View Full Version : The Tech Garage
- Weird cable
- TPMS batteries
- Natural Power Gains
- Fan short-cycling...
- Clutch engagement point
- What brand of oil do you use??
- Weak Start? Just Add Oil!
- First Service. Any suggestions?
- New RX-8
- Need help with Under body panel
- Help! Where is the RPM signal pinout?
- Post-Recall: My idle is going crazy!
- HELP : What kind of Ignition System? DI or Regular Wire System?
- Removing rear trunk panels
- Passed smog with Revi and borla no problems.
- Covered Underside?
- Cooling question?
- Our 6th Gear Ratio of 0.84 - why not lower?
- 2005 RX8 recall
- rev beep
- I have no warranty, so what about recalls?
- Brake Light Keeps Coming on
- Really, how weak are the diff and tranny?
- Dealer didn't do recall!
- Oil Consumption Oddity...
- "S" flash?
- Airbag Flashing any one knows why ?
- What happens when an Apex Seal fails?
- Remote Start Help
- Turbo Timer Problem-need help
- possible result
- size of oil line banjo bolt?
- Racing seat and state inspection
- heads up display
- RX8 Japan Specs Low Power 210HP 5SPM to 250HP High Power
- Too much Oil
- Installed Midpipe & no lights on
- o2 sensor wire colors?
- Grinding noise from my car
- Anyone familiar with the renesis Intake manifolds?
- front end quarter panels
- new rims/suspension cause warning light up
- What is the best turbo timer?
- Clutch problem. Possibly the throw-out bearing.
- Went in for Recall... Found out I have been on R Flash since 7/7/05!
- Fuel Cutoff
- double clutching
- Midepipe cel problem, fixed!
- HELP!! emergency
- anyone need a motor?
- Drive by wire
- upgrade to HID
- Transverse mounting a 13B/Renesis
- FD RX7 front brake calipers
- Tool to push in rear brake caliper cylinders?
- Not one part of thermal recall performed!
- can I put a flowmaster 80 series on my 8??
- Spark Plugs with turbo
- Turbo Timer Question
- Cracked OEM 18" Wheel
- DSC Indepth
- Spark Plug Cleaner.
- Paqrking light flash when u lock car?? well....
- mazda rx8 lpg conversion
- best miles per gallon: 27.175 mpg
- TPMS removal?
- clanking noise from underneath that won't go away!!!
- how to jack up the cars onto the jack stands? HELP HELP!!!
- oil cooler fitting size
- Hood Release Cable
- AC Condenser Damage
- my 8 is sick can you help?...
- NE Gasoline Quality (Not Octane)
- Just got my car back from the recalls, what flash is this?
- How to tell when was my flash updated?
- Another one of my insanely long exhaust tech articles
- How Many New Engines Done---SURVEY
- Stock air filter removal
- Glass-Fibre/Wool packed mufflers
- Greddy Turbo Timer Help!
- fluttering rev counter & popping at idle
- Complete Workshop Manual FREE
- HELP- REVi=gear grind according to dealership
- Oil Viscosity
- Newbie on Maintenance Issue
- Lossing Power Steering?
- What is this part for?!
- tires on right side wearing down faster than those on left side
- Questions You would liked answered from Mazda folks at 7Stock this weekend?
- Torque specs for rear suspension
- Transmission Damage
- Synthetic oil - Another one
- Want a long lasting high mileage Renesis?
- Auto tranny fluid
- Service problems with Koons Mazda
- [Pics] Changed the Plugs
- My gift to all of you!!!
- Oil Pressure sensor
- Anybody have DIY on Side Flares?
- Buyers Remorse Laws
- Shut off Procedure For Stock RX8
- Warning: you may want to reconsider powdercoating your cast wheels
- radiator fluid help
- Why only 200mp/tank consistantly?
- What's that vent in the trunk for?
- RX8 Cruise control Max Speed only at 102Km/h
- Should I change the oil & oil filter @ the first 1,000 miles on my new RX-8?
- 5 speed rx8? wtf!
- Do Flowmasters Sound Good On An Rx-8???
- Can't shift out of 6th gear
- Driving without oil cap for 2 weeks!!!!
- FRUSTRATION (white climate control connectors)
- Wide Open Throttle
- Lub Oil Additives
- Rough Idle, Plugs and Wires at 35k Miles?
- Starting Problem (don't think it's flooded)
- Why 5W-20? Isn't that TOO thin?
- Infra-red pics of RX-8 in operation?
- Claimed VS.Observed WHP (RX7-RX8)
- can you?
- Tools required for Flywheel install.
- Just bought an 04 RX8!
- Stock Fuel pump flow rate?
