Buying a used RX-8, questions.
- Please post DIY for thermostat replacement.
- Wont rev over 6RPM on cold start
- Running in - does the car 'help'?
- Talented Rotary Techs Wanted
- Pennzoil Platinum Full Synthetic vs. Quaker State Advanced Q Full Synthetic - Input?
- won't start
- Schedual 1 vs Schedual 2 maintence record
- Moving to Europe
- Which state of tune?!
- How does the fuel injection system work?
- Oil consumption
- 2nd gear problems when cold
- My dealer yanked out my PCM out of my 8 today...
- Leaded fuel
- non working remote lock
- Lucas 2 stroke Oil
- Royal purple reccomendations
- AT shifting / slipping
- Evil Idle
- The "Mazda" logo on the front/rear...
- Jackstand Positioning...
- Hard start solution ! Fixed today
- GReddy oil filter relocation
- Fully synthetic brake fluid no good?
- Speed Limited
- RB cold air system with stock airbox?
- #@%$ help
- Check Engine Light
- Weight of Stock RX8 Parts
- Dynoresults: power problem!!!
- Need help from Dyno/Auto Math Experts
- Where Can I Get Oem Foglight Brackets?? Help Me Please
- Broke side view mirror
- CAS and Spark Plug Clearance
- Nasty Smell
- Why get Inter-X when MicroTech is cheaper?
- How does DSC feel like?
- Collapsed Motor Mount/Vibration
- Developed Backfires
- Changed tranny fluid, differential, and engine oil and filter.
- can the coils be relocated?
- Tranny and Diff Fluid swap: Gotta take it to a mechanic
- Help With Parts!!
- sludge in dipstick.
- Need Radiator Help
- rx8 engine swap
- Locked in Reverse
- Damn Potholes!!!
- Renesis sounds different when you start it up after being off for over 24 hours
- repairing body damage - need advice
- New type of Rotary engine??
- Help!
- Motor oil for Rotary engine
- E85 fuel mix for the RX-8
- Stalling at start up
- Fuel Leak Problem
- Top speed
- is my car wierd.
- My Tach did something weird...
- Doesn't this seem kind of pricey?
- RP high flow cat clogged
- battery
- possible way to increase idle speed?
- What is this. Push Start? I want it. help please!!!
- Tcs ?
- Trans & Diff fluid change = CEL... Why?
- Replaced battery, now low battery light comes on..
- RE8A-L NGK plug
- Absolutely necessary to resurface front rotor when replacing brake pads?
- Got the new starter and plugs today
- Renesis performance shop in New England
- Airbox Help
- Differential growl/rumble
- Cruise Control and navi screen install
- Mazda is addressing a problem!
- Borla: To weld, or not to weld. That is the question...
- transmission fluid change
- If buying OEM brake pads, specify package WITHOUT HARDWARE
- Air Razor and Magnetic fuel ionizer
- Clutchswap?
- Rattling noise after cat swap-HELP
- Clutch and Steering
- What My chances?
- Flywheel w/ internal counterweight?
- No DIY Exhaust
- An alternative way to turn on and off the headlights
- Mazda serviced at 15k miles
- Help
- Type E
- Is there a way to drain the oil from the oil coolers?
- Brand New RX-8! Mod me!
- Do I need an O2 Simulator
- Induction kits
- Took RX8 To Straight Pipe, Lost All Torque... Now What?
- Remove Steering Wheel
- Towing behind an RV
- First time bleeder
- adding oil
- What if? Random Renesis/Rotary Thoughts
- more HP without Turbo !!!
- trick to remove black plastic clips?
- what is wrong with my car?
- Apex Seals -Question-
- Fuel consumption
vBulletin® v3.7.5, Copyright ©2000-2012, Jelsoft Enterprises Ltd.
