View Full Version : The Tech Garage
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46
  1. Maintenance for low driving miles
  2. Gas Mileage.l..Again
  3. HID Conversion Question
  4. 250PS (Asian) vs 230PS (EU) please distinguish mechanical differences
  5. Life of original battery
  6. Outside Temperature Gauge Problem
  7. Ignition Schematics?
  8. RX-8 Powertrain
  9. 3K oil change in Puerto Rico? Why?
  10. RX8 weight??
  11. Using the Fan not the AC?
  12. Red Line Oil
  13. Stolen Keys - A question/Rant
  14. update for legal clutch problem
  15. Oil level question
  16. Quaker State "High RPM" Motor Oil?
  17. Speedometer Calibration
  18. Japan Flash?
  19. Cold Start in Warm Weather?
  20. Block heater -- that's interesting
  21. 18" rims against pavement holes?
  22. Engine and Cabin Air Filters
  23. cel oil metering pump rear o2sensor
  24. Long Term Effects of Gear Grinding?
  25. Is there a Helms manual out yet?
  26. Installing High Power APV motor for the air intake system
  27. No More Motorcraft at Wal-Mart?
  28. Scheduled maintenance costs?
  29. O2 sensor fooler?
  30. RX8 Rack-and-pinion steering
  31. RX8 seventh oil sample
  32. 15,000 mile service necessary??
  33. Stock Muffler W/Test pipe or Hi flow cat w/o resonator
  34. Direct Fuel Injection for Rotaries?
  35. Anyone know of 200+whp STOCK RX8s? I saw one today...
  36. Oil and Plugs
  37. Oil Burning issues
  38. help - SR Motorsports intake
  39. Winter Weather Driving
  40. we don't need no stinkin' oil filter wrenches
  41. Oil Change
  42. starting up in cold weather
  43. Smoking
  44. DIY Question: program key from streetkeys.com
  45. Rear fender access
  46. Sunglass Holder Foam dislodging
  47. X-Men Shifting sound
  48. Looking for: Renesis HP/Torque Curve
  49. eManage support tools re-written, alpha testing anyone?
  50. Was at Sears last night....
  51. New Starter Available Soon?
  52. The Rotten Egg Strikes
  53. Clutch Install
  54. Question on replacing/programming a new key
  55. HKS fan controller possible to connect to RX-8??
  56. (No) oil pressure gauge?
  57. Gas Mileage / Oil Level Correlation?
  58. latest flash
  59. After she sits in cold weather?
  60. Series of problems leads to new engine
  61. TPMS Questions
  62. Fuel Injector Cleaners
  63. High Octane?!
  64. K&N Typhoon™ Air Intake System
  65. DynoJet on untuned Canzoomer stage 2
  66. Air Filter Dilemma
  67. What to do with multiple charger cables?
  68. "N" Flash and ening rattle @ 6k
  69. stock intake port location?
  70. Thermostat questions...
  71. HID's?
  72. Lets get some thoughts here..
  73. problem with 4th gear
  74. 30k service
  75. carbon fiber drive shaft
  76. Uneven Tire wear Problem
  77. FYI: MAZMART (in Atlanta) has 3 Renesis motors available
  78. Lastest PCM N Flash - More Power?
  79. Which Optima battery is a direct replacement?
  80. Suggestions for Minor Performance/Fuel Economy Upgrades
  81. TSB - 91 Octane ????
  82. charging my battery
  83. Transmission Shifter
  84. AC condenser is NOT COVER under warranty !!
  85. SS clutch line
  86. bought used RX8 + need info
  87. Installing new HIDs?
  88. Have you had to add Coolant yet?
  89. HID lights
  90. Rear View Defrost
  91. rx8 warranty
  92. How to Remove a Stuck Oil Filter
  93. Projectors?
  94. Oil Change Question
  95. clutch problems
  96. HELP?!?!?!?! Modifications?!?!?!?!
  97. break in
  98. aftermarket flywheel
  99. Backfiring...?
  100. Questions about RX8
  101. Borla and warranty
  102. Has anyone every seen spray rubber or aerosol rubber in a can?
  103. tire size
  104. HP vs torque
  105. Scratching noise from engine
  106. Differences between 4 port ECU and 6 port ECU?
  107. pucked clutch?
  108. Really important question!
  109. Problem after DIY key programming...help!
  110. is the free maintenance transferable?
  111. Should i buy an rx8 w/ 80k miles?
  112. Laminar flow to reduce intake turbulence?
  113. Oil cooler grills install... distance from oil cooler itself?
  114. LCD not working....
  115. S.o.s. !!! !
  116. Maintenance & Warranty
  117. Oil Cap Fell Off
  118. Another question about jack stands
  119. Got some new stuff today
  120. Odd Delay After Shifting
  121. twin oil coolers
  122. Rear rotors held on with what???
  123. How much brake fluid?
  124. Durability of the Rotary
  125. Compiled List of Specs
  126. cruise control retro fit
  127. VFAD question?
  128. This, that, and '05 key fob...
  129. DIfference b/w hp?
  130. RX-8 Modified Starter!!!
  131. How do Pulleys Help with HP
  132. Aftermarket alarm system and Power Steering
  133. how many times
  134. Power Window adjustment? Wooshing sound.
  135. To fix or not to fix...
  136. Not the normal missing HP quesiton
  137. Dsc
  138. Transmission Pan
  139. drive belts..?