- 3 diffrent super charger in development for the 8 that you may not have seen yet...
- Tips for Winterization?
- When do you rx8 dudes change your oil?
- Can't see Emanage wires
- Engine flush???
- I Just Did Research Here: How Necessary Are AC Condensor & Oil Cooler Guards/Grills?
- Flash Question
- 3305G Recall stickers? Needed or not?
- top speed
- Anti Freeze Fluid?? What Kind ?
- 1st gear vibration??
- I'm way to afraid to start my car
- Question about 4.777 final gear...
- Possible Wrong Flash help
- RX-8 Exhaust sound level
- 4 ports and 6ports RX8
- Engine reving before shutdown?
- cat-less midpipe CEL trouble
- No A/C = Less vibration / studdering at idle?
- Noise from my engine compartment
- HomeLink GENK40 rear view mirror
- 7500K HID bulbs......
- AirIntake
- Gear oil
- Front Lip/Splitter Rods??
- 5500 rpm stutter
- Interesting Motorcycle Break-In Technique: Run It Hard
- Cold Air Intake for 04' RX8
- AIRBAG TSB - Finally!
- What is green and coming out of my 8?
- Exhaust for 05 RX 8
- Car idles at 800 rpm
- What controls boost levels on a turbo setup?
- Oil coolers
- Creaking seats
- What would cause my compressor to cycle with A?C off
- Transmission Warranty
- A History of Violence
- Starting problems
- Renesis revving above 10k RPM?
- Drawing of Audio CONNECTORS
- TPMS installation instructions
- How the heck do you remove the third brake light bulb?
- Why do we need bearings?
- Did R-Magic make a plasma direct ignition?
- Cruise Control Wonky
- Oil Change, Transmission Flush, Alignment
- Motul
- Specific spark plug question
- Xenon to Halogen
- C.E.L. Code P0456
- Changed transmission fluids at 30k service.
- Texas state inspection- no OBD II data
- synt oil observation
- Driver and passenger side mirrors
- Trans & Diff Fluid Change to Royal Purple
- Which Size(lbs) Jack and Stand?
- Where Can I Get Formable Thermoplastic?
- Anybody heard of this?
- List of great online stores
- Oil Change
- Tire Pressure Indicator Light
- Intake sizing for rotary motor
- How long to install a flywheel and clutch pack
- does anyone have a custom midpipe?
- Drove RX8 at Zoom Zoom event- Clutch much softer than mine!!
- general battery question
- where can i get exhaust flanges???
- Just bought an 8, have a quick question
- Does the rotor have to be shaped like it is?
- Experiment: Changing Intake Port settings
- Just Dynoed - 180 hp, no mods
- White "goop" in oil
- Above 3750 rpms doesn't open Secondary ports at light load
- 2 SparkPlug Defoulers in O2 sensor and STILL have CEL!
- Strange Behavior??
- No start AGAIN.
- Boost controler help!!
- Whdn do you first change your tranny oil??
- Quick way to change oil filter???
- Charcoal Canister
- PCM Replaced
- WARNING About Dieseling
- engine swap
- Anyone else have the same issue?
- what oil is in the car when you buy it?
- question about flywheel
- Another tranny noise thread...
- RX 8 mods
- Spark Plug and Wires Install?
- Avoiding having headlights ripped out- park against another bumper?
- And the dealer says.... (roughy idle cause.)
- Aftermarket amp or LED bulbs causing ABS light???
- Building a 3-rotor 13B, possible?
- Adjusting Low Beam Headlights
- XM NavTraffic
- Hooking up an Air/Fuel Meter (o2 sensor location?)
- Any porblems with remote starters on AT
- Thinking about a Speed6 to Supplement the Rx8
- CEL after changing spark plugs?
- Dirty Spark Plugs
- Gas!?
- The RX-8 Dyno Results Compilation
- Interesting phenomenon...
- Let's Tuning a Little Bit
- Mustang GT vs. RX-8
- Question about 2 rotor potential
- Disabling the tire pressure monitor
- strange noise in 6th
- RCA Splicing?
- QUESTION: APEXi Super Ground Stabilizer
- power steering light
- interior room
- Electronics Glitch?? Remote unlock lights
- Very toxic smell in cold/warm starts...
- Mazda Speed Pin out
- 2005 Application Guide for RX-8
- break in period
- NAV screen interference
- Being towed to Dealership... won't start... Flash while there?
- oil deal !!!!!
- 6th Gear PROBLEMS
- 110 leaded, not good
- navi
- steering wheel not centered
- How to remove the rear license light cover?
- fixed pinging sound
vBulletin® v3.7.5, Copyright ©2000-2012, Jelsoft Enterprises Ltd.
