View Full Version : The Tech Garage
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35
  1. California emissions
  2. Adjusting Pedal Throw
  3. Installed my lowering springs today..!
  4. Suspension upgrade to reduce wheel hop?
  5. Flooding??
  6. Quest for N/A powa!
  7. A little RX8 front end trivia...
  8. size of o2 sensor?
  9. Check Engine Light
  10. Tranny break-in period?
  11. Better gas mileage at higher rpms, true or not?
  12. Another gas mileage thread...with a twist
  13. Light warning light ?
  14. Newbie Post!! Oil ?
  15. GM SyncroMesh Trans Oil
  16. Keyless Entry Fobs Question
  17. Car No start, FLOOD? rolling start procedure...
  18. Revving engine to 3000rpm before shutdown???
  19. What's the magic word for N flash?
  20. Wds
  21. Help
  22. shift light doesnt come on
  23. Turbo timer - do they work with PATS?
  24. Oil question.
  25. Crooked Headlight aim
  26. Car stalled twice and is misfiring at idle after warmed up
  27. Stock Cat.....gutted?
  28. New twist on Rotten Eggs Smell
  29. Newbie, With Lots Of Questions
  30. RX8 6MT engine power drop off at 5250 RPMs
  31. checking cel
  32. I know this is a long shot but...
  33. RX8 Owner Documentation
  34. New Rx8 Owner
  35. new transmission, anything i should know
  36. Speed Cut
  37. Tranny Oil change
  38. Water in foglights
  39. Aftermarket Exhaust, Problems with Smog passing?
  40. Occasional 'popping' at idle
  41. ECU Tuning
  42. Is this normal?
  43. Updated CANScan!!
  44. shift knob removal
  45. Dipping out the back....????
  46. Just cleaned my MAF and wow!
  47. diff fluid change gone bad...advice needed
  48. rumor about electrical problems
  49. vibration at idle = cracked motor mount
  50. Cat-Back install question
  51. Squeking when braking
  52. Mazda didnt screw my rotors back in.....
  53. Possible DIY: Flip Toggle Switches
  54. suddenly lost power
  55. Fog light lense Cracked
  56. mazdaspeed shifter need help
  57. engine cover
  58. What oil filter do you use & where to buy?
  59. Time for oil change?
  60. Squeaking in the engine?
  61. Skinka Difference
  62. Idle vibration and only 1800 miles???
  63. Power Steering Loss :(
  64. Question about ABS
  65. Help me get to the air filter please.
  66. New "P" flash??
  67. Identifying clutch problems
  68. brake squeal
  69. Just got back from the Dealer
  70. Mobil 1?
  71. Gas and oil consumption
  72. Possible to undo N flash
  73. Low octane power boost
  74. Help on Clutch Throwout Bearing Part No.
  75. Using TSB's
  76. Too Much Oil...
  77. Mobil Clean 7500 Semi-Synthetic 5w-20
  78. Found the Cricket Sound
  79. Disconnecting headlight washers
  80. ok, has anyone done an msd or other aftermarket ignition yet
  81. Legal Question Regarding Flashes
  82. Questions about the Fumoto Engine Oil Drain Valve
  83. which strut bar?
  84. RB flywheel and clutch w/pressure plate?
  85. why does my oil light keep coming on?
  86. Confused dealership
  87. Electrical problem after sway bar install
  88. First Drive
  89. driving ? idk if this is the right section...
  90. when acelarating i sometimes hear a knocking???? help
  91. Installing dry sump on Renesis?
  92. Factory ECU - Anyone crack it open and see what processor it uses?
  93. REVi= check engine light
  94. HELP! Removing Stock Exhaust Pipes off the Stock Muffler Canister
  95. car is lower in back then it is in front
  96. LED Display Tripping out when its hot outside!!! HELP!!!
  97. Oil change at dealership and they went to Pennzoil
  98. Help installing side areo flares
  99. Very good article about the WDS
  100. Choking on high RPM's
  101. RX-8 Brake Pad Replacement
  102. $500 burnng hole in pocket
  103. My clutch is getting to be rock hard...
  104. Another Dealer Visit
  105. Okay to put jack stands here?
  106. 15k Service 240$! Reasonable?
  107. Help with screws
  108. Over filling Motor Oil will damage engine?
  109. what does campain sticker mean
  110. flywheel, balance, seals, bearings?
  111. another rotary design . .
  112. Passenger Airbag disablement
  113. So they tell me I need a new clutch...
  114. Spark Plug Confusion
  115. transmission noise?
  116. Are fuel injector cleaners needed with rotaries?
  117. Is a aftermarket oil cooler a must on 8's?
  118. Question about flash
  119. best oil & filter for the 8
  120. help what flash do i have?
  121. Bringing Car Into Dealership list everything!
  122. Protek R
  123. have some wierd sounds?
