View Full Version : The Tech Garage
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46
  1. Another Transmission issue
  2. Guys With tranny problems please stand up
  3. Proper rotary etiquette
  4. Shorter clutch?
  5. help with footwell light wiring
  6. Any slow starting when hot?
  7. Axial flow short shifter
  8. RX-7 Engine Swap
  9. a/c enhancement: Ice32?
  10. does your rx8 backfire?
  11. HEEL TOE aids?
  12. air filter
  13. what's a good aftermarket sparkplug?
  14. Fuel filter replacement
  15. Radiator Fan on..
  16. Brakes squealing again -- After TSB
  17. rear/front guard help
  18. What is the wattage of the fog lights?
  19. The muffler installation
  20. "R" Flash TSB doc in PDF?
  21. Fixing midpipe rattle?
  22. Filling oil, Synthetic or Non Synthetic??
  23. Engine cuts out at high RPMS
  24. Disposable Oil Funnel
  25. Redline Water Wetter.
  26. all lights went on
  27. While at the dealer...
  28. drilling hole in throttle plate - solution to rough idle issue?
  29. Battery conenctors
  30. I was on a dyno day today
  31. 20b
  32. New Plugs
  33. Insulate Fuel Lines
  34. Radiator flush ?
  35. Performance chips on eBay
  36. Observations with a External Wideband O2 Sensor
  37. Rattle in rear driverside door
  38. Brake fluid flush
  39. New Mazda Recall?
  40. what is the operating temp of the renesis engine
  41. Just had a major problem
  42. Catalytic Converter Max Temp
  43. Please help me sort through all this recall noise!
  44. Turbo Timer Install Guide....
  45. Knock sensor
  46. Rx8
  47. 3-rotor Renesis Engine Question
  48. Front end "clunk"
  49. Why is it so?
  50. Is there still multiple fuel maps on open and/or close loop since the latest R flash?
  51. Something Strange...
  52. Messed around with intake, car sounds different now...did I break something???
  53. rx8 center console gets boiling
  54. I Discovered Why Low Mpg And Low Hp
  55. R Flash charts on my 8
  56. New Flash and recall (Not another recall thread)
  57. Flywheel ??? Need info pls.
  58. preparing for a road trip!!
  59. Wrong oil @ dealership????
  60. Can I safely jump start RX-8?
  61. RX-8 not currently available
  62. Car wont start... help?
  63. LOUD chirp when A/C turned on
  64. Can I cut the Start Engine (white/blue wire)?
  65. Engine number
  66. grinding when down shifting!!
  67. Can you swap GT headlights into the GS model ???
  68. Spongy brakes
  69. 1.6l?
  70. Where is the main TPMS unit?
  71. Where is the speed sensor located?
  72. No Oil Consumption
  73. shock sensor
  74. Clicking Noise when Braking
  75. Metal shavings in oil?
  76. opening air filter stock box
  77. Parts diagram of front/underbody?
  78. Alert beeping & electrical motor running??
  79. Problem with my 8
  80. Need to label wires on my wiring harness - what will stand up to the heat?
  81. Frame dimentions. For those with workshop manuals
  82. Oil Leak Between Rotors
  83. 4th gear!!! GRR CRUNCH
  84. Cold Air Intake
  85. Slick50 (and other additives) for the Rensis?
  86. Engine light = +gas mileage?
  87. Clicking sound from motor
  88. Car Stalled Twice Yesterday Once Today!!! Any Ideas!
  89. oil drain plug
  90. Scanalyzer
  91. Battery
  92. Loss of power past ~6500 rpm??!!
  93. Belt chage
  94. Shock Sensor Rattle
  95. Does your A/C do This?????
  96. Not the Usual Break-In Thread
  97. Oil in the Air Filter !!!
  98. Key(/fob) coding didn't work!
  99. Transmission Fluid.... 2 Quarts and still not dripping!
  100. I Invite You All To Call Mazda For A/c Problems Important Thread please don't move
  101. got my grille replaced
  102. Did anyone here get their transmission problems fixed???
  103. hi or lo power RX8
  104. 10,000miles 250hp???
  105. New flash beyond the "R"?
  106. What is this plug for?
  107. Engine cover????
  108. Torque vs HP
  109. Amisol Oil
  110. Fuel Injectors???????
  111. Is the 5W20 "Requirement" Just EPA Strong-Arming?
  112. Engine Failure/ Oil Type Link?
  113. flawless emission test...virtually 0
  114. Black on Tailpipe
  115. FYI: Don't try baking your headlights...
  116. Canzoomer forum?
  117. BEST replacement batteries???
  118. Are there gas tank problems with the RX8?
  119. Engine Dampers: Would our 8 need this?
  120. Why does my oil pressure gauge always read the same
  121. 30k service ???