  140. Oil question
  141. Starting up your car
  142. How often should I change the oil?
  143. Trouble installing springs. Need Help!
  144. 10k to spend!
  145. Tire Pressure Monitors
  146. Rotary Shop in VA or MD?????
  147. First Post- Need Some Info
  148. Sound after turning car off
  149. Mixed engine oil?
  150. question about tranny
  151. Drive by Wire Throttle - Accelerator Pedal Question
  152. Anti-freeze
  153. Center housing port sizes and flow
  154. has there been a resolution to the engine noise
  155. red house on dash?
  156. Can anyone thinkof a way to adjust our idle RPM?
  157. Under carriage bracing vs. sway bars and end links?
  158. No oil, did i damage my engine severley?
  159. Oil level when starting
  160. My car idle problem
  161. I have water in my oil what now?
  162. Holding the Odometer Needle before crank
  163. Is this oil filter one of the better ones?
  164. Discuss: Virtual Exhaust System
  165. Question about the Racing Beat oil cooler screens
  166. my dyno charts
  167. increased accleration with lifting throttle?
  168. Which works better.....
  169. K&N filter in RX-8
  170. Green vs. K&N
  171. My car wont start ><
  172. HID Install Help
  173. ripping from were nav should be to rear seat opening
  174. fly wheel installation help!!!
  175. Help, need a picture of the clockspring
  176. 14k and a check engine again?
  177. false oil warning, has any one else experienced this?
  178. Painting the muffler?
  179. Racing Beat intake
  180. Why Shinka?
  181. Best way to clean spark plugs
  182. Tech Highlights CD
  183. Water Wetter
  184. Engine cover necessary?
  185. Quality of the stock OEM spark plug wires
  186. Reusable oil filters
  187. Red Line tranny oil question
  188. DIY request: installing a subwoofer
  189. Make mine just a half an oil change please
  190. seeking ECU info
  191. What's Striped Zone?
  192. getting ready for rotary revolution please help
  193. Electric Assist Steering controller
  194. The Dexelia oil.Syntetic or not?
  195. So I replaced my spark plugs today with the updated ones
  196. Rotary better than Cylinder?
  197. Running out of gas.....
  198. A different approach to disabling TPMS?
  199. MOP - DTC P1686, DTC P1687, DTC P1688 - LIMP Mode
  200. Tire pressure light?
  201. Braking Question..
  202. temp. change vs. drivability
  203. A Use for 'wasted' exhaust heat ?
  204. Hotter Plug Questions..
  205. Racing Beat Spark Plug Wires
  206. hmmmm - plugs
  207. Diameter of stock exhaust tip
  208. Where to jack the car up?
  209. Rubber things not installed
  210. Automotive Conversions
  211. High HP RX8 a Pipe Dream?
  212. Cryogenic Tempering?
  213. Auto leveling headlights...
  214. Brake Tapping Question..
  215. rotary break-in procedure - run hard?
  216. Disposable Funnels...
  217. Grease Fittings
  218. Rotary Engine City Driving Durability
  219. Brake Squeaking
  220. RX-8 Parts and Service Bulletins
  221. i want to ask if installed this ground kit will it effect the factory warranty ?
  222. Anyone know the thread size of this bolt nut at bottom front shock arm?
  223. changed my oil
  224. Rear Door Disassembly
  225. Question: US/Japan spec differences
  226. How to remove 02 Sensor from stock midpipe?
  227. Very Interesting - Usefulness of Aftermarket Exhausts
  228. Power steering died, then came back after shut down and restart
  229. ECU reset
  230. Suggestions please (e-manage vs. REVi)
  231. What is carbon lock?
  232. Where the RPMs go
  233. Bore inside of the cat's
  234. Getting Tanabe Front Sway Bar with Q's
  235. Turning Traction Control Off
  236. GReddy & Tanabe Club - I'm IN!!
  237. anyone v mount
  238. What mod gives the biggest performance bang for the buck?
  239. Understanding Fuel Milage
  240. RX-8 CD Service Manuals?
  241. Suggestion for custom air intake box?
  242. i got accident.. i have question...
  243. how to remove the mazda emblem from center cap
  244. factory torque specs needed...
  245. Which Flash Do I Have?
  246. All RX8 Tech Bulletins In One Place
  247. California emissions
  248. Adjusting Pedal Throw
  249. Installed my lowering springs today..!
  250. Suspension upgrade to reduce wheel hop?