  124. My A/C is not cooling Is 54 degree's to hot
  125. Too Much Oil?
  126. 5th gear
  127. Got 'P' flash and new pads today
  128. Thermostat questions
  129. Eibach Pro-Kit Actual Lowering Numbers
  130. Loud bang whenever I turn the wheel
  131. Oil question.
  132. Mystery rubber piece???
  133. Best price for Spark Plugs....
  134. Need new brake pads... help with install, choice!
  135. Advice: Jump Starting RX-8
  136. Check Engine Light - What?
  137. please help me what is it?!
  138. Red Line Oil - St Louis Area
  139. The king of Dino oils, Which ones number one?
  140. What recalls should I know about?
  141. clanking noise when i go over bumps?
  142. Gas pedal makin' noises...
  143. Turbo Timers and Flooding
  144. Cryogenic Freezing and a possible Solution to the MPG problem
  145. Grinding... how terrible?
  146. Need Advice - Painting Calipers
  147. Newbie - question on the Shinka's
  148. Quick tune tips
  149. How does it zoom? And, just the facts...
  150. Found a good product for carbon buildup
  151. headlights
  152. Clutch - Flywheel vibrations
  153. Ignition key not turning
  154. Clutch Pedal Sticking?
  155. Flashes, MOP and auto trannies
  156. clutch and flywheel questions
  157. what in the world is it? please help
  158. Too much coolant bad?
  159. Replaced head?
  160. AC Noice
  161. I don't believe this.....
  162. RX8 Workshop Manual
  163. 30,000 miles engine flooded
  164. Idle Issue - Swings Back & Forth
  165. Whistle unresolved after dealer visit...
  166. HIDs and High Beams
  167. Got A CEL yesterday..
  168. Cold Starts - Is the issue solved?
  169. Royal Purple Transmission Fluid
  170. Bleeding the heater core?
  171. hood dent
  172. Battery Part Number help needed
  173. Just installed my RB oil cooler screens
  174. Eighth oil sample
  175. sr motorsports ram air
  176. Photos in the DIY forum
  177. Water temperature and fan efficiency observations
  178. Throttle control scheme....
  179. Actuator valve in A/C
  180. HIDs "bounce" over harsh bumps. Is this normal?
  181. udp help
  182. URGENT - Help needed with Undertray
  183. Reconnecting the battery..
  184. Reverse gear problem
  185. Where to you install the intake mod?
  186. Hessitation at green light
  187. WARNING - Screws fixing undertray get lost
  188. buzzzing noise coming from throttle body...
  189. Reverse popping out or gear
  190. groan
  191. some assorted tech questions, max tire size, max rpm, fi options, camber
  192. engine whistle sound??
  193. Need Interpretation of invoice
  194. When DDSC fails?
  195. GAS Mileage analysis??? by Mazda???
  196. Check your plugs and wires
  197. 13b-msp cmf?
  198. A/C or other fan on, after engine off
  199. Question about what brand oil to use
  200. Dyno Results
  201. canadian cold weather start flash=much better gas mileage
  202. canzoomer stage 1
  203. extra clip from brake pad DIY
  204. Problem with a lugnut
  205. Flashs?
  206. Rubbing noise / Steering wheel feedback at high speeds
  207. Why a wide-band oxygen sensor on the RX8??
  208. Melted Plastic got on the bulb HELP
  209. mush on acceleration from light
  210. Noise while setting in netral with foot off clutch
  211. Just got a new MAF and wow!!
  212. what really works to fix the AC
  213. Use 5W-20 for CA RX-8 or sythentic? or super sythentic
  214. what oil should i use in CA, 5W-20, Sythentic, or super sythentic
  215. Question About the SSV, VDI and APV ?
  216. Oil in the Gas Reduces Octane
  217. Help with brake pads replacement!
  218. Dear Holiness HELP ME
  219. Will the greddy univ. speed cut controller work on my JDM 8
  220. tiniest wankel
  221. Engine Replaced - Break-in Instructions
  222. Just how different is 91 vs 87 octane?
  223. RP SUPERCAT : emissions
  224. I hear fart sound over 5k
  225. wierd problem
  226. Help with engine codes
  227. Just purchase RB AC Condenser and Oil cooleer Screens
  228. How do I install Headlight Bulbs H7 ??
  229. Where does the condensate from the A/C go
  230. Leave Pass seat & air bag out??
  231. coolant merky...
  232. battery dies fast
  233. What does TEST ON mean in the odometer?
  234. Changed out my clutch, still stiff... help!
  235. Mazda Is Killing Me!. Need Your Help!
  236. Leaving Rx8 garaged for a while
  237. Velocity Performance Module
  238. New "R" flash is out
  239. Does my car not make the advertised HP?
  240. damn, stipped nut...
  241. ignition wires
  242. To ALL downshifting GURUs
  243. Removing stock ECU for standalone?
  244. Traction Light On/off??
  245. ATTN: GReddy Turbo Kit owners
  246. General question about exhaust gases and cats
  247. Almost crunchtime to install SR extreme clutch package... scared?
  248. Any thoughts on Nology spark plug wires?
  249. too much oil
  250. Cleaning frequency for the K&N filter