  122. Fuel Injector Cleaner
  123. Compression Test on engine with ~19k miles
  124. Ethanol in a rotary?
  125. Using LEADED gas?
  126. Brake screeching HELP!!!
  127. My tranny has left the building
  128. Cz Connection help
  129. Measuring the engine oil temperature??
  130. How to : Get dealer to flash PCM
  131. When Does Your Gas Light Come On
  132. My Void Warranty.
  133. CEL question
  134. ****Quick Diagnostics Checklist****
  135. Well.. I hope I'm not the first to do this.. (left car running after a short move!)
  136. Road test of 91 Shell vs 87
  137. Driver side leg room area and center console - WARM
  138. Motor Oil ?????? What kind is best?????
  139. 97% Japanese?
  140. Recall Fuel
  141. getttin dyno'd today
  142. Seal Failure
  143. Oil pressure?
  144. Weird Observation
  145. Compression test question for you guys
  146. EPS problem.....
  147. Fuel consumption, HP and MAF voltage
  148. Engine problem! Help!
  149. Blocked Air Vents?
  150. Miles so far...on the RX8?
  151. Cracked windshield
  152. cigarette lighter broken?
  153. R Flash Made Huge Difference
  154. Interceptor X EMS?
  155. VFAD Questions....
  156. Decarbonizing @ 14k miles
  157. getting recall done today.....
  158. Drianing Oil Cooler
  159. Rattle in Tranny
  160. I hear a "symphony"
  161. Need a little help...
  162. Don't know what to do?Big problem
  163. clutch drop while not fully engaged
  164. HELP - Where is the lower control arm bolt
  165. Paranoid about DSC/TCS
  166. Rotarygod's rotary oil tech blog
  167. Help I have a problem with my power steering
  168. Obtaining Workshop Manual
  169. hey guys i need to adjust the level of the HIds how do i do it
  170. Shifting From 1st To 2nd
  171. Stock Wideband O2 Sensor - Can it detect the full range of AFR?
  172. This worries me alot, TRanny issues can have something to do with synthetic oil
  173. Weapon*R Oil Catch Can
  174. CanZoomer Air/Fuel/Ignition controller?
  175. mazdaspeed parts
  176. Is it possible to install REVi without the box?
  177. gear hopping
  178. Am I burning oil?
  179. Looking for an RX-8 car cover
  180. Eibach spring problem?
  181. Remove Volume Knob?
  182. wow...
  183. A/C compressor cycling too often?
  184. Confused on ECU upgrades.
  185. Simple Question
  186. Concerned about oil check
  187. Official A/C Thread
  188. Just got GTech Pro
  189. Oil change before or after?
  190. Parking light flash w/ remote help
  191. Brakes Squeaking?
  192. Electrical Flood---Help?
  193. Royal Purple Oil
  194. Trunk open
  195. Car died need help
  196. Best motor oil
  197. help with dipstick reading?;
  198. From 145 to 188 RWHP on Mustang Dyno
  199. Oil Change
  200. Removing lower seat cushion for the back seat
  201. General question about the ECU
  202. Security Indicator
  203. Oil light question
  204. New 8 Owner with some General Maintenance Questions
  205. The great spark plug debate....
  206. The "warped" brake disc and other myths
  207. Observations in Reverse - MT only
  208. Where are RX8 parts shipped from?
  209. special Ground wire
  210. ethanol fuel
  211. rip in leather....
  212. Transmission Questions
  213. Engine Light StaysOn
  214. swaping engines...
  215. Heat/AC temp control / air mix actuator (restricted part?)
  216. clucking sound
  217. Clicking sound from Clutch
  218. question on parking
  219. Good results on latest Used Oil Analysis
  220. Swaybar Install Post-Mortem
  221. help!! installing brake pads
  222. polished or chrome OE brake calipers
  223. Synthetic Oil???
  224. Engine + moisture?
  225. Gas guage problems
  226. Installing DSC after market?
  227. Coolant for RX8
  228. Spark plug anti-fouler O2 trick for CEL with no cat?
  229. Anyone here use CANSCAN???
  230. dyno problems
  231. Side Vents - once and for all
  232. Does everyone's oil look this dark after 3k miles?
  233. What are TPMS Sensors ?
  234. Anyone else having trouble being smooth with the DBW and Shifting?
  235. Optima Yellow Top D35?
  236. Modifying Typhoon I
  237. Read or reset Odometer
  238. Diamond back battery cables
  239. Gas Info
  240. rattling, clanking sound???
  241. 30000 mile service recomm..
  242. my fuel tank recall experience
  243. Mustang Chassis Dyno Help
  244. Vacuum reading at idle?
  245. Windshield spray level
  246. Grinding transmission, want to change fluid but....
  247. engine stalled a few times today(WTF)
  248. Crazy stuff happen to my 8
  249. Help! Need part numbers and diagram for front strut bar
  250. Sun Roof Rattle
